Reply
Thread Tools View Mode
Old 17th Jan 2013, 00:13   #21
k.3nny
Hypermodder
k.3nny's Avatar
k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.
Macintosh gets an upgrade !
k.3nny is offline   Reply With Quote
Old 17th Jan 2013, 03:16   #22
WhatTheTech
Macmodder Addict
WhatTheTech has yet to learn the way of the Dremel
Definitely excited to see where this goes!
WhatTheTech is offline   Reply With Quote
Old 19th Jan 2013, 10:21   #23
vils
Multimodder
vils's Avatar
vils has yet to learn the way of the Dremel
Internet connection reestablished (for a while) and phone problem solved.
Here are the chisel work in progress:
Sanding almost finished:
The back of the case was also 'cleaned' from various plastic ridges and stands. The blue paper represents a sheet of perspex that will be sanwiched between the case and a inner piece of aluminium. The perspex will be illuminated with leds so that the connecters have a glowing edge around them.
I/O layout planned:
How everything will be placed inside the case depends in part of how deep the connecters are going to be. I'm scouring the web for panel mounted connecters. I've found a few so far but they are a bit too big (deep).
__________________
Current project: Facit
Visit my sponsors:
Intel Microsoft Noctua
vils is offline   Reply With Quote
Old 19th Jan 2013, 17:43   #24
morgansk
I've got wood
morgansk has yet to learn the way of the Dremel
Nothing better than turning an Apple into a real computer.
morgansk is offline   Reply With Quote
Old 19th Jan 2013, 18:13   #25
Pranja
Fenrir The Wolf
Pranja's Avatar
Pranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for president
Originally Posted by morgansk View Post
Nothing better than turning an Apple into a useful computer.
Fixed.
__________________
Cosmos S Reaper L.R.E.C. Scorpio
Arya-under construction ROG Crawler-under construction
Pranja is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
