Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 8th Jan 2010, 10:14   #1
Cutter McJ1b
Home-cut jibs at discount Prices
Cutter McJ1b's Avatar
Cutter McJ1b has yet to learn the way of the Dremel
How to enable Windows 7 God Mode
http://www.bit-tech.net/blog/2010/01...ws-7-god-mode/
Cutter McJ1b is offline   Reply With Quote
Old 8th Jan 2010, 10:20   #2
wuyanxu
still wants Homeworld 3
wuyanxu's Avatar
wuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyan
lol, saw that on OCn, i think it's just a hidden folder in windows search index for start menu quick searches.
therefore i don't see the point in creating such a folder, much easier to just do: Win key --> type the stuff you want.
__________________
i7 2700k \ 16GB \ GTX 970 \ D2x \ Z68x-UD5 \ m4 128GB +2TB \ S12G-550 \ FT02-RW \ G15+G5+G51 \ U2711
X100 \ X-E2 \ 10-24 \ 55-200 \ 18/2 \ 60/2.4 \ Yn560 \ X1.1a \ Hadley Pro -- Photostreamr
wuyanxu is offline   Reply With Quote
Old 8th Jan 2010, 10:30   #3
oMonarca
Elitist Brick
oMonarca's Avatar
oMonarca has yet to learn the way of the Dremel
Unless you don't know what stuff you want, then knowing all the options available might be helpful.
oMonarca is offline   Reply With Quote
Old 8th Jan 2010, 10:59   #4
Krikkit
Super Moderator
Moderator
Krikkit's Avatar
Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.
Or if you're just setting up someone's computer for the first time - instead of having to monkey up and down the masses of control panel categories.
__________________
The Good, The Bad, The Ugly, The Zlad!, The Wut?!, The Kempness
Krikkit is offline   Reply With Quote
Old 8th Jan 2010, 11:27   #5
cybergenics
Registered User
cybergenics has yet to learn the way of the Dremelcybergenics has yet to learn the way of the Dremelcybergenics has yet to learn the way of the Dremel
In case anyone is stupid enought to try it on Vista 64, don't, as when I staggered in drunk the other night, saw this on CNet and thought I would try it, whilst not reading the bit about it crashing Vista 64.
What basically happened (or happened) is as soon as you rename the folder, all the icons on your desktop start flashing and basically the computer becomes inoperable. You can still shut it down though. It also exhibits the same behaviour in safe mode, and you can't access system restore through startup (recovery) to fix it !
But it works fine on my Win 7 64bit lappy !
cybergenics is offline   Reply With Quote
Old 8th Jan 2010, 12:04   #6
Omnituens
Hypermodder
Omnituens's Avatar
Omnituens is a hoopy frood who really knows where their towel is.Omnituens is a hoopy frood who really knows where their towel is.Omnituens is a hoopy frood who really knows where their towel is.Omnituens is a hoopy frood who really knows where their towel is.Omnituens is a hoopy frood who really knows where their towel is.Omnituens is a hoopy frood who really knows where their towel is.Omnituens is a hoopy frood who really knows where their towel is.Omnituens is a hoopy frood who really knows where their towel is.Omnituens is a hoopy frood who really knows where their towel is.Omnituens is a hoopy frood who really knows where their towel is.Omnituens is a hoopy frood who really knows where their towel is.
So giving this a try when I get home.
__________________
Current Rig: i7 D0 4.2GHz, X58 Sabertooth, 12GB RAM, GTX 680, Xonar D2X
Omnituens is offline   Reply With Quote
Old 8th Jan 2010, 13:35   #7
Er-El
Supermodder
Er-El's Avatar
Er-El has yet to learn the way of the DremelEr-El has yet to learn the way of the DremelEr-El has yet to learn the way of the DremelEr-El has yet to learn the way of the DremelEr-El has yet to learn the way of the DremelEr-El has yet to learn the way of the DremelEr-El has yet to learn the way of the Dremel
Still on the first step to grow a big white beard.
Er-El is offline   Reply With Quote
Old 8th Jan 2010, 14:06   #8
mjm25
Supermodder
mjm25's Avatar
mjm25 has yet to learn the way of the Dremelmjm25 has yet to learn the way of the Dremelmjm25 has yet to learn the way of the Dremelmjm25 has yet to learn the way of the Dremelmjm25 has yet to learn the way of the Dremel
i've got a mess of needing-to-be-trimmed beardage... therefore i declare myself Godly, WOOF! i shall give this a go.
P.S. I'm loving your blog section, especially when you guys revealed Ninite to me a few weeks back <3
__________________
EP45-UD3R, QX6800, 8GB Ballistix 6400 4-4-4-12, Radeon 6990, All in an Arc!
mjm25 is offline   Reply With Quote
Old 8th Jan 2010, 18:51   #9
Blackie Chan
Multimodder
Blackie Chan has yet to learn the way of the Dremel
OMG this is so cool. Thank you.
Blackie Chan is offline   Reply With Quote
Old 8th Jan 2010, 19:18   #10
thehippoz
Banned
thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!
yeah folders in vista can use junction points.. you can name it whatever you want, doesn't have to be godmode- can be plonker.{ED7BA470-8E54-465E-825C-99712043E01C}
http://msdn.microsoft.com/en-us/libr...8VS.85%29.aspx
thehippoz is offline   Reply With Quote
Old 8th Jan 2010, 19:19   #11
thehippoz
Banned
lol just rd it in cmd prompt
Old 8th Jan 2010, 22:26   #12
leslie
Just me!
leslie's Avatar
leslie has yet to learn the way of the Dremelleslie has yet to learn the way of the Dremel
Godmode?
It's just a different way of viewing control panel (with fewer options).
leslie is offline   Reply With Quote
Old 8th Jan 2010, 22:59   #13
Omnituens
Hypermodder
Omnituens's Avatar
yeah, it doesn't actually give you more options. Just different way of accessing them.
__________________
Old 9th Jan 2010, 19:30   #14
Blackie Chan
Multimodder
The different way of accessing them is by not going through context menus hidden throughout the OS. I think this should be a standard!
Old 11th Jan 2010, 04:49   #15
hurgh
What's a Dremel?
hurgh has yet to learn the way of the Dremel
Just a note, there is also a few more of these:
Code:
Test1.{00C6D95F-329C-409a-81D7-C46C66EA7F33}
Test2.{0142e4d0-fb7a-11dc-ba4a-000ffe7ab428}
Test3.{025A5937-A6BE-4686-A844-36FE4BEC8B6D}
Test4.{05d7b0f4-2121-4eff-bf6b-ed3f69b894d9}
Test5.{1206F5F1-0569-412C-8FEC-3204630DFB70}
Test6.{15eae92e-f17a-4431-9f28-805e482dafd4}
Test7.{17cd9488-1228-4b2f-88ce-4298e93e0966}
Test8.{1D2680C9-0E2A-469d-B787-065558BC7D43}
Test9.{1FA9085F-25A2-489B-85D4-86326EEDCD87}
Test10.{208D2C60-3AEA-1069-A2D7-08002B30309D}
Test11.{20D04FE0-3AEA-1069-A2D8-08002B30309D}
Test12.{2227A280-3AEA-1069-A2DE-08002B30309D}
Test13.{241D7C96-F8BF-4F85-B01F-E2B043341A4B}
Test14.{4026492F-2F69-46B8-B9BF-5654FC07E423}
Test15.{78F3955E-3B90-4184-BD14-5397C15F1EFC}
GodMode.{ED7BA470-8E54-465E-825C-99712043E01C}
The folder name can be changed by changing the text before the "."
-Hurgh-
hurgh is offline   Reply With Quote
Old 11th Jan 2010, 07:38   #16
Pookeyhead
It's big, and it's clever.
Pookeyhead's Avatar
Pookeyhead is definitely a rep cheat.Pookeyhead is definitely a rep cheat.Pookeyhead is definitely a rep cheat.Pookeyhead is definitely a rep cheat.Pookeyhead is definitely a rep cheat.Pookeyhead is definitely a rep cheat.Pookeyhead is definitely a rep cheat.Pookeyhead is definitely a rep cheat.Pookeyhead is definitely a rep cheat.Pookeyhead is definitely a rep cheat.Pookeyhead is definitely a rep cheat.
Working fine here in 64bit
__________________
MAIN RIG |Intel i7 3960X @ 4.7GHz ¦¦ H105 ¦¦ Asus Rampage IV Extreme ¦¦ 16Gb Mushkin DDR3 2133 ¦¦ 512GB Samsung 830 SSD ¦¦ 4TB of HDD Storage ¦¦ EVGA GTX980 Super-Clocked¦¦ Corsair 650D ¦¦ Eizo ColorEdge CG303W & Dell 2007FP ¦¦
EARTH| Celeron E3200 ¦¦ Gigabyte G31M-ES2L ¦¦ LSI SAS9260-8i ¦¦ 3TB RAID5 ¦¦ Headless - VNC administered
MOON | Thecus N3200pro 3TB RAID5
Pookeyhead is offline   Reply With Quote
Old 31st Jan 2010, 18:43   #17
cdb
No comment
cdb has yet to learn the way of the Dremelcdb has yet to learn the way of the Dremelcdb has yet to learn the way of the Dremelcdb has yet to learn the way of the Dremelcdb has yet to learn the way of the Dremel
Can't use that folder name in my win7 64bit. It doesn't like the symbols.
cdb is offline   Reply With Quote
Old 31st Jan 2010, 18:52   #18
knuck
Hate your face
knuck's Avatar
knuck - may the hammer of Bindi be bestowed on youknuck - may the hammer of Bindi be bestowed on youknuck - may the hammer of Bindi be bestowed on youknuck - may the hammer of Bindi be bestowed on youknuck - may the hammer of Bindi be bestowed on youknuck - may the hammer of Bindi be bestowed on youknuck - may the hammer of Bindi be bestowed on youknuck - may the hammer of Bindi be bestowed on youknuck - may the hammer of Bindi be bestowed on youknuck - may the hammer of Bindi be bestowed on youknuck - may the hammer of Bindi be bestowed on you
what I would like is a way to sort the icons in the control panel vertically instead of horizontally. This pisses me off because every time I search for something it takes me 10times longer than usual because things aren't at the same place depending on the size of the window
argggggg
__________________
| Intel i7 4770K | 12GB DDR3 2000 | Asus Maximus VI Hero | GTX 980 | Samsung 840 Pro 256GB | 10.5TB total | Seasonic X-1250 | Auzentech Bravura X-Fi | Fractal Design Define R3 XL | Corsair H50 | BenQ XL2420T 120Hz |
knuck is offline   Reply With Quote
Old 6th Feb 2010, 21:58   #19
knuck
Hate your face
knuck's Avatar
I am bumping this thread in hope someone has an answer to my question from the post above. I will only bump it once though
__________________
Old 6th Feb 2010, 22:44   #20
M7ck
Ⓜod Ⓜaster
M7ck's Avatar
M7ck is a hoopy frood who really knows where their towel is.M7ck is a hoopy frood who really knows where their towel is.M7ck is a hoopy frood who really knows where their towel is.M7ck is a hoopy frood who really knows where their towel is.M7ck is a hoopy frood who really knows where their towel is.M7ck is a hoopy frood who really knows where their towel is.M7ck is a hoopy frood who really knows where their towel is.M7ck is a hoopy frood who really knows where their towel is.M7ck is a hoopy frood who really knows where their towel is.M7ck is a hoopy frood who really knows where their towel is.M7ck is a hoopy frood who really knows where their towel is.
Cant you just change the view mode to small or large icons? It wont change it to a vertical layout but it will keep them all listed in alphabetical order enableing you to find things quicker.
__________________
M7ck is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
