Reply
Thread Tools View Mode
Old 6th Apr 2010, 12:37   #121
Attila
still thinking....
Attila's Avatar
Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.
Now these parts need to be fixed together. The outer dome heads will be replaced with countersunk screws later.
The next job is to make some more room for cables and bridge the gap between the main cable conduit and the motherboard tray.
So first a section is cut out.
And this is how it looks.
Then a supplementary cover is made from some channel.
And in place.
And the entire assembly.
And in place.
__________________
stillthinking
Attila is offline   Reply With Quote
Old 6th Apr 2010, 12:50   #122
KrunchR
Supermodder
KrunchR's Avatar
KrunchR has yet to learn the way of the Dremel
! awesome work.
KrunchR is offline   Reply With Quote
Old 6th Apr 2010, 19:04   #123
Odin Eidolon
Mad rockclimber
Odin Eidolon has yet to learn the way of the Dremel
Originally Posted by oliverw92 View Post
That looks awesome! And it must be light if you are holding it with one hand!
Option 2: I bet after that arm there is Schwarzenegger.
Odin Eidolon is offline   Reply With Quote
Old 9th Apr 2010, 01:30   #124
dakota67
SOUTH DAKOTA MODDER!!!
dakota67's Avatar
dakota67 has yet to learn the way of the Dremel
Awesome...........
dakota67 is offline   Reply With Quote
Old 9th Apr 2010, 05:27   #125
Aniki Stinson
In cornichons we trust.
Aniki Stinson's Avatar
Aniki Stinson has yet to learn the way of the Dremel
Originally Posted by oldnewby View Post
Two assumptions come to my mind:
  • 1. Your arm is very strong. You might be superman.
  • 2. The structure is very light. You might be supermodder.
I vote for both, with my two left hands in the air (put your hands up, put your hands up !).
Aniki Stinson is offline   Reply With Quote
Old 9th Apr 2010, 12:05   #126
Redkachina
Califragilistsic Expialidocious
Redkachina's Avatar
Redkachina has yet to learn the way of the Dremel
Your skills are very impressive..
when is the next update BTW..can't wait to see it
Redkachina is offline   Reply With Quote
Old 9th Apr 2010, 23:03   #127
nlancaster
Multimodder
nlancaster has yet to learn the way of the Dremel
The force is strong with this one.....
nlancaster is offline   Reply With Quote
Old 10th Apr 2010, 11:12   #128
Attila
still thinking....
Attila's Avatar
Now, to fit the fan bodies............
The fan bodies need to be fixed to the front panel securely and also with attention paid to keeping everything looking as clean as possible. In fact I settled on a system that employs two mounting blocks per fan, and these will be hidden in the main conduit channel. They will be screwed to the rear of the front panel via some blind threaded holes.
The mounting blocks are made from acrylic.
Shaped to fit...
And some gratuitous pics of the fan bodies fitted......
Whoops, accidentally drilled right through. Will bog up later.
__________________
stillthinking
Old 10th Apr 2010, 11:17   #129
p0Pe
gief cake?
p0Pe's Avatar
p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!
thoose hands, how do you program them? autocad or 3dmax?
great work man! amazing to see what one can do with manual tools and a file:
btw, countersunk them bitches
__________________
p0Pe is offline   Reply With Quote
Old 10th Apr 2010, 12:07   #130
brinkz0r
Hypermodder
brinkz0r's Avatar
brinkz0r has yet to learn the way of the Dremel
I'm glad you will be covering up all of those ugly fans, they get forgotten way too often
And @ p0Pe, see you no Wednesday
__________________
My casemodding company: Brink of Modding
My latest casemod: miXture
Custom reservoirs and more: Phase 2 Casemodding
brinkz0r is offline   Reply With Quote
Old 10th Apr 2010, 12:49   #131
Autti
Multimodder
Autti has yet to learn the way of the Dremel
All depends where the piece is going if you want to countersink them, although if the PVC stays its original colour i would say countersink as that bulky strong steel and bolts look just doesn't look right with pvc :P
Autti is offline   Reply With Quote
Old 10th Apr 2010, 19:26   #132
Evenge
Hypermodder
Evenge's Avatar
Evenge has yet to learn the way of the DremelEvenge has yet to learn the way of the Dremel
Yes! Even more aluminum!
__________________
Project: Discovery
Project: Strobe
Main: i5 2500K - 8GB - GTX570 - Win 7
Laptop: Asus U36SD - i5 2430M - 4GB - Win 8 Pro
Evenge is offline   Reply With Quote
Old 10th Apr 2010, 20:28   #133
AnG3L
Ultimate Modder
AnG3L's Avatar
AnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run Crysis
I really love to see modders work with bare hands and a lot of fantasy! Mod on man give us some aluminum pr0n!!!
AnG3L is offline   Reply With Quote
Old 10th Apr 2010, 23:44   #134
gvblake22
mmm, yep
gvblake22's Avatar
gvblake22 has yet to learn the way of the Dremel
Awesome metal work, can't wait to see more!
__________________
::: Phoenix ::: Secret of the Ooze ::: Blue Flame ::: Cavalier 3 ::: First Mod :::
gvblake22 is offline   Reply With Quote
Old 11th Apr 2010, 01:10   #135
Vardy
What's a Dremel?
Vardy has yet to learn the way of the Dremel
This is freaking insane. Keep up the great work.
Vardy is offline   Reply With Quote
Old 11th Apr 2010, 09:16   #136
Attila
still thinking....
Attila's Avatar
Thanks everyone.
Originally Posted by p0Pe View Post
snip...btw, countersunk them bitches
Originally Posted by Autti View Post
snip... i would say countersink
Oh all right!
For mounting the fans my plan calls for the fans to be bolted on only one side and having
half the fan body exposed. This is a bit risky as I don't know if this will hold them rigidly
enough, but just in case, and not to spend a long time making an idea that may not work,
I have a backup plan. If this method is not secure enough then I can make circular clamps to
hold them.
I need to use 8mm plate here because M4 bolts need to go through the edge and into the
fan bodies from the side.
Whew! Just in time to get out of the rain.
This parrot vice is terrific for larger pieces.
The cutouts are first filed and then hit (carefully) with the drum sander, and the part is
continually checked.
Nearly there.
And finished.
It's a nice snug fit so the fan body supports itself.
The little drum sander was so effective that the filing was skipped on the second one.
And we can get a look at the chassis evolving.
It's looking good but I think you all know by now that I may change or modify this part.
I can already see some things I want to change.
Back soon.
__________________
stillthinking
Old 11th Apr 2010, 09:29   #137
stonedsurd
Is a cackling Yuletide Belgian
stonedsurd's Avatar
stonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for president
You really like your dual intakes, huh?
I like how this is sort of hanging off one main structural member (the right side). I want to see what you'll do with the left side.
__________________
My Flickr
Originally Posted by specofdust View Post
You don't believe people can be trusted to be exposed to ideas, to thought, to expression. I choose to say that even if people can't be trusted, it's moral that they should be, because I have no right to elevate myself above them and decide on their behalf what they should be exposed to, because that is authoritarian, discriminatory, and wrong.
stonedsurd is offline   Reply With Quote
Old 11th Apr 2010, 09:46   #138
brinkz0r
Hypermodder
brinkz0r's Avatar
It will probably swing open, I kinda thinks he likes that
I have to say those intakes look awesome, this makes me want to go modding again
__________________
Old 11th Apr 2010, 10:28   #139
slipperyskip
Seemingly Disinterested
slipperyskip's Avatar
slipperyskip is a hoopy frood who really knows where their towel is.slipperyskip is a hoopy frood who really knows where their towel is.slipperyskip is a hoopy frood who really knows where their towel is.slipperyskip is a hoopy frood who really knows where their towel is.slipperyskip is a hoopy frood who really knows where their towel is.slipperyskip is a hoopy frood who really knows where their towel is.slipperyskip is a hoopy frood who really knows where their towel is.slipperyskip is a hoopy frood who really knows where their towel is.slipperyskip is a hoopy frood who really knows where their towel is.slipperyskip is a hoopy frood who really knows where their towel is.slipperyskip is a hoopy frood who really knows where their towel is.
Awesome work mate!
Now teach me how to pronounce it. I got NA-EAR-ALL-SAFE. Is that even close?
slipperyskip is offline   Reply With Quote
Old 11th Apr 2010, 10:47   #140
TonyL
modding on welfare
TonyL's Avatar
TonyL has yet to learn the way of the Dremel
__________________
PSU Connector Part Number Guide | Desk: i7-2600k, Asus Z68-V-Pro, G.Skill Ripjaw 4x4Gb, G/B GTX460, C400 60Gb, 2x 3TB, Fractal R3, Corsair AX850, 2xBenq 22" LCD | Server: Norco 4224, E3-1230, X9SCM-F, 4x4Gb ECC, 24x 2Tb
TonyL is offline   Reply With Quote
Reply
Tags
aluminium, oldnewby
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
