#1 |
Multimodder
Macintosh Atom(?)
I built my wife a comp a year ago, based on a Intel atom board and some leftovers.
The result is a well working but not so good looking object: ![]() But I've just got my hands on this one: ![]() A Macintosh IIcx, my plan is to fit all current internals of the ghetto mod into this lovely case. Apart from the PSU wich won't fit. It's almost a shame to go for a mini-ITX board since a mATX will fit, but finance limits me to what I already got. I will try to get a slot loading dvd though since I will try to make minimal work on the outside of the case. Just widening the floppy port would be the best way to go. Here's some pics of the new case: ![]() ![]() ![]() ![]() Plans are brewing... Last edited by Combatus; 13th Jan 2013 at 20:27. |
#2 |
It's been a long time.
Liking the Idea. You've got a follower. One question though, are you gonna make that slot in the front (which I'm guessing was for a floppy drive) bigger, or are you going to seal that up and make a completely new one?
__________________
I have made some mistakes, started things that i couldn't finish. In a nutshell; a failure. Will I return? Soon, yes I will. Now about my nearly nonexistent paycheck... |
#3 |
Portuguese reviewer
Time for a modd in it !
#4 |
theorycrafting
Nice catch on the case, as it has basically all interiors allready done to simply mount the new hardware into it.
I'll be watching this
__________________
...and allways remember, that the world is an orange!
Define Mini Black [Gigabyte Z77MX-D3H | intel i5-3450 | Kingston HyperX DDR3-1600 8GB | Gigabyte GTX660OC Windforce2 | intel 330 120GB | WD AV GP 1TB] |
#5 | |
Multimodder
Thanks for the comments to you and Raiden. |
#6 |
Belgian freedom
looks promising, nice ghetto-mod btw, was your wife happy with it :d
#7 |
Supermodder
Oh, like it! Your "old" box looks quite like my skeleton case (the mod is still alive, I just can't find the time to finish it
). Can't wait to see what you make of this
__________________
Q6600@3.25GHz / Prolimatech Megahalems | EP45-UD3R | 2*2GB G.Skill + 2*1GB Transcend 860MHz@CL4 | MSI N460GTX-768D5 | 3 HDDs=1.3TB | Corsair VX550W | Win 7 Pro | Samsung SM2232BW + SM710MP
ThinkPad R500 | 15.4" WXGA | T5870 | 2*2 GB DDR3 | X4500HD | 128GB Kingston V100 | Ubuntu 11.10 x64 |
#8 |
The Keeper of History
I love putting PCs into other people's products. I watch.
john
__________________
My deepest gratitude to this community.
#9 |
Thread Closer
im watching this
__________________
XBL | Twitter Nexxo - I thought the Catholic church had a time-honoured tradition of sodomy? Cheapskate - @The beast - NAMBLA= Nasty Aged Men Banging Little An*ses Korraz - That iPad vs Stone one is an insulting lie! I never expected to see something so mediocre as THIS an this holy thread! You disgust me! A stone HAS a Touchscreen! |
#10 |
I will be watching, from a tree outside your bedroom window!
If you are planning to hackintosh on the software side, be warned that OSX was updated to not allow atom machines to boot. Not sure how easy this is to get around (probably just not updating )
__________________
#11 |
Thread Closer
its already been fixed, that story was last weeks news. I have 10.6.2 on my mini and its working fine. [/hijack]
__________________
#12 |
There is no rep for awesomeness.
Moderator
Because we need pics of work in progress. And when you have, let me know and I'll move it back to Projeft Logs.
__________________
"You actually hope to achieve your ideals, I just use mine as an excuse to hate everything" --specofdust "Right wing Republicans, all the murderousness of nut-job Iranian ayatollahs, none of the bearded coolness" --specofdust Last edited by Nexxo; 2nd May 2011 at 21:24. |
#13 |
Hypermodder
For obvious reasons, I like this (I'm doing something similar with an IBM case)
Is the apple a working system? Would be a shame if it were to destroy it, but I like the idea none the less!
__________________
Mosquito Scratch Builds: Just A-PC | Mini HTPC | Music Box | Ham Theater PC |
#14 | ||
Multimodder
Ok, this have been on ice for too long. My Facit project exhausted resources and energy but now things are on the move.
Well, here are the progress so far. All hardware was ripped out of the case and all odd plastic stands were trimmed off. I have enlarged the floppy-slot so it can be used for a slot-in Blu-ray burner. The bottom of the case is now lined with an aluminium plate for mounting Mobo and all other devices. Basic planning: ![]() I don't want to change the exterior of the case to much so all i/o ports will be housed in the original holes with cables attatched to the mobo. ![]() ![]() The original 0n/off and reset buttons were mounted directly to the mobo pcb (activated with plastic pins from the front of the case). I salvaged some nice clicky switches from an old VCR that I will mount in some way. ![]() The computer will be used as a media server so I'm looking for a itx-board with hdmi and that are not too heat producing. |
#15 |
Multimodder
The last days I've been playing around with card-board mock ups in the case and tried different positions of the hardware.
There are plenty of room but not in the right places, this will be tricky to get right. But challanges like this is one of the reasons for that I like cramming new stuff in odd old cases. Nostalgia might be another one. I'm now contemplating to use a PicoPSU with a 12v AC-DC converter housed inside the case to get some more flexibility with the inside logistics. Both SFX and Flex PSUs poses tremendous placement problems. Any good ideas a welcome. |
#16 |
theorycrafting
The SFX-PSU should fit nicely, if you turn it by 90°. It has only 125mm width, but yeah, a picoPSU would make it even easier to place the components, and it wouldn't be much more expensive either.
__________________
#17 |
What's a Dremel?
love the idea, I'm watching this.
#18 |
Shut up and Mod
Look at all that EDO RAM lmao.
__________________
Life. Liberty. The pursuit of those who oppose it.![]() Guides: Modular PSU ~ FC foam removal Mods: Blue on Black ~ DVD-ROM Worklog: Acronymus ~ Carbide @furballzen |
#19 | |
Multimodder
I did intend to show you some pics of this painstaking chore but for some reason I no longer can transfer pics from the phone to the computer. I can hopefully solve this until tomorrow. Apart from blisters in my palm I have also produced a stand for the internal on/off and reset buttons. But more about this later when I can post pics again. |
#20 |
sudo rm -Rf /
That puppy maxed out at 20Mb of ram!!
__________________
I always wanted to have that ideal father son relationship. You know, where I get to see him for like eight hours every other weekend, and send checks to some woman I hate. -- Tucker, Red vs. Blue |
| Thread Tools | |
| View Mode | |
