#1 |
Folding@Home CC Captain 2010/11/12
The Official - Show us your folding rig thread!
Hi all, this thread is for people to show off their Folding Rigs and/or any modifications to their rigs in the name of a folding IE getting out the
to get 8 GPU's into a small tower case! ![]() Many of you have got some great rigs that I'm sure we would all like to admire and get some ideas from, also a few of us got farms to try and keep going which I know can be quite problematic sometimes but any pictures of racking, cooling etc are all helpful! ![]() I've been meaning to start a thread like this for ages but didn't ever seem to get around to it but as I have loads of pics sat about I thought its about time I got them up to share! ![]() I will keep the 2nd post free for making a total list/summary of CPU's, GPU's & OS's used, should be some interesting results I think ![]() Anyway, use the below template for sharing the spec on your rig(s) then add anything else you want to underneath... Folding @ Home rig type - Make/Model/MHz of CPU(s) - Make & Model of GPU(s) - Case & Motherboard - Any Modifications Done - The Rig's average PPD - Operating system Used - Virtual or Native SMP(s) - Power Consumption used - Any other info to share - Examples: Folding @ Home rig type - Dedicated or part time Make/Model/MHz of CPU(s) - Intel Q6600 @ 3.4ghz or AMD Phenom II 550 @ 3.4ghz Make & Model of GPU(s) - 3 x Asus Nvidia GTX260's or 2 x ATI 5850's Case & Motherboard - Antec 902 & Asus P6T Deluxe Any Modifications Done - Rear fan grill cut out & hole made for water pipes The Rig's average PPD - 31,000 PPD Operating system Used - Windows 7 64 bit or Ubuntu 9.04 64 bit Virtual or Native SMP(s) - VMware 3.0 & NotFred VM on 4 cores or Windows/Linux SMP Power Consumption used - Wattmeter shows 480w from the wall while folding Any other info to share - Corsair HX1000 PSU & 4gb OCZ 800mhz DDR II etc... And then some photos... If im missing anything you think would be good to know let me know, otherwise hope this is useful & interesting to everyone. Fold on team 35947!
__________________
My Main Rigs:~ H2O'd i7 3770K @ 4.5 - 16GB - H2O'd GTX 670 | Asus Z9PE-W8, EP-Xeon 2670 @ 3.2 - 16GB
| ~~~ My Current Dual EP-Xeon 2670 Project ~~~ | ~~~ My Mitsubishi Evo Track Car Project ~~~ | Last edited by coolamasta; 5th Feb 2010 at 11:14. |
#2 |
Reserved...
__________________
| ~~~ My Current Dual EP-Xeon 2670 Project ~~~ | ~~~ My Mitsubishi Evo Track Car Project ~~~ | |
#3 |
My main home PC folding rig, rest to follow
![]() Folding @ Home rig type - Full time but not dedicated folder Make/Model/MHz of CPU(s) - Intel Core i7 @ 4.2ghz Make & Model of GPU(s) - XFX Nvidia GTX295 Case & Motherboard - Antec 1200 & Asus P6T Deluxe Any Modifications Done - Front & Roof mounted radiator mods, 120mm Yate Loon & Kaze Juyni fans The Rig's average PPD - 27,000 PPD Operating system Used - Windows 7 Pro 64-bit Virtual or Native SMP(s) - VMware 3.0 & Virtual NotFred using -smp 8 -bigadv Power Consumption used - IIRC around 520w from the wall fully loaded Any other info to share - 800w Gigabyte Modular PSU, water cooled CPU & GPUs, 6GB OCZ mem, 300gb Raptor ![]() ![]() Dedicated farm rig number #1 Folding @ Home rig type - Dedicated Make/Model/MHz of CPU(s) - AMD Athlon 7750 BE @ 3GHz Make & Model of GPU(s) - 3 x XFX Nvidia 9800 GX2's (6 GPU's in total) Case & Motherboard - Lian-Li PC-50 case & MSI K9A2 Motherboard Any Modifications Done - 2nd 80mm fan added to rear, side panel modded with 4 x 120mm fans The Rig's average PPD - 32,000 PPD Operating system Used - Windows XP Pro 32 bit Virtual or Native SMP(s) - VMware 2.0 & Virtual NotFred Any other info to share - CoolerMaster 1250w PSU, 4GB OCZ 1066mhz DDR-2 ![]()
__________________
| ~~~ My Current Dual EP-Xeon 2670 Project ~~~ | ~~~ My Mitsubishi Evo Track Car Project ~~~ | Last edited by coolamasta; 5th Feb 2010 at 11:30. |
#4 |
Another CPC refugee .....
Nice
How about adding a template line on - Power Consumption (Wattmeter reading under F@H load)
#5 |
忍び So say we all
I will get a few pics on tommozz night as its bedtime now ...some have work @5 in morning :-( ...cool thread though
__________________
#6 |
Folding in memory of my father
Good start! Can I suggest adding the case, and any mods done, since cooling multiple GPUs is so important.
__________________
#7 | ||
Thanks chaps, I got loads more to add just not had the time to sort it all out yet...
__________________
#8 |
Folding for Margaret 17/3/2011 RIP
Dedicated folder No. 1, External View, modified from the picture in the Mag by adding 2 Fans to the front, 0ne BZ 502 and one EX 33A and I have removed theEx23A as it was not effective in blowing air into the Box, this allows me to put the side on
__________________
1) MSI 790FX-GD70, AMD PH.II X4 955, 4GB Corsair DDR3, 2 X GTX 275, 1000W PSU in Lian Li 2100. 2) MSI 790FX-GD70, AMD PH II X3 720, 4GB Corsair DDR3, 1 X GTX 275 600W PSU in Lian Li 1100. Alienware M17x-R2 folding on i5 520M |
#9 |
Internal View of No.1 showing 2 x 275's etc. Running 2 GPU's and 1 Vmware SMP. chassis modded for Water cooling.
Folding @ Home rig type - dedicated Make/Model/MHz of CPU(s) -AMD Phenom ll 955 Make & Model of GPU(s) - 2 x Palit GTX 275@s Case & Motherboard -Lian li Heavily Modded 2100 Any Modifications Done -Lots top fans fitted Underneath modded for Water cooling (not fitted yet) The Rig's average PPD -20,000 Operating system Used -Vista 64 bit Virtual or Native SMP(s) -1 Virtual SMP Power Consumption used -502 Watt Any other info to share -Two fan units added to front and Deep fans 38mm to back and top No overclocking yet
__________________
1) MSI 790FX-GD70, AMD PH.II X4 955, 4GB Corsair DDR3, 2 X GTX 275, 1000W PSU in Lian Li 2100. 2) MSI 790FX-GD70, AMD PH II X3 720, 4GB Corsair DDR3, 1 X GTX 275 600W PSU in Lian Li 1100. Alienware M17x-R2 folding on i5 520M Last edited by Taffy; 6th Feb 2010 at 06:29. |
#10 |
忍び So say we all
![]() ![]() ![]() ![]() Folding @ Home rig type -Very part time always gaming and doing other stuff Make/Model/MHz of CPU(s) -q6700 2.66-3.2 depending on what doing Make & Model of GPU(s) - 1 nvidia bfg 285 ....very nice not overclocked Case & Motherboard -Nasty pc world one Janetech.Motherboard Gigabyte 965P-DS3 Any Modifications Done -Erm not realy but needs a real good hoover out The Rig's average PPD -10-13k Operating system Used -windows 7 64 ultimate love it for gaming Virtual or Native SMP(s) -GPU2 client and notfreds 3.0 Power Consumption used -Far 2 much :-) No no idea Any other info to share -4 gig ram .650 be quiet psu 1st one ... Old in the tooth but serves me well .......Next to follow
__________________
#11 |
忍び So say we all
2nd rig
![]() ![]() ![]() ![]() Geting cleaned out @ last ![]() oh and Logitech Z-4 Speaker System for gaming and movies Folding @ Home rig type -Also very part time Make/Model/MHz of CPU(s) -q6600@ 2.8 mhz Make & Model of GPU(s) -xfx 9800 xxx Case & Motherboard -SCAN ISOTOPE case luv it.Gigabyte ga-73vm-s2 matx Any Modifications Done -Just a few more lights The Rig's average PPD -7k ish Operating system Used -erm....I change it all the time normally windows7 but now back 2 xp due to problems Virtual or Native SMP(s) -gpu2 c and notfreds 3.0 Power Consumption used -not sure Any other info to share -520 watt corsair psu and a big 37 monitor I do have 2 more machine1 is dead ie psu has died in it so no pics for that but it has a X2amd cpu and 2 8800 gt's will be back on when I can afford a new one :-) the other is not worth telling about.....All in all some old kit there that is still going....a big upgrade is planned but when I will get around to it is another thing ...................Fold on folks After a bit of a tidy up .....
__________________
#12 |
Nice rigs Taffy & Chin, always liked those isotope cases
Come on everyone else, get those pics & spec's up!
__________________
#13 |
Multimodder
these 2 rigs use 500 watts at the wall
my main q6600 general usage downloading file storage dvd burnig Folding @ Home rig type - dedicated occasional other Make/Model/MHz of CPU(s) - intel q6600 @ 2.4ghz Make & Model of GPU(s) - nvidia 8800gt Case & Motherboard - coolermaster 690 xfx 680ilt Any Modifications Done - just cut side window and all plastic grills and metal honycomb out with a few bigger cable holes The Rig's average PPD - 400-500 for smp 4000-5600 for gpu Operating system Used - winxp pro sp2 Virtual or Native SMP(s) - native Power Consumption used - about 200-300 ![]() ![]() my i5 750 gaming rig Folding @ Home rig type - dedicated occasional gaming Make/Model/MHz of CPU(s) - intel i5 750 @ 2.66 Make & Model of GPU(s) - zotac 260gtx 192 + zotac 260gtx 192 Case & Motherboard - coolermaster 590 asus p55d pro Any Modifications Done - none The Rig's average PPD - 4000-7000 per gpu and 400-500 per smp Operating system Used - xppro sp2/win 7 64 ultimate Virtual or Native SMP(s) - native smp Power Consumption used - 200-300 Any other info to share -
__________________
MAIN:i5 2500k@3.3:660GTXGAME:i5 750@2.6:P7P55DPRO:2x460GTXGAME2:i5 750@2.6:P7P55D-E:460GTXF1:E5200@2.5:P5N-E SLI:260GTX
#14 |
Multimodder
these 3 rigs use 750 watts at the wall
my second q6600 rig Folding @ Home rig type - dedicated Make/Model/MHz of CPU(s) - intel q6600 3.2ghz Make & Model of GPU(s) - evga 260gtx 192 Case & Motherboard - coolermaster 690 xfx 780i Any Modifications Done - cut out plastic grills The Rig's average PPD - 4000-7000 Operating system Used - winxp pro sp2 Virtual or Native SMP(s) - none Power Consumption used - 300-350 Any other info to share - has only 1 260 now ![]() my 2 e5200 rigs ![]() 1 Folding @ Home rig type - dedicated Make/Model/MHz of CPU(s) - intel e5200 @ 2.5ghz Make & Model of GPU(s) - xfx 8800gs 96 + xfx 8800gs 96 Case & Motherboard - generic maplin asus p5ne-sli Any Modifications Done - none The Rig's average PPD - 3000-4000 per gpu 300-400 smp Operating system Used - winxp pro sp3 Virtual or Native SMP(s) - native Power Consumption used - 200-300 Any other info to share - ![]() ![]() 2 Folding @ Home rig type - dedicated Make/Model/MHz of CPU(s) - intel e5200 @ 2.5ghz Make & Model of GPU(s) - xfx 260gtx 192 + zotac 260gtx 192 Case & Motherboard - generic maplin asus p5ne-sli Any Modifications Done - cut hd cage out The Rig's average PPD - 4000-7000 per gpu 300-400 smp Operating system Used - winxp pro sp3 Virtual or Native SMP(s) - native Power Consumption used - 200-300 Any other info to share - ![]()
__________________
#15 |
Sweet rigs John, excellent choices in hardware mate
__________________
#16 |
Folder No 2 a smaller version of No 1
Folding @ Home rig type - Make/Model/MHz of CPU(s) -AMD Phenom II X3 720 Make & Model of GPU(s) - Palit 275 Case & Motherboard -Lian li 1100 MSI 790FX-GD70 Any Modifications Done -Fan fitted to Front of case and 2 on top The Rig's average PPD -8/9000 ppd Operating system Used - Windows 7 Virtual or Native SMP(s) -Native windows Power Consumption used -295W Any other info to share -Need a better psu and case
__________________
1) MSI 790FX-GD70, AMD PH.II X4 955, 4GB Corsair DDR3, 2 X GTX 275, 1000W PSU in Lian Li 2100. 2) MSI 790FX-GD70, AMD PH II X3 720, 4GB Corsair DDR3, 1 X GTX 275 600W PSU in Lian Li 1100. Alienware M17x-R2 folding on i5 520M Last edited by Taffy; 7th Feb 2010 at 17:22. |
#17 |
CPC hang out zone (i Fix pcs i do )
edited due to all systems off line for the time been, reworking on what i am going to be doing -- post some pics in an bit just got my pre payment list that Eon send me every 3 months seems to be eating £215 avg over 3 moths (£650 total) i am moveing to Npower Biz so unit rate be 2p cheaper per unit, i now have an E Home power monitor that you Clip onto the monitor + side that goes into the consumer unit, i use about 20p an hr (AVG is £4-5 an day on the meater) but some times it goes to 36-70p an unit depending if cooking or washing or drying or all 3 at the same timewell me power bill did go down when i went onto Npower Biz
__________________
i7-920 (4Ghz) <> Titian ferna <> Rampage extreme III<> GTX480 <> 6gb 3x2gb OCZ Gold 1600 <> SSD M225 256gb / segate .11 1.5TB <> X-Fi Titanium Fatal1ty <> TK 1000w Toughpower <win7 x64> GreenFrog Computers Warrington Last edited by leexgx; 27th Nov 2010 at 00:08. |
#18 |
Multimodder
Folding @ Home rig type - Main Workstation
Make/Model/MHz of CPU(s) - Intel X9770 @ 3.2GHz Make & Model of GPU(s) - 2x nVidia 460GTX Case & Motherboard - Silversone TJ09/Asus Maximus Formula SE Any Modifications Done - Internal fan mount has 120mm rad and roof has 240mm rad The Rig's average PPD - 8000+2x9000PPD Operating system Used - Win XP Pro 32bit Virtual or Native SMP(s) - Win SMP/Win GPU Power Consumption used - ~350W Last edited by StreetSam; 19th Nov 2011 at 12:45. |
#19 |
What's a Dremel?
What a great thread coolamasta and long over due. In a bit of a work coma at the moment but will post data and picks in the next 24 hours. I love the pictures and submissions to date.
Mad Dog
__________________
#20 |
Multimodder
Theres some quality hardware there, nice gear all. Can't beat hardware photos!
Folding @ Home rig type - General use, Gaming, Folding 24/7 Make/Model/MHz of CPU(s) - i7 920@3.8 Make & Model of GPU(s) - 2 x GTX275 Case & Motherboard - Corsair 800D, Asus Rampage II Extreme Any Modifications Done - Just 1 Extra fan aimed at the cards The Rig's average PPD - ~34,000 ppd Operating system Used - W7 64 Virtual or Native SMP(s) - Virtual Linux BIGADV, 2xGPU Power Consumption used - Dont want to know! Any other info to share - ![]() Folding @ Home rig type - Dedicated, Headless Make/Model/MHz of CPU(s) - Q6600@3.0 Make & Model of GPU(s) - GTX260 with artic extreme cooling Case & Motherboard - Cheap case, Asus P5K Premium Any Modifications Done - Door fell of Hard disk caddy removed to improve air flowThe Rig's average PPD - ~10000 ppd Operating system Used - XP 32 Virtual or Native SMP(s) - NotFred, GPU Power Consumption used - Again, Dont want to know... Any other info to share - ![]() Folding @ Home rig type - Wifes General use Make/Model/MHz of CPU(s) - Q6600@2.9 Make & Model of GPU(s) - 9600GT Case & Motherboard - Cheap case, Asus P5W DH Deluxe Any Modifications Done - None The Rig's average PPD - ~7000ppd Operating system Used - XP 32 Virtual or Native SMP(s) - NotFred, GPU Power Consumption used - Ditto. Any other info to share - ![]()
__________________
Keith's Current WU's. i7920@3.8-Rampage II Extreme-60GB OCZ Vertex SSD-1TB Samsung F3-6GB XMS3-2xGTX275-1000wCorsair-H50 CPU Cooling-Corsair 800D-W764. |
| Thread Tools | |
