Reply
Thread Tools View Mode
Old 7th Mar 2010, 15:56   #21
Neji
Multimodder
Neji's Avatar
Neji has yet to learn the way of the Dremel
It actually looks great. Well done.
Neji is offline   Reply With Quote
Old 7th Mar 2010, 16:23   #22
slipperyskip
Member
slipperyskip's Avatar
slipperyskip - it's over 9000!!!!!!!!1!1!1!!!slipperyskip - it's over 9000!!!!!!!!1!1!1!!!slipperyskip - it's over 9000!!!!!!!!1!1!1!!!slipperyskip - it's over 9000!!!!!!!!1!1!1!!!slipperyskip - it's over 9000!!!!!!!!1!1!1!!!slipperyskip - it's over 9000!!!!!!!!1!1!1!!!slipperyskip - it's over 9000!!!!!!!!1!1!1!!!slipperyskip - it's over 9000!!!!!!!!1!1!1!!!slipperyskip - it's over 9000!!!!!!!!1!1!1!!!slipperyskip - it's over 9000!!!!!!!!1!1!1!!!slipperyskip - it's over 9000!!!!!!!!1!1!1!!!
Originally Posted by oldnewby View Post
The design calls for two fans but I wanted some chunky, fat turbine looking things.
I know I've seen these somewhere before but I can't remember, so props to who-
ever you are.
sunnyXtremist's Satella
Maybe this is the person you are thinking of. This is some of sunnyXtremist's work. I also like the look of this kind of modded fan.
I'm looking forward to watching this project.
__________________
slipperyskip.com
slipperyskip is offline   Reply With Quote
Old 7th Mar 2010, 17:33   #23
Xion X2
Multimodder
Xion X2's Avatar
Xion X2 has yet to learn the way of the Dremel
And the man who graces MDPC's latest masterpiece is already back in action.
Looks great so far, but I'm concerned about the weight of those hard drives hanging from the PCB and motherboard slot. You've reinforced the PCB except for the very bottom PCI-e connector which is a thin plastic. Two standard HDDs are heavier than any copper waterblock that I know of, so it would put a lot of stress on that piece.
Have I missed it, and are you somehow able to mount through the motherboard and into the standoffs/tray? It looks like you're using laptop drives (they look smaller) so maybe they are much lighter?
I'm amazed that you're able to get such quality out of mostly hand tools such as your hacksaw. This pic here is incredible.
__________________
Project: r e f l e X i o n
Sponsored by: MNPCTech | DangerDen | Lamptron | Performance PCs
Xion X2 is offline   Reply With Quote
Old 7th Mar 2010, 17:36   #24
dakota67
SOUTH DAKOTA MODDER!!!
dakota67's Avatar
dakota67 has yet to learn the way of the Dremel
Amazing work! Awesome.
dakota67 is offline   Reply With Quote
Old 8th Mar 2010, 01:02   #25
shakka65
Multimodder
shakka65 has yet to learn the way of the Dremel
He'ssss Back! When I came here today and saw that you were back modding, it sure made my day. I was very thrilled. I really enjoyed reading your logs. Your work is so good it looks factory made and not by hand. Let me say that you are definitely off to a great start.
shakka65 is offline   Reply With Quote
Old 8th Mar 2010, 01:16   #26
Attila
still thinking....
Attila's Avatar
Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.
Thanks a lot guys.
It turned out an easy matter to balance the fans. I have an action shot but have
refrained from posting it due to the "safety first backlash".
But while I was doing this my mind drifted back to before I started making the fans.
Back to when I was trying to source materials for making the nose. The first place I went to was the local RC hobby store because I was after those spinners they put on the nose of RC
aircraft. This shop only had three examples and none were the right size, so I found the foam
eggs and yadda yadda ya. Well, I decided to look further afield and found, about 35km's
away, a really big hobby store that had a box full of spinners. Sorting through all the stuff I
found four examples of what was needed(45mm diameter). So now all doubt has gone and
I'm very happy with what will be possible with these.
You have to agree these are pretty sweet.
This project will have a color scheme. So a couple of colors will be tried.
And while the fans were being primered, colored, and clear coated, the second frame had
to be made.
A coat of primer after initial filling shows up areas that need more attention.
My desk looks like a scene from "Earth versus flying saucers".
Be still my beating heart.
__________________
stillthinking
Attila is offline   Reply With Quote
Old 8th Mar 2010, 12:25   #27
prettynifty
What's a Dremel?
prettynifty has yet to learn the way of the Dremel
wicked
Hello oldnewby,
I loved your Cygnus X1 mod. But is looking good as well
definitely subbed,
Prettynifty
prettynifty is offline   Reply With Quote
Old 8th Mar 2010, 19:50   #28
craigbru
Now... with more CNC!
craigbru's Avatar
craigbru has yet to learn the way of the Dremelcraigbru has yet to learn the way of the Dremel
Oh man, what a great start! Good to see you back at it!
__________________
Originally Posted by disturbed13
'to cram everything in the box, you must think outside the box'
craigbru is offline   Reply With Quote
Old 8th Mar 2010, 20:15   #29
KrunchR
Supermodder
KrunchR's Avatar
KrunchR is almost as Godly as yodasarmpitKrunchR is almost as Godly as yodasarmpitKrunchR is almost as Godly as yodasarmpitKrunchR is almost as Godly as yodasarmpitKrunchR is almost as Godly as yodasarmpitKrunchR is almost as Godly as yodasarmpitKrunchR is almost as Godly as yodasarmpitKrunchR is almost as Godly as yodasarmpitKrunchR is almost as Godly as yodasarmpitKrunchR is almost as Godly as yodasarmpitKrunchR is almost as Godly as yodasarmpit
Awesome work. Will be watching closely
KrunchR is offline   Reply With Quote
Old 8th Mar 2010, 21:10   #30
Dot_Kappa
100% Puppet
Dot_Kappa's Avatar
Dot_Kappa has yet to learn the way of the Dremel
It's simply F-A-N-T-A-S-T-I-C the way you transform common objects into special one !!!!!
The foam easter gave me an idea
Great modder
Dot_Kappa is offline   Reply With Quote
Old 8th Mar 2010, 21:28   #31
p0Pe
gief cake?
p0Pe's Avatar
p0Pe is definitely a rep cheat.p0Pe is definitely a rep cheat.p0Pe is definitely a rep cheat.p0Pe is definitely a rep cheat.p0Pe is definitely a rep cheat.p0Pe is definitely a rep cheat.p0Pe is definitely a rep cheat.p0Pe is definitely a rep cheat.p0Pe is definitely a rep cheat.p0Pe is definitely a rep cheat.p0Pe is definitely a rep cheat.
you got me hooked man! that harddrive pci-e thing beats ANY Z-drive outthere in looks!
cant wait to see what you comes up with of ideas with this one. your cygnus X1 build was mindblowing
p0Pe is offline   Reply With Quote
Old 13th Mar 2010, 10:05   #32
Attila
still thinking....
Attila's Avatar
I'm not really happy with theses square frames. You see the internal frame has some
very interesting shapes and having these big, square blocks sitting on the front just
doesn't cut it. So with that in mind I went hunting for something that comes close to the
picture in my mind. It still has to be fat and chunky just not square.
And I found these PVC plumbing bushes.
It looks quite good, with segments that look like cooling slots, and it's made from thick
and solid material. But there are some problems. The internal diameter is only 110mm and
the old frames have a diameter of 116.85mm. There is also a lip on the inside on one side.
But I need to get a look at what this could look like with a fan inside. So the quickest way
to do this is to reduce the fan diameter. So I first used an old fan.
OK this doesn't look bad but I'm still not won over. So lets get a look at this with another old
fan and a spinner.
Meh! I quickly sprayed the fan silver.
Back soon.
__________________
stillthinking
Old 13th Mar 2010, 19:07   #33
Boddaker
TRON CAT!
Boddaker's Avatar
Boddaker is definitely a rep cheat.Boddaker is definitely a rep cheat.Boddaker is definitely a rep cheat.Boddaker is definitely a rep cheat.Boddaker is definitely a rep cheat.Boddaker is definitely a rep cheat.Boddaker is definitely a rep cheat.Boddaker is definitely a rep cheat.Boddaker is definitely a rep cheat.Boddaker is definitely a rep cheat.Boddaker is definitely a rep cheat.
Great job on the fans Attila. Are you planning on doing anything about the stock propeller slots in the nose cones? You could easily glue in a patch and use filler to smooth it out. Although I guess they won't be too noticeable with the fans spinning lol.
I really like the chrome trim ring in between the fan and nose tho!
__________________
www.bods-mods.com
Originally Posted by my brother
Is the name "Neptune's Trident" something you came up with? I can't see how a planet and chewing gum are related.
Boddaker is offline   Reply With Quote
Old 13th Mar 2010, 19:31   #34
stonedsurd
Is a cackling Yuletide Belgian
stonedsurd's Avatar
stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.
I was going to mention that too. Really like the new spinners, the sharper point is nicer than the eggshells. I still can't get over the way you've made these fans.
__________________
stonedsurd is offline   Reply With Quote
Old 13th Mar 2010, 22:34   #35
Mankz
5318008
Mankz's Avatar
Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.
Okay, how did I manage to miss this??
Mankz is offline   Reply With Quote
Old 13th Mar 2010, 23:21   #36
jhanlon303
The Keeper of History
jhanlon303's Avatar
jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.
I need to get on line more! This is quite the start. Fat fans are neat and the siding covers are a novel idea. I drop in from time to time for sure.
john
__________________
Coming to a forum near you. January 2014.
jhanlon303 is offline   Reply With Quote
Old 14th Mar 2010, 00:06   #37
Asulc
Supermodder
Asulc's Avatar
Asulc has yet to learn the way of the Dremel
Those fans look amazing... and the hard drive mounting? spectacular...
__________________
~Asulc~
Mac G5 Case Mod
Asulc is offline   Reply With Quote
Old 14th Mar 2010, 04:00   #38
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming Saiyan
Sweeeeeeet! I have to say leave the holes in the cones. It would be a waste to hide the pornographic milled aluminum.
__________________
The Iron Turnip·BlooBalls·Hypnotoad·Plank·Reservoir-Things·NUC-Tooobular·C7Waterblocks·Crusty McBeanbags III·GlassGreen
Powered by: AMD·Gigabyte·Swiftech·Hardware Labs·Noctua·DangerDen
Cheapskate is offline   Reply With Quote
Old 14th Mar 2010, 10:15   #39
ringo
Supermodder
ringo has yet to learn the way of the Dremel
The new design design of the fan's look much better than the first one.
ringo is offline   Reply With Quote
Old 14th Mar 2010, 19:12   #40
Cleveland216
Carbon Fiber King
Cleveland216 has yet to learn the way of the DremelCleveland216 has yet to learn the way of the DremelCleveland216 has yet to learn the way of the DremelCleveland216 has yet to learn the way of the DremelCleveland216 has yet to learn the way of the DremelCleveland216 has yet to learn the way of the Dremel
Damn you!!! You make me want to throw my current build on the floor and start all over again. You have some great little ideas when it comes to mounting and stuff.
Cleveland216 is offline   Reply With Quote
Reply
Tags
aluminium, oldnewby
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
