Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 30th Dec 2009, 11:28   #1
Claave
You Rebel scum
Claave's Avatar
Claave has yet to learn the way of the DremelClaave has yet to learn the way of the DremelClaave has yet to learn the way of the Dremel
How to Build a DVD Server
Andy decided that forking out tens of thousands for an expensive 'Kaleidoscape' server was simply crackers. So, like any good modder, he built one himself, for less. In this article, he guides us through how you can make your own: from hardware to software.
http://www.bit-tech.net/modding/guid...a-dvd-server/1
Claave is offline   Reply With Quote
Old 30th Dec 2009, 11:33   #2
Rkiver
Cybernetic Spine
Rkiver's Avatar
Rkiver has yet to learn the way of the DremelRkiver has yet to learn the way of the DremelRkiver has yet to learn the way of the DremelRkiver has yet to learn the way of the DremelRkiver has yet to learn the way of the DremelRkiver has yet to learn the way of the Dremel
Oooh, I rather like that idea. Nice write up and find for Cinemar also.
__________________
Time for me to learn how to mod....
Rkiver is offline   Reply With Quote
Old 30th Dec 2009, 11:42   #3
Yemerich
I can has PERSUADETRON?
Yemerich's Avatar
Yemerich is almost as Godly as yodasarmpitYemerich is almost as Godly as yodasarmpitYemerich is almost as Godly as yodasarmpitYemerich is almost as Godly as yodasarmpitYemerich is almost as Godly as yodasarmpitYemerich is almost as Godly as yodasarmpitYemerich is almost as Godly as yodasarmpitYemerich is almost as Godly as yodasarmpitYemerich is almost as Godly as yodasarmpitYemerich is almost as Godly as yodasarmpitYemerich is almost as Godly as yodasarmpit
Nice idea! Really good article too.
I would like to see the machine an its innards in some photos if possible too. What can I say... I am a nerd....
__________________
----------------------------- Yemerich -----------------------------
Hephaestus (best design Windows Vista Magazine - 2007, MotM nominee 2008)
Odinn (CCE best design in CP-Brazil 2008)
Hades (Best advanced casemod design CP-Brazil 2010)
Take a look on my projects here.
Yemerich is offline   Reply With Quote
Old 30th Dec 2009, 11:42   #4
PureSilver
E-tailer Tailor
PureSilver's Avatar
PureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpit
Excellent writeup; now, you can blame yourself for the bank robbery I'm going to commit to buy parts.
__________________
Intel Core i7 920 @ 3Ghz, Noctua NH-U12P SE, Asus P6T Deluxe V1, Corsair 12GB (6x2GB) 1600Mhz C8 @ XMP,
EVGA GTX-680, Corsair AX760, 2x Samsung SpinPoint F3 1TB, Lian-Li V1020R with 3x Noctua NF-P12 & 3x NF-P14FLX
2.4Ghz 13" unibody MacBook, 4GB RAM & 128GB Samsung SSD
PureSilver is offline   Reply With Quote
Old 30th Dec 2009, 12:20   #5
yakyb
i hate the person above me
yakyb's Avatar
yakyb can run Crysisyakyb can run Crysisyakyb can run Crysisyakyb can run Crysisyakyb can run Crysisyakyb can run Crysisyakyb can run Crysisyakyb can run Crysisyakyb can run Crysisyakyb can run Crysisyakyb can run Crysis
still think that XBMC connected to a simple Windows share / Local Drive is easier to setup and use all films just need to be in their own directory and named in accordance to theMovieDB.org however the easiest to setup (if not the most impressive) is mediabrowser with the Metabrowser installed for MetaData
yakyb is offline   Reply With Quote
Old 30th Dec 2009, 12:23   #6
Ross1
Multimodder
Ross1 can run CrysisRoss1 can run CrysisRoss1 can run CrysisRoss1 can run CrysisRoss1 can run CrysisRoss1 can run CrysisRoss1 can run CrysisRoss1 can run CrysisRoss1 can run CrysisRoss1 can run Crysis
my 'server' is just my main pc.... the lian-li pc-a77 has space for a good 15 hard drives, more if you use 4in3's. Ive only got 10 connected at the moment (mainly because my mobo has 10 sata ports). span, 'share folder', done. my ion 330 with xbmc downstairs reads everything perfectly, including 18mbps 1080p stuff.
tis a bit of a power monster, but I use the pc all day anyway, download a lot of things during the night, so it would be on all the time even if it didnt act as a server for the house.
Ross1 is offline   Reply With Quote
Old 30th Dec 2009, 12:33   #7
-Acid-
What's a Dremel?
-Acid- has yet to learn the way of the Dremel
good soild well written guide
glad to see something that is bit-tech brewed and not a mag copy
I run a shuttle for my mcp connected to a projector and 5.1 setup
been on mce for years now i,ve something fo rthe new year to get stuck into
-Acid- is offline   Reply With Quote
Old 30th Dec 2009, 12:42   #8
rickysio
N900 | HJE900
rickysio has yet to learn the way of the Dremel
Well, to be honest I was expecting something like a case mod or a DIY case... -.-lll
rickysio is offline   Reply With Quote
Old 30th Dec 2009, 12:56   #9
Flibblebot
Smile with me
Flibblebot's Avatar
Flibblebot is a Super Spamming SaiyanFlibblebot is a Super Spamming SaiyanFlibblebot is a Super Spamming SaiyanFlibblebot is a Super Spamming SaiyanFlibblebot is a Super Spamming SaiyanFlibblebot is a Super Spamming SaiyanFlibblebot is a Super Spamming SaiyanFlibblebot is a Super Spamming SaiyanFlibblebot is a Super Spamming SaiyanFlibblebot is a Super Spamming SaiyanFlibblebot is a Super Spamming Saiyan
I looked at XBMC, but it does a load of things that I don't need it to do - I already have a music server that pipes music around the house, I don't listen to internet radio, and I watch/record TV programmes on the Sky+ box and TV.
I'm a bit of a control freak, and I wanted something that did only what I wanted it to do: just keep a track of my film collection, let me browse it and play whatever film I choose with the minimum of fuss.
Cinemar handles that nicely for me, and it provides the expandability and flexibility that I need. Being used to home automation systems, it also does it in a way that is familiar to me.
If you like and use XBMC, that's fine - I'm not suggesting that Cinemar is better in any way, just that it's what I decided to use based on my own set of requirements. Just because I decided to use it, doesn't mean it's the perfect solution for others
__________________
My uber-system: 66Mhz 486DX2, 8Mb RAM, 20Mb hard drive, 256 colour VGA adaptor (goes all the way up to 800x600!), keyboard AND serial mouse
Flibblebot is offline   Reply With Quote
Old 30th Dec 2009, 12:57   #10
GW42
Minimodder
GW42 has yet to learn the way of the Dremel
+1 on windows media centre (sorry, center...), mediabrowser and metadata. Mediabrowser has a very nice interface, fairly customisable (I think very customisable if you really want to and know your way around html??). I haven't bothered looking into that yet though as there are lots of standard options which look very good to me, so I haven't felt the need to customise further
I want my htpc to cover tv watching and recording (so obvious advantage to MCE there) but also cope well with ripped tv series, not just films. Mediabrowser and metadata do that well. And if you don't want any of the other MCE stuff, there are menu editors that let you remove the stuff you don't want so you don't see it.
I may have missed it, but Inot sure you mentioned whether Cinemar sits on tops of windows - given the other software plugins you've mentioned, I presume it must do. If you have a copy of windows with MCE included, then as mediabrowser and metadata are free it's a very competitive price!
(I've not ventured into HD or Blu-ray yet, but I understand that the plugins mentioned integrate with MCE as well?)
Having said all of the above, I am tempted to install mediaportal to see what that's like. (it is free after all) XBMC is no good to me, as it doesn't do TV recording or watching, but you don't want tv so I'd be interested in the reasons why you chose not to use XBMC (which is, again, free...)
EDIT: the problem with longish posts is that someone posts before you and answers the question before you've asked it
GW42 is offline   Reply With Quote
Old 30th Dec 2009, 13:00   #11
Devolve
Deadbeat
Devolve's Avatar
Devolve has yet to learn the way of the Dremel
nice idea, but i still prefer using WMC with media browser, such a nice interface. Plus with the many possible plugins, internet tv is a possibility aswell. The storage option is better than what i've been looking at though. nearly bought windows server.
Only problem is with me ripping films, even after a shrink im using 4gig a film. Its a hellish amount when you backup aswell (i didnt once and the disk drive failed, 50 odd indexed films down the pan).
__________________
PRAESIS UT PROSIS
Evolution is the myth. Look around you the world isn't
evolving...it's DEvolving.
Devolve is offline   Reply With Quote
Old 30th Dec 2009, 13:06   #12
Ross1
Multimodder
encode to a more efficient codec than mpeg2, this one is obvious.
Old 30th Dec 2009, 13:27   #13
DeathAwaitsU
I'm Back :D
DeathAwaitsU's Avatar
DeathAwaitsU has yet to learn the way of the DremelDeathAwaitsU has yet to learn the way of the DremelDeathAwaitsU has yet to learn the way of the DremelDeathAwaitsU has yet to learn the way of the Dremel
Tversity tbh
__________________
DeathAwaitsU is offline   Reply With Quote
Old 30th Dec 2009, 13:37   #14
lacuna
Supermodder
lacuna is the Cheesecake. Relix smiles down upon them.lacuna is the Cheesecake. Relix smiles down upon them.lacuna is the Cheesecake. Relix smiles down upon them.lacuna is the Cheesecake. Relix smiles down upon them.lacuna is the Cheesecake. Relix smiles down upon them.lacuna is the Cheesecake. Relix smiles down upon them.lacuna is the Cheesecake. Relix smiles down upon them.lacuna is the Cheesecake. Relix smiles down upon them.lacuna is the Cheesecake. Relix smiles down upon them.lacuna is the Cheesecake. Relix smiles down upon them.lacuna is the Cheesecake. Relix smiles down upon them.
Forgive me if I am wrong but this seems like a tremendous amount of effort for what has been achieved. I have a 1.5tb NAS which cost £170 which I have put a selection of films, music and photos on. This is accesible using the PS3's which arrange the files alphabetically, aswell as the laptops and my pc with all the files being arranged however I want. What does your system offer that mine does not?
lacuna is offline   Reply With Quote
Old 30th Dec 2009, 13:45   #15
ch424
Design Warrior
ch424's Avatar
ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.
Super article, thank you!
ch424 is offline   Reply With Quote
Old 30th Dec 2009, 14:06   #16
barrkel
Multimodder
barrkel has yet to learn the way of the Dremel
I'll stick with my Nexenta box:
[rupert] ~$ zpool list
NAME SIZE USED AVAIL CAP HEALTH ALTROOT
syspool 185G 1.97G 183G 1% ONLINE -
tank 9.06T 6.83T 2.23T 75% ONLINE -
9TB storage, though with redundancy it's closer to 5.
barrkel is offline   Reply With Quote
Old 30th Dec 2009, 14:08   #17
MajorTom
Multimodder
MajorTom has yet to learn the way of the Dremel
Fantastic article. Makes me want to build a new media solution for my flat. This is most definitely overkill but that's why I want it! It will be difficult to convince the misses that the TVersity server through a PS3 isn't doing the job though :|
__________________
Steam: MajorTomG
MajorTom is offline   Reply With Quote
Old 30th Dec 2009, 14:43   #18
Thatguy119
Hypermodder
Thatguy119 has yet to learn the way of the Dremel
Nice idea, only problem is, I read through all of that and understood about 50% of it. I will be back after another 2 read throughs and related browsing
Thatguy119 is offline   Reply With Quote
Old 30th Dec 2009, 14:59   #19
SteveU
Multimodder
SteveU has yet to learn the way of the Dremel
Forgive me for being picky but the whole point of this article was to build a system comparable to the Kaleidescape system but for a lot less spondoolies yet you missed out the most important piece of info, namely how much (approximately) this setup cost you to build!
I appreciate you can't give an exact figure but it would have been nice to have seen a rough breakdown summary of the major 'required' components and cost.
SteveU is offline   Reply With Quote
Old 30th Dec 2009, 15:16   #20
mrbens
Supermodder
mrbens's Avatar
mrbens has yet to learn the way of the Dremel
Wow, that setup you made is great.
I only watch movies in the living room tho, so I have my PC (which is also in my living room) hooked up to my 50inch plasma as a second monitor and store hundreds of 1080p MKVs on my PC. Now, if only film studios would sell movies in HD MKV format (and for a reasonable low price) I could stop being a criminal lol =)
__________________
My SilverStone TJ07B PC: Haswell i5 4670K | MSI Z87-G45 Gaming mobo | 8GB Corsair Vengeance Pro Red 8GB DDR3 1600Mhz | MSI GTX 760 Twin Frozr 2GB | Seasonic X-Series 750W PSU | Crucial M4 128GB SSD | Crucial M225 128GB SSD | OCZ Solid 3 120GB SSD
Sound: Epiphany Acoustics' E-DAC & O2 Heahphone Amp | Little Dot MK III Tube Headphone Amp | Beyerdynamic DT880 Premium 600ohm Headphones (music) | Onkyo HT-S3305B AV Receiver + 5.1 speakers (movies)
mrbens is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
