#62 |
Multimodder
I love the colors you have selected for the mod. Excellent job mod on!
#63 |
Reverse/srvR
Thanks for the comments guys, keep them comming!
The window, take 2: Cutting the panel, again: So, I’ll be fair to you guys.. I was not looking forward to this task.. It was time to enlarge the cut window. But, the window I had was perfectly cut, filed and sanded! It was just a bit (read: way) too small. In fact. I decided it should be at least 10cm taller. So, after delaying the task for a few weeks (!) it was finally time to do it. I got myself together, grabbed all my courage, and went for it. This was how the panel looked: I covered the panel with painter’s tape to prevent it from damaging: ![]() I even taped the perfectly filed edges, just so I didn’t have to redo those: ![]() Then came the time to measure (once, twice, heck! I even measured three times) the area to cut. As said before, the hole should only get taller. ![]() The came the cutting… I wanted to drill a hole in the to-cut-area, but for some reason my Dremel wasn’t working properly. It simply couldn’t drill a hole in the panel… So, after a while I gave up. And took the jigsaw to make a rough cut. Of course, I was afraid the jigsaw would damage my panel, so it got the tape treatment as well! ![]() So 4 layers of tape between the tool and the panel, should be enough.. right? I said I would use the jigsaw to make a rough cut right? And when I mean rough…. I mean rough! ![]() After using the jigsaw I needed to file/sand away 5mm of the metal! But, I’d rather file for hours than mess up my panel. I started filing like a lunatic, and after about an hour I was getting close. I took off the masking-tape to check my progress. Turned out I was about 1mm off at some places. So, a piece of masking-tape as a guideline: ![]() And off we go again! ![]() 3 complete hours after I started (it was dark at this time) I was finally done cutting, filing and sanding my sidepanel. ![]() Throughout the day a lot of snow had fallen. And together with the snow that had been there for a few days and the dark sky…. You guessed it.. I took the panel outside for a high-contrast picture: ![]() The black panel and the white snow… Aaaaah Here you can also see the clean cut. Soundproofing: The Fractal Design Define R2 comes with excellent soundproofing material. It’s called Bitumen, and it’s very heavy (it also smells a bit). So, I had taken the Bitumen plate out when I started the first cuts on the sidepanel, but I felt like sticking it back on. To keep it a bit more soundproof (HDD and DVD bays are the noisy parts.) So I took the panel back inside, when I thought: Aah damn, all that snow… Gotta wait for it to melt and dry before I can continue… So my snow picture may be good, It took away a lot of my time.. ![]() Then I laid over the old Bitumen plate: ![]() Turned the panel over and marked the window on the Bitumen plate. Then I took about 3cm of clearance and cut the Bitumen. This is also when I noticed the Bitumen smells…. Tadaaaaa! I’m done with that as well! I’ll wait with sticking it back on, at least until I receive my Plexiglas for the window. ![]() Done: I took a permanent marker (sharpie) to cover up the plain metal on the edges. Looks like it was ment to be like this now! After that I decided to clean the panel with some Glassex (Windex for you Americans) to make my fingerprints disappear. ![]() Then stuck it back to the case, for the final look: ![]() That shot was made with an angle, you can see the top and back fan guards through the window! And of course, a shot from a 90 degree angle: ![]() A shoutout to my sponsors, for making this mod happen:
__________________
Project: Reverse² Last edited by Reverse; 19th Jan 2010 at 14:09. |
#64 |
Supermodder
Thats a window!
Damn good job.
__________________
Intel Q6600 - Asus P5Q-VM - Corsair TwinX 4x1GB - 8600GT - 640GB storage space - OCZ ModXStream 400w - Modded P180 Mini |
#65 | |
Is a cackling Yuletide Belgian
Beautiful. That's a great looking case!
__________________
My Flickr
#66 | |
Rookie Modder
I just drilled up the rivets to remove the top temporary and now the hdd-bay is removed. Maybe I link some pics of it when i finished my mod. I really like your window! Normaly I hate windows but yours was just big enough |
#67 |
Multimodder
What stonedsurd said.
#68 |
Food Maestro.
An amazing mod with an amazing log, very well done!
#69 |
Usually spilling liquid...
doing a really good job man,
whats next?! |
#70 | |
Reverse/srvR
Thanks man! I try to keep the log as entertaining and detailed as I can =) Thanks! Up next, painting.
__________________
Project: Reverse² |
#71 |
Food Maestro.
How are you going to light up the front line? Getting a light with even brightness all the way down is going to be hard.
#72 |
Multimodder
#73 |
Food Maestro.
Diffuse Plexi...
#74 |
Multimodder
#75 | ||
Reverse/srvR
There is no way a CCFL would fit there. Yes, but is there orange diffuse plexi on the market?
__________________
Project: Reverse² |
#76 |
Food Maestro.
Errrmm.... How about frosted Perspex. Stick some orange diffused LEDs behind it and it should look fairly even.
LEDs : http://www.phenoptix.co.uk/10mm_Oran...f-ora-4500.htm Perspex : http://www.plasticstockist.com/index...e=MDNTMjAwMA== EDIT: Or polypropylene may be better, 1mm thick and comes naturally frosted. Polypropylene : http://www.directplasticsonline.co.u...leneSheet/1mm/
__________________
"Are there any experienced suicide bombers?" Last edited by Rotcrack; 21st Jan 2010 at 17:07. |
#77 |
Food Maestro.
Bump...
#78 | |
Reverse/srvR
__________________
Project: Reverse² |
#79 |
Food Maestro.
Happy for you, mind sending me the link of where you found it ( if on-line). Looking forward to the first pictures of the lighting.
#80 |
Reverse/srvR
The orange has been ordered (at the start of this project) at BouwPlastics.nl, but they have a DB-error atm, so i can't give the exact link.
I just ordered the smoked plexi at WSV Kunstoffen today, after receiving excellent samle's of the stuff. =)
__________________
Project: Reverse² |
| Tags |
| deboled, fractal design, rasurbo, reverse, xilence |
| Thread Tools | |
| View Mode | |
