Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 15th Jan 2010, 14:03   #1
Cutter McJ1b
Home-cut jibs at discount Prices
Cutter McJ1b's Avatar
Cutter McJ1b has yet to learn the way of the Dremel
The Easy Core i3 Upgrade?
http://www.bit-tech.net/blog/2010/01...re-i3-upgrade/
Cutter McJ1b is offline   Reply With Quote
Old 15th Jan 2010, 14:16   #2
okenobi
Ultramodder
okenobi's Avatar
okenobi is definitely a rep cheat.okenobi is definitely a rep cheat.okenobi is definitely a rep cheat.okenobi is definitely a rep cheat.okenobi is definitely a rep cheat.okenobi is definitely a rep cheat.okenobi is definitely a rep cheat.okenobi is definitely a rep cheat.okenobi is definitely a rep cheat.okenobi is definitely a rep cheat.okenobi is definitely a rep cheat.
Yes, it's cheap. But I wouldn't buy from OcUK. I still think a 530 with the P55-UD2 is a smart way to go, as there's room for an i5/i7 in the future.
I would also still like to see some numbers on i3-530 vs AMD Phenom II X2 550BE as budget options.
If Scan were to offer a bundle with a similar overclock and a Fenrir - that could well interest me.
okenobi is offline   Reply With Quote
Old 15th Jan 2010, 16:05   #3
Unknownsock
Supermodder
Unknownsock has yet to learn the way of the Dremel
Well you can ask them to change certain partsd, such as a fenrir, not sure about memory but possibly.
I live next CCL but ocuk just cant be beat in price most of the time imo.
Unknownsock is offline   Reply With Quote
Old 15th Jan 2010, 18:20   #4
Cupboard
I'm not a modder.
Cupboard's Avatar
Cupboard has yet to learn the way of the DremelCupboard has yet to learn the way of the DremelCupboard has yet to learn the way of the Dremel
That is around the same price I got my i7 motherboard/CPU/RAM/cooler for.
It was most definitely second hand, the stepping is the older sort and the motherboard is a bit suspect but I would go for second hand faster over new, slower components any day.
__________________
i7 920, 5870, 6GB Corsair all in an Intel DX58SO; 60GB Vertex, 1.5TB F2; Fractal Design R2
ThinkPad Edge 13.
Cupboard is offline   Reply With Quote
Old 15th Jan 2010, 19:01   #5
Farfalho
Supermodder
Farfalho's Avatar
Farfalho has yet to learn the way of the Dremel
OCuk sell pretty good bundle's and although I'm an AMD user, I think that is quite a bundle with out-of-store oc, you still got guarantee of that from OCuk although the manufacturer is gone. Pretty sweet actually
Farfalho is offline   Reply With Quote
Old 16th Jan 2010, 16:27   #6
vampalan
Multimodder
vampalan's Avatar
vampalan has yet to learn the way of the Dremel
A quick search for "online shop review" overclockers found:
http://www.reviewcentre.com/reviews5686.html
__________________
Project Log: HAL Obelisk
Project Log: Cardboard box
Photos: Flickr Site
vampalan is offline   Reply With Quote
Old 17th Jan 2010, 15:21   #7
dec
[blank space]
dec's Avatar
dec can run Crysisdec can run Crysisdec can run Crysisdec can run Crysisdec can run Crysisdec can run Crysisdec can run Crysisdec can run Crysisdec can run Crysisdec can run Crysisdec can run Crysis
thats pretty bold. bringing 4ghz to the entry level. that takes the fun (and stress ) out of doing it yourself though.
@okenobi - i dont think we'll see that comparison because nehalem is so much better than K10.5 and 550BE are only $30 or so cheaper than i3-530's.
__________________
Pure. Refreshing. Bacon.
dec is offline   Reply With Quote
Old 18th Jan 2010, 11:58   #8
joco2_uk
Multimodder
joco2_uk's Avatar
joco2_uk is definitely a rep cheat.joco2_uk is definitely a rep cheat.joco2_uk is definitely a rep cheat.joco2_uk is definitely a rep cheat.joco2_uk is definitely a rep cheat.joco2_uk is definitely a rep cheat.joco2_uk is definitely a rep cheat.joco2_uk is definitely a rep cheat.joco2_uk is definitely a rep cheat.joco2_uk is definitely a rep cheat.joco2_uk is definitely a rep cheat.
It would still be interesting to see how far ahead it was compared to the 550BE
joco2_uk is offline   Reply With Quote
Old 19th Jan 2010, 11:03   #9
woodss
Yes Louis Wu
woodss's Avatar
woodss has yet to learn the way of the Dremel
when they first started ocUK was a bit of a pain for me, but only in that 2 deliveries took 1 week each. But this was years ago and now they are flawless from my last few years using them, id rate them everytime.
woodss is offline   Reply With Quote
Old 19th Jan 2010, 15:13   #10
okenobi
Ultramodder
okenobi's Avatar
Well my bad experiences were a while ago too, but that kind of rep is hard to improve. Especially when the people you're now happy with haven't messed up yet.
Old 20th Jan 2010, 23:58   #11
Landy_Ed
Combat Novice
Landy_Ed's Avatar
Landy_Ed is a Super Spamming SaiyanLandy_Ed is a Super Spamming SaiyanLandy_Ed is a Super Spamming SaiyanLandy_Ed is a Super Spamming SaiyanLandy_Ed is a Super Spamming SaiyanLandy_Ed is a Super Spamming SaiyanLandy_Ed is a Super Spamming SaiyanLandy_Ed is a Super Spamming SaiyanLandy_Ed is a Super Spamming SaiyanLandy_Ed is a Super Spamming SaiyanLandy_Ed is a Super Spamming Saiyan
Is it my imagination, or are the same combination of parts available from Scan for £42 less? in these forums I'd say that much of a variance is relevant!
__________________
CDR SPUD
Landy_Ed is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
