| View Poll Results: Which faceplate design do you like? (Faceplates on page 6) | |||
| Don't change anything! |
31 | 14.62% |
| Faceplate 1 |
14 | 6.60% |
| Faceplate 2 |
59 | 27.83% |
| Faceplate 3 |
12 | 5.66% |
| Faceplate 4 |
57 | 26.89% |
| Faceplate 5 |
15 | 7.08% |
| Faceplate 6 |
31 | 14.62% |
| Faceplate 7 |
28 | 13.21% |
| Some other design! |
14 | 6.60% |
| Multiple Choice Poll. Voters: 212. You may not vote on this poll | |||
Thread Tools | View Mode |
#41 |
Cad Pro Quo
Hello folks! Hope everyone is ready to gear up for the holidays, I know I am. This may be one of my last posts until the new year, I'm flying home (across the US) for Christmas break starting Friday, so I'm busting my butt to get a lot of stuff done before then. So, enjoy the show!
We got a new granite inspection table this week. This thing is incredibly heavy (I'm guessing over 1000 pounds): ![]() Side Pieces: This weekend I've been working on the side pieces and the backplate. If you recall my design, I have to make to of the following pieces: ![]() These pieces were rather big, so the aluminum was hard to come up with. We had a piece of aluminum 9.75" in diameter (cylinder) and almost 3" thick. I couldn't cut the piece in half to make both of the sections, but if I cut it 9mm off center and then stepped across the centerline 9mm to the other side, I could fit the 2 pieces in!! Yay for me! Also...this thing took forever to cut in half. The aluminum bandsaw blade snapped (and I about pissed myself) so I had to use the steel bandsaw. Took about 30 minutes to cut through .This is how big this chunk of aluminum is: ![]() Putting it in the CNC, I faced the top and the sides to get a nice 0,0,0 position: ![]() After facing the piece, I cut an inch or so off of the other side to get the piece closer to the final size. I milled the alignment holes in each side, then I roughed it out (CNC go go!). ![]() ![]() ![]() Then I finished the piece with a long, small ball end mill. ![]() ![]() Seems like I forgot to take a finish shot. That'll be in my next update. Motherboard Backplate: Since I didn't want to spend all night at the machine shop, I chose something easy. Here's what the piece should look like: ![]() Cut the piece out of 1/16" aluminum: ![]() Cutting the pattern! ![]() ![]() ![]() Prying the piece of aluminum off of the plexi (very good double sided tape) was a pain in the butt. ![]() Did I ever mention I hate sanding aluminum? That gunk sticks to your hand. ![]() Final shots! ![]() ![]()
#42 |
Faux Pro Modder
#43 |
Busy procrastinating
#44 |
Pump Killer
This is looking great! /Subbed!
Btw, to get aluminum off of your hands, just use normal dishwasher soap, with lemon aroma! The lemon is the secret!
__________________
It's NOT a mac... http://forums.bit-tech.net/showthread.php?t=139635 - Motm nomineeWII - UNLimited Edition http://forums.bit-tech.net/showthread.php?t=179763 - Moty nominee Liquid Cooled CarPC - Sponsored by Mushkin Enhanced & Centrafuse http://forums.bit-tech.net/showthread.php?t=207889 - Motm nominee The Theory of Everything http://forums.bit-tech.net/showthread.php?t=219504 - Motm WINNER!
#45 |
Banned
What an awesome thread. You are surely gifted mate. Can't wait to see the finished article!
#46 | |
Cad Pro Quo
By the way, I love your Wii mod :-D, and thanks for the support! |
#47 |
Cad Pro Quo
Top Assembly of Case
So since I'm leaving on Friday and I'm busy Thursday night, I'm busting my butt to get everything ready and started! I got my plexi today!! ![]() I do have one question for you guys before I get started here. I'm going to have pins connecting the pieces to align them. I was thinking stainless originally, but I have a rod of brass I recently acquired. I'm up in the air as to which one to use (I need 26 of them, so both is probably out of the question). Any help? ![]() ![]() ![]() Anyway...here's what I'm doing with the top piece to CNC the inside. I put the blocks together as shown here, and layered it with the plexi I cut out. ![]() ![]() ![]() ![]() Here's some pictures with the plexi sitting on top. ![]() ![]() ![]() I had to pin the alignment holes to see the correct diameter. The stainless and brass rods are 1/4" thick, so I was expecting to shave just a tiny bit off. Turns out I'll be taking them down to 0.265" or so. ![]() I started a nice process in which to make the 26 little pins. What a pain!! I lathe it down, chamfer one end, polish it, part it, then set it aside. After all are done, I put a stop in the chuck of the lathe, machine one to the correct length, then face all of the rest of them, then chamfer them! Yikes! Test pieces: ![]() I'll be updating you guys tomorrow, hopefully. The CNC process for this piece will be an all day venture, so we shall see how it goes! Here's a shot of the solid model just to give you guys an idea of how this will look after it is done:
#48 | ||
Faux Pro Modder
#49 |
Never stuck with stock@Hotmods.net
Dunno why I didn't subscribe to this one before, but here I go!
__________________
Best regards, Nutman Project: Nutman - Sponsored by: Coolerkit - Specialtech - EK Waterblocks |
#50 |
DIY ADDICT
At least no one can steal it. It looks like it's shaping up into a two-person lift from all the solid aluminum!
Case looks really sweet though, keep it up! Wtb access to a machine shop for personal use... |
#51 |
↓ Don't trust that face!
Friggen hell, man! This is going to rule! (no... It already does.
)How awesome is a computer project that requires steel-toe boots? -Good call on the stainless pins. The brass would have darkened over time. I'm curious to see how you are clamping all this down.
__________________
#52 |
Cad Pro Quo
Happy new year everyone!
Big update here. Time wise, not quite content wise. These next pictures are over the course of a few days, just to complete one thing! If you can remember, I had the 3 solid pieces of aluminum lined up ready to CNC. Well, here's the process! Roughing ![]() Roughing Mounted ![]() Roughing Closeup ![]() Roughing No Flash ![]() Finishing in Action ![]() Finishing in Action ![]() Finishing in Action ![]() Finishing in Action ![]() Finishing in Action ![]() Finished Aluminum Pieces ![]() Finished Aluminum Pieces ![]() Acrylic Set up for Machining ![]() Roughing of Acrylic ![]() Roughing of Acrylic ![]() Roughing of Acrylic ![]() Roughing of Acrylic ![]() Roughing of Acrylic ![]() Finish Passes ![]() Finish Passes ![]() Finish Passes ![]() Finish Passes ![]() Finish Passes ![]() Finished Acrylic Section ![]() Here's a finished shot showing some improvements on sanding that need to be done (finished with 620 grit, will do more when I get some). Finished, Sanded ![]() Finished, Sanded ![]() Finished Closeup ![]() Happy New Year!
__________________
Completed: Acronym |
#53 |
Sparky
Very nice work.
#54 |
Wizard Ninja :P
Good god I hope I get access to a CNC machine at some point in my life, nice work and happy new year!
__________________
X3 720 BE @3.5GHz - MSI 790FX-GD70 - XFX 4870 XXX @ 795/995 - 4GB Corsair XMS3 1333MHz http://www.cpcff.co.uk Project λ-Zephyr |
#55 |
Thread Closer
damn, epic start. Sub'd!
__________________
XBL | Twitter Nexxo - I thought the Catholic church had a time-honoured tradition of sodomy? Cheapskate - @The beast - NAMBLA= Nasty Aged Men Banging Little An*ses Korraz - That iPad vs Stone one is an insulting lie! I never expected to see something so mediocre as THIS an this holy thread! You disgust me! A stone HAS a Touchscreen! |
#56 |
Supermodder
very cool, a cnc machine make some things easier. Very good work.
#57 |
Please... Just call me Stu.
I reckon this case will have cost you more than the rest of the hardware.
#58 | |
Cad Pro Quo
![]() Although, with a slim blu-ray slot drive, the price jumped up a bit, so I may be safe.
__________________
#59 |
Pump Killer
3D milling cheesecake!
How long did it take to machine the 3D aluminum? And what software do you use? BTW, still loooooove this one!
__________________
#60 |
+1 on what AngelOD said, ('Specially the looooove part.)
I'm currently shopping for CAM software, and the prices are a direct hit on the groin area.
__________________
| Tags |
| boob case, cnc, plexiglas |
| Thread Tools | |
| View Mode | |
