Go Back   bit-tech.net Forums > Technology > Custom PC and bit-tech Folding Team
Reply
Thread Tools
Old 9th Feb 2010, 17:53   #21
StreetSam
Multimodder
StreetSam's Avatar
StreetSam has yet to learn the way of the Dremel
Another one from StreetSam
Folding @ Home rig type - Dedicated no.1
Make/Model/MHz of CPU(s) - Intel Q6600 @ default
Make & Model of GPU(s) - 3 x nVidia GTS450
Case & Motherboard - Antec 300/eVGA 680SLi
The Rig's average PPD - 3 x 12000
Operating system Used - Win 7 64bit
Virtual or Native SMP(s) - 3 x WinGPU slots
Power Consumption used - ~325W
Folding @ Home rig type - Dedicated no.2
Case & Motherboard - Lian Li 7B/eVGA 680SLi
Folding @ Home rig type - Dedicateded no. 3
Make/Model/MHz of CPU(s) - Intel E4300 @ default
Make & Model of GPU(s) - 2x nVidia GTX460
The Rig's average PPD - 2 x 18000 PPD
Virtual or Native SMP(s) - 2 x Win GPU slots
Power Consumption used - ~300W
Folding @ Home rig type - Dedicated no. 4
Make & Model of GPU(s) - 3x nVidia GTS450
Virtual or Native SMP(s) - 3 x Win GPU slots
Folding @ Home rig type - Dedicated no. 5
Make/Model/MHz of CPU(s) - Intel E4500 @ default
Folding @ Home rig type - Dedicated no.6
Make & Model of GPU(s) - 3 x nVidia GTX650Ti
Case & Motherboard - Fractal Design Core 3000/eVGA 680SLi
The Rig's average PPD - 3 x 18000
__________________
Folding stats
Current Folding@Home stats
StreetSam is offline   Reply With Quote
Old 17th Feb 2010, 17:52   #22
Unicorn
Uniform November India
Unicorn's Avatar
Unicorn is the Cheesecake. Relix smiles down upon them.Unicorn is the Cheesecake. Relix smiles down upon them.Unicorn is the Cheesecake. Relix smiles down upon them.Unicorn is the Cheesecake. Relix smiles down upon them.Unicorn is the Cheesecake. Relix smiles down upon them.Unicorn is the Cheesecake. Relix smiles down upon them.Unicorn is the Cheesecake. Relix smiles down upon them.Unicorn is the Cheesecake. Relix smiles down upon them.Unicorn is the Cheesecake. Relix smiles down upon them.Unicorn is the Cheesecake. Relix smiles down upon them.Unicorn is the Cheesecake. Relix smiles down upon them.
Nice gear everyone
As I've already mentioned elsewhere, all my rigs are currently down due to hardware failures and are getting rebuilt in a more efficient configuration, so once that is finished over the next couple of weeks I will get some photos of them up along with the specs.
Unicorn is offline   Reply With Quote
Old 10th Jun 2010, 07:10   #23
songzila
Minimodder
songzila has yet to learn the way of the Dremel
my F@Home viewer is hanging out on windows 7.. did anyone notice it?
songzila is offline   Reply With Quote
Old 27th Jun 2010, 11:57   #24
Somer_Himpson
Hypermodder
Somer_Himpson's Avatar
Somer_Himpson should be considered for presidentSomer_Himpson should be considered for presidentSomer_Himpson should be considered for presidentSomer_Himpson should be considered for presidentSomer_Himpson should be considered for presidentSomer_Himpson should be considered for presidentSomer_Himpson should be considered for presidentSomer_Himpson should be considered for presidentSomer_Himpson should be considered for presidentSomer_Himpson should be considered for presidentSomer_Himpson should be considered for president
Originally Posted by coolamasta View Post
My main home PC folding rig, rest to follow
Folding @ Home rig type - Full time but not dedicated folder
Make/Model/MHz of CPU(s) - Intel Core i7 @ 4.2ghz
Make & Model of GPU(s) - XFX Nvidia GTX295
Case & Motherboard - Antec 1200 & Asus P6T Deluxe
Any Modifications Done - Front & Roof mounted radiator mods, 120mm Yate Loon & Kaze Juyni fans
The Rig's average PPD - 27,000 PPD
Operating system Used - Windows 7 Pro 64-bit
Virtual or Native SMP(s) - VMware 3.0 & Virtual NotFred using -smp 8 -bigadv
Power Consumption used - IIRC around 520w from the wall fully loaded
Any other info to share - 800w Gigabyte Modular PSU, water cooled CPU & GPUs, 6GB OCZ mem, 300gb Raptor
Fantastic looking kit there.
Dedicated farm rig number #1
Make/Model/MHz of CPU(s) - AMD Athlon 7750 BE @ 3GHz
Make & Model of GPU(s) - 3 x XFX Nvidia 9800 GX2's (6 GPU's in total)
Case & Motherboard - Lian-Li PC-50 case & MSI K9A2 Motherboard
Any Modifications Done - 2nd 80mm fan added to rear, side panel modded with 4 x 120mm fans
The Rig's average PPD - 32,000 PPD
Operating system Used - Windows XP Pro 32 bit
Virtual or Native SMP(s) - VMware 2.0 & Virtual NotFred
Any other info to share - CoolerMaster 1250w PSU, 4GB OCZ 1066mhz DDR-2
Somer_Himpson is offline   Reply With Quote
Old 28th Jul 2010, 10:54   #25
r3loaded
Hypermodder
r3loaded's Avatar
r3loaded has yet to learn the way of the Dremelr3loaded has yet to learn the way of the Dremelr3loaded has yet to learn the way of the Dremelr3loaded has yet to learn the way of the Dremelr3loaded has yet to learn the way of the Dremel
Time to show off my unashamedly ramshackle folding setup!
Exhibit A: My laptop - my main work/gaming/folding system. Runs SMP on a C2D 2.5GHz T9300, and GPU2 on an 8600M GT. I disable folding for gaming and graphic-intensive work, but it otherwise runs 24/7. I've also taken the keyboard off and use a small desk fan to keep it extra cool. CPU stays around 55C, GPU runs at 85-90C without the fan, and at 68C with
Exhibit B: The server (on the left)- runs SMP on an Athlon II X3 400e at 2.2Ghz. Folding runs 24/7 on this, while serving up files with practically no slowdown. Thanks to the energy-efficient CPU, temps never go above 40C. Computer to the right is an old P4 system, no folding runs on that.
Exhibit C: An old Advent laptop - runs single-core client on a 1.6Ghz Turion. Has a very annoying fan, so the desk fan blows some cool air across the desk to keep its fan speed down.
Altogether, this setup generates 2200 PPD. Yes, that's all outclassed by a single high-performance graphics card, but it's still something. Next purchase is likely to be a GTS 450 for the server to really boost my output.
__________________
Main: Silverstone FT03 | Asus P8P67-M Pro | i5 2500K @ 4.6Ghz | CM 212+ | 16GB Corsair Vengeance 1600Mhz | MSI Radeon 7970 | 128GB Crucial C300 + 1TB Samsung F3 | CM Silent Pro Gold 600W | Samsung XL2270HD
Server: Asus M3N78-AM | Athlon II X3 400e | 4GB Corsair XMS2 | 4x 2TB Samsung F4EG (RAID-5) | LSI MegaRAID 8708EM2 | Corsair CX400
r3loaded is offline   Reply With Quote
Old 28th Jul 2010, 12:29   #26
Phalanx
Needs more dragons and stuff.
Phalanx's Avatar
Phalanx should be considered for presidentPhalanx should be considered for presidentPhalanx should be considered for presidentPhalanx should be considered for presidentPhalanx should be considered for presidentPhalanx should be considered for presidentPhalanx should be considered for presidentPhalanx should be considered for presidentPhalanx should be considered for presidentPhalanx should be considered for presidentPhalanx should be considered for president
Nice rigs. I must get mine up on here soon. I'll do it once I get my next 2 rigs up and running, then I'll take an overall shot (I run a server cabinet for my folding).
__________________
XBOX Live!: Ph4lanx | Steam: Catachan
Phalanx is offline   Reply With Quote
Old 19th Aug 2010, 14:10   #27
DJRenegade
Yorkshire Warrior!
DJRenegade's Avatar
DJRenegade has yet to learn the way of the Dremel
Nice Rigs, im afraid mine is nothing compared to most of these
__________________
Phenom II X4 955 BE @ 3210MHz | Crosshair III Formula | 2GB Corsair Dominator DDR3 | XFX 5770 | XFX 8800GS (PhysX Dedi) | 650w Modular PSU | Antec 902
DJRenegade is offline   Reply With Quote
Old 6th Oct 2010, 08:28   #28
Goku
What's a Dremel?
Goku has yet to learn the way of the Dremel
Hi All,
as I have just broke the 400k barrier thought I'd list my rig:
Make/Model/MHz of CPU(s) - AMD 955 BE @ 4Ghz
Make & Model of GPU(s) - Gainward Nvidia GTX260
Case & Motherboard - Antec 1200 & Asus M4A89TD Pro
The Rig's average PPD - @8000 PPD
Operating system Used - Windows 7 Ultimate 32bit
Must say that I'm a bit dissapointed with the AMD running at 4Ghz as it only produces about 350 PPD under Win7. But my PPD may change quite a bit as I'm considering buying another graphix card - probably a GTX460 and then I'll stick the GTX260 in the other machine which should then produce another 7-7.5 PPD
__________________
Regards
Mark
Folding stats
Goku is offline   Reply With Quote
Old 7th Oct 2010, 11:26   #29
Christopher N. Lew
Folding in memory of my father
Christopher N. Lew's Avatar
Christopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for president
That's way too low, are you running a classic client? You should be able to get about 10-fold increase using the latest SMP client - which is now much easier to setup and run than previous versions. You may have to run 24/7 (or approaching that) to meet the tight deadlines.
__________________
Folding stats
Christopher N. Lew is offline   Reply With Quote
Old 7th Oct 2010, 17:38   #30
Unicorn
Unicorn's Avatar
Off-topic: CNL, you've got mail - did you get it?
Old 17th Oct 2010, 12:48   #31
jdcrispe95
Windows XP ♥
jdcrispe95's Avatar
jdcrispe95 has yet to learn the way of the Dremel
I got the same Laptop charger as you XD
Trust heap of **** lol
jdcrispe95 is offline   Reply With Quote
Old 14th Nov 2010, 09:33   #32
seacombe2379
Old Folder
seacombe2379's Avatar
seacombe2379 has yet to learn the way of the Dremel
Folding @ Home rig type - HTPC come Folder come Gaming rig
Make/Model/MHz of CPU(s) - Intel Q6600 @ 3GHZ
Make & Model of GPU(s) - 2X Nvidia 9600GT (Bottom one is dead)
Case & Motherboard - Thermaltake SwordM (Limited edition never seen another one) XFX 780i SLI
Any Modifications Done - Fitted new fan to NB (Old one couldnt blow a stamp across the desk)
The Rig's average PPD - 3.5k
Operating system Used - Win7 Ultimate 64
Virtual or Native SMP(s) - ???
Power Consumption used - Dont care
how you like it guys
__________________
Folding stats
seacombe2379 is offline   Reply With Quote
Old 16th Nov 2010, 20:36   #33
paddi70
Multimodder
paddi70 has yet to learn the way of the Dremel
Folder 1. Runs GPU2 with watercooled GTX 295 & 260.
Folder 2. Runs GPU3 with 3 x GTS 450
__________________
Folding stats
paddi70 is offline   Reply With Quote
Old 6th Jan 2011, 00:50   #34
StreetSam
Multimodder
StreetSam's Avatar
Folding @ Home rig type - BigAdv I
Make/Model/MHz of CPU(s) - Intel i7 920 (hopefully @ 3.8GHz)
Make & Model of GPU(s) - nVidia 7200 I think
Case & Motherboard - Silverstone TJ09
Any Modifications Done - 240mm rad in the roof
The Rig's average PPD - ~40,000 I hope
Virtual or Native SMP(s) - Win SMP (BigAdv)
Power Consumption used - Don't know yet
Any other info to share - Still awaiting a PSU and DVD ROM drive, currently leak testing, the nasty PSU is powering the pump.
I brought the mobo and ram as I had a 920 that was displaced by a 980 and I had meant to update my main machine with it, but couldn't bear to go to all the trouble of transfering all my programs and setting from XP to Win7, so as I had all the other bits hiding behind a sofa I decided to use them, now I have another machine and nowhere to put it .
P.S. Yes that is toilet paper under the pump, there was a slight leak there and I find that the coloured water shows up really well on toilet paper
__________________
Folding stats
Old 8th Jan 2011, 22:40   #35
chin913
忍び So say we all
chin913's Avatar
chin913 has yet to learn the way of the Dremel
Loving the toilet paper streetsam.....is it aldi brand or tesco ?
__________________
Folding stats
chin913 is offline   Reply With Quote
Old 4th Feb 2011, 01:08   #36
meandmymouth
I *am* a Dremel
meandmymouth's Avatar
meandmymouth - it's over 9000!!!!!!!!1!1!1!!!meandmymouth - it's over 9000!!!!!!!!1!1!1!!!meandmymouth - it's over 9000!!!!!!!!1!1!1!!!meandmymouth - it's over 9000!!!!!!!!1!1!1!!!meandmymouth - it's over 9000!!!!!!!!1!1!1!!!meandmymouth - it's over 9000!!!!!!!!1!1!1!!!meandmymouth - it's over 9000!!!!!!!!1!1!1!!!meandmymouth - it's over 9000!!!!!!!!1!1!1!!!meandmymouth - it's over 9000!!!!!!!!1!1!1!!!meandmymouth - it's over 9000!!!!!!!!1!1!1!!!meandmymouth - it's over 9000!!!!!!!!1!1!1!!!
I shall put up a picture once I get my new case!
__________________
Folding stats
meandmymouth is online now   Reply With Quote
Old 4th Feb 2011, 01:20   #37
standinwave
Folding in memory of my mum
standinwave has yet to learn the way of the Dremel
Be sure to include some random household item in shot, just to amuse everyone
standinwave is offline   Reply With Quote
Old 13th Apr 2011, 15:56   #38
Sankia
Minimodder
Sankia's Avatar
Sankia has yet to learn the way of the Dremel
Some of these machines are ridiculously good, and others are just ridiculous. As a human biologist working in cancer research myself, I applaud anybody who goes out of their way to fold, bravo guys.
Sankia is offline   Reply With Quote
Old 26th Apr 2011, 16:05   #39
Raxxx
What's a Dremel?
Raxxx has yet to learn the way of the Dremel
Amazing cases, what else is those water cooling pipes connected to?
Raxxx is offline   Reply With Quote
Old 4th May 2011, 09:47   #40
Leroyingo
Multimodder
Leroyingo's Avatar
Leroyingo has yet to learn the way of the Dremel
Wow, there are some awesome computers here. Almost makes me want to try water cooling.
Leroyingo is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
