Go Back   bit-tech.net Forums > Modding > Modding
Reply
Thread Tools View Mode
Old 20th Jan 2010, 19:18   #1
Teek5449
What's a Dremel?
Teek5449 has yet to learn the way of the Dremel
Relocating indicator lights and power button question.
I have a quick question that a quick search yielded no results. I would like to relocate the HDD led, power led, power switch , and reset switch to an alternate location and was wondering how far, length wise, is it possible to wire them? For example I would like to move them outside my case and inside a project enclosure that would sit on top of my desk resulting in maybe a four foot wire length, is this doable? I know there is a voltage drop over copper line and I would never imagine this working over great distances but a small increase seems possible without any negative consequences. Has anyone done this before?
Thanks for your replies
Teek5449 is offline   Reply With Quote
Old 20th Jan 2010, 21:45   #2
Teek5449
What's a Dremel?
Sounds like what I was thinking, no issues... thank you for your quick reply.
Reply
Tags
hdd, led, length, power, wire
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
