Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 30th Nov 2009, 11:54   #1
Cutter McJ1b
Home-cut jibs at discount Prices
Cutter McJ1b's Avatar
Cutter McJ1b has yet to learn the way of the Dremel
Budget overclocking is back!
http://www.bit-tech.net/blog/2009/11...cking-is-back/
Cutter McJ1b is offline   Reply With Quote
Old 30th Nov 2009, 12:28   #2
Psytek
Multimodder
Psytek has yet to learn the way of the Dremel
Definitely sticking with core 2 for a while. I contemplated getting a core 2 quad, but money is tight, so I'm just waiting it out for i5/i7 prices to drop.
The main thing for me is the price of the motherboards. New cpus tend to always be the same price, but even the cheap 1156 boards are way more expensive than 775 boards were a couple of years ago.
Psytek is offline   Reply With Quote
Old 30th Nov 2009, 12:45   #3
mi1ez
Game Boy Modder
mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!
Perfectly happy with my Q6600. might wait for a price drop, might wait till I'm struggling to play a certain game. Chances are the 4870 will be changed before mobo/cpu/ram
__________________
The Angel Delights?
mi1ez is offline   Reply With Quote
Old 30th Nov 2009, 12:50   #4
Centy-face
Caw?
Centy-face's Avatar
Centy-face has yet to learn the way of the Dremel
I'm thinking about a completely new system in the new year and I think I'll probably end up going with an i5 I mean it's getting harder and harder to buy the decent core 2 chips now.
Centy-face is offline   Reply With Quote
Old 30th Nov 2009, 13:34   #5
dicobalt
Multimodder
dicobalt's Avatar
dicobalt has yet to learn the way of the Dremel
I am getting the new PDC E6500 2.93GHz to replace an old c2d E6300 1.8GHz@2.8. That was a wallet friendly $95 usd. I figure I should be able to get at least 3.8GHz without going over 1.3625V.
dicobalt is offline   Reply With Quote
Old 30th Nov 2009, 14:00   #6
wuyanxu
still wants Homeworld 3
wuyanxu's Avatar
wuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyan
price-wise, a q6600 still rocks.
but in terms of raw performance, you can't beat an i7 or i5. besides, the Nehalem architecture is so good, i don't see any reason not to own it.
i personally go for the latest, greatest architecture i can afford. GT200 was the greatest (in its size) and now the Nehalem (cos it's the latest and best)
__________________
i7 2700k \ 16GB \ GTX 970 \ D2x \ Z68x-UD5 \ m4 128GB +2TB \ S12G-550 \ FT02-RW \ G15+G5+G51 \ U2711
X100 \ X-E2 \ 10-24 \ 55-200 \ 18/2 \ 60/2.4 \ Yn560 \ X1.1a \ Hadley Pro -- Photostreamr
wuyanxu is offline   Reply With Quote
Old 30th Nov 2009, 14:24   #7
Jack_Pepsi
Clan BeeR Founder
Jack_Pepsi's Avatar
Jack_Pepsi has yet to learn the way of the DremelJack_Pepsi has yet to learn the way of the Dremel
I won't be upgrading to a new board & CPU for at least 2 years. I have absolutely no need. My Q9550 is more than enough and I haven't had all the fun out of it yet. I'm debating to buy a new motherboard as I believe my current P5E3 is causing some issues with my HDDs.
My next purchase will most likely be an PCIe SSD if the other half buys me a certain DX11 card for Chrimbo.
__________________
During the rectification of the Vuldronaii the Traveler came as a large, moving Torb. Then, during the third reconciliation of the last of the Meketrex supplicants they chose a new form for himóthat of a giant Sloar. Many Shubs and Zuuls knew what it was to be roasted in the depths of the Sloar that day, I can tell you.
Jack_Pepsi is offline   Reply With Quote
Old 30th Nov 2009, 15:47   #8
munim
Minimodder
munim has yet to learn the way of the Dremel
My E8400 @ 3.6 and 4890 play Crysis at max with 4xAA @ 1680x1050 and with consolification, I won't need anything faster for years to come. Woohoo!
munim is offline   Reply With Quote
Old 30th Nov 2009, 16:30   #9
Sheiken
Wat?
Sheiken's Avatar
Sheiken is almost as Godly as yodasarmpitSheiken is almost as Godly as yodasarmpitSheiken is almost as Godly as yodasarmpitSheiken is almost as Godly as yodasarmpitSheiken is almost as Godly as yodasarmpitSheiken is almost as Godly as yodasarmpitSheiken is almost as Godly as yodasarmpitSheiken is almost as Godly as yodasarmpitSheiken is almost as Godly as yodasarmpitSheiken is almost as Godly as yodasarmpitSheiken is almost as Godly as yodasarmpit
Budget overclocking!
Phenom II 550 BE @ 4 cores running 3.6ghz happily!
beat that
__________________
Whoring Out My Hardware 4.6!
Portaputer - rMBP Late 2013 - 13" / i5 / 8GB / 256gb ssd
Sheiken is offline   Reply With Quote
Old 30th Nov 2009, 16:39   #10
Neophyte4Life
Minimodder
Neophyte4Life has yet to learn the way of the Dremel
I don't know about that. I believe a certain someone said, "You'll never need more than 64K of memory". I bet he is scratching his head now. I just upgraded to an i7 a couple of months ago and couldn't be happier. It wasn't cheap but i love being able to run server 2008, backtrack, and xp inside vista x64 and still have enough power to spare. Although i have had to postpone my W7 upgrade........
I think you will need several more halves to afford that.
Neophyte4Life is offline   Reply With Quote
Old 30th Nov 2009, 16:56   #11
Sifter3000
I used to be somebody
Sifter3000's Avatar
Sifter3000 has yet to learn the way of the DremelSifter3000 has yet to learn the way of the DremelSifter3000 has yet to learn the way of the DremelSifter3000 has yet to learn the way of the DremelSifter3000 has yet to learn the way of the DremelSifter3000 has yet to learn the way of the DremelSifter3000 has yet to learn the way of the Dremel
+ rep for that
__________________
The Rt Hon Alex Watson.
Dennis Publishing Emerging Platforms, bit and CPC alumni.
My weblog is The Wired Jester.
Photos on Flickr.
Sifter3000 is offline   Reply With Quote
Old 30th Nov 2009, 17:22   #12
SteveU
Multimodder
SteveU has yet to learn the way of the Dremel
I'm more than happy with my recent upgrade to an E8400 & P5Q-E, currently at 3.8GHz stable at stock vcore. It's more than fast enough for me as I'm not a big PC gamer.
I'd love an I5 but it would have cost double my current setup for me to upgrade what with having to buy new ram too.
Steve
SteveU is offline   Reply With Quote
Old 30th Nov 2009, 18:45   #13
Primoz
Minimodder
Primoz has yet to learn the way of the Dremel
THinking about a Clarkdale system with a mATX mobo (and a 5770) to change my Abit QuadGT (which doesn't have a sound and a network card anymore), E6750 @ 3,2 GHz and a 7900 GTO... No point in staing on LGA-775 anymore i think, but yeah, a new system is quite expensive.
Primoz is offline   Reply With Quote
Old 30th Nov 2009, 19:15   #14
Shagbag
All glory to the Hypnotoad!
Shagbag has yet to learn the way of the Dremel
My single core Opteron 144 does everything I need. Virtual Box runs WinXP for the wife with very little performance hit. I would like an IntelVT or AMD-V CPU but I'd have to upgrade my mobo and RAM as well as the CPU and that's just not worth it for me.
Shagbag is offline   Reply With Quote
Old 30th Nov 2009, 21:53   #15
Arkanrais
Supermodder
Arkanrais's Avatar
Arkanrais has yet to learn the way of the Dremel
I built myself an E5300/4GB ddr800/1TB/GTX260+ a few months ago and haven't gone too hard at overclocking yet (got 3.9GHz, but temps creeped up to 80+ and wasn't fully stable, settled for 3.4GHz). I'll be sticking with that till I get a job with a decent amount of disposable income, which will probably be in time for LGA1366 6 core equivalent of the i7 920 (and need to find a new place to live, so that'll bugger the upgrade process for a while).
I built an i7 920/6GB 1866mhz/ 1TB/ 8800gt system for a mate before I built my system, and he couldn't be happier with it, aside from having to RMA his ram cause of one dead stick. his last system was an athlon x2 4800+ machine.
__________________
Visit my youtube page or I'll make you squeal like a piggy and throw a spatula at you.
FEAR THE SPATULA!
What the hell part of a chicken is the nugget?! goddamn McDonalds and their LIES!
Arkanrais is offline   Reply With Quote
Old 30th Nov 2009, 22:14   #16
sadlydefiant
Minimodder
sadlydefiant's Avatar
sadlydefiant has yet to learn the way of the Dremel
My newly built e5200 / gts250 system is fine, has no problem playing crysis at my prefered settings.
i5 and i7 is way to expensive for me and will be for some time.
If I was going to build a new system it would be a budget AMD quad core for about $130AU.
What I would like is a descent 775 HSF setup but the problem is they cost more than the cpu I have only just purchased.
sadlydefiant is offline   Reply With Quote
Old 1st Dec 2009, 11:22   #17
xaser04
Ba Ba Ba BANANA!
xaser04's Avatar
xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.
I jumped ship to a core i7 920 setup earlier this year (actually around the launch of the i7 in the UK). It is currently running @ 3.6ghz (Corsair H50 cooling) alongside 2 overclocked GTX260-216's in SLI (had them up to 740/1600/2500 when benching) all contained withing my recently purchased Fractal Design R2.
I was thinking about chopping out the GTX260s for a pair of HD5850s but I realised that no game I play at the moment really stresses the GTX cards enough to warrant upgrading (everything is more than playable).
My next move is porbably a Intel X25-m 80GB SSD and windows 7 X64 (running Vista X64 atm) but, tbh, everything works just right at the moment and I doubt I would notice enough of a difference to warrant the outlay (north side of £250).
Whilst the core setup was expensive (CPU & motherboard) the rest of the system was pretty well priced. I managed to get the two GTX260 cards on offer at £120 each whilst the case was around £80.
__________________
Daedalus - Clevo P170SM | i7 4700MQ @ 3.4Ghz | GTX780M 4GB @980/6000 | 16GB DDR3 | 17.3" 1920x1080 |
ZPM "VIVE" Mini - Fractal Node 202 | i7 4770S | GTX1070 | 8GB DDR3 | 4K TV / HTC VIVE |
Consoles / Retro - PS4 Pro | PS4 | Xbox One x2 | Dreamcast x2 (VGA) | WiiU | Retron5 |
xaser04 is offline   Reply With Quote
Old 1st Dec 2009, 11:23   #18
Xtrafresh
It never hurts to help
Xtrafresh's Avatar
Xtrafresh can run CrysisXtrafresh can run CrysisXtrafresh can run CrysisXtrafresh can run CrysisXtrafresh can run CrysisXtrafresh can run CrysisXtrafresh can run CrysisXtrafresh can run CrysisXtrafresh can run CrysisXtrafresh can run CrysisXtrafresh can run Crysis
For budget overclocking, it'll be really intresting to see the upcoming i3 CPUs. The i3 530 for example. Dualcore Nehalem with HT and 2,93GHz stock speed at just 100 euros? Yes please! Here's hoping they scale the range all the way down like they did with Core.
__________________
Think of how stupid the average person is, and realize half of them are stupider than that.
- George Carlin
Xtrafresh is offline   Reply With Quote
Old 1st Dec 2009, 16:50   #19
H2O
Burnt Acrylic - Mmmmmm
H2O's Avatar
H2O has yet to learn the way of the Dremel
My E8400/X48 is going into a media/backup server and my gaming rig is going to get a i7 920/X58.
__________________
Regards, Chris
In Progress: "Project Red Water" Core i7 920 | Classified E760 | 6GB Dominator GT 1600 | GTX380 SLI | Murdermod TJ07 | Corsair HX1000
H2O is offline   Reply With Quote
Old 7th Dec 2009, 00:32   #20
dec
[blank space]
dec's Avatar
dec can run Crysisdec can run Crysisdec can run Crysisdec can run Crysisdec can run Crysisdec can run Crysisdec can run Crysisdec can run Crysisdec can run Crysisdec can run Crysisdec can run Crysis
im planning on upgrading in like 4 or 5 years so then lynnfield will be like how pentium 3 is now.
if i was to do it now id go with AMD. im not gonna pay $1k for an unlocked multi
__________________
Pure. Refreshing. Bacon.
dec is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
