#1 |
E22.BIZ
Evolution
Current Status
Well hello there, After realising my last build was just to small I began to sketch up some designs for a much larger case similar in size to the infamous tj07. After about 2 weeks of scratching my head I just jumped in and figured if I start cutting away at metal then maybe some ideas will form. While that did seem to have the desired effect it also had the knock on of alot of mistakes down to poor planning maybe I'll make a blooper reel at the end or something ![]() The Design consists of a 2 tiered case with the bottom section holding hard drives, PSU, radiator and most of the wiring junctions while the top holds the rest. Made a render of my original sketchup to stick in the shop and help guide my crazy mind. ![]() So anyhow for the first post I'll be spamming a load of pictures that have been taken along the way ![]() First off here is some of the hardware going into the build and my work space including my Christmas presents of a pillar drill, vice and bending brake. Not alot but it beats the hell out of having to work on and old washing machine. ![]() ![]() Created a basic frame from 1/2" aluminium bars held together with countersunk m4 bolts, then cut out a plate from 2mm aluminium sheet for the middle. The supports in the lower compartment were to hold the radiator but scrapped the design for something nicer. ![]() Instead of those mounts I decided to hold the radiator in place directly to the side so started working on the bottom compartment panel. Traced my design onto some shiny black 5mm plexi and went ridiculously slow with the jigsaw making sure to stay in the lines by a fair bit for some serious filing/sanding later ![]() ![]() Couldn't resist a test fit. ![]() Cut 2 x 3/4" channels and fixed them in, A plate will go in the front of these to hold the reservoir and also gives me the space to route all the wiring out of sight. ![]() To hold the pump and drives in place and give yet more room to manage wiring I cut and drilled a plate to fit in the left side. ![]() I wanted to add a bit of a glow to the case from the middle plate so cut out a overlay from some 3mm fluorescent blue plexi following a similar design to the radiator grill. ![]() Next on the list was the drive rack, marked out and used the jigsaw to cut the main piece then a long necked fretsaw for the hole details. Left a lot of excess as I'm petty new to the joys of bending and didn't want to end up short. ![]() Cut and filed to size then mounted using some temporary fixings ![]() ![]() A couple of my favourite shots after a test fit/light ![]() ![]() So that's where I'm at now, still a lot to get done but having a great time seeing it come together. Last edited by Editor22; 16th Sep 2011 at 14:46. Reason: Title |
#2 |
Music Enthusiast
You have only just started but my mind is seriously blown i love the way you've layed the whole case out drive rack on front
is the bottom section just for radiators and wcing gear?
__________________
deadp1xels@yahoo.co.uk |
#3 |
Usually spilling liquid...
that is looking really sweet!
the craftsmanship of this build is impressive, subscribed! |
#4 |
Terminating People Since 1980....
Its going to turn out amazing i wish i could do something like this!
__________________
The Rig: i7 3770K @ 4.6Ghz/ Asus Maximus Gene V/ 16Gb Corsair Vengeance (Red) / 120Gb Kingston V+200 SSD / Asus HD7970 / Corsair AX850 / CM Storm Trooper / Mionix Zibal 60 / The Water: EK Supreme HF CPU Block / EK 7970 CSQ GPU Block / XSPC H2O 750 V4 / 2 x 240mm AlphaCool NeXXXos UT60 RADs / The Project: Antec TwelvOrange |
#5 |
Multimodder
Man I'm speechless at the work you have done so far. Really incredible. I hope you still have the protective covering on your plexi so you dont scratch it up.
#6 |
E22.BIZ
@ flame696, imersa - Thanks
![]() @ DeadP1xels - The bottom houses the Psu, hard drives and a 2x120 radiator, theres some more going down there but I'm holding back posting it until the designs finalized ![]() @ shakka65 - Thanks, The protective plastic got lost somewhere, honestly wasn't me being impatient to see the result at all lol but its ok as there is a metal plate to go on top so a lot of it wont be seen.
#7 |
Multimodder
The case looks really nice so far, and you are really doing your render justice.
#8 |
Yes Louis Wu
Nice work! keep it up, especially like the well cut vents!
__________________
I am into my pico projector's mostly, also philosophy and general technology development and theory, what are you into? |
#9 |
Multimodder
lookin great already
#10 |
E22.BIZ
@ razerz - Thanks mate, I'm really trying to stick to it the best I can this time but crazy ideas jump into my head and I end up getting side tracked onto other parts of the case
![]() @ woodss - Thanks they turned out better than I was expecting actually still got some work to do on that area for the gap in the middle but that is for a later log post ![]() @ StEm - Thanks |
#11 |
E22.BIZ
Update 30/01/10
Hey everyone
been busy for the last week so was itching to get into the garage today and make some progress, here's what I've been up to.Needed to make a plate which spans the 2 U channels to the left of the motherboard tray, the idea is that all the cables will route behind it but it also serves the purpose of supporting the reservoir and adding some illumination to it. Started off by cutting out some 2mm sheet aluminium and drilling the mounting holes, after this I moved onto a 1" hole saw for the window. ![]() Next it was onto the Vice and using some angles and a square I started filing and sanding until I was happy with a nice smooth straight edge. ![]() ![]() Fixed it in and found a scrap piece of plexi which happened to be just the right size for a test fit ![]() Clipped in the reservoir and flicked on 2 x cathodes to get an idea of how its going to look ![]() That's all for now, maybe some more tomorrow if I can bear the cold again
#12 |
E22.BIZ
HDD Mounting
Took some time over the weekend to figure out a way to mount the hard drives and after spending most of Saturday bouncing ideas about for cages and elaborate rails I settled on something simple but effective. The main design needed to allow air to flow from the radiator through the drives and out of the case.
![]() Finally content with the design I converted it from sketchup to a 2d image, printed it out as a template and taped it to some 2mm aluminium. ![]() After the usual process of Drilling, sawing & filing it started to take shape. The cut outs in the corners are so it sits flush against some of the main frame rails. ![]() Time for a test fit with some old broken hard drives. ![]() I want to try and keep the noise of the build to a minimum so using a step drill I enlarged the mounting holes and added some mini grommets. The final mounting will be done with black thumb screws but the cheepo blue ones I have are years old and have lost most of there thread. ![]() Here you can see that there is still a lot of space behind the radiator. Think I might upgrade to a thicker one or maybe run push/pull... ![]() Thats all I got for tonight
#13 | |
Is a cackling Yuletide Belgian
Is it alright to have the drives just 'hanging' there?
__________________
My Flickr
#14 |
E22.BIZ
Should be I checked the strength and it seems solid, leaving the drives in for a few days to check for any drop or warping and if there is I'll add some support angles or tap the drives for some M4 socket heads.
#15 |
What's a Dremel?
This is a really great project - love the work I'm seeing so far. The radiator grill looks awesome!
Only thing I would say is that whilst the HDDs probably are secure, they just 'look' unfinished, being secured only from one side. It would look a lot better in my opinion if you put up a central support to secure them on the other side too, just for balance - or maybe a HDD cage all around them. Anyway - great project and I look forward to seeing more!
__________________
- Rob --- New rig (work in progress) ---
Cosmos 1000 PURE, PCP&C Silencer 750w Quad Crossfire, Phenom II X4 955 BE, 8GB Corsair Dominator XMS3 RAM, ASUS Crosshair III Formula, BFG GeForce 9800GTX {GPU to be replaced} |
#16 |
E22.BIZ
-> Fazanitar
Thanks for the comments I see what you mean about the drive rack now I look at it more guess I'll be making a second plate for the middle if only there was a stockist of lan-li cages that actually had some in stock! lol
#17 |
Some really really good ideas here.
Some of the aspects of the build seem so common yet you've added a person touch/twist too them! Really smart case. Wish I could render designs! Keep it up. |
#18 |
↓ Don't trust that face!
You might want to add just a thin strip to support the other side of the drives. The leaning is likely making the bottom edge of the drives rest on the cage. That will make the addition of grommets useless.
-Or add a 2nd set of grommets that seat on the bottom of the drives. ![]() Yer doing great! I had to go back to the start because I thought you were modding a LianLi at first.
__________________
#19 | ||
E22.BIZ
![]() Quote:
I see what you mean about the bottom resting on the cage, its not quite there yet but I've a feeling it would be once the drives are spinning non stop for a few weeks. hmmmm I'm really not sure if I like the drives any more I have something planned in SU that I'm trying to figure out if it would actually work or not maybe I'll post a screen shot and get some feedback Glad its looking something similar to a Lianli.... oh wait or is that just because I nabbed a mobo tray to stick inside lol. Bah enough rambling on
#20 |
I like wood ಠ_ಠ
Very nice, I really like the "hanging" hdds
__________________
- i7 3770k - MSI Z77A-GD65 - EVGA GTX 570 - 8Gb G.Skill Sniper (1.25v) - Fractal R3 Black - Corsair H50 - Corsair 750HX - Samsung 830 128Gb SSD - 6 Samsung F4EG 2TB - 2 WD Black 1TB - 2 WD Black 750GB - Dell UltraSharp U2410 - WASD V1 Custom - IBM Model M SSK - KBC Poker (Ergo-Clears) - Logitech Mx518 & G500 - Audio Technica AD700 - Logitech Z4 - Windows 7 Pro -
| Thread Tools | |
| View Mode | |
