Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 1st Feb 2010, 14:26   #1
Cutter McJ1b
Home-cut jibs at discount Prices
Cutter McJ1b's Avatar
Cutter McJ1b has yet to learn the way of the Dremel
My Experience With Jailbreaking So Far
Cutter McJ1b is offline   Reply With Quote
Old 1st Feb 2010, 14:56   #2
bodkin
Overheating
bodkin's Avatar
bodkin is the Cheesecake. Relix smiles down upon them.bodkin is the Cheesecake. Relix smiles down upon them.bodkin is the Cheesecake. Relix smiles down upon them.bodkin is the Cheesecake. Relix smiles down upon them.bodkin is the Cheesecake. Relix smiles down upon them.bodkin is the Cheesecake. Relix smiles down upon them.bodkin is the Cheesecake. Relix smiles down upon them.bodkin is the Cheesecake. Relix smiles down upon them.bodkin is the Cheesecake. Relix smiles down upon them.bodkin is the Cheesecake. Relix smiles down upon them.bodkin is the Cheesecake. Relix smiles down upon them.
One major problem I have noticed on both my 3G and 3GS is that jailborken phones are far less stable and much more prone to the broken keyboard problem
bodkin is offline   Reply With Quote
Old 1st Feb 2010, 15:28   #3
yakyb
i hate the person above me
yakyb's Avatar
yakyb can run Crysisyakyb can run Crysisyakyb can run Crysisyakyb can run Crysisyakyb can run Crysisyakyb can run Crysisyakyb can run Crysisyakyb can run Crysisyakyb can run Crysisyakyb can run Crysisyakyb can run Crysis
very interesting the Bit have put this on their home page what are the moral / legal issues around jailbreaking as i bought an android specifically because it was a more open platform
yakyb is offline   Reply With Quote
Old 1st Feb 2010, 16:04   #4
Xir
I Mod, Therefore I Own
Xir's Avatar
Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.
Just make sure that if ever iTunes gives you the option to send information to Apple about what’s on your iPhone hard disk - such as the Apps Genius feature - choose No.
...are you sure it ALWAYS asks you before sending?
(just my Windows-paranoia talking here)
Xir
__________________
SN25P
A64 3700+ (San Diego)
2 GB DDR400 OCZ Platinum EL 2-3-2-5 1T
X1800XT 512mb Sapphire
200GB Samsung SP2004C 24" Asus VW246H 1920x1080
Xir is offline   Reply With Quote
Old 1st Feb 2010, 16:10   #5
Cutter McJ1b
Originally Posted by Xir
Just make sure that if ever iTunes gives you the option to send information to Apple about whatÂ’s on your iPhone hard disk - such as the Apps Genius feature - choose No.
Xir
I jailbroke my new iPhone 3GS. It was the first time I'd plugged it in to my new PC. I got asked about Apps genius once, said no. I also turned off autosync. No problems at all so far.
Old 1st Feb 2010, 16:38   #6
Cutter McJ1b
Can't say I've had any issues with my keyboard...
Old 1st Feb 2010, 16:43   #7
Combatus
Bit-tech Modding + hardware reviews
Moderator
Combatus's Avatar
Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.
Err read paragraphs 7, 8, 9 and 10
__________________
My Mods Project: SFX | How to photograph your project | Join the Case Mod Index and WIN PRIZES!
Originally Posted by Mattmc91 View Post
Is the res loud, like, constantly making you need a piss loud?
Combatus is offline   Reply With Quote
Old 1st Feb 2010, 17:07   #8
Anfield
I *am* a Dremel
Anfield's Avatar
Anfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming Saiyan
So you have to "hack" a Iphone in order to be able to transfer files with drag and drop? lulz...
__________________
i7 6700k, Asus Maximus Gene VIII, 2x8GB Corsair Vengeance 3000 DDR4, Reference GTX 980Ti, 512GB Samsung 950 Pro, 4TB WD Black, Corsair H105, Corsair RM850i, Corsair Carbide Air 240.
Max Blackbird TKL Mech KB, Logitech G402, AOC U3477PQU (34" 21:9 ftw)
Anfield is offline   Reply With Quote
Old 1st Feb 2010, 17:51   #9
wuyanxu
still wants Homeworld 3
wuyanxu's Avatar
wuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyan
SBsetttings: i can't imagine ANYONE without it!
i won't recommend blackrain. it is jailbreak by fiddling with files through USB, with chances of messing up. use PwnageTool to create your own firmware, then use Apple's iTunes to write to the iPhone, nothing can go wrong
__________________
i7 2700k \ 16GB \ GTX 970 \ D2x \ Z68x-UD5 \ m4 128GB +2TB \ S12G-550 \ FT02-RW \ G15+G5+G51 \ U2711
X100 \ X-E2 \ 10-24 \ 55-200 \ 18/2 \ 60/2.4 \ Yn560 \ X1.1a \ Hadley Pro -- Photostreamr
wuyanxu is offline   Reply With Quote
Old 1st Feb 2010, 18:29   #10
yakyb
yakyb's Avatar
how the **** did i miss that
Old 1st Feb 2010, 19:05   #11
Sifter3000
I used to be somebody
Sifter3000's Avatar
Sifter3000 has yet to learn the way of the DremelSifter3000 has yet to learn the way of the DremelSifter3000 has yet to learn the way of the DremelSifter3000 has yet to learn the way of the DremelSifter3000 has yet to learn the way of the DremelSifter3000 has yet to learn the way of the DremelSifter3000 has yet to learn the way of the Dremel
Don't worry, it is a Monday
__________________
The Rt Hon Alex Watson.
Dennis Publishing Emerging Platforms, bit and CPC alumni.
My weblog is The Wired Jester.
Photos on Flickr.
Sifter3000 is offline   Reply With Quote
Old 1st Feb 2010, 21:50   #12
DeMoB
All of my Dremel wheels are broke!
DeMoB's Avatar
DeMoB has yet to learn the way of the Dremel
Originally Posted by wuyanxu View Post
i won't recommend blackrain. it is a tethered jailbreak with chances of messing up. use PwnageTool to create your own firmware, then use Apple's iTunes to write to the iPhone, nothing can go wrong
That's not really true now is it.
If you're stuck with a tethered jailbreak with blackra1n, you'll still be stuck with a tethered jailbreak with pwnage tool too. It's not down to the program you use to jailbreak, but rather if you've got an iphone with the new bootrom hardware. Which I think that was any made after oct 09.
As for anyone using the SBSettings with the default theme, do yourself a favour and grab the "Apple Congruency Black" theme for it. Looks as swish as the rest of the OS then.
Dan
DeMoB is offline   Reply With Quote
Old 1st Feb 2010, 22:09   #13
wuyanxu
wuyanxu's Avatar
Dan
sorry, i didn't mean tethered jailbreak, i mean messing with files through USB connection (hence confusion with the word "tether") creating an IPSW file and flashing the phone is as clean jailbreak as you can get.
__________________
Old 2nd Feb 2010, 10:43   #14
phuzz
This is a title
phuzz's Avatar
phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.
I jailbroke my work iPhone as soon as I got it (and uninstalled itunes as soon as it was activated).
Still glad I don't have to use one as my daily phone though, without Cydia/Jailbreaking then it would be almost un-customisable.
phuzz is offline   Reply With Quote
Old 2nd Feb 2010, 12:39   #15
kenco_uk
I unsuccessfully then tried again
kenco_uk's Avatar
kenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyan
I'm biting! I just need to know a few things...
I'm on o2 with the 3.1.2 phone firmware and 05.11 modem firmware. I don't want to unlock the carrier.
Can I just use redsn0w 0.9.2?
It says it requires a tethered reboot.. is that whenever the phone runs out of juice and reboots when it's got enough charge again? So I'd have to have it connected to a computer rather than the mains-usb adapter? And is that any computer or the one I ran redsn0w on?
Can I still use itunes as normal? I.e. podcasts, purchases, apps?
How do I uninstall it?
What happens if I upgrade to Apple's 3.1.3 firmware? Anything I need to do/make sure of beforehand?
__________________
formaggio gâteau
kenco_uk is offline   Reply With Quote
Old 2nd Feb 2010, 14:14   #16
Cutter McJ1b
Sadly, I'm unsure about a lot of this stuff as jailbreaking is still very new to me and I don't want to misinform. Perhaps someone else can help?
When I did it, I just plugged in my new iPhone and got stuck in.
Old 2nd Feb 2010, 14:50   #17
wuyanxu
wuyanxu's Avatar
if you upgrade to new firmware, you'll loose jailbreak, so wait until the dev-team have gotten a jailbreak before upgrading.
not sure about redsnow, i always use Pwnaget Tool which creates a custom firmware and there is no need to do a tethered reboot. best source and most reliable source for everything about jailbreaking: http://blog.iphone-dev.org/ (personally don't trust any other method of jailbreaking, that includes ZiPhone, blackra1n, redsnow.
__________________
Old 2nd Feb 2010, 16:21   #18
kenco_uk
kenco_uk's Avatar
I'm under the impression that pwnagetool is specifically for mac and that the same team that developed it are those that have released the windows version called redsn0w. Looking at the tut for installing redsn0w, it has (c) iphone dev team on the installer.
I can only find two 'Windows options' on iclarified - either redsn0w or BlackRa1n Link. BlackRa1n looks easier but there could be an issue with wifi suddenly not working (although for some people multiple resets or subjecting the rear of the iphone to freezing temperatures fixes it! - gps and youtube are fixable thru' Push It app) from what I read.
edit - wtf, each of the custom ipsw files I try to d/l are iphone1,2_3.1.2_7D11_Restore.zip - extracting the zip gives me 3 .dmg files and all bloody sorts.
ninja edit - ahh, I rename the file from .zip to .ipsw - correct? It's come up with the proper icon, at least!
__________________
formaggio gâteau
Old 2nd Feb 2010, 21:32   #19
wuyanxu
wuyanxu's Avatar
be careful, from the file name, it is for iPhone 3G, not 3GS.
pwnage tool is reliable because it fiddles with the file system on your computer, and then the pre-jailbroken, custom made firmware is flashed to the phone through relatively more reliable itunes.
__________________
Old 3rd Feb 2010, 05:35   #20
|V| 4 L k i 3 R
Supermodder
|V| 4 L k i 3 R has yet to learn the way of the Dremel
I've done it with Pwnage tool on my 3GS and with BlackRa1n on a 3G in order to get them on different carries while abroad. Both phones still work/sync flawlessly with iTunes.
__________________
Gaming - MSI P67A-GD53 (B3) |i5-2500k 3.3Ghz | Thermaltake Frio| 3x2Gb OCZ 1600 | 2 x Gigabyte GTX580 3Gb | Crucial M4 64Gb | 2 x Barracuda 1Tb | LG Bluray Drive | NZXT Phantom | Antec HCP-750 | Win7 Home Pre | Logitech G500 Mouse/G15 Keyboard/G27 Wheel| Onkyo HT-RC160 w/ Z-5500 satelite speakers | 2 x Dell U2711 | Gateway XHD3000 |
Portable - 17" MacBook Pro | LaCie 500Gb Firewire 800
Other - Linksys E2000 | ReadyNAS RNV2-S2 | 4 x 2Tb Seagate Barracuda | iPhone 3Gs 32Gb | iPad 3g 32Gb
|V| 4 L k i 3 R is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
