#81 |
Supermodder
Wonderful work, as usual.
#82 | |
If it ain't broke....Tweak it.
Was that intentionel, or just one of those things?http://en.wikipedia.org/wiki/Iota_Orionis
__________________
Argueing on the internet, is like running in the special olympics. Even if you win, you're still retarded.... Last edited by Bullitdodger; 26th Mar 2010 at 08:40. Reason: typo |
#83 |
Custom PC/bit-tech modding sections
Hopefully the core components will be with you soon! Intel thought they'd sent the CPU, our calls to Gigabyte went unanswered as our contact had left and the HD 5870 was my fault
It had been sitting in out lab for 3 weeks! 5870 is on it's way and we've chased up Gigabyte and Intel! Should be with you soon!
__________________
My Mods Project: SFX | How to photograph your project | Join the Case Mod Index and WIN PRIZES! | Mod of the Month March 2013 is here! Vote now! |
#84 |
still thinking....
Continuing on with the struts, the rest are cut and then roughly ground down as a group with an angle grinder.
![]() ![]() And after some more filing........ ![]() ![]() Still the early stages for these parts. ![]()
__________________
stillthinking Last edited by Attila; 25th Mar 2013 at 23:02. |
#85 |
still thinking....
The next step is to fix the struts to the lower main support. This is accomplished with two M4 socket head screws for each strut.
![]() Once the holes are drilled, they are then counter bored to take the heads of the screws. ![]() Then the struts are drilled and tapped. ![]() ![]() And fitted. ![]() ![]() ![]() ![]() ![]() Back soon.
__________________
stillthinking Last edited by Attila; 25th Mar 2013 at 23:54. Reason: photobucket f**k up. |
#86 |
Avoiding the "I guess.." since 2004
Not only is it shaping up to be another great project from you, it's also an awesome testimony to what can be done with a proper bench press and a jig saw
__________________
Half a dozen operational setups and truckloads of spare parts.
AllTheMods - MetkuMods - LedCalc - Flickr - BF:BC2 |
#88 |
Packaging Master!
good god man!! I love working with ally. But how do you file so straight? Vertically i mean? Horizontally i just use a piece of stainless steel along the line and stop filing when the sound changes. Also, a bit late, but well done on Cygnus X1. You inspire me to seek perfection in my build.
#89 |
Reformed Grumpy Sod..kinda
Remarkable this is. I will watch this mod with interest. Amazing work oldnewby!
__________________
-Banana in disc drive error- To win the battle, is to be prepared to die - Miyamoto Musashi |
#90 |
What's a Dremel?
Just amazed at your ability with the jigsaw - especially on 6mm AL. Wow!
#91 |
Engineering The Extreme
What alloy is this? 6061, 5052 or something else? seems to have a duller sheen than the 6061 that I've used so I doubt it's that.
great work as always
__________________
[Project] :::Mil-Spec::: @ Bit-Tech [Project] :::Flow::: @ Bit-Tech MOTY Second Prize ![]() |CPU: PHII 955 BE @ 3.8ghz | GPU: 2 x 4890 XXX @ 950 | 8gb Crucial ballistix tracer DDR3 1600 CL8| |
#92 |
Supermodder
Stunning work with a jigsaw!
#93 |
↓ Don't trust that face!
This thread makes my brain all tingly.
I have all kinds of crazy ideas thanks to you.Everyone, Commence rep bombing!
__________________
#94 | |
Is a cackling Yuletide Belgian
Bombing completed skipper!
__________________
My Flickr
#95 |
still thinking....
Now some of you may have noticed the gap between the rear support (mobo tray support) and the front fan carrier/panel. This is the area that will take the conduit to take all the cables from the PSU to the motherboard and graphics card.
The main component for this is a U channel I found in the offcuts bin at my aluminium vendor. It's powder coated white, but I'll get rid of this later. ![]() Once cut to the correct length, it goes here. ![]() Using an old PSU I can map how the cables will run, and make cut-outs accordingly. ![]() And various areas removed. ![]() ![]() The first cut outs are made to clear the fan bodies. ![]() Back soon.
__________________
stillthinking Last edited by Attila; 26th Mar 2013 at 00:06. Reason: photobucket f**k up. |
#97 |
Packaging Master!
Oldnewby, i have no words. Thank you so much!!! I've never seen work like this in my life.... arghh struggling to find the right words to describe this....amazing...
Neal |
#98 |
Supermodder
Thanks for the tutorial! I took notes. Of course, now I have to go clean up some of my previous work, but whatever
__________________
Project: Nomad Notebook: Apple 15" MBP 2010 i5/128SSD/320 Optibay conversion NAS: Jetway JNC62K | AMD 4850e 2.5 GHz AM2 | 2GB RAM | 2.7 TB RAID-5 - OFFLINE, EVALUATING |
#99 | |
Packaging Master!
#100 |
Is the daddy!
that's not hard, waterjets make a royal mess of edges.
My favourite file is the *******, never leaves my side when modding.
__________________
Project log Mocha70 Workstation: Q6600, DFI P45-T2RS Plus, 8GB Reaper HPC, Quadro FX3450, 60Gb Vertex 2 Game: i7 930, GA-X58-USB3, 12GB Kingston, GTX280, 1Tb Seagate, WC
| Tags |
| aluminium, oldnewby |
| Thread Tools | |
| View Mode | |
