Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 15th Dec 2009, 11:11   #1
Cutter McJ1b
Home-cut jibs at discount Prices
Cutter McJ1b's Avatar
Cutter McJ1b has yet to learn the way of the Dremel
Crysis - Did you upgrade?
http://www.bit-tech.net/blog/2009/12...d-you-upgrade/
Cutter McJ1b is offline   Reply With Quote
Old 15th Dec 2009, 11:38   #2
Xir
I Mod, Therefore I Own
Xir's Avatar
Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.
It was (and is) as stepping stone.
It's not just graphic demand that went up, also standart resolution went up tremendously from 1280x720 to 1680x1050 and now 1920x1200 (1080). So there's 2,5 times more pixels to be filled.
Still Crysis wont run well on older hardware even with the old 1280x720 standard ;-)
For me...still waiting to get new hardware and haven't touched crysis yet ;-)
I mean, the ATI5870 is the fastest single core card yet, right? Will it doe Crysis with everything on full at 1920x1200?
__________________
SN25P
A64 3700+ (San Diego)
2 GB DDR400 OCZ Platinum EL 2-3-2-5 1T
X1800XT 512mb Sapphire
200GB Samsung SP2004C 24" Asus VW246H 1920x1080
Xir is offline   Reply With Quote
Old 15th Dec 2009, 11:42   #3
GFC
Multimodder
GFC has yet to learn the way of the Dremel
I think a game like Crysis is good once in a while. It makes GPU makers happy, it makes other game companies try harder on their games.
GFC is offline   Reply With Quote
Old 15th Dec 2009, 11:44   #4
Spiny
Multimodder
Spiny has yet to learn the way of the Dremel
Nope, the hype about the system requirements put me off & I didn't buy it. No point in upgrading for a single game, especially when everything else is limited due to needing to run on consoles.
Spiny is offline   Reply With Quote
Old 15th Dec 2009, 11:52   #5
wuyanxu
still wants Homeworld 3
wuyanxu's Avatar
wuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyan
indeed. IMHO graphics card development have almost stopped before Crysis came out.
and now, most people owning 8800GT or above would look at the games say they've got a good enough card, thus limiting the graphical advances in games.
we need more games like Crysis, pushing the envelope and making progress.
__________________
i7 2700k \ 16GB \ GTX 970 \ D2x \ Z68x-UD5 \ m4 128GB +2TB \ S12G-550 \ FT02-RW \ G15+G5+G51 \ U2711
X100 \ X-E2 \ 10-24 \ 55-200 \ 18/2 \ 60/2.4 \ Yn560 \ X1.1a \ Hadley Pro -- Photostreamr
wuyanxu is offline   Reply With Quote
Old 15th Dec 2009, 12:00   #6
Paradigm Shifter
de nihilo nihil fit
Paradigm Shifter's Avatar
Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.
No, I didn't upgrade for Crysis. When I bought Crysis I had an X1950XTX, and that served perfectly on medium settings at 1920x1200. Didn't find any spots where the framerate nosedived. OK, so it was medium settings but it still looked incredible!
I picked up an 8800GT some considerable time after I bought Crysis (after getting three that were DOA) and thought I could try high settings... which were fine until I hit ice. As soon as that happened, it, too, needed medium (or a custom selection of medium/high) to get it playable.
First time I played Crysis all on High was with a 4850. It did very well. But even a 4870X2 didn't give what I consider playable framerates on very high at 1920x1200.
__________________
Core i7 5820K | 32GB Crucial DDR4 | Asus Rampage V Extreme | Titan X | 1TB SSD + 6TB HDD | 7680x1440 + 1920x1200
Paradigm Shifter is offline   Reply With Quote
Old 15th Dec 2009, 12:02   #7
oMonarca
Elitist Brick
oMonarca's Avatar
oMonarca has yet to learn the way of the Dremel
Well, Crysis should have the gameplay that matched the graphics. It started in an awesome way, but then it funnelled and placed aside it's strengths in favour of a linear approach and boring enemies.
We don't need more games like Crysis. We need games that not only raise the bar in graphics, but in gameplay too.
oMonarca is offline   Reply With Quote
Old 15th Dec 2009, 12:06   #8
faugusztin
I *am* the guy with two left hands
faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.
With 2xAA yes. With higher AA, no.
faugusztin is offline   Reply With Quote
Old 15th Dec 2009, 12:06   #9
Skiddywinks
Hypermodder
Skiddywinks has yet to learn the way of the DremelSkiddywinks has yet to learn the way of the Dremel
I didn't upgrade, mainly because I had no rig at the time. I don't ever upgrade PC's (would rather run it out of its useful life and then build a new one), but I may have for Crysis.
People see it as upgrading for just one game. But the fact is, the intention may only be for one game, but it's not like the upgrade would only apply to Crysis; surely your other games would benefit? If you can already play everything else at max, upgrading would be a waste in my eyes, but under any other circumstance it wouldn't be a bad idea.
I don't know if Crysis helped or hindered the market, but I sure as hell want another one. Maybe not as stupidly unplayable, but definitely omething that stresses my card more than any of the other console ports would be nice.
Skiddywinks is offline   Reply With Quote
Old 15th Dec 2009, 12:16   #10
kenco_uk
I unsuccessfully then tried again
kenco_uk's Avatar
kenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyan
Not only did I upgrade to a DX10 card, I upgraded to Vista from XP.
__________________
formaggio g‚teau
kenco_uk is offline   Reply With Quote
Old 15th Dec 2009, 12:24   #11
alecamused
Supermodder
alecamused's Avatar
alecamused is definitely a rep cheat.alecamused is definitely a rep cheat.alecamused is definitely a rep cheat.alecamused is definitely a rep cheat.alecamused is definitely a rep cheat.alecamused is definitely a rep cheat.alecamused is definitely a rep cheat.alecamused is definitely a rep cheat.alecamused is definitely a rep cheat.alecamused is definitely a rep cheat.alecamused is definitely a rep cheat.
I guess i spent half an hour just watching the sunrise ... The engine is awesome, even the ingame menus (suit controls, gun mods) are really great and inventive but the gameplay wasn't up to the graphics.
I vote for more games like crysis (btw, crytek is hiring so there might be something new coming) but they really should care a bit more about the story and character development.
__________________
"Shirty is an absolute legend"
alecamused is offline   Reply With Quote
Old 15th Dec 2009, 12:27   #12
Elton
Officially a Whisky Nerd
Elton's Avatar
Elton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming Saiyan
I didn't upgrade for Crysis. That was a byproduct.
In truth it was Oblivion that compelled me to upgrade. Well from an X1600XT at least.
__________________
Gotta keep it 100 we got fundamentals.
Elton is offline   Reply With Quote
Old 15th Dec 2009, 12:54   #13
MaverickWill
Dirty CPC Mackem
MaverickWill's Avatar
MaverickWill can run CrysisMaverickWill can run CrysisMaverickWill can run CrysisMaverickWill can run CrysisMaverickWill can run CrysisMaverickWill can run CrysisMaverickWill can run CrysisMaverickWill can run CrysisMaverickWill can run CrysisMaverickWill can run CrysisMaverickWill can run Crysis
I bought the super-computer, THEN bought Crysis.
Aside from beating the snot out of that first turtle, I've not really played it much!
__________________
Antony's got his hat on, hip, hip, hip, hooray!
MaverickWill is offline   Reply With Quote
Old 15th Dec 2009, 13:03   #14
tron
Supermodder
tron has yet to learn the way of the Dremeltron has yet to learn the way of the Dremel
I upgraded after the release of Crysis, but mostly for other games. If Crysis was my favorite game, then yes I would have upgraded for it as I am a hardcore gamer who values cutting edge graphics.
A lot of other PC gamers upgraded around that time, mostly for the ability to run Crysis at a decent framerate on very high detail settings.
I don't think Crysis was a step too far at all. It was highly scalable for people to play on reduced quality on older hardware, and nobody is forced to put up their settings to very high.
So it's a win-win situation: those who don't want to upgrade can play it on lower (console-level) details, and those who care enough to want to experience the (then) revolution in graphics, can upgrade.
For the quote: "PC gamers who have defected to consoles was that they refused to spend hundreds of pounds upgrading their PCs to play one game"; my response is that either PC gaming was not supposed to be for those persons in the first place, or the excuse they use is flawed: If they 'defect' to console gaming because they didn't want to upgrade for Crisis, then they lose the ability to play Crysis at all. Or they may prefer to wait for Crysis 2 on a console and play it with new optimized lower graphics textures.
tron is offline   Reply With Quote
Old 15th Dec 2009, 13:06   #15
Blarte
Moderate Modder
Blarte's Avatar
Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!
what was Crysis developed on?
__________________
Watering down PC's since 2009....
Blarte is offline   Reply With Quote
Old 15th Dec 2009, 13:07   #16
MaverickWill
Dirty CPC Mackem
Judging from its power, I'd say Mars.
__________________
Old 15th Dec 2009, 13:14   #17
smc8788
...at least I have chicken
smc8788's Avatar
smc8788 is definitely a rep cheat.smc8788 is definitely a rep cheat.smc8788 is definitely a rep cheat.smc8788 is definitely a rep cheat.smc8788 is definitely a rep cheat.smc8788 is definitely a rep cheat.smc8788 is definitely a rep cheat.smc8788 is definitely a rep cheat.smc8788 is definitely a rep cheat.smc8788 is definitely a rep cheat.smc8788 is definitely a rep cheat.
IIRC Crytek admitted from the start it wasn't playable at max settings on any hardware that was available at that time it was developed - they instead wanted to 'future-proof' it by making higher settings available for when more powerful GPUs were available so those settings would become playable.
__________________
My Rig: [FD Define Mini] - [Asus P8Z77-M Pro] - [i5 2500k @ 4.4GHz/1.34V] - [Corsair H60] - [8GB Corsair Vengeance LP] - [Asus GTX TITAN] - [512GB Vertex 4, 1TB F3, 2TB F4 x 2] - [Corsair HX650]
Other stuff I own: [BenQ XL2411T/Dell 2407WFP] - [CM Novatouch TKL] - [Zowie FK1] - [Fostex TH900] - [Woo Audio WA7 Fireflies] - [Sony Bravia KDL65W855] - [Onkyo TX-NR515] - [B&W 685]
[Steam] - [Battlelog]
smc8788 is offline   Reply With Quote
Old 15th Dec 2009, 13:47   #18
sear
Guest
Posts: n/a
I think it was a good kick in the pants. It still does tons of things that most games implement in extremely limited forms (or not at all), and while some might claim it's unoptimised, it's more that it attempts more than any other game in one of the most difficult environments possible (large open environments, which are hard to optimise for every situation). Some games may get by on art design, but I think Crysis is raw technical mastery (with good but somewhat bland art direction). It really just does not compromise very often.
Old 15th Dec 2009, 14:10   #19
uz1_l0v3r
Multimodder
uz1_l0v3r has yet to learn the way of the Dremel
I did plan on upgrading solely for playing Crysis, but it soon became apparent that even the best GPUs at the time (8800 GTX) were not up to the job. I waited a full three years before finally upgrading. I still wanted Crysis and Warhead, but really I just wanted a good gaming PC. I paired a GTX 275 with a core i7 920 and ran Crysis/Crysis Warhead on enthusiast settings at 1280 * 1024. I for one was very impressed with both the graphics and gameplay.
uz1_l0v3r is offline   Reply With Quote
Old 15th Dec 2009, 14:57   #20
PegasusM
Stand back, I'm doing science
PegasusM's Avatar
PegasusM is definitely a rep cheat.PegasusM is definitely a rep cheat.PegasusM is definitely a rep cheat.PegasusM is definitely a rep cheat.PegasusM is definitely a rep cheat.PegasusM is definitely a rep cheat.PegasusM is definitely a rep cheat.PegasusM is definitely a rep cheat.PegasusM is definitely a rep cheat.PegasusM is definitely a rep cheat.PegasusM is definitely a rep cheat.
yes, and we need another Crysis like game in this sea of console ports with comparably poor graphics. Maybe more console gamers would turn to PC gaming if they saw what the PC is capable of in more games.
Also I really enjoyed Crysis, even before I upgraded and saw the graphics on high I thought the gameplay was fun, the story wasn't fantastic but I don't think it needed to be.
PegasusM is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
