#1 |
Multimodder
ASUS Xtreme Design contest stage 2 build modscases.com
first i want to thanks asus and brian and Eric
![]() ![]() here i will show off my process here is the design ![]() sponsors ![]() here what i received the awesome hardware ![]() ![]() first i am waiting for the case to make my design in it ![]() pic of what i get to done the job safety first ![]() ![]() plastic sheet that to make the letter X ![]() and the corner ![]() Traditional form of a letter X to take measurements ![]() here what i should look like ![]() Measurements taken in the plastic for the X ![]() tools ![]() i start cutting the letter ![]() ![]() i done of the two side of the letter X ![]() i have done the the other side of the 3d X yup sure and we back here the corners to get the letter X together with a clear glue ![]() ![]() and here is the cooler for the extreme overclocking the Corsair Hydro H50 CPU Liquid Cooler - 120mm Fan, Copper Cold Plate, Aluminum Radiator ![]() ![]() back to attach the corner to the letter x really hard to get it together my brother he help me a lot ![]() ![]() ![]() now is the time to get the sides of the letter together ![]() ![]() ![]() ![]() thumb screws ![]() here is the letter X almost finish just waiting for the case ![]() ![]() more pic soon more pic soon ![]() Last edited by modscases.com; 28th Nov 2009 at 05:38. |
#2 |
Multimodder
nice job on the X
will the case be watercooled? |
#3 |
Multimodder
thank you and it will be use a Corsair Hydro H50 CPU Liquid Cooler
#4 |
Multimodder
So I'm curious... Any particular reason you chose clear acrylic for the X, rather than metal sheets? Or is it so you can show us something within the X?
Maybe it's a secret =^P Anywho, looking forward to the updates. |
#5 |
Multimodder
i use the acrylic it's easy to use than metal the x will be part of the case like the pic of the design
#6 |
Multimodder
Nice. I'm excited to see it come together.
#7 |
Multimodder
thanks man soon it will done it should done before 11/23
new update
here is the case ![]() ![]() ![]() here i have done of the front of the case D litter ![]() ![]() i have cut the top for the LCD and fan control ![]() here i put them together ![]() ![]() ![]() more work coming |
#8 |
Multimodder
#9 |
Multimodder
ok i am back here where i will put the DVD ROM it will go up side down
![]() here i start cut ![]() here what is look like for the extreme design ![]() ![]() here what the letter will fit in the side of the case ![]() ![]() ![]() here is the front of the XD case ![]() here is the time to get it together ![]() here is the i7 860 and ram and the cooler holder ![]() here the water cooler for max overclocking ![]() and here is the 260 ![]() |
#10 |
Multimodder
hey hey we back will see a lot today here what is look like after manage the cables
![]() here some of custom paint in the back ![]() here i am going to cut the side panel of the case to make some of the asus logo in the MB chip cooler ![]() ![]() ![]() ![]() ![]() ![]() here is the lights i will make a video for light when it's work ![]() ![]() ![]() more pic will add by tomorrow |
#11 |
Multimodder
here after i add the letter x and to the case but more work will made and i have done the side panel from cutting and i add the sheet with the MB logo chip cooler
![]() i will add a other GPU to the case i have a 260 so it will work with the asus 260 we will go SLI it was so easy to make a SLI with this mother board really great MB ![]() ![]() ![]() ![]() here is a close look of the side panel ![]() ![]() ![]() her i have get some of the overclocking i can get 4 with this mother board very great of supporting the OC and the sponsors goods to make it work great also the turbo v EVO very great for OC and easy to use nice program ![]() ![]() more OC more of adding 7'' screen more games more Folding@home and more for this xtreme MB and all sponsors |
#12 |
Multimodder
hi to all we back here is new of OC and design and a lot
here after but the letter X in the case just to see how it look like more work will made for the X will post it soon it done ![]() here is the EPU-6 engine it's what it now go green great utility and just one bottom in the remote make it more easier ![]() ![]() ![]() ![]() ![]() ![]() here some pic of how easy is the OC with remote and turbov evo ![]() here i got to 3.80 i will get more like 4.00 ![]() ![]() here is the easy program to OC you GPU one click you OC you GPU what more easy than that ![]() here is some of folding@home ![]() ![]() more coming in
#13 |
Multimodder
back with a lot
here i make the the x looks mush Better ![]() ![]() here it's a 7" screen to add to the letter x i will add more pic soon i add it on ![]() ![]() i add a asus in the front of the case in the D ![]() ![]() i will add a lot of pic of what i have done some of the bios pic ![]() ![]() ![]() ![]() ![]() ![]() now is the overclocking i hit ti 190 f ![]() ![]() score of mark3d one single gpu hit 18509 with sli i get a 22766
#14 |
Multimodder
hi all here some pic of the final look of the XD design
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() thanks for looking i will show off what games that i am playing see you all |
#15 |
Moderate Modder
some really interesting features on your case. I like the DVD mounting position Might plagurise that in next case if I use a onboard side screen, and the bevelled front looks kinda funky.
#16 |
Multimodder
Looks awesome... only the lights are too much o.O it's not the kind of colors who work well together!
#17 |
Portuguese reviewer
What???
You received all that free material to do such project????? Its not the best project i ve seen and its not even good looking .. the ideas of it are also old and seen them many times ... im amazed as you received sponsoring and did such a lame project ![]() But its ok i guess its not finished LOOL it could be a lot better with the material you won for the competition and better work in the case i guess the standards of Asus are low .
#18 |
Supermodder
you know what Raiden, so many of your comments ive seen you write are negative... how about some support for people once in a while..... Done any mods yourself lately, oh wait, yes you have... a little bitter about the lack of interest me thinks.... Someone smack Mr negative with a big arse banhammer.
good work modcases, Only thing im not sure about is where the X joins the case, seems like theres a bit of a gap there. Love the idea of the screen in the X and the dvd placement. Last edited by skunkmunkey; 23rd Dec 2009 at 12:51. |
#19 | |
Portuguese reviewer
Its my opinion Spunk at least respect it, for a sponsored mod its nothing outstanding its a normal mod thats what i meant ! For me the interest aint the best part of a mod .. a mod its to be enjoyed by the person who does it , i meant this is not a sick mod , its a regular mod so please dont hit me because its my opinion as i respect yours respect mine OK? ![]() And you dont like my mods dont see it ok? ![]() Geez .. i thougth we had freedom of speech i guess not
#20 | |
ASUS
I know its the internet and people can lack class here and there but seriously, telling someone their project is lame goes a bit boarderline yeah? |
| Thread Tools | |
| View Mode | |
