Go Back   bit-tech.net Forums > Modding > Modding
Reply
Thread Tools View Mode
Old 10th Oct 2010, 12:25   #301
Kovoet
Alweer in die kak
Kovoet's Avatar
Kovoet is definitely a rep cheat.Kovoet is definitely a rep cheat.Kovoet is definitely a rep cheat.Kovoet is definitely a rep cheat.Kovoet is definitely a rep cheat.Kovoet is definitely a rep cheat.Kovoet is definitely a rep cheat.Kovoet is definitely a rep cheat.Kovoet is definitely a rep cheat.Kovoet is definitely a rep cheat.Kovoet is definitely a rep cheat.
WWWWWWWWWWOOOOOOOOOOWWWWWWWWWWW absolute awesome I want one as well
__________________
[Coolermaster Cosmos II] [i7 i2700K] [Hydro H100i] [ASUS 7970 DirectCUii Top] [16GB Corsair Vengeance 1600mhz] [Asus Sabertooth Z77] [Corsair AX850] [1 x 300gb VelociRaptor] [1 x 1TB samsung F3] [Dell U2312H & U2311HM] [Corsair K70] [Belkin (razer) N52te] [QPAD QH90 White] [120GB Corsair pro SSD] [ Mushkin 120GB deluxe SSD Sata 3 ][Corsair M65 white] [ASUS Xonar DX soundcard]
Asus Nexus Tablet
Kovoet is offline   Reply With Quote
Old 10th Oct 2010, 13:13   #302
Razer2007
Building Proxima
Razer2007's Avatar
Razer2007 has yet to learn the way of the DremelRazer2007 has yet to learn the way of the DremelRazer2007 has yet to learn the way of the DremelRazer2007 has yet to learn the way of the DremelRazer2007 has yet to learn the way of the DremelRazer2007 has yet to learn the way of the Dremel
Agree. here in SA, if found a place that sells bench top size CNC's and the cheapest is like R25 000!!! have to make one myself some time.
__________________
Razer2007 is offline   Reply With Quote
Old 10th Oct 2010, 18:34   #303
Fonne
Multimodder
Fonne has yet to learn the way of the Dremel
Originally Posted by lenne0815 View Post
Mine are 3nm but theyre underpowered, i would recomment to use atleast 6nm nema 34 on a build like mine, if its smaller u can use 3nm, but dont get anything less than that, loosing steps because of insufficient motor torque is a big hassle and u can easily avoid it.
Thanks a lot ..... Looking at some Nema 34 Stepper Motor 1318oz (9.3 Nm), but dont know about the quality yet - These:
http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=190453950269
On your newest version you are using Linear Guide block + rails on the Y and X Axis - Before you used Liniar ball bearings + Support Rail - Any special reason for this chance, where only your Z Axis are using Ball bearings + Support rails now ?
But show some more cutting action - Amazing machine and quality
Fonne is offline   Reply With Quote
Old 12th Oct 2010, 08:49   #304
lenne0815
What has been seen cannot be unseen
lenne0815's Avatar
lenne0815 has yet to learn the way of the Dremellenne0815 has yet to learn the way of the Dremellenne0815 has yet to learn the way of the Dremel
Thank you very much guys
Theres no specific reason for the blocks, it was just what i could get of ebay in the proper size u can pretty much use whatever u want, but if go for that set ( which is aweseome, should have bought that ) rather use something "heavy duty" like my rails because with these steppers metal cutting is not too far off but remember if u build a moving gantry type u want to use two steppers for the long axis so all in all u need four !
lenne0815 is offline   Reply With Quote
Old 6th Nov 2010, 16:00   #305
lenne0815
lenne0815's Avatar
Ok guyse, long time no see... lets do this
My new ultra awesome edgefinger tool, 0,05mm precise ( enough for wood )
Two sheets of balsa are the starting point for this little project...
Wood gleue makes them one piece
Vacuum clamped to the table
Routing a shape out
Formating and routing an multiplex board
this looks familiar
Mating balsa and Multiplex
Back onto the Table
Roughing
Finishing
Finished
After doing the other side aswell it looks like this:
and no, its not the well known german v2, its a longboard hybrid core
Some other stuff i made from POM
slidepads
And, last but not least some HD vids for ur viewing pleasure !
Old 6th Nov 2010, 21:14   #306
Yaka
Supermodder
Yaka is a hoopy frood who really knows where their towel is.Yaka is a hoopy frood who really knows where their towel is.Yaka is a hoopy frood who really knows where their towel is.Yaka is a hoopy frood who really knows where their towel is.Yaka is a hoopy frood who really knows where their towel is.Yaka is a hoopy frood who really knows where their towel is.Yaka is a hoopy frood who really knows where their towel is.Yaka is a hoopy frood who really knows where their towel is.Yaka is a hoopy frood who really knows where their towel is.Yaka is a hoopy frood who really knows where their towel is.Yaka is a hoopy frood who really knows where their towel is.
oh that wooden longboard board looks really nice love the effect you can see in the pics
Yaka is offline   Reply With Quote
Old 6th Nov 2010, 21:24   #307
lenne0815
lenne0815's Avatar
Its just the core, itll be laminated with carbon but a glassfibre version where u can see through is planned aswell...
Old 6th Nov 2010, 23:33   #308
stonedsurd
Is a cackling Yuletide Belgian
stonedsurd's Avatar
stonedsurd - may the hammer of Bindi be bestowed on youstonedsurd - may the hammer of Bindi be bestowed on youstonedsurd - may the hammer of Bindi be bestowed on youstonedsurd - may the hammer of Bindi be bestowed on youstonedsurd - may the hammer of Bindi be bestowed on youstonedsurd - may the hammer of Bindi be bestowed on youstonedsurd - may the hammer of Bindi be bestowed on youstonedsurd - may the hammer of Bindi be bestowed on youstonedsurd - may the hammer of Bindi be bestowed on youstonedsurd - may the hammer of Bindi be bestowed on youstonedsurd - may the hammer of Bindi be bestowed on you
Lenne, has anyone ever told you that you're nuts?
__________________
stonedsurd is offline   Reply With Quote
Old 6th Nov 2010, 23:49   #309
lenne0815
lenne0815's Avatar
repeatedly.
Old 7th Nov 2010, 02:12   #310
GCOFIELDD
Multimodder
GCOFIELDD's Avatar
GCOFIELDD has yet to learn the way of the Dremel
This is the first time I have seen this thread; I was reading through it and got to about page 8 and was thinking “ this is cool this guy is making his own CNC…I am going to skip ahead and see how it turns out.”
When I jumped to page 16 and saw the finished product I thought “holly sh*t did someone sponsor this guy a CNC!” I can’t believe your end product man, it is awesome! Congratulations, you earned it man! I went back and read the rest of the thread. It is funny and a little twisted that you were using the CNC to make its own parts
GCOFIELDD is offline   Reply With Quote
Old 7th Nov 2010, 04:20   #311
RabidCicada
Multimodder
RabidCicada's Avatar
RabidCicada has yet to learn the way of the Dremel
So...I haven't read the whole thread...but how do you drive a custom CNC rig? Is there off the shelf software you buy and then calibrate for your setup?
RabidCicada is offline   Reply With Quote
Old 9th Nov 2010, 14:04   #312
lenne0815
lenne0815's Avatar
Thanks guys, much appreciated !
To "drive" the cnc u need some essential parts:
Controller board
A mainboard that works flawlessly ( very hard to find for me )
And the Software ( in this case Mach3, but there are many others aswell )
If u got these parts u can connect the controller board via ltp and control away, obvoiusly u have to configure the software to ur specs / needs
Old 9th Nov 2010, 17:24   #313
noobieocer
Minimodder
noobieocer has yet to learn the way of the Dremel
there's also a few free linux based versions, and if you have a parallel port then most software will only require a translator and a simple H bridge amplifier to drive the motors. (made a mini CNC for last year uni project )
noobieocer is offline   Reply With Quote
Old 10th Nov 2010, 12:29   #314
lenne0815
lenne0815's Avatar
true, but i think especially when ure beginner mach 3 and a good breakout board are the best option for a setup ( especially security funktions like charge pump and end switches is an absolut necessity for beginners ! )
Old 10th Nov 2010, 16:09   #315
noobieocer
Minimodder
okay tbh i kinda made my own software and system when making my project, i assume end switches are limit and home position switches for the axis, but what is charge pump?
Old 10th Nov 2010, 17:25   #316
lenne0815
lenne0815's Avatar
Chrge pump is a 12khz "kill switch" signal which runs on one pin, if that fails, the router instantly stops, i disconnected my iphone once while i was routing ( stopid me, never do something else than routing on the controller pc ) and it broke only the bit luckily. ill never route without charge pump signal again...
Old 24th Nov 2010, 13:56   #317
noobieocer
Minimodder
aka emergency stop button, i dont get it why did the bit broke cause you disconnected a iphone?
Old 24th Nov 2010, 21:59   #318
lenne0815
lenne0815's Avatar
Its totally different from an estop, u can just press it to hold the machine...
its broke because the 40khz control signal got interrupted its quiet "fragile", no charge pump, the cnc interprets the signals wrong - fail.
For understanding that u have to realise that the cnc signals run in realtime on winxp, which is quiet hard t o achieve to start, but running anything else than the controller software is likely to kill the signal.
Old 7th Dec 2010, 21:38   #319
Xye
Supermodder
Xye's Avatar
Xye has yet to learn the way of the DremelXye has yet to learn the way of the Dremel
I have to say I admire the workmanship there. and indeed this entire thread. I once thought of making a similar CNC machine (much smaller) but then considered what i might use it for and that kind of decided me against it at the time.
Now though I wish I had a way of making things direct from my pc (i do alot of CAD work) and this seems so much fun to make.... but again time and money are a hinderance.
On the subject of your fragile signals... The CNC machines i am familiar with have their own dedicated interface and built in pc where you simply plug in your usb pen with the file on and hit go. Surely it would be better for you to use an old PC to run the machine while you can use the other PC as you like without having to worry about it?
Xye is offline   Reply With Quote
Old 8th Dec 2010, 02:45   #320
SuicideNeil
I'm insane, not stupid.
SuicideNeil's Avatar
SuicideNeil is almost as Godly as yodasarmpitSuicideNeil is almost as Godly as yodasarmpitSuicideNeil is almost as Godly as yodasarmpitSuicideNeil is almost as Godly as yodasarmpitSuicideNeil is almost as Godly as yodasarmpitSuicideNeil is almost as Godly as yodasarmpitSuicideNeil is almost as Godly as yodasarmpitSuicideNeil is almost as Godly as yodasarmpitSuicideNeil is almost as Godly as yodasarmpitSuicideNeil is almost as Godly as yodasarmpitSuicideNeil is almost as Godly as yodasarmpit
Missed a few updates- I was wondering what that piece of wood was going to become, then I thought 'longboard?' after having seen a few here and there...
Awesome work, its like a license to print money having your own CNC.
__________________
ASUS P8Z77-M PRO | INTEL CORE i5 2500K @ 4.3GHZ | EVGA GEFORCE GTX 670FTW | CORSAIR VENGENCE DDR3 1600MHZ 2x 4GB | SAMSUNG SPINPOINT F3 1TB | TITAN FENRIR | ACER PREDATOR | WIN 7PRO x64
SuicideNeil is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
