Reply
Thread Tools View Mode
Old 18th Jan 2010, 23:41   #1
Pfaffen
Supermodder
Pfaffen's Avatar
Pfaffen can run CrysisPfaffen can run CrysisPfaffen can run CrysisPfaffen can run CrysisPfaffen can run CrysisPfaffen can run CrysisPfaffen can run CrysisPfaffen can run CrysisPfaffen can run CrysisPfaffen can run CrysisPfaffen can run Crysis
Cray-1
I had an idea to make a scale version of a truly remarkable computer, the Cray-1.
Here is the idea on paper. You'll notice it was designed to support two complete computers (mobo, psu, dvd, hdd, etc...)
Here is the lay out on plywood. I plan on covering the lower part with Naugehide, like the original, so the plywood won't show through. Also, it is lighter than MDF or solid wood.
Here are the roughed in lines
another shot
Here is a shot with the Mobo and placeholders laid out
Here are the cutouts.
top and bottom
here they are together with the spacers
Here is a shot with the vertical pieces in place, dry-fit together.
Here is a view from the back.
__________________
Pfaffen
Wood Case Mods: Completed: World Map, Fibonacci, Canary Mesa, Molesworth, Cray-1, Federal Cellarette, Newbery TARDIS
Wood Case Mods: Under Construction: Vogel Haus, Four Hokusai Cases
Pfaffen is offline   Reply With Quote
Old 18th Jan 2010, 23:43   #2
Pfaffen
Supermodder
Pfaffen's Avatar
Sorry, wrong last pic.
Here is the back.
__________________
Pfaffen
Old 18th Jan 2010, 23:49   #3
Shadow703793
Supermodder
Shadow703793 has yet to learn the way of the DremelShadow703793 has yet to learn the way of the Dremel
Nice. Any chance of installing Acrylic windows so you can see the guts of the system?
Like this:
Also, do you plan to keep the original Cray -1 colors?
Shadow703793 is offline   Reply With Quote
Old 18th Jan 2010, 23:53   #4
Pfaffen
Supermodder
Pfaffen's Avatar
I was playing with the idea... may just do that.
__________________
Pfaffen
Old 19th Jan 2010, 00:08   #5
PureSilver
E-tailer Tailor
PureSilver's Avatar
PureSilver is a hoopy frood who really knows where their towel is.PureSilver is a hoopy frood who really knows where their towel is.PureSilver is a hoopy frood who really knows where their towel is.PureSilver is a hoopy frood who really knows where their towel is.PureSilver is a hoopy frood who really knows where their towel is.PureSilver is a hoopy frood who really knows where their towel is.PureSilver is a hoopy frood who really knows where their towel is.PureSilver is a hoopy frood who really knows where their towel is.PureSilver is a hoopy frood who really knows where their towel is.PureSilver is a hoopy frood who really knows where their towel is.PureSilver is a hoopy frood who really knows where their towel is.
Sweet. Supercomputers used to be built with so much more soul back in the day, things like Jaguar now are nothing more than big server farms. I miss monsters like the Cray-2, that needed coolant that costs $300 a gallon and still had a waterfall of it just because it looked cool...
__________________
Intel Core i7 920 @ 3Ghz, Noctua NH-U12P SE, Asus P6T Deluxe V1, Corsair 12GB (6x2GB) 1600Mhz C8 @ XMP,
EVGA GTX-680, Corsair AX750, 2x Samsung SpinPoint F3 1TB, Lian-Li V1020R with 3x Noctua NF-P12 & 3x NF-P14FLX
2.4Ghz 13" unibody MacBook, 4GB RAM & 128GB Samsung SSD
PureSilver is offline   Reply With Quote
Old 19th Jan 2010, 00:10   #6
jrs77
theorycrafting
jrs77's Avatar
jrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for president
Why do you use multiple optical drives? A single USB-DVD would do it aswell, no?
Other then that, this is going to be huge
__________________
...and allways remember, that the world is an orange!
Define Mini Black [Gigabyte Z77MX-D3H | intel i5-3450 | Kingston HyperX DDR3-1600 8GB | Gigabyte GTX660OC Windforce2 | intel 330 120GB | WD AV GP 1TB]
jrs77 is online now   Reply With Quote
Old 19th Jan 2010, 00:13   #7
The_Beast
I like wood ಠ_ಠ
The_Beast's Avatar
The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!
very cool idea
__________________
- i7 3770k - MSI Z77A-GD65 - EVGA GTX 570 - 8Gb G.Skill Sniper (1.25v) - Fractal R3 Black - Corsair H50 - Corsair 750HX - Samsung 830 128Gb SSD - 6 Samsung F4EG 2TB - 2 WD Black 1TB - 2 WD Black 750GB - Dell UltraSharp U2410 - WASD V1 Custom - IBM Model M SSK - KBC Poker (Ergo-Clears) - Logitech Mx518 & G500 - Audio Technica AD700 - Logitech Z4 - Windows 7 Pro -
The_Beast is offline   Reply With Quote
Old 19th Jan 2010, 03:06   #8
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for president
Thee tower area just screams for radiators. *hint*
Cheapskate is offline   Reply With Quote
Old 19th Jan 2010, 03:21   #9
shakka65
Multimodder
shakka65 has yet to learn the way of the Dremel
WOW! Super Computer Super huge.
I hope you have a Super large desk to put it on.
shakka65 is offline   Reply With Quote
Old 19th Jan 2010, 05:31   #10
jhanlon303
The Keeper of History
jhanlon303's Avatar
jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.
The cable management will be a problem since a Cray's wiring is measured in 0.01 mm and done with individual wires because of timing requirements. I interviewed with Seymour Cray in 1981. Brilliant engineer.
The insides:
/edit
Excellent idea by the way!
__________________
My deepest gratitude to this community.
jhanlon303 is offline   Reply With Quote
Old 19th Jan 2010, 14:24   #11
Shadow703793
Supermodder
^ Damn never knew that. Must have been a huge PITA to upgrade/fix.
Old 19th Jan 2010, 21:02   #12
Breach
Modding in Exile
Breach has yet to learn the way of the Dremel
Very cool! The Cray 1 is probably my all time favorite old time computer, this will look awesome sitting beside a desk.
And good start, it already looks the part
__________________
Project :: Kaiten X [In Progress]
Breach is offline   Reply With Quote
Old 19th Jan 2010, 22:07   #13
Pfaffen
Supermodder
Pfaffen's Avatar
I had planned on one dedicated for each system. Wasn't sure I could slave a USB-DVD between them.
The overall dimensions are roughly 35" across and 25" tall. I does take up a lot of space though. May have to make a special stand for it.
__________________
Pfaffen
Old 19th Jan 2010, 22:08   #14
Pfaffen
Supermodder
Pfaffen's Avatar
I know... I have been toying with the idea. There is soooo much space in there!
__________________
Pfaffen
Old 19th Jan 2010, 22:16   #15
Pfaffen
Supermodder
Pfaffen's Avatar
The insides:
/edit
Thank you very much. I am envious. You have met and interviewed a truly brilliant man. I researched alot for the project and found he (Mr. Cray) had hired women (seamstresses) if I'm not mistaken to handle the myraid of individual wires to minimize the distance travelled.
I hope I can do justice to such an extraordinary computer.
__________________
Pfaffen
Old 19th Jan 2010, 22:20   #16
Pfaffen
Supermodder
Pfaffen's Avatar
Here is a shot of the back of the Cray at the Smithsonian in DC.
__________________
Pfaffen
Old 19th Jan 2010, 23:25   #17
jhanlon303
jhanlon303's Avatar
I see your problem - it's the blue wire! - Field Engineer
Each of the early Cray computers were shipped with a dedicated Field Engineer( job they wanted me for). The engineer was hired when the order was placed and ONLY knew one box - his/hers.
The FE lived with the unit as it was being assembled, transported, installed, first boot, and turn over to customer. Serious money for serious dedication. Hardware and Unix software.
__________________
Old 20th Jan 2010, 01:52   #18
The_Beast
I like wood ಠ_ಠ
The_Beast's Avatar
Very cool little fact
__________________
Old 20th Jan 2010, 08:25   #19
confusis
Kiwi-modder
confusis's Avatar
confusis can run Crysisconfusis can run Crysisconfusis can run Crysisconfusis can run Crysisconfusis can run Crysisconfusis can run Crysisconfusis can run Crysisconfusis can run Crysisconfusis can run Crysisconfusis can run Crysis
jhanlon303 - knows all, imparts wisdom in all he speaks to!
confusis is offline   Reply With Quote
Old 20th Jan 2010, 15:24   #20
badders
Neuken in de Keuken
badders's Avatar
badders has yet to learn the way of the Dremelbadders has yet to learn the way of the Dremelbadders has yet to learn the way of the Dremelbadders has yet to learn the way of the Dremelbadders has yet to learn the way of the Dremelbadders has yet to learn the way of the Dremelbadders has yet to learn the way of the Dremelbadders has yet to learn the way of the Dremel
Still done, with stuff like Radars.
__________________
Originally Posted by Silver51 View Post
John Hanlon standing on an oil pipeline during a blizzard, punching an angry polar bear in the balls. I heard he really did that once.
badders is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
