Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 6th Jan 2010, 13:24   #1
Cutter McJ1b
Home-cut jibs at discount Prices
Cutter McJ1b's Avatar
Cutter McJ1b has yet to learn the way of the Dremel
Should I get a PSP Go?
http://www.bit-tech.net/blog/2010/01...-get-a-psp-go/
Cutter McJ1b is offline   Reply With Quote
Old 6th Jan 2010, 13:32   #2
PureSilver
E-tailer Tailor
PureSilver's Avatar
PureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpit
Originally Posted by Cutter McJ1b
I thought it might also be interesting to see if anyone else suffered from this affliction of wanting to buy a portable console and then never using it?
Yeah, I sold my GBA - I bought it full of ideas about wasted time on buses I could play it, and in fact used it about twice. Kept the PSP, though - it does more than play games. God the Go's ugly, though - what's wrong with a normal PSP?
__________________
Intel Core i7 920 @ 3Ghz, Noctua NH-U12P SE, Asus P6T Deluxe V1, Corsair 12GB (6x2GB) 1600Mhz C8 @ XMP,
EVGA GTX-680, Corsair AX760, 2x Samsung SpinPoint F3 1TB, Lian-Li V1020R with 3x Noctua NF-P12 & 3x NF-P14FLX
2.4Ghz 13" unibody MacBook, 4GB RAM & 128GB Samsung SSD
PureSilver is offline   Reply With Quote
Old 6th Jan 2010, 13:34   #3
harveypooka
Fond of rumpots and crackpots
harveypooka has yet to learn the way of the Dremel
They cost a fortune!
harveypooka is offline   Reply With Quote
Old 6th Jan 2010, 13:34   #4
sear
Guest
Posts: n/a
Don't buy the PSP Go. If you must get a PSP, get the regular PSP-3000. There is no reason to get the PSP Go whatsoever - it has a smaller screen, it has a less comfortable design, and no disc drive means any games that you previously had are totally useless. On top of that, the base cost is more expensive, and the regular PSP can do all the same PSN stuff the PSP Go can, including downloading retail games. You also have to buy totally new peripherals for it, since Sony decided to make sure nothing old would be compatible with it (apparently a way of consoling retailers, who didn't want to stock the device due to all the games being digital).
Old 6th Jan 2010, 13:45   #5
CardJoe
Freelance Journalist
CardJoe's Avatar
CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.
No.
__________________
I was Bit-tech's Games Editor. Now I'm freelance. Find me at:
www.joemartinwords.com
@joethreepwood on Twitter
CardJoe is offline   Reply With Quote
Old 6th Jan 2010, 13:54   #6
proxess
Ultramodder
proxess is definitely a rep cheat.proxess is definitely a rep cheat.proxess is definitely a rep cheat.proxess is definitely a rep cheat.proxess is definitely a rep cheat.proxess is definitely a rep cheat.proxess is definitely a rep cheat.proxess is definitely a rep cheat.proxess is definitely a rep cheat.proxess is definitely a rep cheat.proxess is definitely a rep cheat.
No.
__________________
Clevo P150SM: i7 4930MX @4.2GHz; 4x 8GB Kingston HyperX Impact 1600MHz; Nvidia 980M 8GB +220MHz Core/+350MHz Memory; Samsung 840 EVO mSATA 250GB; Ubuntu 16.04 x64 and Windows 10 Pro.
Linux #429448
proxess is offline   Reply With Quote
Old 6th Jan 2010, 14:03   #7
dolphin-promotions
Modder
dolphin-promotions has yet to learn the way of the Dremel
Bought a DS Lite for myself when they first came out. Played it for about 5 hours. It has kept my girlfriend entertained ever since, so i can't complain really.
dolphin-promotions is offline   Reply With Quote
Old 6th Jan 2010, 14:04   #8
Omnituens
Hypermodder
Omnituens's Avatar
Omnituens is a hoopy frood who really knows where their towel is.Omnituens is a hoopy frood who really knows where their towel is.Omnituens is a hoopy frood who really knows where their towel is.Omnituens is a hoopy frood who really knows where their towel is.Omnituens is a hoopy frood who really knows where their towel is.Omnituens is a hoopy frood who really knows where their towel is.Omnituens is a hoopy frood who really knows where their towel is.Omnituens is a hoopy frood who really knows where their towel is.Omnituens is a hoopy frood who really knows where their towel is.Omnituens is a hoopy frood who really knows where their towel is.Omnituens is a hoopy frood who really knows where their towel is.
No. Just get FFVII on a normal PSP. It's not PSPGo exclusive, it can be downloaded and played fine on the PSP 1000/2000/3000 models. And they are cheaper, and more comfortable to use (for me at least).
__________________
Current Rig: i7 D0 4.2GHz, X58 Sabertooth, 12GB RAM, GTX 680, Xonar D2X
Omnituens is offline   Reply With Quote
Old 6th Jan 2010, 14:13   #9
Spiny
Multimodder
Spiny has yet to learn the way of the Dremel
No.
Spiny is offline   Reply With Quote
Old 6th Jan 2010, 14:16   #10
Aracos
Ultramodder
Aracos's Avatar
Aracos can run CrysisAracos can run CrysisAracos can run CrysisAracos can run CrysisAracos can run CrysisAracos can run CrysisAracos can run CrysisAracos can run CrysisAracos can run CrysisAracos can run CrysisAracos can run Crysis
Everyone says no, you know the answer is no, but I have a feeling you'll get one anyway? Is this more like one of those convince me not to get one posts that's hidden as a "should I get one?".
__________________
Originally Posted by Ubisoft CEO
Our clear goal today is to come more regularly with our top brands
Ragnarok: i5 750 @ 3200MHz | Titan Fenrir | MSI P55-GD65 | 8GiB Vengence 1600MHz CAS 9 | 1GiB 6950 DirectCU II | 60GB Crucial M4 | Samsung F3 500GB | Samsung F3 1TB | Seasonic X-750 | X-Fi XtremeGamer | HAF932 | Win 7 Pro | openSUSE
Aracos is offline   Reply With Quote
Old 6th Jan 2010, 14:27   #11
Skiddywinks
Hypermodder
Skiddywinks has yet to learn the way of the DremelSkiddywinks has yet to learn the way of the Dremel
No. There are plenty of other ways of playing FF7 anyway, and at the end of the day, if you really want a portable, a PSP3000 is a much better way to go about it. For the love of God, do not support the PSP Go!
Skiddywinks is offline   Reply With Quote
Old 6th Jan 2010, 14:33   #12
Jamie
ex-Bit-Tech code junkie
Jamie's Avatar
Jamie is definitely a rep cheat.Jamie is definitely a rep cheat.Jamie is definitely a rep cheat.Jamie is definitely a rep cheat.Jamie is definitely a rep cheat.Jamie is definitely a rep cheat.Jamie is definitely a rep cheat.Jamie is definitely a rep cheat.Jamie is definitely a rep cheat.Jamie is definitely a rep cheat.Jamie is definitely a rep cheat.
No
__________________
Jamie is offline   Reply With Quote
Old 6th Jan 2010, 14:33   #13
flibblesan
Destroyer
flibblesan is almost as Godly as yodasarmpitflibblesan is almost as Godly as yodasarmpitflibblesan is almost as Godly as yodasarmpitflibblesan is almost as Godly as yodasarmpitflibblesan is almost as Godly as yodasarmpitflibblesan is almost as Godly as yodasarmpitflibblesan is almost as Godly as yodasarmpitflibblesan is almost as Godly as yodasarmpitflibblesan is almost as Godly as yodasarmpitflibblesan is almost as Godly as yodasarmpitflibblesan is almost as Godly as yodasarmpit
No
flibblesan is offline   Reply With Quote
Old 6th Jan 2010, 15:18   #14
Sifter3000
I used to be somebody
Sifter3000's Avatar
Sifter3000 has yet to learn the way of the DremelSifter3000 has yet to learn the way of the DremelSifter3000 has yet to learn the way of the DremelSifter3000 has yet to learn the way of the DremelSifter3000 has yet to learn the way of the DremelSifter3000 has yet to learn the way of the DremelSifter3000 has yet to learn the way of the Dremel
Y....
I mean no.
__________________
The Rt Hon Alex Watson.
Dennis Publishing Emerging Platforms, bit and CPC alumni.
My weblog is The Wired Jester.
Photos on Flickr.
Sifter3000 is offline   Reply With Quote
Old 6th Jan 2010, 15:39   #15
andrew8200m
Mod Master
andrew8200m's Avatar
andrew8200m is a Super Spamming Saiyanandrew8200m is a Super Spamming Saiyanandrew8200m is a Super Spamming Saiyanandrew8200m is a Super Spamming Saiyanandrew8200m is a Super Spamming Saiyanandrew8200m is a Super Spamming Saiyanandrew8200m is a Super Spamming Saiyanandrew8200m is a Super Spamming Saiyanandrew8200m is a Super Spamming Saiyanandrew8200m is a Super Spamming Saiyanandrew8200m is a Super Spamming Saiyan
No. Hunt for the original PSP and if possible the japanese version. The original is better mate and more robust. The japanese version of th original also has a much better screen
Andy
andrew8200m is offline   Reply With Quote
Old 6th Jan 2010, 15:52   #16
eek
CAMRA ***.
eek - it's over 9000!!!!!!!!1!1!1!!!eek - it's over 9000!!!!!!!!1!1!1!!!eek - it's over 9000!!!!!!!!1!1!1!!!eek - it's over 9000!!!!!!!!1!1!1!!!eek - it's over 9000!!!!!!!!1!1!1!!!eek - it's over 9000!!!!!!!!1!1!1!!!eek - it's over 9000!!!!!!!!1!1!1!!!eek - it's over 9000!!!!!!!!1!1!1!!!eek - it's over 9000!!!!!!!!1!1!1!!!eek - it's over 9000!!!!!!!!1!1!1!!!eek - it's over 9000!!!!!!!!1!1!1!!!
Yes.
This post is sponsored by j2o - it's metter to bix things up!
eek is offline   Reply With Quote
Old 6th Jan 2010, 15:55   #17
Narishma
Multimodder
Narishma has yet to learn the way of the Dremel
As others have said, get the normal PSP-3000 instead. It does everything the PSP Go does and more and cheaper.
Narishma is offline   Reply With Quote
Old 6th Jan 2010, 16:48   #18
nukeman8
Hypermodder
nukeman8's Avatar
nukeman8 has yet to learn the way of the Dremelnukeman8 has yet to learn the way of the Dremelnukeman8 has yet to learn the way of the Dremelnukeman8 has yet to learn the way of the Dremel
just to be different, buy a PS1 with the screen attachment and a battery pack for it.
Anything's better than the psp go :P
__________________
Originally Posted by Nexxo
It is typical tin-foil-hat rambling caused by people's usual propensity for reasoning errors and seeing shapes in random clouds, self-importance induced paranoia and a bad understanding of science.
nukeman8 is offline   Reply With Quote
Old 6th Jan 2010, 17:25   #19
SteveU
Multimodder
SteveU has yet to learn the way of the Dremel
Just save you money and imagine playing FF7 in your head.
Remember the golden rule about playing older games, they rarely live up to the memory of playing them the first time round!
SteveU is offline   Reply With Quote
Old 6th Jan 2010, 18:19   #20
wuyanxu
still wants Homeworld 3
wuyanxu's Avatar
wuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyan
no
how about iPhone 3GS: one device to replace them all. jailbreak it and put PSX on there for your favourite games.
__________________
i7 2700k \ 16GB \ GTX 970 \ D2x \ Z68x-UD5 \ m4 128GB +2TB \ S12G-550 \ FT02-RW \ G15+G5+G51 \ U2711
X100 \ X-E2 \ 10-24 \ 55-200 \ 18/2 \ 60/2.4 \ Yn560 \ X1.1a \ Hadley Pro -- Photostreamr
wuyanxu is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
