Reply
Thread Tools View Mode
Old 2nd Apr 2010, 12:24   #101
Attila
still thinking....
Attila's Avatar
Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.
Before continuing, I decided to fit the PSU and motherboard that will actually be used.
The only to do here is to tap the threads to takeM4 screws. Care needs to taken not to leave any small bits of metal loose inside the PSU.
These screws will be replaced with countersunk ones later.
Once fitted, the PSU just 'hangs'.
__________________
stillthinking
Attila is offline   Reply With Quote
Old 2nd Apr 2010, 12:26   #102
Burnout21
Is the daddy!
Burnout21's Avatar
Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.
Originally Posted by oldnewby View Post
You know, sometimes I just don't get it. I can't write the word b*****d or s**t but
a drawing of a girl blowing a guy on the front page of the forums is OK.
not sure where you saw that image, lol!
__________________
Project log Mocha70
Workstation: Q6600, DFI P45-T2RS Plus, 8GB Reaper HPC, Quadro FX3450, 60Gb Vertex 2
Game: i7 930, GA-X58-USB3, 12GB Kingston, GTX280, 1Tb Seagate, WC
Burnout21 is offline   Reply With Quote
Old 2nd Apr 2010, 12:56   #103
Attila
still thinking....
Attila's Avatar
As well as the conduit to run the cables, there will be a compartment in front of the power supply. This will hide the cables coming out of the PSU, but the two hard drives will also go in here. I'm going to make this follow the shape of the lower support rather than imitate the square shape of the power supply.
To start off, a pattern is made from plastic sheet.
This is then transferred to aluminium sheet.
__________________
stillthinking
Old 2nd Apr 2010, 15:08   #104
craigbru
Now... with more CNC!
craigbru's Avatar
craigbru has yet to learn the way of the Dremelcraigbru has yet to learn the way of the Dremel
bumrush's photo on the bottom of the forum main page.
Lol, am I the only one that backed out of this thread just to go check?
__________________
Originally Posted by disturbed13
'to cram everything in the box, you must think outside the box'
craigbru is offline   Reply With Quote
Old 2nd Apr 2010, 15:53   #105
Der-Dom
Silent reader
Der-Dom has yet to learn the way of the Dremel
No, you're not
Der-Dom is offline   Reply With Quote
Old 2nd Apr 2010, 22:16   #106
nlancaster
Multimodder
nlancaster has yet to learn the way of the Dremel
diffinatly not.....
wonder if he has more......
*$&# did i say that outloud?!?!
nlancaster is offline   Reply With Quote
Old 3rd Apr 2010, 00:17   #107
Xion X2
Multimodder
Xion X2's Avatar
Xion X2 has yet to learn the way of the Dremel
Thanks for sharing your filing techniques. +rep.
__________________
Project: r e f l e X i o n
Sponsored by: MNPCTech | DangerDen | Lamptron | Performance PCs
Xion X2 is offline   Reply With Quote
Old 3rd Apr 2010, 06:22   #108
Attila
still thinking....
Attila's Avatar
Continuing on with the hard drive compartment, a small part is made for the back. The bends are made but using various set-ups in the vice.
This part is trimmed to fit around the lower corner of the motherboard.
__________________
stillthinking
Old 3rd Apr 2010, 08:24   #109
[ZiiP] NaloaC
I Mod, Therefore I Own
[ZiiP] NaloaC's Avatar
[ZiiP] NaloaC - it's over 9000!!!!!!!!1!1!1!!![ZiiP] NaloaC - it's over 9000!!!!!!!!1!1!1!!![ZiiP] NaloaC - it's over 9000!!!!!!!!1!1!1!!![ZiiP] NaloaC - it's over 9000!!!!!!!!1!1!1!!![ZiiP] NaloaC - it's over 9000!!!!!!!!1!1!1!!![ZiiP] NaloaC - it's over 9000!!!!!!!!1!1!1!!![ZiiP] NaloaC - it's over 9000!!!!!!!!1!1!1!!![ZiiP] NaloaC - it's over 9000!!!!!!!!1!1!1!!![ZiiP] NaloaC - it's over 9000!!!!!!!!1!1!1!!![ZiiP] NaloaC - it's over 9000!!!!!!!!1!1!1!!![ZiiP] NaloaC - it's over 9000!!!!!!!!1!1!1!!!
By the mod gods....
First CygnusX1 blew my mind, and now this.
Some may argue, "ah sure, it's not all that pimpin" but when you consider that this is done by hand, it is simply stunning and your skills are beyond repute.
Keep up the excellent work fella
__________________
ZiiP Gamestore
[ZiiP] Gaming Community - IW BlackMailers and loonies abound!
Sui Generis: i7 920, Corsair H50, 6GB Dominator C7 1600, EVGA x58 SLI LE, Corsair F3 120GB SSD, Samsung F3, Sapphire 5870 Vapor-X, Corsair HX850W, Corsair Obsidian 800D, Iiyama 26" Prolite, Logitech G15, Logitech G5, Sennheiser PC350.
[ZiiP] NaloaC is offline   Reply With Quote
Old 3rd Apr 2010, 09:45   #110
stonedsurd
Is a cackling Yuletide Belgian
stonedsurd's Avatar
stonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for president
Having used M4 almost exclusively for everything in the past, I now find that M3 does the job just as well and is much easier on the eyes (by virtue of being smaller, of course).
Lookin' good
__________________
My Flickr
Originally Posted by specofdust View Post
You don't believe people can be trusted to be exposed to ideas, to thought, to expression. I choose to say that even if people can't be trusted, it's moral that they should be, because I have no right to elevate myself above them and decide on their behalf what they should be exposed to, because that is authoritarian, discriminatory, and wrong.
stonedsurd is offline   Reply With Quote
Old 3rd Apr 2010, 16:23   #111
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for president
Oh, that looks soooo goooood. You were worried about the back looking boxy. Just hinge a radiator off of it at an odd angle.
Cheapskate is offline   Reply With Quote
Old 3rd Apr 2010, 17:12   #112
Jipa
Avoiding the "I guess.." since 2004
Jipa's Avatar
Jipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run Crysis
Quite likely going to be the heaviest aluminum case.... in the world.
__________________
Half a dozen operational setups and truckloads of spare parts.
AllTheMods - MetkuMods - LedCalc - Flickr - BF:BC2
Jipa is offline   Reply With Quote
Old 3rd Apr 2010, 19:04   #113
skreenname
Allons-y!
skreenname's Avatar
skreenname has yet to learn the way of the Dremel
You're seriously too great at this.
Every time I see something you do It makes me wanna start working on a new computer.
Which is bad since I don't really have the money to do that.
__________________
AMD Phenom X4 9650 [2.7GHz] | Nvidia GeForce GTX 560ti | 4GB GSKILL DDR2 800 | Gigabyte GA-MA780G-UD3H
______________________________________
Zotac ION-ITX-A-U | 2GB A-Data DDR2 800
skreenname is offline   Reply With Quote
Old 4th Apr 2010, 01:08   #114
Krog_Mod
Supermodder
Krog_Mod's Avatar
Krog_Mod has yet to learn the way of the DremelKrog_Mod has yet to learn the way of the DremelKrog_Mod has yet to learn the way of the DremelKrog_Mod has yet to learn the way of the Dremel
Wonderful work! I can't wait to see how this will look when you do wet sand the parts.
I do cringe every time I go through and look at this because that graphics card that you used was better than my current one... (I'm still on AGP8x, I'm saving up for the upgrade..)
Krog_Mod is offline   Reply With Quote
Old 4th Apr 2010, 05:37   #115
Attila
still thinking....
Attila's Avatar
The next part of this area is the outside wall of the wiring/drive compartment.
This will follow the shape of the lower main support. I'm using 1.6mm sheet here and to get the curve, I'll be using a small set of curving rolls just purchased off ebay.
The first bend can't be done in the brake so it's done on the bench.
The last bend can be made in the brake.
And it goes here.
In reality it took a couple of attempts to get it right.
__________________
stillthinking
Old 4th Apr 2010, 14:45   #116
ringo
Supermodder
ringo has yet to learn the way of the Dremel
Amazing work.
ringo is offline   Reply With Quote
Old 4th Apr 2010, 17:44   #117
Burnout21
Is the daddy!
Burnout21's Avatar
you forgot about Darkblade, now sit in the corner as you clearly forget to do your homework. lol!
__________________
Project log Mocha70
Old 4th Apr 2010, 18:04   #118
Skorchio
Supermodder
Skorchio's Avatar
Skorchio has yet to learn the way of the DremelSkorchio has yet to learn the way of the DremelSkorchio has yet to learn the way of the Dremel
Amazing workmanship
Skorchio is offline   Reply With Quote
Old 6th Apr 2010, 06:41   #119
Attila
still thinking....
Attila's Avatar
Now to hold the parts of the cable/drive compartment together, a joining piece needs to be made.
I'm using some 8mm plate for this.
A top is also made.
I also made a fixing support for the top, but ended up not using this.
__________________
stillthinking
Old 6th Apr 2010, 12:14   #120
oliverw92
Supermodder
oliverw92's Avatar
oliverw92 has yet to learn the way of the Dremeloliverw92 has yet to learn the way of the Dremel
That looks awesome! And it must be light if you are holding it with one hand!
oliverw92 is offline   Reply With Quote
Reply
Tags
aluminium, oldnewby
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
