Old 17th Apr 2010, 06:52   #161
Attila
still thinking....
Attila's Avatar
Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.
Thanks everyone.
This part, the chassis, is actually slightly larger than the the chassis for CX1. This is due, among
other things, to the giant size of the GFX card.
I'm posting this now, even though just one of the struts isn't even complete, because making
four of these things will take a lot of time, so I won't be back for a while.
First a pattern needed to be made in some scrap alu, to transfer the design to the alu bar.
Much easier to cut the pieces with a power saw.
Then the design is tranfered over onto the bar.
A couple of guide holes drilled.
Now this thickness (12mm) is testing the limits of what I can cut with the jigsaw. The work-
piece is getting very hot and even a new blade lasts only a short time. The cut is very rough.
The filing is also very slow. About a third of the time is spent resting my right arm.
So having spent the whole of my available time on this, the first arm is not even close to
being finished but I can get a good look at how it goes with the rest of the chassis.
Well, I like the look of that very much. It's even concievable that no pads are needed thus
reducing the height a little. But I'll have to think about that a bit.
EDIT
I remembered the cut-outs for the rear support so I tried the large one for the pads.
It may be OK with large diameter, low profile pads. Hmmm.
Back soon.
__________________
stillthinking
Attila is offline   Reply With Quote
Old 17th Apr 2010, 06:55   #162
stonedsurd
Is a cackling Yuletide Belgian
stonedsurd's Avatar
stonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for president
If you get rid of the pads, you'll have to make the center section (where the 4 struts meet) slightly less pointy (and shorter).
Wait, I'm giving advice to you. Obviously you thought of that
__________________
My Flickr
Originally Posted by specofdust View Post
You don't believe people can be trusted to be exposed to ideas, to thought, to expression. I choose to say that even if people can't be trusted, it's moral that they should be, because I have no right to elevate myself above them and decide on their behalf what they should be exposed to, because that is authoritarian, discriminatory, and wrong.
stonedsurd is offline   Reply With Quote
Old 17th Apr 2010, 07:22   #163
Editor22
E22.BIZ
Editor22's Avatar
Editor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run Crysis
Damn this log just gets better and better, I dare anyone to read it and not feel inspired to go out and create something. On a side note I bet your filing arm is going to look something like this when your done on that 12mm bar! just crazy!
__________________
Store: E22
Social: Youtube | Facebook
Projects: Evolution | K2 MK1
Editor22 is offline   Reply With Quote
Old 17th Apr 2010, 11:41   #164
The_Gnu
8-bit addict
The_Gnu's Avatar
The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.
I love your projects, shows of your patience and attention to detail and im impressed by how fast this project is developing. Good work
Originally Posted by Editor22 View Post
... I bet your filing arm is going to look something like this when your done on that 12mm bar! just crazy!
Naah... I would guess more like this
__________________
Project: ProtoHype (paused)
Project: GET A LIFE (Complete)
Project: Widescreen Projector(Complete)
Guide: How to brush Aluminum
The_Gnu is offline   Reply With Quote
Old 17th Apr 2010, 13:01   #165
Dot_Kappa
100% Puppet
Dot_Kappa's Avatar
Dot_Kappa has yet to learn the way of the Dremel
It's simply a pleasure looking at your worklog!!
On each update the "modding-rod" is set to an higher level
__________________
|||||| Modder Supercharged
Dot_Kappa is offline   Reply With Quote
Old 17th Apr 2010, 15:07   #166
Attila
still thinking....
Attila's Avatar
Yep!
Haha, thanks. Yes I try and go to great lengths in the log to show that anyone can make
nice parts, right now with only a few tools and some sweat. I think it would be
great if more viewers became active modders and builders.
Oh and as far as the filing is concerned, it's good to think of something so you don't
get bored. I think of CNC machines a lot.
Thanks mate.
Thanks a lot Dot.
__________________
stillthinking
Old 17th Apr 2010, 15:08   #167
talladega
I'm Squidward
talladega's Avatar
talladega is a hoopy frood who really knows where their towel is.talladega is a hoopy frood who really knows where their towel is.talladega is a hoopy frood who really knows where their towel is.talladega is a hoopy frood who really knows where their towel is.talladega is a hoopy frood who really knows where their towel is.talladega is a hoopy frood who really knows where their towel is.talladega is a hoopy frood who really knows where their towel is.talladega is a hoopy frood who really knows where their towel is.talladega is a hoopy frood who really knows where their towel is.talladega is a hoopy frood who really knows where their towel is.talladega is a hoopy frood who really knows where their towel is.
that must be Mankz!
kingnewby, what kind of blade do you use in your cutoff saw?
__________________
"...clearly poop is not nutritious and it tastes bad." -Bindibadgi
"Get off... my... property!"
-Clint Eastman, in Grand Tornado
talladega is offline   Reply With Quote
Old 17th Apr 2010, 15:35   #168
Attila
still thinking....
Attila's Avatar
That's a carbide tipped 10inch blade made for alu. The teeth have a negative hook angle.
Wood blades have the teeth angled towards the direction of rotation, a positive hook angle.
__________________
stillthinking
Old 17th Apr 2010, 21:35   #169
oliverw92
Supermodder
oliverw92's Avatar
oliverw92 has yet to learn the way of the Dremeloliverw92 has yet to learn the way of the Dremel
For cutting that thicker stuff with the jigsaw have you considered a different type of blade? I use a ceramic blade when cutting thick aluminium and it eats through it like butter, leaving a very clean finish that just takes a little sanding. They look like this:
oliverw92 is offline   Reply With Quote
Old 18th Apr 2010, 12:53   #170
AnG3L
Ultimate Modder
AnG3L's Avatar
AnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run Crysis
Wow wow wow!!! OMG! (Awesome vocabulary here huh?)
AnG3L is offline   Reply With Quote
Old 18th Apr 2010, 16:00   #171
Blooddrunken
In Flames we Trust
Blooddrunken's Avatar
Blooddrunken has yet to learn the way of the Dremel
You inspired me so much with your logs, I started again with modding after 5 Years of pause and just reading.
Blooddrunken is offline   Reply With Quote
Old 18th Apr 2010, 18:17   #172
Mankz
dat steak
Mankz's Avatar
Mankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on you
Originally Posted by talladega View Post
that must be Mankz!
Mankz is offline   Reply With Quote
Old 19th Apr 2010, 05:12   #173
stonedsurd
stonedsurd's Avatar
Originally Posted by Mankz View Post
__________________
My Flickr
Old 19th Apr 2010, 15:45   #174
Locknload
Multimodder
Locknload has yet to learn the way of the Dremel
Hi again old newby,
Just a thought you could also use an Electric ceramic tile cutter on the aluminium, these also come with a little water trough which makes the process a lot smoother as it lubricates the cutting process they are only cheap to buy...plasplugs make a version of it.
Locknload is offline   Reply With Quote
Old 21st Apr 2010, 08:44   #175
Attila
still thinking....
Attila's Avatar
Thanks for the tip. I'll go and get some of those blades, I'll try anything that can
make life easier.
Haha, thanks Ang3L.
Thanks, I'm happy that you got some inspiration from this.
Originally Posted by Locknload View Post
Hi again old newby,
Thanks a lot L&L. I'll look for one of those next time I'm down at the hardware
Barn.
I've done most of the shaping for the support struts. The top curves were easy to get nice
but I'm having difficulty in getting a nice smooth curve on the underside. Just have to keep
at it.
Trying to speed things up a little, a 50 grit sanding disc was used to remove the bulk of the
material from the top of the three remaining struts.
Here are some pics of what it should look like. I've just arranged the struts roughly and please
excuse the uneven curves on the lower sufaces.
Back soon.
__________________
stillthinking
Old 21st Apr 2010, 09:15   #176
stonedsurd
stonedsurd's Avatar
Uneven? You call that UNeven?
It's looking great man. I rather like the angular nature of the ends of the struts but if you're incorporating round shapes elsewhere (the fans) then perhaps you might want to rethink adding the pads - just thin 1/4" or 1/2" ones.
__________________
My Flickr
Old 21st Apr 2010, 09:43   #177
Attila
still thinking....
Attila's Avatar
Thanks, yes I'm thinking about rounding off the ends of the struts and yes again,
large, low profile pads are the way to go.
__________________
stillthinking
Old 21st Apr 2010, 20:20   #178
Kylevdm
The Mod Zoo Podcast Host
Kylevdm's Avatar
Kylevdm is a hoopy frood who really knows where their towel is.Kylevdm is a hoopy frood who really knows where their towel is.Kylevdm is a hoopy frood who really knows where their towel is.Kylevdm is a hoopy frood who really knows where their towel is.Kylevdm is a hoopy frood who really knows where their towel is.Kylevdm is a hoopy frood who really knows where their towel is.Kylevdm is a hoopy frood who really knows where their towel is.Kylevdm is a hoopy frood who really knows where their towel is.Kylevdm is a hoopy frood who really knows where their towel is.Kylevdm is a hoopy frood who really knows where their towel is.Kylevdm is a hoopy frood who really knows where their towel is.
DUDE! This build has come along sooo much since I last saw it! Loving all the aluminium! I love my aluminium! <3
__________________
Kyle van der Merwe host at www.TheModZoo.com Podcasts!
Project: Codename C :: LANBOY APOCALYPSE (built with MNPCTECH!) :: Project: Deadline :: Project: MNU
Projects supported by EK Waterblocks, MNPCTECH, Fractal Design, NZXT, ENERMAX, and TM3 Connections
Core i7 920 D0 :: Asus P6T Deluxe v2 :: 6GB Crucial BalistiX :: Asus GTX 570 :: ENERMAX Platimax 850W :: OCZ Agility 3 120GB :: 4x Samsung SpinPoint F3 1TB
Kylevdm is offline   Reply With Quote
Old 21st Apr 2010, 21:28   #179
shomann
Supermodder
shomann's Avatar
shomann has yet to learn the way of the Dremel
You would swear this was done by CNC oldnewby. Really loving the build so far. Rock on.
__________________
Project: Nomad
Notebook: Apple 15" MBP 2010 i5/128SSD/320 Optibay conversion
NAS: Jetway JNC62K | AMD 4850e 2.5 GHz AM2 | 2GB RAM | 2.7 TB RAID-5 - OFFLINE, EVALUATING
shomann is offline   Reply With Quote
Old 21st Apr 2010, 21:40   #180
skreenname
Allons-y!
skreenname's Avatar
skreenname has yet to learn the way of the Dremel
Of course it's uneven!
Can't you see the right front strut is 12nanometers thichker than the left at the same spot?!
@Oldnewby
Stop being awesome.
You're making me want to mod more stuff.
__________________
AMD Phenom X4 9650 [2.7GHz] | Nvidia GeForce GTX 560ti | 4GB GSKILL DDR2 800 | Gigabyte GA-MA780G-UD3H
______________________________________
Zotac ION-ITX-A-U | 2GB A-Data DDR2 800
skreenname is offline   Reply With Quote
Reply
Tags
aluminium, oldnewby
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
