Reply
Thread Tools View Mode
Old 24th Dec 2009, 13:33   #1
mnpctech
bit-tech sponsor
mnpctech's Avatar
mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.
Project .::District 9::. Cooler Master 840 ATCS Case Mod
This Case Mod was done by bit-tech's MOTM Sponser, Mnpctech!
Customize your PC or window with custom Stickers from Mnpctech HERE
This PC is for the Cooler Master suite at the 2010 CES show. It will be showcasing a Heat Sink design to be announced at the show.
You can watch video in HD here
Final photos
Mitron Interlink Fan Controller was cannibalized and mounted in the rear of the chassis.
The prawn canister resides in the front 5.25 bays, under a single DVD drive.
MNU logo painted on the optical drive face. Did Christopher steal this to access archived files?
Flexible conduit seen through exploded hole in the right side panel.
The Prawn lettering was hand painted. You can download the font, http://www.district9movie.com/downlo...tdownload.html
Rusted and scratches were hand painted on the exterior.
The theme for this PC was inspired by this Prawn Arc gun.
The canvas for the "PRAWN" PC build is the Cooler Master 840 ATCS
Log Update 10/02/09
CNC milled front intake plate with "DISTRICT 9" theme
I've cut the window from Lexan. It's tougher than plexiglass/acrylic, but 2 or 3 times more expensive. It won't shatter or crack "easily" You can buy Lexan sheets at Home Depot, Lowes and some hardware stores like Ace.
The window will be fastened with 1/4" socket head screws, for reinforced armour look
Using center punch to mark each fastener hole.
Using 3/8" drill bit
Using wire cutter to make cracks around the hole
Etching Rotary Tool (or Dremel) Engraving Bits
Using the dremel to emulate some cracks
I'm adding bullet holes to the case too, so I drilled holes in the 840's aluminum panel. I then used a tin snip and needle nose plier to cut and rip the 3/8" hole open
Exploded hole in right side panel.
One of the easiest steps to fit this theme was replacing the OEM handle on the Cooler Master 840 motherboard tray with machined aluminum handle. I had one spare handle left over from our previous stock. The new version has been revised with rounded finger grips, as shown here, http://www.mnpctech.com/MnpctechBill...leGrooved.html
Diamond Knurl Computer Case Feet
http://www.mnpctech.com/Aluminum_Com...Case_Feet.html
1/4" thick acrylic sheets as the reinforced segments of the side panels.
The "Pumpkin" Orange color was done first. The perimeter of the " exploded hole" will be airbrushed by Brad with a burned surface effect
The 840 normally comes with Black frame 230mm fans, no leds.
side panel
Left side panel, the hole will have burned effect airbrushed on later
Flexible conduit cables!
Here is some screen shots taken from the movie trailer on Youtube. I think it's important to have the prawn canister implemented into the case. If Cooler Master had requested watercooling, it would been fun to make a reservoir based on the canister, but the system will be air cooled.
Original Prawn canister from a screen shot taken from the movie.
My canister will be lit with a 4" UV cold cathode, mounted on the inside wall of the back cover.
Once it's painted and the window is darkened a bit, it should look eerie.
canister back cover
for canister window, I'm going to bend a piece of clear 1/8" thick case acrylic, http://www.mnpctech.com/acrylic_colo..._windows1.html
Prawn canister window was tinted like original
RUSTED GPU!
Watch E.E.L. Embiense demonstrate how to use the Sophisticated Finishes products for adding a rust effect to your Mods.
http://www.youtube.com/watch?v=26Ud9T-doAc
I think Christopher left his scrap PC out in the rain a few times. To create those results, I apply the Iron Surfacer to the top panel first, then the Rust Solution after 10 mins. I repeated these steps over different locations on the exterior. The more Rust Solution you apply, the more Orange colored effect you get.
__________________
My GPU support brackets We Ship International Orders!
mnpctech is offline   Reply With Quote
Old 24th Dec 2009, 13:33   #2
mnpctech
bit-tech sponsor
mnpctech's Avatar
The lighting needs to be dimmed down a bit,for a more eerie looking feel
__________________
Old 24th Dec 2009, 13:38   #3
Colossous
Hypermodder
Colossous's Avatar
Colossous can run CrysisColossous can run CrysisColossous can run CrysisColossous can run CrysisColossous can run CrysisColossous can run CrysisColossous can run CrysisColossous can run Crysis
Top notch as ever duder
Colossous is offline   Reply With Quote
Old 24th Dec 2009, 14:24   #4
Reverse
Reverse/srvR
Reverse's Avatar
Reverse has yet to learn the way of the Dremel
Have been following it on TMD forums. Looking good Bill!
__________________
Project: Reverse˛
Reverse is offline   Reply With Quote
Old 24th Dec 2009, 16:04   #5
Angel OD
Pump Killer
Angel OD's Avatar
Angel OD - it's over 9000!!!!!!!!1!1!1!!!Angel OD - it's over 9000!!!!!!!!1!1!1!!!Angel OD - it's over 9000!!!!!!!!1!1!1!!!Angel OD - it's over 9000!!!!!!!!1!1!1!!!Angel OD - it's over 9000!!!!!!!!1!1!1!!!Angel OD - it's over 9000!!!!!!!!1!1!1!!!Angel OD - it's over 9000!!!!!!!!1!1!1!!!Angel OD - it's over 9000!!!!!!!!1!1!1!!!Angel OD - it's over 9000!!!!!!!!1!1!1!!!Angel OD - it's over 9000!!!!!!!!1!1!1!!!Angel OD - it's over 9000!!!!!!!!1!1!1!!!
This is just a thing of beauty!
I love the rust!
__________________
It's NOT a mac... http://forums.bit-tech.net/showthread.php?t=139635 - Motm nominee
WII - UNLimited Edition http://forums.bit-tech.net/showthread.php?t=179763 - Moty nominee
Liquid Cooled CarPC - Sponsored by Mushkin Enhanced & Centrafuse
http://forums.bit-tech.net/showthread.php?t=207889 - Motm nominee
The Theory of Everything http://forums.bit-tech.net/showthread.php?t=219504 - Motm WINNER!
Angel OD is offline   Reply With Quote
Old 24th Dec 2009, 16:21   #6
xDeaDReckoninGx
****ing delete my account,
xDeaDReckoninGx has yet to learn the way of the Dremel
nice
xDeaDReckoninGx is offline   Reply With Quote
Old 24th Dec 2009, 17:38   #7
oatey4519
can't be arsed...
oatey4519's Avatar
oatey4519 has yet to learn the way of the Dremel
very nice job... looks awesome
__________________
Intel i7 3770K @ 4.5GHz EK HF Nickel Blocked - 8GB Corsair Vengeance 1866 RED - EVGA Z77 FTW - 2 x 120GB Corsair Force GT RAID - 1TB Samsung F1 - 1TB Samsung F3 - EVGA GTX 660 FTW Sig2 3GB - Coolermaster Silent Pro M1000 W - Corsair 800D - Dell 2209W 1920 x 1080 - ASUS Xonar Dx - Sennheiser PC350 Headphones - Saitek Keyboard & Logitech G9 Mouse
oatey4519 is offline   Reply With Quote
Old 25th Dec 2009, 11:08   #8
Bu Do
Crazy Kiwi
Bu Do's Avatar
Bu Do has yet to learn the way of the Dremel
Love this mod Keep it up Bill.
Bu Do is offline   Reply With Quote
Old 25th Dec 2009, 11:23   #9
b1g-d0g
Mod Master
b1g-d0g's Avatar
b1g-d0g is a Super Spamming Saiyanb1g-d0g is a Super Spamming Saiyanb1g-d0g is a Super Spamming Saiyanb1g-d0g is a Super Spamming Saiyanb1g-d0g is a Super Spamming Saiyanb1g-d0g is a Super Spamming Saiyanb1g-d0g is a Super Spamming Saiyanb1g-d0g is a Super Spamming Saiyanb1g-d0g is a Super Spamming Saiyanb1g-d0g is a Super Spamming Saiyanb1g-d0g is a Super Spamming Saiyan
I love the detail you put into all your builds Bill
b1g-d0g is offline   Reply With Quote
Old 25th Dec 2009, 12:46   #10
mnpctech
bit-tech sponsor
mnpctech's Avatar
Thanks for tuning into this build and commenting!
MERRY CHRISTMAS!
I've gotta keep plugging away at this, so it's finished in time to be shipped to Vegas for the 2010 CES.
Whats this? It's a cannibalized Mitron Interlink, 3.5" bay fan controller
__________________
Old 25th Dec 2009, 12:50   #11
Burnout21
Is the daddy!
Burnout21's Avatar
Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.
I am ashamed at you. Your American and faked bullet holes.
I am sure if you went down a firing range some one would help you out, could have made it interesting by marking the location of the desired hole and let them tune there target practice abilities.
Except the fact that the acrylic would have pretty much been totally ruined by a single shot causing massive cracks potentially splitting the whole window into several pieces....
__________________
Project log Mocha70
i7 930, GA-X58-USB3, 12GB Kingston, GTX980, 240GB Cruical SSD, 1Tb Seagate, WC
Burnout21 is offline   Reply With Quote
Old 25th Dec 2009, 14:18   #12
stonedsurd
Is a cackling Yuletide Belgian
stonedsurd's Avatar
stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.
Originally Posted by Burnout21 View Post
I am ashamed at you. You're American and faked bullet holes.
Sorry, had to be done.
But I agree. I would've shot the sucker, just to see what would happen
__________________
stonedsurd is offline   Reply With Quote
Old 26th Dec 2009, 14:28   #13
[ZiiP] NaloaC
I Mod, Therefore I Own
[ZiiP] NaloaC's Avatar
[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan
This is a valid point. I had a thread in the modding section about shattered acrylic. I took my .22 Ruger and shot some 6mm acrylic and it held perfectly well and the results were fantastic.
.22 subsonic hollow-points silenced. Might incorporate it into something some day.
Liking the look of this build as ever Bill
__________________
ZiiP Gaming Community
Sui Generis: i7 5820K, Corsair H105, 16GB Kingston 2133, ASUS X99-S, Samsung 950 Pro 512GB M2, Samsung 850 1TB EVO, Corsair F3 120GB SSD & Samsung EVO 250GB SSD, MSI GTX 970, Corsair HX850W, Corsair Obsidian 800D, AOC 34", Logitech G15, Shogun Bros Ballista Mk-1, Corsair 1500.
[ZiiP] NaloaC is offline   Reply With Quote
Old 26th Dec 2009, 14:54   #14
GravitySmacked
Mostly Harmless
GravitySmacked's Avatar
GravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming Saiyan
Ooooh very nice indeed!
GravitySmacked is offline   Reply With Quote
Old 26th Dec 2009, 15:15   #15
badje
boni
badje's Avatar
badje has yet to learn the way of the Dremel
Lol naloc good point, like ur acrilic panels to!
OT: even if the bullet holes aren't real, they still look very nice.
That prawn canister looks nice too, the gray color is cool.
keep on modding
badje is offline   Reply With Quote
Old 26th Dec 2009, 22:49   #16
Burnout21
Is the daddy!
Burnout21's Avatar
+rep
__________________
Project log Mocha70
Old 27th Dec 2009, 01:17   #17
mnpctech
bit-tech sponsor
mnpctech's Avatar
Creating the illusion is more challenging and more FUN
Mnpctech Painter, Brad Galvin starts the transformation from pristine to weathered and dilapidated. He starts by creating the illusion of a scratched-up exterior, imagine Christopher dragged his computer in the gravel. Did he have to wrestle it away from somebody at one time?
The Orange & White exterior finish has been scratched done to the bare metal. This is done by hand using enamel "One Shot" Silver paint and a paint brush.
Notice the paint is chipped around the bullet holes.
__________________
Old 27th Dec 2009, 02:14   #18
PureSilver
E-tailer Tailor
PureSilver's Avatar
PureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpit
Wow, looking good! (As usual!)
__________________
Intel Core i7 920 @ 3Ghz, Noctua NH-U12P SE, Asus P6T Deluxe V1, Corsair 12GB (6x2GB) 1600Mhz C8 @ XMP,
EVGA GTX-680, Corsair AX760, 2x Samsung SpinPoint F3 1TB, Lian-Li V1020R with 3x Noctua NF-P12 & 3x NF-P14FLX
2.4Ghz 13" unibody MacBook, 4GB RAM & 128GB Samsung SSD
PureSilver is offline   Reply With Quote
Old 27th Dec 2009, 12:30   #19
mnpctech
bit-tech sponsor
mnpctech's Avatar
Thank you for commenting Pure! Brad has painted a variety of Prawn insignia, language and graphics by hand. The bolts are given weathered effects. Christopher left his PC out in the rain. ....Acid rain perhaps?
There was an expolsion in the right side panel at one time.
__________________
Old 27th Dec 2009, 13:10   #20
Kylevdm
The Mod Zoo Podcast Host
Kylevdm's Avatar
Kylevdm is definitely a rep cheat.Kylevdm is definitely a rep cheat.Kylevdm is definitely a rep cheat.Kylevdm is definitely a rep cheat.Kylevdm is definitely a rep cheat.Kylevdm is definitely a rep cheat.Kylevdm is definitely a rep cheat.Kylevdm is definitely a rep cheat.Kylevdm is definitely a rep cheat.Kylevdm is definitely a rep cheat.Kylevdm is definitely a rep cheat.
DUDE!!! that is insane, love it!
__________________
Kyle van der Merwe host at www.TheModZoo.com Podcasts!
Project: Codename C :: LANBOY APOCALYPSE (built with MNPCTECH!) :: Project: Deadline :: Project: MNU
Projects supported by EK Waterblocks, MNPCTECH, Fractal Design, NZXT, ENERMAX, and TM3 Connections
Xeon x5660 @ 4.4GHz :: Asus P6T Deluxe v2 :: 6GB Crucial BalistiX :: GTX 970:: Corsair AX760i
Kylevdm is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
