News Adobe Acrobat, Reader under attack
Discussion in 'Article Discussion' started by CardJoe, 15 Dec 2009.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. Skiddywinks
    Skiddywinks Minimodder
    10 Aug 2008
    Christ. Again?
  3. scawp
    scawp What's a Dremel?
    8 Sep 2009
    SazBard likes this.
  4. Ryun
    Ryun What's a Dremel?
    28 Apr 2009
    I wouldn't say that. The UI is 'eh' and the plugin is hit or miss. I like it's benefits over my issues with it -- and I do use it over Acrobat -- however, but I don't think it's better than Acrobat for people who just want the software to work (I'm referring to the plugin mainly here).
  5. dicobalt
    dicobalt What's a Dremel?
    21 Mar 2009
    Wherever javascript goes bad security tags along. You can blame the majority of serious browser vulnerabilities across all browsers and platforms on javascript. That is why NoScript functionality should be a standard feature in ANYTHING that uses javascript. It's like UAC for the web.
  6. whiskers
    whiskers What's a Dremel?
    11 Dec 2009
    After Foxit installed Ask toolbar on my computer even though I checked "no" I decided to search for yet another alternative - http://www.docu-track.com/home/prod_user/PDF-XChange_Tools/pdfx_viewer
    It's even faster than Foxit, has a much nicer looking user interface, and WILL save your changes like highlights and underlines (though I only READ PDFs occasionally)
  7. bogie170
    bogie170 What's a Dremel?
    11 Aug 2008
    Adobe = Bloatware.
    Foxit +1
  8. l3v1ck
    l3v1ck Fueling the world, one oil well at a time.
    23 Apr 2009
    +1
  9. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    it's adobe's fault.. they need to make sure when someone issues a System.Shell.execute, it's handled correctly
  10. DarkLord7854
    DarkLord7854 What's a Dremel?
    22 Jun 2005
    Adobe are really bad about this stuff..
  11. ffjason
    ffjason What's a Dremel?
    27 Jul 2009
    Adobe 150MB+ hard drive -- Foxit ~10MB
    Adobe loads 1-2 minutes -- Foxit in 1-2 seconds
    Adobe ram usage ~500MB -- Foxit ~150MB
    (same document)
    I could go on.
    Another alternative is Sumatra PDF which is a tiny program however it has RAM leakage problems and I have seen ram usage 1GB+ for large files (same document as above). Otherwise a brilliant program though.
    Never had any problems with the Foxit plugin in firefox or chrome - what the hell are you trying to open? I actually found it to be better and less buggy than Adobe's. Although I had stopped using way before adobe starting installing stuff I didn't want it to, that was the final straw. If I install a program I only want to have to uninstall that one program, not two or more!? In addition to that Adobe doesn't "just work" - have you seen how many exploits have been targeted at it? Using a less popular browser/pdf viewer etc always helps to avoid these vulnerabilities as exploit creators don't target them!
    Also never had this issue and I have installed it over 100 times - are you sure you unticked it?
  12. LucusLoC
    LucusLoC What's a Dremel?
    28 Nov 2006
    i hate adobe products. 90+ mb for a reader? what on earth for! someone please tell me! and their other products are just as bloated and broken. how did they manage to become an industry standard?!
  13. samkiller42
    25 Apr 2006
    OSX's preview program opens PDF's which is handy, but windows still chugs along with Adobe, but with my system specs, it's not the end of the world. But it's nice to see another company being targeted over Microsoft, kinda feel sorry for MS, hum, ah well.
    Sam
  14. Aracos
    Aracos What's a Dremel?
    11 Feb 2009
  15. Digi
    Digi The not-so-funny Cockney
    23 Nov 2009
    CutePDF here. No hassles.
  16. forum_user
    forum_user forum_title
    4 Jan 2012
    Sorry for reanimation of long dead thread. I did a search and this was the closest thread to represent my question.
    I need an alternative to Adobe Reader. Is there any software out there that is simple, malware/bloatware/adware free. That will not want to update itself all the time.
Tags: Add Tags
