Old 30th May 2010, 19:39   #141
skreenname
Allons-y!
skreenname's Avatar
skreenname has yet to learn the way of the Dremel
I love how industrial that looks.
<3
I may be a bit late to the party, but in my opinion the CoolerMaster fans are a bit loud.
It might just be the air they're pushing, but If I can hear them, they're too loud.
And I can hear them.
__________________
AMD Phenom X4 9650 [2.7GHz] | Nvidia GeForce GTX 560ti | 4GB GSKILL DDR2 800 | Gigabyte GA-MA780G-UD3H
______________________________________
Zotac ION-ITX-A-U | 2GB A-Data DDR2 800
skreenname is offline   Reply With Quote
Old 30th May 2010, 21:45   #142
Anubus
Multimodder
Anubus's Avatar
Anubus has yet to learn the way of the Dremel
I love smoked plexi
This is going to be awesome!
__________________
http://valid.canardpc.com/cache/banner/2051995.png
^current overclock
Anubus is offline   Reply With Quote
Old 31st May 2010, 01:01   #143
Attila
still thinking....
Attila's Avatar
Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.
I hadn't noticed how the side panel wraps around the front. Very tasty.
__________________
stillthinking
Attila is offline   Reply With Quote
Old 31st May 2010, 01:10   #144
The boy 4rm oz
Project: Elegant-Li
The boy 4rm oz's Avatar
The boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the Dremel
That's some great metal work there . It's looking really great.
__________________
Project: Elegant-Li *NEW*
Project: Alpha FINISHED
Project: LEXA Revival FINISHED
Project: LEXA FINISHED MOTM Nominee October 08
The boy 4rm oz is offline   Reply With Quote
Old 31st May 2010, 08:35   #145
Editor22
E22.BIZ
Editor22's Avatar
Editor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run Crysis
<3
I feel the same which is why I have a box on its way from Germany right now
Originally Posted by Anubus View Post
I love smoked plexi
Thanks guys
__________________
Store: E22
Social: Youtube | Facebook
Projects: Evolution | K2 MK1
Editor22 is offline   Reply With Quote
Old 31st May 2010, 12:06   #146
Nicksen
Danish Kid :D
Nicksen has yet to learn the way of the Dremel
Nice work :O
Nicksen is offline   Reply With Quote
Old 31st May 2010, 16:51   #147
Editor22
E22.BIZ
Editor22's Avatar
Ok so until I stump up the cash for a new graphics card I'll be leaving my 4890 on air which means some temporary ventilation needs to be made in the top of the case. To try and bring it in with the SSD window I designed this panel to run over the top of the case.
Excuse the quick render but it shows what I'm thinking more or less
The plan is to use this until I go watercooling on the gfx at which point I'll fabricate a new plexi panel without the grill and just have a fancy looking top window to showcase the gfx plate.
But first the SSD window
Same old story of cutting, filing and light sanding to end up with this.
Next onto the plexi cut out a panel and clamped it down to the aluminium top to transfer the mounting holes across.
The holes were then countersunk and using m4 bolts it was fastened to the frame.
I'm using a radiator template again for the 15mm space. This is because I want the option of adding a second loop in case the 2 stealth's don't cut it when the gfx is added.
A quick test fit later and I'm less then impressed by the 1mm clearance over the cardboard motherboard template but I think it will suffice and shouldn't niggle at me to much for the couple of months its going to be in place.
That's all I've got :P
__________________
Store: E22
Old 31st May 2010, 17:04   #148
Fabou
Supermodder
Fabou's Avatar
Fabou has yet to learn the way of the Dremel
Sweet. The more you make progresss, the more I want to see!
__________________
Linux user! Join the revolution
Originally Posted by AnG3L View Post
I really like your comment mate I wish I could express myself like this too! Thanks buddy!!
Fabou is offline   Reply With Quote
Old 31st May 2010, 19:12   #149
Nicksen
Danish Kid :D
Once again: "Nice work :O"
I love the top panel!
Old 31st May 2010, 23:11   #150
Editor22
E22.BIZ
Editor22's Avatar
Thanks guys
__________________
Store: E22
Old 31st May 2010, 23:49   #151
stonedsurd
Is a cackling Yuletide Belgian
stonedsurd's Avatar
stonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for president
Even I missed the fact that the side panel wraps around. Great idea and execution!
__________________
My Flickr
Originally Posted by specofdust View Post
You don't believe people can be trusted to be exposed to ideas, to thought, to expression. I choose to say that even if people can't be trusted, it's moral that they should be, because I have no right to elevate myself above them and decide on their behalf what they should be exposed to, because that is authoritarian, discriminatory, and wrong.
stonedsurd is offline   Reply With Quote
Old 1st Jun 2010, 13:40   #152
brinkz0r
Hypermodder
brinkz0r's Avatar
brinkz0r has yet to learn the way of the Dremel
I missed the entire project, that's even worse Great work Editor22, I'm following from now on.
__________________
My casemodding company: Brink of Modding
My latest casemod: miXture
Custom reservoirs and more: Phase 2 Casemodding
brinkz0r is offline   Reply With Quote
Old 1st Jun 2010, 16:03   #153
Editor22
E22.BIZ
Editor22's Avatar
Thanks
Welcome aboard Brinkz0r
__________________
Store: E22
Old 1st Jun 2010, 17:10   #154
ModaRobby
Supermodder
ModaRobby's Avatar
ModaRobby has yet to learn the way of the Dremel
Still lovin this mod editor22. Unfortunately, due to my dumb-ass, I missed your last two updates because I didn't realize bit-tech won't send you subscription updates if you don't sign in.... Lol
__________________
I've seen a lot of mods in my life and I've noticed something. Some of them, they are so complicated with so many blink blinks, little lcd's popping out from everywhere etc etc. U can paint your case red and add a watercooling system and maybe it will look waaaaaaaaaay better than a mod that costs 6000 dollars with all of these useless thingies in it! Btw, modding is art and we are some goddamn good artists!!!
ModaRobby is offline   Reply With Quote
Old 1st Jun 2010, 20:48   #155
Editor22
E22.BIZ
Editor22's Avatar
Started today by editing the radiator template for the cut outs then masking it to the top panel.
I went all cheap and decided to use the jigsaw rather than buy a large costly hole saw so some holes needed to be made to get the blade in.... and yes I'm padding a light update :P
Had to go really slow and steady with the jigsaw so no working shots but as you can see its not that bad of a circle
Threw a couple of fans in for a test fit then fancied trying it with some mesh.
How it looks together.. I'm really bad for assembling the case after every small change to make sure the design is still working.
Finally a small video of the work done this evening.
well that's it from me tonight
__________________
Store: E22
Old 1st Jun 2010, 20:59   #156
DeadP1xels
Music Enthusiast
DeadP1xels's Avatar
DeadP1xels - it's over 9000!!!!!!!!1!1!1!!!DeadP1xels - it's over 9000!!!!!!!!1!1!1!!!DeadP1xels - it's over 9000!!!!!!!!1!1!1!!!DeadP1xels - it's over 9000!!!!!!!!1!1!1!!!DeadP1xels - it's over 9000!!!!!!!!1!1!1!!!DeadP1xels - it's over 9000!!!!!!!!1!1!1!!!DeadP1xels - it's over 9000!!!!!!!!1!1!1!!!DeadP1xels - it's over 9000!!!!!!!!1!1!1!!!DeadP1xels - it's over 9000!!!!!!!!1!1!1!!!DeadP1xels - it's over 9000!!!!!!!!1!1!1!!!DeadP1xels - it's over 9000!!!!!!!!1!1!1!!!
So much epic it hurts
__________________
deadp1xels@yahoo.co.uk
DeadP1xels is offline   Reply With Quote
Old 1st Jun 2010, 21:02   #157
Remmes
Be One With Your Mod
Remmes's Avatar
Remmes has yet to learn the way of the Dremel
looks good, when fully building don't put in the fans the wrong way
i really like the looks of that alu + the blue lighting what, colour will it be in the end, or will it stay like this??
__________________
Originally Posted by bulldogjeff View Post
I wouldn't go round bragging to the ladies that you got a floppy that keeps popping out, especially if it's only a 3,1/2 inch
Remmes is offline   Reply With Quote
Old 2nd Jun 2010, 00:19   #158
skreenname
Allons-y!
skreenname's Avatar
I'm assuming you did some filing after you cut those holes?
They're too perfect.
._.
__________________
Old 2nd Jun 2010, 00:26   #159
ModaRobby
Supermodder
ModaRobby's Avatar
Lookin schweeeeeet!
__________________
Old 2nd Jun 2010, 05:58   #160
Editor22
E22.BIZ
Editor22's Avatar
Thanks dude :P
Im not sure which way the fans will go in yet, I may just run some stress tests and go with what ever performs better. As for the case... it will be powder coated I'm thinking satin black internal and gloss black external.
._.
You know, all I've done in those shots is remove the tape. There is still a few rough edges though
Originally Posted by ModaRobby View Post
Lookin schweeeeeet!
Thanks Robby
__________________
Store: E22
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
