#161 |
Project: Elegant-Li
Exhaust fans look good without damaging the style of the case, very nice
__________________
Project: Elegant-Li *NEW* Project: Alpha FINISHED Project: LEXA Revival FINISHED Project: LEXA FINISHED MOTM Nominee October 08 |
#162 |
Danish Kid :D
Looks amazing!
#163 |
Ultimate Modder
Sick! I love when I see quick updates of this project! Again, moooooooar!!! Mod on bro
#164 |
Supermodder
Those hole are really perfectly circle shaped. I'm sure holesaw seller hate you for unfair competition.
#165 | |||
E22.BIZ
![]() Got a parcel from Germany today It was pretty late and I really didn't fancy anything to strenuous so just went ahead and made probably the last full component test fit. Not really much to photograph but did make a video after it was all together ![]() Contents ![]() 4 x enermax everest 120mm 1 x twin 12" UV ccfl 2 x 45 degree compression fittings 2 x black res brackets because snapped my last ones ![]() 1 x led port for the res ![]() got the fans on ![]() Last edited by Editor22; 2nd Jun 2010 at 20:56. |
#166 |
Ultimate Modder
Got a quick question. Are you going to leave fans as it is or are you going to paint/mod them?
Thanks |
#168 |
Danish Kid :D
Really nicely done! Love it!
#169 | |
Supermodder
The Enermax Everest and Cluster fans are awesome. Especially when they are painted.
__________________
#170 |
Multimodder
Thats a very nice looking scratch build, I'll be following from now on!
#171 |
E22.BIZ
Thanks guys
![]() Got home early from work today so made some headway on the top panel. First up was to remove the panel and give it a light sand with some 800 wet and dry to remove all the rough edges from the cutting I did the other day. Also got the smoked plexi panel masked up and ready. ![]() ![]() Using the aluminium top as a template I began to make some multi coloured markings to run some ideas about. ![]() ![]() Then drilled some 3mm pilot holes followed by 10mm ![]() ![]() ![]() I then marked up the lines to join each hole and set about it with the jigsaw making sure I stayed a good 1mm inside the line to allow a nice finish with filing/sanding. ![]() ![]() Still have the filing and sanding to do but had a test fit before calling it a night ![]() ![]() Right that's all I got
#172 |
Hypermodder
this is some really nice work your doing here. I just read up on your log. Taking my first foray into aluminum on my current project, i can appreciate the time and attention to detail your are doing here.
__________________
Previous Project: Zenith Antique Radio Scratch Build Current project: Project Quintessence |
#173 |
Project: Elegant-Li
The top grills look great. The fans look pretty cool to IMO.
__________________
#174 |
Ultimate Modder
Very nice and neat man, keep going!
#175 |
Danish Kid :D
Once again nicely done. I'm looking forward to see the fans up and running with that top panel. Looks great!
#176 | |||
E22.BIZ
Thanks again guys, I have just been informed that my photobucket account has overstepped its bandwith allowance for the month I started using flikr for the last few posts but I'm really not getting along with it. anyone have any any ideas on a new hosting site for the pictures?
#177 | |
Is a cackling Yuletide Belgian
__________________
#178 |
Minimodder
Damn that's nice.
#179 | |
Supermodder
Do you post tweets on twitter or hoots on hooter?
__________________
#180 |
Allons-y!
You could use Bit-Tech's hosting.
__________________
AMD Phenom X4 9650 [2.7GHz] | Nvidia GeForce GTX 560ti | 4GB GSKILL DDR2 800 | Gigabyte GA-MA780G-UD3H
______________________________________ Zotac ION-ITX-A-U | 2GB A-Data DDR2 800 |
| Thread Tools | |
| View Mode | |
