Go Back   bit-tech.net Forums > Technology > Custom PC and bit-tech Folding Team
Reply
Thread Tools
Old 24th Dec 2010, 15:11   #61
standinwave
Folding in memory of my mum
standinwave has yet to learn the way of the Dremel
Originally Posted by jondi_hanluc View Post
I just copied what Saspro said, below is a screenie of mine:
I tried this to no avail:
Uploaded with ImageShack.us
Filezilla works but this gives error 550, test connection failed
standinwave is offline   Reply With Quote
Old 31st Dec 2010, 19:50   #62
standinwave
Still doesn't work, but now a different error Maybe it is blueyonder?
Old 31st Dec 2010, 20:05   #63
StreetSam
Multimodder
StreetSam's Avatar
StreetSam has yet to learn the way of the Dremel
I just couldn't get the auto upload to work. I ended up using Filezilla and manually uploading whenever I remember
Sorry I forgot, Fling is the prog I use to auto upload the webpage.
__________________
Folding stats
Current Folding@Home stats
StreetSam is offline   Reply With Quote
Old 31st Dec 2010, 20:16   #64
standinwave
i shall try that! Thanks
Old 1st Jan 2011, 09:02   #65
standinwave
Fling worked! Thanks for that one!
Old 12th Jan 2011, 21:33   #66
houch
Multimodder
houch's Avatar
houch - it's over 9000!!!!!!!!1!1!1!!!houch - it's over 9000!!!!!!!!1!1!1!!!houch - it's over 9000!!!!!!!!1!1!1!!!houch - it's over 9000!!!!!!!!1!1!1!!!houch - it's over 9000!!!!!!!!1!1!1!!!houch - it's over 9000!!!!!!!!1!1!1!!!houch - it's over 9000!!!!!!!!1!1!1!!!houch - it's over 9000!!!!!!!!1!1!1!!!houch - it's over 9000!!!!!!!!1!1!1!!!houch - it's over 9000!!!!!!!!1!1!1!!!houch - it's over 9000!!!!!!!!1!1!1!!!
hiya, is there instructions on how to set this up anywhere as i have no idea what im doing thank u
__________________
folding my pov gtx 275
houch is offline   Reply With Quote
Old 17th Jan 2011, 21:10   #67
houch
Multimodder
houch's Avatar
dw sorted it
__________________
Old 20th Jun 2011, 12:11   #68
CraigWatson
Level Chuck Norris
CraigWatson's Avatar
CraigWatson is a hoopy frood who really knows where their towel is.CraigWatson is a hoopy frood who really knows where their towel is.CraigWatson is a hoopy frood who really knows where their towel is.CraigWatson is a hoopy frood who really knows where their towel is.CraigWatson is a hoopy frood who really knows where their towel is.CraigWatson is a hoopy frood who really knows where their towel is.CraigWatson is a hoopy frood who really knows where their towel is.CraigWatson is a hoopy frood who really knows where their towel is.CraigWatson is a hoopy frood who really knows where their towel is.CraigWatson is a hoopy frood who really knows where their towel is.CraigWatson is a hoopy frood who really knows where their towel is.
Shame that this doesn't run on Linux, seems FaHmon is the only way to monitor Linux clients
__________________
Laptop: 2011 MacBook Air 11" | 4GB RAM | 256GB SSD | Core i7 1.8GHz
Storage: LaCie 2Big Network 2 | 2 x Samsung Spinpoint F3 1TB (RAID1)
Phone: iPhone 4S 16GB | Headphones: Sennheiser IE-80 IEMs
Bass Guitars: Akai Project 1997 4-string | Fender American Deluxe Precision V 5-string
CraigWatson is offline   Reply With Quote
Old 23rd Mar 2012, 11:43   #69
StreetSam
Multimodder
StreetSam's Avatar
HFM 0.9.0
Hi All,
Anyone tried this with the V7 client yet?
I thought I'd try the V7 client on one machine to see what it was about. Then realised that I couldn't monitor it. Then I found the new version of HFM that does. Only to find that I can't get it to work.
I have both machines firewalls turned OFF.
I have a remote access password set and the ip of the monitoring machine added to the remote access allow list in the V7 client.
I have the password and ip address of the v7 machine configured in HFM, but no luck.
What have I missed?
***EDIT***
Doh! I needed to restart the FAH client, all fixed.
__________________
Folding stats
Old 1st Apr 2012, 13:48   #70
FingAZ
Minimodder
FingAZ's Avatar
FingAZ has yet to learn the way of the Dremel
Hi All,
<SNIP>
What have I missed?
***EDIT***
I'm running the FAH7 client on Debian 64bit too- but can't get it to monitor in HFM no matter what- could you post an example of your config perhaps?
I'm running with "--command-allow 192.168.0.6" and i still get
Code:
13:43:15:Server connection id=1 on 0.0.0.0:444 from 192.168.0.6
13:43:17:WARNING:Command server access denied
What i'd really like is to allow all, as i'm using a passphrase anyway- but putting in "0.0.0.0" or "0.0.0.0/0" don't work either... could it be because i've changed the command port?
Edit: Also worth mentioning is that in order to get it to listen on this port i've had to switch the running user to root... Not massively secure, but meh!
FingAZ is offline   Reply With Quote
Old 2nd Apr 2012, 09:34   #71
StreetSam
Multimodder
StreetSam's Avatar
Sorry can't help all mine run some kind of Windows.
__________________
Folding stats
Old 2nd Apr 2012, 19:27   #72
FingAZ
Minimodder
FingAZ's Avatar
No problem, have posted a new thread instead in case someone can help
__________________
Folding stats
Old 20th Jul 2012, 19:30   #73
Scorpuk
Supermodder
Scorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run Crysis
New update available and this will work with linux 12.04 and create web stats. Version 0.9.1 - Revision 595
Got it up and running on my server (Linux 12.04) and sending stats to my ISP's web space via ftp
__________________
Folding stats
Folding Summary
Desktop: Corsair Carbide 400R; Asus Sabertooth X79; Intel i7-3930K; Hydro H100; EVGA GTX 580 772MHz; Corsair Vengeance 16GB DDR3 1600MHz; Corsair HX850W; Samsung 256GB 840 Pro; 2TB HDD; Windows 7 Ult. 64bit.
Scorpuk is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
