Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 5th Jan 2010, 12:36   #1
Cutter McJ1b
Home-cut jibs at discount Prices
Cutter McJ1b's Avatar
Cutter McJ1b has yet to learn the way of the Dremel
I Noobtube
http://www.bit-tech.net/blog/2010/01/05/i-noobtuber/
Cutter McJ1b is offline   Reply With Quote
Old 5th Jan 2010, 12:57   #2
Gunsmith
Maximum Win
Gunsmith's Avatar
Gunsmith is definitely a rep cheat.Gunsmith is definitely a rep cheat.Gunsmith is definitely a rep cheat.Gunsmith is definitely a rep cheat.Gunsmith is definitely a rep cheat.Gunsmith is definitely a rep cheat.Gunsmith is definitely a rep cheat.Gunsmith is definitely a rep cheat.Gunsmith is definitely a rep cheat.Gunsmith is definitely a rep cheat.Gunsmith is definitely a rep cheat.
when your games target audience is chavs and children then you will get chavs and children whining online.
__________________
The King of Crysis
// This is currently not used anywhere (David: and I don't see what this would be used for. Our hero is not Jesus).
m_stats.isWalkingOnWater = false;
Gunsmith is offline   Reply With Quote
Old 5th Jan 2010, 13:07   #3
smc8788
...at least I have chicken
smc8788's Avatar
smc8788 is definitely a rep cheat.smc8788 is definitely a rep cheat.smc8788 is definitely a rep cheat.smc8788 is definitely a rep cheat.smc8788 is definitely a rep cheat.smc8788 is definitely a rep cheat.smc8788 is definitely a rep cheat.smc8788 is definitely a rep cheat.smc8788 is definitely a rep cheat.smc8788 is definitely a rep cheat.smc8788 is definitely a rep cheat.
The 'tube + Danger Close = awesome for clearing out Headquarters. That's all I use it for, but I have a whole class dedicated to it because it gets the job done and helps win the game.
The only thing that annoys me is people exploiting the ridiculously easy knife mechanic, and sometimes the ridiculously overpowered akimbo shotguns (though I do use the akimbo G18's and they're not much better).
__________________
My Rig: [FD Define Mini] - [Asus P8Z77-M Pro] - [i5 2500k @ 4.4GHz/1.34V] - [Corsair H60] - [8GB Corsair Vengeance LP] - [Asus GTX TITAN] - [512GB Vertex 4, 1TB F3, 2TB F4 x 2] - [Corsair HX650]
Other stuff I own: [BenQ XL2411T/Dell 2407WFP] - [CM Novatouch TKL] - [Zowie FK1] - [Fostex TH900] - [Woo Audio WA7 Fireflies] - [Sony Bravia KDL65W855] - [Onkyo TX-NR515] - [B&W 685]
[Steam] - [Battlelog]
smc8788 is offline   Reply With Quote
Old 5th Jan 2010, 13:10   #4
Stuey
You will be defenestrated!
Stuey's Avatar
Stuey has yet to learn the way of the DremelStuey has yet to learn the way of the DremelStuey has yet to learn the way of the DremelStuey has yet to learn the way of the DremelStuey has yet to learn the way of the DremelStuey has yet to learn the way of the Dremel
The issue is the same in the 1st game. Some people overuse it greatly, but the worst part is that it requires no skill. Firing randomly towards a spawn point can usually score one or more kills.
Don't even get me started about those that camp up and start randomly shooting through walls towards spawn points - they piss me off even more than noobtubers do. It's cheap and unsportsmanlike, and again demonstrates absolutely no skill.
There is a way to use the grenade launcher tactfully and skillfully, but too many don't - all they do is tube away.
__________________
ToolGuyd - Stuey's Tool Blog
Stuey is offline   Reply With Quote
Old 5th Jan 2010, 13:12   #5
Jamie
ex-Bit-Tech code junkie
Jamie's Avatar
Jamie is definitely a rep cheat.Jamie is definitely a rep cheat.Jamie is definitely a rep cheat.Jamie is definitely a rep cheat.Jamie is definitely a rep cheat.Jamie is definitely a rep cheat.Jamie is definitely a rep cheat.Jamie is definitely a rep cheat.Jamie is definitely a rep cheat.Jamie is definitely a rep cheat.Jamie is definitely a rep cheat.
I hate it when people complain too.
There is nothing like as satisfying as getting a quad kill in headquaters with the grenade launcher!
What bugs me is when under 18s are on servers.
__________________
Jamie is offline   Reply With Quote
Old 5th Jan 2010, 13:15   #6
Unknownsock
Supermodder
Unknownsock has yet to learn the way of the Dremel
Oo Why chavs that word is so over used nowadays, im sure 95% of people don't even know the meaning other than a burberry jumper...
I completely agree here though, although people running around with dual machien pistols and those dam dual shotties can get annoying.
Unknownsock is offline   Reply With Quote
Old 5th Jan 2010, 13:28   #7
GFC
Multimodder
GFC has yet to learn the way of the Dremel
Some people just have this one (or maybe more) things that they just don't seem to agree with. I.e. I think shotguns, knifing, even the crate package glitch are valid strategies, but I just can't sem to understand 'why the hell did developers include the noobtube'. It's that simple, I think it has too much of an explosion range. I don't mind the 1hit kills, explosion, but the fact that you can shoot roughly to my direction and score a kill just makes me really pissed off.
GFC is offline   Reply With Quote
Old 5th Jan 2010, 13:37   #8
Skiddywinks
Hypermodder
Skiddywinks has yet to learn the way of the DremelSkiddywinks has yet to learn the way of the Dremel
It's not so much that the launcher is overpowered or anything, it's how it's used that bugs me. If someone is running around with their assault rifle, killing each individual person, sees a few run in to the headquarters or finds some people camping a room, the launcher is the perfect tool, and that is how it should be used.
It's the people that run around with it equipped, shooting it at the first person they see, almost definitely getting the kill, and then doing that again and again until they run out of ammo. It's almost a sure kill per shot, and it is just a cheap tactic to get as many kills as you can with the least amount of skill or effort. They then run out of grenades, suck terribly, die, and then start the process again.
It's the use of it that bugs me, not the actual mechanic.
Skiddywinks is offline   Reply With Quote
Old 5th Jan 2010, 13:41   #9
Spiny
Multimodder
Spiny has yet to learn the way of the Dremel
"It's the people that run around with it equipped, shooting it at the first person they see, almost definitely getting the kill, and then doing that again and again until they run out of ammo. It's almost a sure kill per shot, and it is just a cheap tactic to get as many kills as you can with the least amount of skill or effort. They then run out of grenades, suck terribly, die, and then start the process again."
You'll probably find that's people grinding the XP reward for the grenade launcher kills unlock (10 iirc)
Spiny is offline   Reply With Quote
Old 5th Jan 2010, 13:50   #10
Skiddywinks
Hypermodder
Well, since it was so abundantly used in CoD4 and even with a lot of people I play LAN with, I think that is a bit of a poor excuse. I have no doubt some people will be grinding the challenge, but I really don't think that will be a significant amount.
Old 5th Jan 2010, 13:51   #11
Joeymac
Multimodder
Joeymac has yet to learn the way of the Dremel
Where does the thumper come into this? I use that as my secondary weapon, seems just the same as the attachment. I've only recently started with that and it's quite fun. Both the attachment and the thumper take time to switch and reload (more so with the thumper) so if you run around with it you leave yourself open for longer, that a trade off risk. Personally I don't play HQ so haven't had the joy of taking out a load of people at once, but I have used the thumper quite successfully as a close quarters weapon, it's very satisfying to smack some one in the head with a grenade when they come around the corner. Plus that requires a little skill, it's one shot also so again there's a trade off. I've also used it by deliberately aiming it up into the air and hitting a person sniping in a window across the map on Rundown purely because I had run out of bullets to shoot him with.. is that wrong?
Joeymac is offline   Reply With Quote
Old 5th Jan 2010, 13:59   #12
pbryanw
Multimodder
pbryanw has yet to learn the way of the Dremel
Takes me back to the ridiculously overpowered, BFG (Big F**king Gun) in Quake II.
You used to get the same sort of people complaining if you ever unleashed this gun. And, with very little skill - just point and shoot - you could clear a room of 4-5 other players quite easily. And the temptation to do so was often too great, despite the abuse you'd receive.
It's my first memory of a massively overpowered weapon in an on-line game, and sprung to mind reading this article.
pbryanw is offline   Reply With Quote
Old 5th Jan 2010, 14:11   #13
salesman
Multimodder
salesman has yet to learn the way of the Dremelsalesman has yet to learn the way of the Dremel
My friends still play Halo for the xbox, they are ridiculous. If you were to play someone with that has comparable skills in MW2, glitches and all, you would be PISSED! Yet, my friends play it all the time, and have a good time. They deliberately take advantage of the game mechanics, it's how they play. It is skill that they possess because they will beat you 9 times out of 10. You guys have describe some cheap tactics here in the comments but I say it is part of the game and it should stay that way. If you can't beat them join them, and if you don't want to then I guess you do need to vent you frustration, but remember there will always be noobtubers. If you are good at the game I don't think you would get pissed I think you would enact revenge on the ones who frustrate you, it's what I do and I have a fun time playing the game.
__________________
E8400 3.0GHz | ASRock P45X3 Deluxe | EVGA 570 GTX | 8 GB GSkill memory | Crucial M4 64GB Boot Drive | 3x Samsung F3 1TB Raid 0 | 2x Samsung F4EG 1.5TB Raid 0 | Corsair AX750 PSU | Noctua NH-U12P | Antec P180 | M-Audio Audiophile 192 | Marantz PM5004 | Cambridge Soundworks Speakers | Duckey Shine | Dell U2410 |
salesman is offline   Reply With Quote
Old 5th Jan 2010, 14:45   #14
sear
Guest
Posts: n/a
I'd say they need to worry about the aimbots, wallhacks and ****ing hideously overpowered knife (which is only that way due to the lag caused by no dedicated servers) before they go trying to nerf the grenade launcher. Oh, yeah, can't forget the underpowered sniper rifles, totally ineffectual SMGs, and pinpoint-accuracy-from-across-the-entire-level assault rifles. The game is unbalanced as hell.
Old 5th Jan 2010, 14:46   #15
Dreaming
Supermodder
Dreaming's Avatar
Dreaming has yet to learn the way of the Dremel
tbh the reason 'noobtubing' is annoying generally speaking is that I've found it takes less skill, i.e. almost anyone can pick it up and score kills because its a one shot kill. So you might be playing a good game, avoiding fire, building up your kill streak, then someone fires in your general direction and gets a kill because of his nade. He probs died a second later :P
But this is the game and its better in MW2 because the games are smaller, so its harder to spam it as much. Whereas (and I've used it in the past) in CoD4 you can just point it at places where you expect people to be and get 1-2 kills every time. Easy peasy.
__________________
Dreaming
C2D E6300 @ 2.8 | | Abit IP35 Pro | | 4GB Corsair XMS2 800 | | BFG 9800GT OC 1GB | | Antec NeoHE 550 | | Lian Li PC A05B (with top blowhole mod) | | LG 32LH4000 + Samsung 226BW 22"
Dreaming is offline   Reply With Quote
Old 5th Jan 2010, 15:09   #16
capnPedro
Hacker. Maker. Engineer.
capnPedro's Avatar
capnPedro is a hoopy frood who really knows where their towel is.capnPedro is a hoopy frood who really knows where their towel is.capnPedro is a hoopy frood who really knows where their towel is.capnPedro is a hoopy frood who really knows where their towel is.capnPedro is a hoopy frood who really knows where their towel is.capnPedro is a hoopy frood who really knows where their towel is.capnPedro is a hoopy frood who really knows where their towel is.capnPedro is a hoopy frood who really knows where their towel is.capnPedro is a hoopy frood who really knows where their towel is.capnPedro is a hoopy frood who really knows where their towel is.capnPedro is a hoopy frood who really knows where their towel is.
To people who whine I say this; "If it's so stupid, why is it in the game? It's not an exploit - it's playing the game as it was designed to be played." Then I kill them again.
__________________
There is no better previewing system than the 'Submit Reply' button.
I <3 Aquatuning & Enermax long time!
capnPedro is offline   Reply With Quote
Old 5th Jan 2010, 15:20   #17
Veles
DUR HUR
Veles's Avatar
Veles has yet to learn the way of the DremelVeles has yet to learn the way of the DremelVeles has yet to learn the way of the DremelVeles has yet to learn the way of the DremelVeles has yet to learn the way of the DremelVeles has yet to learn the way of the DremelVeles has yet to learn the way of the Dremel
What you are doing is not noob tubing, noob tubing is when all you do is run around with the grenade launcher and that is it. When they run out of their two shots they either will die soon anyway or they'll scavenge perk for more.
The grenade launcher is also very effective at close ranges, no detenation direct impacts kill instantly.
It's not the cheapest or most annoying thing to do in the game, but it's still annoying when people run around with grenade launchers and nothing else.
__________________
Veles on: Xbox Live (My Halo stats), Steam Community, Twitter
Originally Posted by Fod View Post
spam gangsters might as well tap into all those machines for their zombie networks.
Veles is offline   Reply With Quote
Old 5th Jan 2010, 15:25   #18
dicobalt
Multimodder
dicobalt's Avatar
dicobalt has yet to learn the way of the Dremel
I don't play MW2 but I do play COD4. When too many people use the tube so do I. Or maybe I will switch to RPD to wall them into submission and then hear them complain right back lol This is a practice that will get you banned on most servers. Yet it is in the game and not considered an exploit.
The main problem with the nade launcher is that people will shoot once and get multiple kills, that really does not take any skill at all. It's a weapon that takes no skill to use, hence the noob aspect of it. It's hard to respect the skill of someone who uses such a weapon.
I have always thought that airstrike and helicopter kills should not count towards more airstrikes and helicopters. To get an airstrike or heli you should have to get the kills with bullets. Sometimes I equip the nade launcher to strictly shoot at heli's. I never ever use the nade launcher against non nade heavy teams.
dicobalt is offline   Reply With Quote
Old 5th Jan 2010, 15:30   #19
Skiddywinks
Hypermodder
No one is saying it's an exploit. We're saying it's a cheap and skill-less way to get kills (when used this way at least).
Old 5th Jan 2010, 15:48   #20
[WP@]WOLVERINE
Supermodder
[WP@]WOLVERINE's Avatar
[WP@]WOLVERINE has yet to learn the way of the Dremel[WP@]WOLVERINE has yet to learn the way of the Dremel
i have no problem with the Tube because i use an UZI/FMJ and a USP/Tactical knife along with Marathon PRO, Ninja Pro and lightweight pro so by the time their grenade gets to where i was im already stabbing them in the face
__________________
Intel i7 980X EE | 6gb HyperX 2ghz DDR3 | Asus P6T Deluxe OC Palm ed | Asus 7950 DCII | Corsair HX1000 | SB X-Fi Fatality | 5.1tb storage+2xX25M 80gb SSD | Lian Li pc201 | 3xBenQ G2420HDB@Eyefinity | Ms Natural 4000 | Corsair M60 | Logitech Z-5450.
[WP@]WOLVERINE is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
