Go Back   bit-tech.net Forums > Technology > Custom PC and bit-tech Folding Team
Reply
Thread Tools
Old 29th Jun 2011, 00:04   #41
davebodger
My Dremel's bigger than your Dremel
davebodger's Avatar
davebodger has yet to learn the way of the Dremel
Folding @ Home rig type - Dedicated workhorse - gets used for everything but Folding always runs 24/7. Running Client 7 and ordinary "big" SMP now.
Make/Model/MHz of CPU(s) - Intel Q6600 @ 3.43GHz summer setting (put up to 3.5+ whatever I can get out of it in the winter). CPU Runs at 90C+ and has done for about 4 years now. Air cooled. Toasty. Cools down to 85C or below in the winter.
Make & Model of GPU(s) - ATI HD3870 (not used for folding anymore).
Case & Motherboard - Case is a XClio BlackBox something or other I got from Scan Computers because it was cheap and had big fans. ASUS Maximus Formula SE X38 motherboard with a knackered Northbridge chip so I can't change the memory multiplier. 4Gb G-Skill DDR2 fitted - runs at 384 Bclk.
Any Modifications Done - 40mm fan screwed to Northbridge chip heatsink to stop it melting down.
The Rig's average PPD - around 8500 +/- 500 or so, depends on what else I'm doing.
Operating system Used - WinXP SP3. OEM version unfortunately so I'm stuck with it the way it is. I would dearly love to upgrade the hardware but MicroSoft says NO. Naughty. Naughty. Even though I tried waving fivers at them. I want to update the OS to the Retail version as I have a silly amount of applications installed and don't want to re-install them on Win7/8/whatever but Microsoft in it's great wisdom will not sell me a copy (or even a new license). If anyone knows a way around this (black magic or vodoo acceptable) then please PM me.
Virtual or Native SMP(s) - Native.
Power Consumption used - Around 350W'ish but I haven't measured it for ages.
Any other info to share -APC SmartUPS 1400. BeQuiet Dark Power Pro 850W PSU.
Folding @ Home rig type - Dedicated.
Make/Model/MHz of CPU(s) - Intel i7 970 @ 4.35GHz (Ubuntu), 4.4GHz (Win7).
Make & Model of GPU(s) - ATI HD6950 flashed to 6970 spec. Not used for folding.
Case & Motherboard - Thermaltake Kandalf case, ASUS P6T Delux Rev 1.0 motherboard with 6Gb Corsair Dominator DDR3-1280(1600) memory running at 1744 with 1.66 volts.
Any Modifications Done - Yes. Oh, you want me to list them; OK then..... Plastic bit on top ripped off to improve ventilation and give me somewhere to stand the water reservoir. 120mm internal front fan replaced with a 38mm thick model, reversed the mounting bracket so it sticks out the front where it can actually suck some air in. That made it hit the nice electro-luminescent display and I couldn't close the front doors, so that got ripped out too. More ventilation goodness. Apogee SwifTech GTX CPU waterblock. EK Mosfet and full Northbridge waterblocks. XSPC tall reservoir (don't buy the small one it's useless because it airiates the coolant). Liang DDC Ultra+ pump. T-Balancer to control the fans and the coolant pump. BlackIce 360 radiator fitted with 3 SilenX Ixtrema Pro 120 fans (90cfm each) 38mm deep these actually move air without sounding like Concorde taking off.
Another 38mm thick fan has been fitted to the side cover. This is not natural for a Kandalf case and it complained loudly whilst I attacked it with a Dremel. It's feeling much cooler now.
The Rig's average PPD - 62000 doing bigadv, but I'll update you once I've returned my first bigbeta 6904 WU.
Operating system Used -Ubuntu 10.10-ck at present but it's a multi-boot system with WinVista SP1 and Win7 Ultimate SP1 also.
Virtual or Native SMP(s) -Native.
Power Consumption used -365~395W at the wallplug plus 25W for the UPS.
Any other info to share -APC SmartUPS 1500i. BeQuiet Dark Power Pro 850W PSU.
CPU core temps 58~73C max with the room at 28C this summer. Much cooler in winter and the fans run slower/quieter too.
All together now.
The UPS's that lurk underneath.
__________________
Folding since 20th August 2004.
Folding stats
davebodger is offline   Reply With Quote
Old 22nd Apr 2012, 11:22   #42
vasileioszografos
Modder
vasileioszografos's Avatar
vasileioszografos has yet to learn the way of the Dremel
That's me
http://www.youtube.com/watch?v=esTAZ...38AUAAAAAAABAA
It is running at 4.6 Ghz now.
__________________
--- Ferramentis venit et vadit. Scientia manet ---
Folding stats
vasileioszografos is offline   Reply With Quote
Old 20th May 2012, 20:21   #43
Eldorado
Needs new glasses..
Eldorado's Avatar
Eldorado has yet to learn the way of the Dremel
F@H rig semi dedicated/weekend kid rig.
CPU: Phenom2 710x3@3.25Ghz (4-8k ppd, depends on WU)
GPU: Palit GT 430 @800Mhz (3-7k ppd, again, depends on WU)
4GB ddr3 RAM.
Mods: 80mm case fan on BE cooler (10° lower than the whiny stock fan, quieter too!, affixed with epoxy resin!)
F@H Part timer/Chimper/Main rig.
CPU: Phenom2 955BE(c2) 3.6-4.0Ghz depending on air temp (6-16k ppd, depends on WU, those 600 pointers are good)
TT Contac29 cooler (Best £12 ever spent)
GPU: Palit GTX460@850Mhz (8-16k ppd, again depends on WU)
8GB ddr3 RAM (8-8-8-22-1t-1333). (Kingston value)
Mods: none really, put a sticker on it and added the odd fan..
Eldorado is offline   Reply With Quote
Old 16th Aug 2012, 10:06   #44
coolamasta
Folding@Home CC Captain 2010/11/12
coolamasta's Avatar
coolamasta is a hoopy frood who really knows where their towel is.coolamasta is a hoopy frood who really knows where their towel is.coolamasta is a hoopy frood who really knows where their towel is.coolamasta is a hoopy frood who really knows where their towel is.coolamasta is a hoopy frood who really knows where their towel is.coolamasta is a hoopy frood who really knows where their towel is.coolamasta is a hoopy frood who really knows where their towel is.coolamasta is a hoopy frood who really knows where their towel is.coolamasta is a hoopy frood who really knows where their towel is.coolamasta is a hoopy frood who really knows where their towel is.coolamasta is a hoopy frood who really knows where their towel is.
Quote from the Doc below and his mass of amazing folding kit
Originally Posted by DocJonz View Post
By popular demand from fellow Folders(!) ..... here's some snapshots of the current setup around the house
Left photo: i7 980 & i7 980X
Right photo: MediaPC (Non-Folding) and i7 3930k
Left photo: Q6600 Linux TestPC, 4P Opteron (floor) & Q6600 Win TestPC (this is the Computer room )
Right photo: two i7 930's (bread and butter PC's)
Left photo: i7 980
Right photo: i7 980X
The current project will not look quite so ordinary ..... I aim to build one of the i7 980's into a water cooled system inside a piece of IKEA furniture
__________________
My Main Rigs:~ H2O'd i7 3770K @ 4.5 - 16GB - H2O'd GTX 670 | Asus Z9PE-W8, EP-Xeon 2670 @ 3.2 - 16GB
| ~~~ My Current Dual EP-Xeon 2670 Project ~~~ | ~~~ My Mitsubishi Evo Track Car Project ~~~ |
coolamasta is offline   Reply With Quote
Old 16th Aug 2012, 20:21   #45
DocJonz
Another CPC refugee .....
DocJonz's Avatar
DocJonz is a hoopy frood who really knows where their towel is.DocJonz is a hoopy frood who really knows where their towel is.DocJonz is a hoopy frood who really knows where their towel is.DocJonz is a hoopy frood who really knows where their towel is.DocJonz is a hoopy frood who really knows where their towel is.DocJonz is a hoopy frood who really knows where their towel is.DocJonz is a hoopy frood who really knows where their towel is.DocJonz is a hoopy frood who really knows where their towel is.DocJonz is a hoopy frood who really knows where their towel is.DocJonz is a hoopy frood who really knows where their towel is.DocJonz is a hoopy frood who really knows where their towel is.
Following on from Coolamasta's post above of my post .... the conversion from an Antec Twelve Hundred to an IKEA chest ...
__________________
Folding stats
Folding Farm Stats (HFM): http://www.docjonz.net/summary.html
DocJonz is offline   Reply With Quote
Old 16th Aug 2012, 20:24   #46
kirk46
Cheesecake Nom Nom
kirk46's Avatar
kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.
lol quality
make sure no one puts there laundry in there
__________________
2x Xeon 5620 @ 3.8GHz under water
3770k @ 4.8GHz, Custom loop, GTX680 OC'd
kirk46 is online now   Reply With Quote
Old 16th Aug 2012, 20:42   #47
DocJonz
DocJonz's Avatar
Originally Posted by kirk46 View Post
lol quality
.... or even on it, as it would roast!!
I've gone down the cop-out route and bought a Corsair H100, and built a frame for it, to swap the Frio out, as its too loud. I'll switch it over when I get a moment ....
__________________
Folding stats
Old 16th Aug 2012, 21:17   #48
coolamasta
coolamasta's Avatar
That is a damn good idea Doc, I have the space on my landing for one of those, think im gonna have to copy your idea lol what framework have you got in there with it all bolted too?
__________________
Old 16th Aug 2012, 21:37   #49
DocJonz
DocJonz's Avatar
Cheers! The cube framework is an aluminium machine building system (20mmx20mm section) - it costs a bit of money, but does a nice job, in that the PC is fully contained within the aluminium frame, which then just slots into the chest - hence I can return it to a chest in about 60 seconds if required! Google 'item mbs'. There are cheaper systems though, try RS, for example.
__________________
Folding stats
Old 16th Aug 2012, 23:03   #50
Christopher N. Lew
Folding in memory of my father
Christopher N. Lew's Avatar
Christopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for president
Nice one, Doc
I envy the clean, tidy look of your house - I wish mine was like it.
__________________
Folding stats
Christopher N. Lew is offline   Reply With Quote
Old 17th Aug 2012, 05:43   #51
One_Box
Folder of the month April 2012
One_Box has yet to learn the way of the Dremel
What a brilliant idea Doc
__________________
Folding stats
Folding stats
One_Box is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
