| View Poll Results: Which faceplate design do you like? (Faceplates on page 6) | |||
| Don't change anything! |
31 | 14.62% |
| Faceplate 1 |
14 | 6.60% |
| Faceplate 2 |
59 | 27.83% |
| Faceplate 3 |
12 | 5.66% |
| Faceplate 4 |
57 | 26.89% |
| Faceplate 5 |
15 | 7.08% |
| Faceplate 6 |
31 | 14.62% |
| Faceplate 7 |
28 | 13.21% |
| Some other design! |
14 | 6.60% |
| Multiple Choice Poll. Voters: 212. You may not vote on this poll | |||
Thread Tools | View Mode |
#61 |
theorycrafting
I wish I had the possibility to use a CNC aswell. So many ideas, that simply can't be done because of the lack of such tools
![]() ![]() Nevertheless... that's some real nice stuff there
__________________
...and allways remember, that the world is an orange!
Define Mini Black [Gigabyte Z77MX-D3H | intel i5-3450 | Kingston HyperX DDR3-1600 8GB | Gigabyte GTX660OC Windforce2 | intel 330 120GB | WD AV GP 1TB] |
#62 |
mmm, yep
Great work here. It's so cool to have these machines available and be able to actually produce whatever your imagination can put together! Keep it up!
![]() How much does the case weigh with the parts you have made so far? That is a lot of thick aluminum!
__________________
::: Phoenix ::: Secret of the Ooze ::: Blue Flame ::: Cavalier 3 ::: First Mod ::: |
#63 | ||||
Cad Pro Quo
While I'm here, I'll update you guys quickly! I spent most of my day yesterday trying to get mounting hole measurements for a slim optical drive. I had none laying around, and the only one available to me was on my laptop. Unfortunately, I have a Dell Studio and they don't let you just slide the optical drive out. So, this is the pain that took me half the day...I hope I don't screw up the computer that I use to post! Parts Galore ![]() More Parts Galore ![]() The Culprit ![]() All this was just to get the mounting hole measurements and locations. This had to be done so I could start on the bottom piece. I was too impatient to wait for my new drive to come in from China in like 3 weeks! Well...moment of truth, does it work when put back together? Woo Hooooo! ![]() Here's the solid block for the bottom piece. Drool over it .Bottom Aluminum ![]() I faced the bottom piece with the acrylic together to save some time. Facing ![]() Close-Up! ![]() This is a fairly big block of material. The size escapes you in the pictures. It's roughly 45mm thick and 220mm x 280mm big. Hunk-o-Material ![]() Someone was wondering how I was going to clamp the case down. I haven't let onto that yet, so I'll continue to keep that my secret! Here is my solution to better hold the pieces together instead of all those clamps (and so I could leave the thing running overnight). I drilled holes through the aluminum, partly into the acrylic. I then tapped the acrylic portion, and put screws through the aluminum to the acrylic! Solid! Mounting Screws ![]() Mounting Screw Close-Up ![]() Mounting Screw Side Shot ![]() When trying to write the program for the machining, I freaked out a bit at first. The acrylic piece is some random depth, meaning I faced one side and didn't face the others. If you've ever really worked with acrylic before, you know that it varies wildly in thickness over the entire material due to the polishing they do. So, with a piece of acrylic the same size as the aluminum, how would I get an accurate zero for the tools that didn't change much over the area of the material? Ah hah! I don't need a portion of the acrylic, and the aluminum IS faced, so the aluminum can be my zero! I was very proud of myself after figuring this out! ![]() Zeroing ![]() The piece sitting there is a machined (very accurately) 2" zero tool. It creates an electrical connection between the top and the bottom when the tool hits the surface, turning the light on. I love this thing. Zeroing ![]() The program I wrote would take 22 hours-ish. It's a very big piece, and I didn't have the feed rate up very high since I could just leave it overnight and do other things, so I wasn't really concerned with how long it took. I'll update you guys tomorrow with what's left after the piece is done! As for a teaser... Teaser
__________________
Completed: Acronym |
#64 |
E-tailer Tailor
This is shaping up brilliantly - and you're right, I didn't realise the aluminium was so huge!
__________________
Intel Core i7 920 @ 3Ghz, Noctua NH-U12P SE, Asus P6T Deluxe V1, Corsair 12GB (6x2GB) 1600Mhz C8 @ XMP,
EVGA GTX-680, Corsair AX750, 2x Samsung SpinPoint F3 1TB, Lian-Li V1020R with 3x Noctua NF-P12 & 3x NF-P14FLX 2.4Ghz 13" unibody MacBook, 4GB RAM & 128GB Samsung SSD |
#66 | |
Cad Pro Quo
Kidding! Thanks for the link!!!
__________________
#67 |
↓ Don't trust that face!
You give us a pic 30 seconds into the cut? YES! That is a teaser! -The cruelest tease ever!
__________________
#68 | |
theorycrafting
__________________
#70 |
OMG! Pink towel!
__________________
#73 |
Never stuck with stock@Hotmods.net
People with free access to CNC machines should not be considered modders, as there's no real modding involved in their work - it's all made by computers and tools - no real skills involved - no real.... ah, **** it. Simply just **** it...because, who am I kidding? THIS ROCKS!!!!!!!!
__________________
Best regards, Nutman Project: Nutman - Sponsored by: Coolerkit - Specialtech - EK Waterblocks |
#74 |
Is it me, or has the level of building on BT gone WAY up lately? I think the bar was raised three times, and I'm still working to top that bottom rung...
You gotta polish the insides now! That would look amazing.
__________________
#75 |
Multimodder
fantastic modelling skills there. One day I'll buy a CNC machine or something, soo many plans so little tools.
Also I have that mobo in my Redemption build, its very good for Bluray playback but it suxs ass for gaming.
__________________
Craigr1982 ---------- Toxicity- A HAF932 Mod - Asus P5KE-WiFi, Intel Q9450 @ 3.4Ghz, XFX GTX275, 4Gb Kingston 1066, 60Gb OCZ Vertex 2 SSD, 2x 1Tb HDD. |
#76 |
Supermodder
awesome design. You've created a very nice design, and machined in aluminium it should look fantastic! I'll be following from the sideline, and also: I agree with cheapskate you must polish the inside, it'll look wicked! Keep it up!
#77 | |||
Cad Pro Quo
![]() Quote:
Good news....all of the big pieces are CNCed! Yay! The only things left are the frontplate, the mounting pieces, and the motherboard backplate (some dimensions were a tiny bit off on the first one). On Sunday, I was in the process of making the other side piece. Since I forgot to take pictures of the first one, I took some this time! Look at the amount of chips there were...insane! The plan? To go from big, to small! ![]() I love this tool...3mm at a time. ![]() Chips Galore! ![]() Starting of the CNC ![]() Ta Da! ![]() While this was running, I made the connecting rods out of stainless. These rods have an inside thread on the bottom and an outside thread on the top. The top screws into the top aluminum. The bottom is made such that a bolt can be screwed in from underneath the bottom aluminum, into the stainless rod. This clamps the pieces down, pulling everything together. Here's what I mean: Connecting Rods ![]() Drilling the Ends ![]() Threading ![]() Threading in Action ![]() Connecting Rod ![]() All 4! ![]() Here's a process picture of what was waiting for me after the teaser picture I left you before: Bottom being CNCd ![]() And here's a shot of everything assembled (not screwed in or pinned). With Flash ![]() With Flash Close-Up ![]() Without Flash Close-Up ![]() Without Flash ![]() I'm working on the little pins now...which are a pain in the ass and will most likely drive me mad over the next few days. I can only deal with doing 6 or so at a time before I start going nuts, so it may take a bit .Then, it's sanding time!
__________________
#78 |
E-tailer Tailor
This looks amazing! Out of interest, why CNC the inside before the outside? And what colour are you having it anodized?
__________________
#79 | |
Cad Pro Quo
Most likely black, to keep with the sleek AV look, but I'm open to suggestions!
__________________
#80 |
Cad Pro Quo
I need your help! I don't like the current faceplate design, it just seems a little bland and doesn't meld well with the rest of the case. Here's what it looks like so far:
Current Faceplate ![]() So, give me some feedback on some of the following designs! The non-existent spaces would be acrylic material (don't worry about the construction, I'll take care of that). Faceplate 1 ![]() Faceplate 2 ![]() Faceplate 3 ![]() Faceplate 4
__________________
| Tags |
| boob case, cnc, plexiglas |
| Thread Tools | |
| View Mode | |
