Reply
Thread Tools View Mode
Old 20th Mar 2010, 21:51   #61
brinkz0r
Hypermodder
brinkz0r's Avatar
brinkz0r has yet to learn the way of the Dremel
The other one being his previous case
__________________
My casemodding company: Brink of Modding
My latest casemod: miXture
Custom reservoirs and more: Phase 2 Casemodding
brinkz0r is offline   Reply With Quote
Old 22nd Mar 2010, 04:42   #62
shazza
What's a Dremel?
shazza has yet to learn the way of the Dremel
Just amazing to watch this come together - wonderful stuff!!!
shazza is offline   Reply With Quote
Old 22nd Mar 2010, 16:12   #63
Xion X2
Multimodder
Xion X2's Avatar
Xion X2 has yet to learn the way of the Dremel
Excellent work on the mobo tray. You do some great work with files. I also like that you're bringing something new to fans as I tire of their usual cheap, redundant look. Those will look really nice.
__________________
Project: r e f l e X i o n
Sponsored by: MNPCTech | DangerDen | Lamptron | Performance PCs
Xion X2 is offline   Reply With Quote
Old 22nd Mar 2010, 20:28   #64
talladega
I'm Squidward
talladega's Avatar
talladega is a hoopy frood who really knows where their towel is.talladega is a hoopy frood who really knows where their towel is.talladega is a hoopy frood who really knows where their towel is.talladega is a hoopy frood who really knows where their towel is.talladega is a hoopy frood who really knows where their towel is.talladega is a hoopy frood who really knows where their towel is.talladega is a hoopy frood who really knows where their towel is.talladega is a hoopy frood who really knows where their towel is.talladega is a hoopy frood who really knows where their towel is.talladega is a hoopy frood who really knows where their towel is.talladega is a hoopy frood who really knows where their towel is.
looks like another MOTY award for you......
__________________
"...clearly poop is not nutritious and it tastes bad." -Bindibadgi
"Get off... my... property!"
-Clint Eastman, in Grand Tornado
talladega is offline   Reply With Quote
Old 24th Mar 2010, 07:40   #65
Attila
still thinking....
Attila's Avatar
Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.
Having settled on the PVC bushings for the fan bodies, some supports needed to be made to hold the fan motors.
These are marked up and cut from 3mm sheet.
With the fan motor mounts cut and fixed to the fan body, they can be filed to better fit the curves of the body.
Back soon.
__________________
stillthinking
Attila is offline   Reply With Quote
Old 24th Mar 2010, 08:34   #66
KrunchR
Supermodder
KrunchR's Avatar
KrunchR has yet to learn the way of the Dremel
Awesome.
KrunchR is online now   Reply With Quote
Old 24th Mar 2010, 23:32   #67
500mph
The Right man in the Wrong place
500mph's Avatar
500mph has yet to learn the way of the Dremel500mph has yet to learn the way of the Dremel500mph has yet to learn the way of the Dremel500mph has yet to learn the way of the Dremel
I like your metal work, keep it up!
__________________
Rocketfeesh Emergen-C!
[Web][Twitter][Steam]
500mph is offline   Reply With Quote
Old 25th Mar 2010, 00:07   #68
Boxcarr
Will use any tool available.
Boxcarr has yet to learn the way of the Dremel
Originally Posted by shakka65 View Post
The MB plate looks totally awesome. It seems as if it was done on a Mill.
^ fixed that for ya'
Excellent handiwork there newb. I really like how this build is coming together as well. Might I guess that your avatar is a particular angle of the new build?
Boxcarr is offline   Reply With Quote
Old 25th Mar 2010, 01:00   #69
wahoomcdaniel
Multimodder
wahoomcdaniel has yet to learn the way of the Dremel
My first thought when I saw the photo of the hole saw drilling into the 8mm aluminum was, "Oh no, he took apart Cygnus and is using the wood as a drilling platform."
wahoomcdaniel is offline   Reply With Quote
Old 25th Mar 2010, 05:33   #70
Attila
still thinking....
Attila's Avatar
The fans will be mounted to a front panel and this panel is the last large aluminium part. It's 8mm and will form only about half of the front panel.
All the straight edges are filed true first.
And then the cut-outs for the fan bodies are sanded down until the bodies fit tightly.
Nearly there.
And how they will look.
Back soon.
__________________
stillthinking
Old 25th Mar 2010, 06:37   #71
Bullitdodger
If it ain't broke....Tweak it.
Bullitdodger's Avatar
Bullitdodger has yet to learn the way of the Dremel
The new piece looks like a giant "sword handle".....If that is the correct term?
__________________
Argueing on the internet, is like running in the special olympics.
Even if you win, you're still retarded....
Bullitdodger is offline   Reply With Quote
Old 25th Mar 2010, 18:07   #72
SNiiPE_DoGG
Engineering The Extreme
SNiiPE_DoGG's Avatar
SNiiPE_DoGG has yet to learn the way of the DremelSNiiPE_DoGG has yet to learn the way of the DremelSNiiPE_DoGG has yet to learn the way of the Dremel
I believe hilt is the word your looking for, but yeah I see that now that you mention it
__________________
[Project] :::Mil-Spec::: @ Bit-Tech
[Project] :::Flow::: @ Bit-Tech MOTY Second Prize
|CPU: PHII 955 BE @ 3.8ghz | GPU: 2 x 4890 XXX @ 950 | 8gb Crucial ballistix tracer DDR3 1600 CL8|
SNiiPE_DoGG is offline   Reply With Quote
Old 25th Mar 2010, 19:35   #73
shomann
Supermodder
shomann's Avatar
shomann has yet to learn the way of the Dremel
How in the holy hell did I miss the first 6 weeks of this build?!
Not sure about anyone else, but I am digging that while its obvious he has plans (and he teases us a bit with them in the photography), he isn't throwing the design up first. The journey is half the fun right?
  • Love the hard drive mount/solution
  • Love the metal work (as always, and jealous too)
  • Love that you sold the case and some gear for an upgraded drill press. (I mean really, if you can build things like CX1 from scratch, what would you EVER need with a stock case, even one as nice as the Corsair ?)
  • LOVE that the metal thickness is going up. The next build will probably be just be an armored sphere 20mm thick.
  • Hate that we have to wait for art.
__________________
Project: Nomad
Notebook: Apple 15" MBP 2010 i5/128SSD/320 Optibay conversion
NAS: Jetway JNC62K | AMD 4850e 2.5 GHz AM2 | 2GB RAM | 2.7 TB RAID-5 - OFFLINE, EVALUATING
shomann is offline   Reply With Quote
Old 25th Mar 2010, 19:36   #74
Bullitdodger
Right on the money.....Just the word I was looking for. I remember the german industrial band "Die Krupps" had a hit called "To The Hilt"
The worst video ever, but a cool song. http://www.dailymotion.com/video/x2s...the-hilt_music
__________________
Old 25th Mar 2010, 21:56   #75
Attila
still thinking....
Attila's Avatar
To tie the front and rear together, I'm going to use some 20mm clear acrylic.
Once this is cut and filed, it's drilled and tapped for location at the top of the chassis. M4 countersunk screws are used here.
__________________
stillthinking
Old 25th Mar 2010, 22:28   #76
Locknload
Multimodder
Locknload has yet to learn the way of the Dremel
Hi Atilla,
Its great to see you back here with yet another mouthwatering build.
Congratulations on the success of Cygnus, it was truly worthy of the praise and adoration and was a glowing testament to your patience and skill.
I noticed that wood also that you were using for a drill press bench, and I recognised it from Cygnus.
I think you should combine it with some Aluminium and make a keyboard for Cygnus...lol
Look forward to seeing you toil in the workshop again this Year, good luck with the build.
Locknload is offline   Reply With Quote
Old 26th Mar 2010, 04:09   #77
shomann
Supermodder
shomann's Avatar
Originally Posted by oldnewby View Post
@shomann Thanks mate It's been a long time since I saw any progress
on your build.
Oh crap...I think I was just called out
Its been 5 months to be exact. No excuses seem appropriate, but the project is not dead.
__________________
Project: Nomad
Old 26th Mar 2010, 05:34   #78
Attila
still thinking....
Attila's Avatar
The case will be supported by four struts terminating in some turned pads (feet). Below is the original SU design.
A template was made from the SU measurements. And then transferred to the bar.
And then the struts are cut from 12mm x 40mm bar. This was quite difficult because of the small size.
I first made one strut (roughly) to get a look at it in place.
And with a disc to get a rough idea with a pad.
Hmmm, not bad.
__________________
stillthinking
Old 26th Mar 2010, 06:20   #79
MikeMania
Multimodder
MikeMania has yet to learn the way of the Dremel
Oh man, I kept away from this thread because I thought it was some sort of fantasy LoTR mod. Then I saw who the author was.
As expected, completely amazinggg.
MikeMania is offline   Reply With Quote
Old 26th Mar 2010, 08:19   #80
oliverw92
Supermodder
oliverw92's Avatar
oliverw92 has yet to learn the way of the Dremeloliverw92 has yet to learn the way of the Dremel
This is nuts! Nice job newby
oliverw92 is offline   Reply With Quote
Reply
Tags
aluminium, oldnewby
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
