Reply
Thread Tools View Mode
Old 9th Feb 2010, 21:51   #21
Editor22
E22.BIZ
Editor22's Avatar
Editor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run Crysis
-> The_Beast - Thanks dude Its still a bit of a love/hate thing now
__________________
Store: E22
Social: Youtube | Facebook
Projects: Evolution | K2 MK1
Editor22 is offline   Reply With Quote
Old 9th Feb 2010, 22:30   #22
The_Beast
I like wood ಠ_ಠ
The_Beast's Avatar
The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!
Are the loud?
__________________
- i7 3770k - MSI Z77A-GD65 - EVGA GTX 570 - 8Gb G.Skill Sniper (1.25v) - Fractal R3 Black - Corsair H50 - Corsair 750HX - Samsung 830 128Gb SSD - 6 Samsung F4EG 2TB - 2 WD Black 1TB - 2 WD Black 750GB - Dell UltraSharp U2410 - WASD V1 Custom - IBM Model M SSK - KBC Poker (Ergo-Clears) - Logitech Mx518 & G500 - Audio Technica AD700 - Logitech Z4 - Windows 7 Pro -
The_Beast is offline   Reply With Quote
Old 10th Feb 2010, 06:49   #23
Editor22
E22.BIZ
Editor22's Avatar
Nope there pretty silent as far as I can tell but have not been able to do any stress tests yet. The main thing I'm not sure about is the aesthetics of them guess I should carry on and see how they look once its more completed
__________________
Store: E22
Old 21st Feb 2010, 16:10   #24
Editor22
E22.BIZ
Editor22's Avatar
Well its been a few weeks and if I'm honest this is going to be a bit of a small update since if had a bad case of the man flu and haven't really felt like doing much. I did how ever manage to bring the case inside and plonk it on my desk in the hope of getting some ideas.
Ok here we go... first off I scrapped the mini grommets in favour of some chunky hard rubber tap washers. Also tapped the hard drive to M4 which seems to have fixed the slight lean the drive was getting. Still need to put some washers between the plate and the drive but noes I've run out of M4 x 12mm hex caps
Got the left side of the case cut and fitted in place. There is a 1/2" gap in between the side and the internal pump panel where some of the cables run from the top section and down into the bottom.
You might also spot the CPU block being used, its the Ybris black sun... more on that later.
A closer look down between the two panels. and of course the generic foot shot
Using the same method with a step drill and long necked fret saw I made the hole for the pump & led wiring to pass through.
That's it for now fingers crossed I'll get a fair bit done in the next few weeks, cutting it close to being ready for painting in the summer at this rate lol
__________________
Store: E22
Old 17th Mar 2010, 19:38   #25
cool_dude
Me ^ | My Post ->
cool_dude's Avatar
cool_dude - it's over 9000!!!!!!!!1!1!1!!!cool_dude - it's over 9000!!!!!!!!1!1!1!!!cool_dude - it's over 9000!!!!!!!!1!1!1!!!cool_dude - it's over 9000!!!!!!!!1!1!1!!!cool_dude - it's over 9000!!!!!!!!1!1!1!!!cool_dude - it's over 9000!!!!!!!!1!1!1!!!cool_dude - it's over 9000!!!!!!!!1!1!1!!!cool_dude - it's over 9000!!!!!!!!1!1!1!!!cool_dude - it's over 9000!!!!!!!!1!1!1!!!cool_dude - it's over 9000!!!!!!!!1!1!1!!!cool_dude - it's over 9000!!!!!!!!1!1!1!!!
looking good
__________________
Cheers, Cool_Dude.
...Talk is cheap.
cool_dude is offline   Reply With Quote
Old 17th Mar 2010, 19:57   #26
p0Pe
gief cake?
p0Pe's Avatar
p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!
you got a REALLY cool mod going on here man! the design in post 1 is utterly awsome
+rep for building it from the ground!
__________________
p0Pe is offline   Reply With Quote
Old 20th Mar 2010, 17:55   #27
Editor22
E22.BIZ
Editor22's Avatar
And off we go again
Been ages since I managed to get some stuff done but I finally managed to get some build time in the last few days so here is a light update.
Seeing as I'm using the xspc clear pump top I really wanted to show it off by hiding the actual pump so a shroud was in order! I wanted the shroud to be back lit via 2 4" UV cathodes so started off by cutting 2 pieces of 3/4" aluminium channel. Then marked out the hole for the light to come through and using a step drill and long necked fret saw took out the middle. Also added a recess in the end for cable routing from the cathode.
Measured out a piece of 3mm fluorescent blue plexi, drilled, tapped and screwed into place to allow some fine sanding of the top and bottom edges.
Masked off the pump and attached it to the inside panel. I used this as a template aposed to measuring it all up, lazy I know but I got a bit ahead of myself and all impatient.
Spent the next 2 hours cutting, filing, cutting, sanding, cutting.... you get the idea until I had a pretty tight fit around the pump top. The plexi panel is held in place via 4x m4 bolts with 2x 5mm m4 threaded spacers on each one.
And with the lights off
Still got some work to do on this part like bending a piece to fit in behind the compression fitting, sticking the vinyl design to the back of the plexi and just general sanding but fancied getting an update in so you all know its not dead
Take it easy till next time
__________________
Store: E22
Old 21st Mar 2010, 14:47   #28
Editor22
E22.BIZ
Editor22's Avatar
Spent another day in the garage today I needed to create a support plate to hold the motherboard tray stable. The plate will join the tray to the reservoir bracket that I made earlier.
Started off by measuring it all up and cutting the first piece out of 2mm aluminium sheet, Then used this as a template for some more of the 3mm blue plexi I'm using.
After some filing and sanding it was starting to get a bit shiny
Made a hole for the 24 pin the come through.
Other than a bit of final sanding this piece is finished. Should look pretty cool once its all lit up with the wires routed through
__________________
Store: E22
Old 21st Mar 2010, 15:05   #29
subset7
Spanking the Monkey
subset7's Avatar
subset7 should be considered for presidentsubset7 should be considered for presidentsubset7 should be considered for presidentsubset7 should be considered for presidentsubset7 should be considered for presidentsubset7 should be considered for presidentsubset7 should be considered for presidentsubset7 should be considered for presidentsubset7 should be considered for presidentsubset7 should be considered for presidentsubset7 should be considered for president
Great work,this is shaping up nicely
__________________
Project:PURE
subset7 is offline   Reply With Quote
Old 21st Mar 2010, 16:19   #30
ringo
Supermodder
ringo has yet to learn the way of the Dremel
Great work, and a interesting project.
ringo is offline   Reply With Quote
Old 21st Mar 2010, 16:33   #31
craigbru
Now... with more CNC!
craigbru's Avatar
craigbru has yet to learn the way of the Dremelcraigbru has yet to learn the way of the Dremel
Pure sweetness. The pump lighting looks outstanding!
__________________
Originally Posted by disturbed13
'to cram everything in the box, you must think outside the box'
craigbru is offline   Reply With Quote
Old 21st Mar 2010, 19:43   #32
Editor22
E22.BIZ
Editor22's Avatar
Thanks guys, its really nice to get some feedback been feeling a bit swamped among all these amazing builds people are knocking up at the moment.
__________________
Store: E22
Old 29th Mar 2010, 12:33   #33
The boy 4rm oz
Project: Elegant-Li
The boy 4rm oz's Avatar
The boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the Dremel
I like a good scratch build, and this is no exception, keep up the good work and congrats on your MOTM nomination .
__________________
Project: Elegant-Li *NEW*
Project: Alpha FINISHED
Project: LEXA Revival FINISHED
Project: LEXA FINISHED MOTM Nominee October 08
The boy 4rm oz is offline   Reply With Quote
Old 29th Mar 2010, 12:57   #34
mrdbristol
Voided my warranty years ago
mrdbristol's Avatar
mrdbristol has yet to learn the way of the Dremelmrdbristol has yet to learn the way of the Dremelmrdbristol has yet to learn the way of the Dremelmrdbristol has yet to learn the way of the Dremelmrdbristol has yet to learn the way of the Dremel
Getting my vote
Looks superb so far, keep it up
__________________
| i5 2500k @ 4.5Ghz | Asrock Z77 Extreme 4 | Asus 7970 DCII TOP 3gb | 8Gb Geil 2133MHz | Lian Li PC-X1000 | Xonar Essence STX |
( May 10 ) : Monolith
( Jan 10 ) : Purple Rain ( CustomPC - Issue 81 ( April '10 ) / MOTY '10 Nominee
( Aug 08 ) : Dark Water
mrdbristol is offline   Reply With Quote
Old 29th Mar 2010, 16:50   #35
Editor22
E22.BIZ
Editor22's Avatar
Wow thanks, I just got back from A&E after slicing through my finger so this really has made my day so much better
__________________
Store: E22
Old 29th Mar 2010, 18:32   #36
Skorchio
Supermodder
Skorchio's Avatar
Skorchio has yet to learn the way of the DremelSkorchio has yet to learn the way of the DremelSkorchio has yet to learn the way of the Dremel
This is going to be supper sweet when it finished!
Skorchio is offline   Reply With Quote
Old 31st Mar 2010, 21:05   #37
Editor22
E22.BIZ
Editor22's Avatar
Thanks Skorchio
Well with my buggered finger I haven't been able to get much case work done but I have played about with the camera and Photoshop to recreate the lighting\colours a little better. Also made a template for future pictures to hopefully make the rest of the log much more enjoyable
__________________
Store: E22
Old 1st Apr 2010, 19:55   #38
ModaRobby
Supermodder
ModaRobby's Avatar
ModaRobby has yet to learn the way of the Dremel
Im loving the black and blue theme. My favorite color scheme over all. Just a small observation, your pictures are still a little blurry in places. Mod on
__________________
Originally Posted by AnG3L View Post
I've seen a lot of mods in my life and I've noticed something. Some of them, they are so complicated with so many blink blinks, little lcd's popping out from everywhere etc etc. U can paint your case red and add a watercooling system and maybe it will look waaaaaaaaaay better than a mod that costs 6000 dollars with all of these useless thingies in it! Btw, modding is art and we are some goddamn good artists!!!
ModaRobby is offline   Reply With Quote
Old 1st Apr 2010, 22:23   #39
Editor22
E22.BIZ
Editor22's Avatar
Thanks even though its been done a gazillion times before I still love blue lighting to
As for the pics, its a case of trying to snap while I work rather than taking time out to get some quality shots something I need to work on for the sake of the log I guess.
__________________
Store: E22
Old 2nd Apr 2010, 00:45   #40
ModaRobby
Supermodder
ModaRobby's Avatar
Everyone loves eye candy
__________________
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
