Reply
Thread Tools View Mode
Old 21st Feb 2011, 14:50   #61
djzic
Bokehlicious!
djzic's Avatar
djzic is the Cheesecake. Relix smiles down upon them.djzic is the Cheesecake. Relix smiles down upon them.djzic is the Cheesecake. Relix smiles down upon them.djzic is the Cheesecake. Relix smiles down upon them.djzic is the Cheesecake. Relix smiles down upon them.djzic is the Cheesecake. Relix smiles down upon them.djzic is the Cheesecake. Relix smiles down upon them.djzic is the Cheesecake. Relix smiles down upon them.djzic is the Cheesecake. Relix smiles down upon them.djzic is the Cheesecake. Relix smiles down upon them.djzic is the Cheesecake. Relix smiles down upon them.
very nice work.
__________________
PC: i5 4670k | Gigabyte GA-Z87MX-D3H | 8GB Crucial Ballistix Tracer 1866 | EVGA GTX 770 ACX SC
Parvum S1.0 | Samsung Spinpoint 1TB | OCZ Agility 3 120gb
Asus MW221U | Razer BlackWidow | Spyder2Express
Cam: Canon 400D | 35mm f/2.8 | Helios 44-2
djzic is offline   Reply With Quote
Old 21st Feb 2011, 15:15   #62
coolamasta
Folding@Home CC Captain 2010/11/12
coolamasta's Avatar
coolamasta is definitely a rep cheat.coolamasta is definitely a rep cheat.coolamasta is definitely a rep cheat.coolamasta is definitely a rep cheat.coolamasta is definitely a rep cheat.coolamasta is definitely a rep cheat.coolamasta is definitely a rep cheat.coolamasta is definitely a rep cheat.coolamasta is definitely a rep cheat.coolamasta is definitely a rep cheat.coolamasta is definitely a rep cheat.
Hows this project coming along now bud as im about to start a big watercooling project off in my old PC-70 case and im looooooving that new front panel and PSU mount a lot!!
__________________
Main Rigs:~ i7 4790K @ 4.8 WC'd - 16GB @ 2400 - EVGA GTX 980Ti | Alienware 13 Laptop, i7, Dual M.2 SSD's, 16GB and Graphics Amp
| ~~~ My Current Dual EP-Xeon 2670 Project ~~~ | ~~~ My Mitsubishi Evo Track Car Project ~~~ |
coolamasta is offline   Reply With Quote
Old 7th Mar 2011, 20:45   #63
schmunk
What's a Dremel?
schmunk has yet to learn the way of the Dremel
Hey Guys
Hello,
I also am modding an old PC-70 case and saw this site. I currently am using a Antec P-180 and was planning in putting my 240mm BI 2 in the bottom where the HDs go vertically like this:
and I was going to vent each side panel so I could bring cool air into my rad sandwich, but the more I looked at it, the more of a drag it was to try to cram everything in, and I would also only have 4 5.25" bays, and loose my one 3.5" bay. I also had to fit my T line fill port and reservoir, my 120mm rad, and my two pumps. Meanwhile I had this PC-70 case that I got on CL for $20, so I decided to clean it up.
I had a Lian Li aluminum mouse pad that someone game me as a joke gift back when I had a PC-65. I am using that piece of metal for my front 120mm fan mod. On the other side will be a 120mm fan sandwiched Black Ice Stealth. I decided to make mine as low as possible cause the fan screws rest on the bottom of the 80mm fan cut out, so it is extra support.
I took out the drive hardware from the bottom of the case, and I'm moving them up with a Lian Li EX-34NB, which will give another 120mm fan to the front. My dual 350 pumps with XPSC dual head will go down in the front bottom also.
I will fit my 240mm rad at the top, under a black "Bricky" Phobya Triple Radiator Grill (I think the triple looks more proportionate on such a big case) and all of my drives are black on the front. I am using a black plastic 120mm blank under one spot on the grill, but may invest in a 360 radiator down the road.
I am going to use 80mm quiet Nexus fans on the back, and the 120mms on the radiator and PSU should be enough to exhaust the case, so I do not plan to mod the back PSU plate.
Good to see some other modders with this case still!
Schmunk
schmunk is offline   Reply With Quote
Old 8th Mar 2011, 20:01   #64
schmunk
What's a Dremel?
Finished the front:
Old 7th Oct 2011, 12:39   #65
Burnout21
Is the daddy!
Burnout21's Avatar
Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.
Nice! I really should look at finishing the case now, no reason not to other than running my own business, learning HTML, Arduino and many more things! eek!
__________________
Project log Mocha70
i7 930, GA-X58-USB3, 12GB Kingston, GTX980, 240GB Cruical SSD, 1Tb Seagate, WC
Burnout21 is offline   Reply With Quote
Old 8th Oct 2011, 11:32   #66
Angel OD
Pump Killer
Angel OD's Avatar
Angel OD - it's over 9000!!!!!!!!1!1!1!!!Angel OD - it's over 9000!!!!!!!!1!1!1!!!Angel OD - it's over 9000!!!!!!!!1!1!1!!!Angel OD - it's over 9000!!!!!!!!1!1!1!!!Angel OD - it's over 9000!!!!!!!!1!1!1!!!Angel OD - it's over 9000!!!!!!!!1!1!1!!!Angel OD - it's over 9000!!!!!!!!1!1!1!!!Angel OD - it's over 9000!!!!!!!!1!1!1!!!Angel OD - it's over 9000!!!!!!!!1!1!1!!!Angel OD - it's over 9000!!!!!!!!1!1!1!!!Angel OD - it's over 9000!!!!!!!!1!1!1!!!
All good things come to those who wait!
But more than a year since last update? Get on with it!
__________________
It's NOT a mac... http://forums.bit-tech.net/showthread.php?t=139635 - Motm nominee
WII - UNLimited Edition http://forums.bit-tech.net/showthread.php?t=179763 - Moty nominee
Liquid Cooled CarPC - Sponsored by Mushkin Enhanced & Centrafuse
http://forums.bit-tech.net/showthread.php?t=207889 - Motm nominee
The Theory of Everything http://forums.bit-tech.net/showthread.php?t=219504 - Motm WINNER!
Angel OD is offline   Reply With Quote
Old 8th Oct 2011, 11:38   #67
stonedsurd
Is a cackling Yuletide Belgian
stonedsurd's Avatar
stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.
__________________
stonedsurd is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
