Reply
Thread Tools View Mode
Old 5th Feb 2010, 14:35   #1
nagyizom
Supermodder
nagyizom's Avatar
nagyizom has yet to learn the way of the Dremelnagyizom has yet to learn the way of the Dremelnagyizom has yet to learn the way of the Dremelnagyizom has yet to learn the way of the Dremel
Sandcrawler Mod
Greetings for all bit.tech users!
Firstly, let me introduce myself. My name is Gábor, I'm from Hungary and I'm 23 years old.
I've been occupied with modding since 2003, I have some modded case at home, but this is my first CaseCon! I Presented it at the Win7 mod-tech Hall 2009, Hungary's biggest modding event!
http://modtechhall.radikalmod.hu/
Some finished photo:
It was the second place in the competition, so I'm proud about it
From the case:
As you can see, this is the Jawa Sandcrawler from Star Wars, this is the one of my favorite vehicle. As far as I start modding, I want to bulid it, and put the PC into it.
In 2008, the time has come to make my dream come true
Firstly, I had to find some informations about the vehicle. Fortunately, the internet helped me, I fond a lot of pictures, descriptions.
I want to put the motherboard, the drives into the middle, the power supply goes into the back. I created a cardboard mock-up of the case to see how it all went together:
I put the motherboard into a special position, you can use the I/O panel from the bottom.
I used the cardboard sections as templates for made a mobo tray:
Made a lower section by plywood:
I marked up and cut out the holes for the I/O panel both on the tray and the plywood:
Put it all together:
With the mobo:
I fix the parts together with self-tapping screw:
The next step: How to fix the power supply to the vehicle' s body?
Firstly, I marked up and cut out the hole for the supply:
Think I use two-side tape, but its not strong enough, maybe made a alu-frame, but finally I use some screw:
That's all for today! See you soon!
nagyizom is offline   Reply With Quote
Old 5th Feb 2010, 14:43   #2
Picarro
I Mod, Therefore I Own
Picarro's Avatar
Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.
Uhh, I love the sandcrawlers. Nice mod
__________________
Intel Core i5 2500k @ 5gHz -:- Gigabyte Z68X-UD3H-B3 -:- 2x4 gbCorsair Vengeance 1,5v 1600mHz -:- Gigabyte Windforce X3 GTX 670 -:- Crucial M4 128 gb -:- Samsung F3 Spinpoint 640 gb -:- Corsair H60 with 2x Gentle Typhoon 1850 in push-pull -:- Corsair HX650 -:- Lian Li A05FN -:- Dell U2410 flanked by 2x Dell U2001FP -:- BenQ W1000+ -:-
Picarro is offline   Reply With Quote
Old 5th Feb 2010, 15:18   #3
Roboduck
01110001 01110101 01100001 01100011
Roboduck's Avatar
Roboduck has yet to learn the way of the DremelRoboduck has yet to learn the way of the DremelRoboduck has yet to learn the way of the Dremel
Very cool! I love the rust effect paint
Roboduck is offline   Reply With Quote
Old 5th Feb 2010, 16:58   #4
The_Beast
I like wood ಠ_ಠ
The_Beast's Avatar
The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!
Very cool mod
__________________
- i7 3770k - MSI Z77A-GD65 - EVGA GTX 570 - 8Gb G.Skill Sniper (1.25v) - Fractal R3 Black - Corsair H50 - Corsair 750HX - Samsung 830 128Gb SSD - 6 Samsung F4EG 2TB - 2 WD Black 1TB - 2 WD Black 750GB - Dell UltraSharp U2410 - WASD V1 Custom - IBM Model M SSK - KBC Poker (Ergo-Clears) - Logitech Mx518 & G500 - Audio Technica AD700 - Logitech Z4 - Windows 7 Pro -
The_Beast is offline   Reply With Quote
Old 6th Feb 2010, 15:44   #5
nagyizom
Supermodder
nagyizom's Avatar
Thank you guys!
Next update will appears tomorrow!
Old 7th Feb 2010, 17:33   #6
nagyizom
Supermodder
nagyizom's Avatar
Sandcrawler mod !Update!: Caterpillar and Chassis 07-02-2010
Hello Guys!
Here's the next update!
Today I'll show you, how to make a caterpillar and a chassis like an original
The core of the caterpillars are made by pulpwood.
Firstly, I cut out theese trapezoidal shaped items.
Drilled two holes into them, and every second item were fixed together with glue and dowel:
As you can see, two of them constitutes the core of one caterpillar
The cores with the lower section:
I made consoles for the drives, theese were made by plexy:
The chassis:
Here's some picture I found in the internet. I made a sandcrawler about them, in particular, there were a great help to the chassis construction. In these pictures can be seen in the original modell, which were used in the film.
In this picture you can see the true extent of the modell
The original chassis was made by plywood, with stirol covering.
I use PVC sheets. I used cardboard to make mock-ups, and if it passed, I cut out the final item from PVC.
Finally I glued together the items:
And that's for today.....I hope, I come back soon!
Old 9th Feb 2010, 12:48   #7
nagyizom
Supermodder
nagyizom's Avatar
No comments?
Old 27th Mar 2010, 09:21   #8
nagyizom
Supermodder
nagyizom's Avatar
Devil is in the details- Make a cover
Hy Guys!
I haven't got enough time to update this blog for a while.
I show you in the last updte, how to build a chassis. Today I' ll read about the details!
Armor plate
After that I glued together the pieces of the chassis, I decided to made the armor plate.
it was made by 1mm thick stirofoam.
I cut out the plate
Marked up the lines:
And I made notches with my scalpel. I think it seems to be an armor plate.
I glued up this panels to the chassis. I think it seems to be an armor plate.
Thats all for today, I hope you like it!
See you soon!
The details
The modders are very often used to provide materials that others throw away. I also put away a lot of garbage, which I still see fantasy. I made the details from this materials on the top, and also on the rear.
Here is the result of my work:
Front door
The next thing what I made, was the front door:
As you can see, it made from PVC and stirofoam.
I put the switches and the opening of the DVD:
Caterpillars
Continue the work with the caterpillars.
Fit them to the chassis with this L shaped clamps and srews:
I went to the biggest Salvage Yard in the city. I searched for ribbed belt. I found some of them, and it was free
I cut the fan belt ang glues them onto the core of the caterpillars. Because of the rigidity, I incisioned them with my scalpel. After that, the belts were fit perfectly
After that I made the details of the caterpillars:
Cut out a right shaped stirofoam.
I used washers to make driving wheels:
Old 27th Mar 2010, 09:44   #9
Colossous
Supermodder
Colossous's Avatar
Colossous has yet to learn the way of the DremelColossous has yet to learn the way of the DremelColossous has yet to learn the way of the DremelColossous has yet to learn the way of the DremelColossous has yet to learn the way of the DremelColossous has yet to learn the way of the DremelColossous has yet to learn the way of the Dremel
Good work - looking forward to seeing it finished
Colossous is offline   Reply With Quote
Old 27th Mar 2010, 12:06   #10
Neji
Multimodder
Neji's Avatar
Neji has yet to learn the way of the Dremel
Love fun projects like this. This one is shaping up very nicely.
Neji is offline   Reply With Quote
Old 27th Mar 2010, 13:16   #11
dakota67
SOUTH DAKOTA MODDER!!!
dakota67's Avatar
dakota67 has yet to learn the way of the Dremel
I love Star Wars...this is awesome.
dakota67 is offline   Reply With Quote
Old 29th Mar 2010, 17:42   #12
artoodeeto
Modder
artoodeeto has yet to learn the way of the Dremel
Looks good! I've been working on one of these myself for the past several years, I've got a worklog going over at TBCS that you might enjoy looking at. It's rather long, but the newest pictures are on the last few pages.
http://www.thebestcasescenario.com/f...ad.php?t=21039
Congrats on the contest results too!
artoodeeto is offline   Reply With Quote
Old 30th Mar 2010, 13:45   #13
maRiio
Multimodder
maRiio's Avatar
maRiio has yet to learn the way of the DremelmaRiio has yet to learn the way of the DremelmaRiio has yet to learn the way of the Dremel
That's amazing handcraft you show us here. Respect and keep on the good work.
__________________
Projects
Rusty NAS - in progress | Rusty HDD-Case(s) - finished
Social
Facebook
maRiio is offline   Reply With Quote
Old 1st Apr 2010, 18:43   #14
nagyizom
Supermodder
nagyizom's Avatar
Thank you guys!
I hope to enjoy the last chapter of the latest update, which 'll presented for you in the next few days. If everything works out as I planed, I'll show you some unique pictures from the sandcrawler
Artooo: Awesome work, what you've done! I'm so jealous of you for your patience, for being such a precision could make the reactor!
Old 1st Apr 2010, 19:03   #15
legoman666
Beat to fit, paint to match.
legoman666's Avatar
legoman666 has yet to learn the way of the Dremellegoman666 has yet to learn the way of the Dremel
Hah, that's awesome.
legoman666 is offline   Reply With Quote
Old 1st Apr 2010, 21:08   #16
artoodeeto
Modder
Thanks! I do have to say though, you've only built one of these...I've done it 3 times. My first two didn't look even remotely as good as yours, so definitely you should be proud of it. Heck, if I'd made either of the first two as well as yours, I probably wouldn't have made mine for a 3rd time. Good job! I also find it amazing that we did the same mod completely independently of each other - I started my first one 9 years ago, and you began yours about a year before I put anything online about mine. I can understand lots of R2D2 cases and such, but the sandcrawler isn't quite as prominent in the films. I'm looking forward to seeing the rest of your worklog pictures!
Old 23rd Apr 2010, 15:28   #17
nagyizom
Supermodder
nagyizom's Avatar
Hello guys!
Sorry to be late, a lot of things were in high school, we had to work, but now I make it up for lost time, That is Update time
Artoo:
When I came up with to build a sandcrawler, I began to search, to whom he has had to construct
this vehicle. I found many beautiful model pictures, but curiously, i found only one sandcrawler, which used for computer case. After I saw your project log on TBCS forum, I realized, it was your work!
I agree, not so prominent, but we see through the world with modder's eyes, and I think the vehicle gives the shape itself to put a PC into it, if you know what I mean..
So, in this update, you will see, how I made a real sandcrawler look for this "thing"
Let' begin to paint!
The paint is a very important session on this case.I tried to replicate the surface as closely as possible I can. A specific procedure is used to imitate rust.
The first thing I did was that the whole vehicle painted black:
Sandcrawler: Balck Edition!
I polished up the mobo tray, and put it into the case:
While the black paint dried, I made the right shade of mixture, which gives the color of rust.
It looked like Caterpillar equipment
The next movement was to prepare the final surface, with a dark brown paint, I used a sponge for painting, for the more rustic surface.
I made some soldering work on the DVD player:
And I sleeved all cables:
As you can see, not much work remains, the last finishing touches are done. In the next post you can see the final images.
Any comments are welcomed!
Bye!
Old 8th Aug 2010, 20:40   #18
nagyizom
Supermodder
nagyizom's Avatar
Hello All!
This is the time, when I show you the final pictures from the Sandcrawler. Some of them made on the Mod Tech Hall 2009 competition at Budapest, most of the pictures made at home, in my room.
We made a little video about the competition, I hope you like it:
http://www.youtube.com/watch?v=rsTMDG3rOj8
After the competition, I presented my work to the the big world on the TV. There' s a link, where you can watch this episode:
http://radikalmod.hu/index.php?p=5&x...c-9b5257240f7b
Some pictures
And some funny shoot
Thanks for watching, I hope You like it!
Old 9th Aug 2010, 08:51   #19
BLUEHORSESTUDIOS
I haven't lost a finger yet!
BLUEHORSESTUDIOS's Avatar
BLUEHORSESTUDIOS has yet to learn the way of the DremelBLUEHORSESTUDIOS has yet to learn the way of the DremelBLUEHORSESTUDIOS has yet to learn the way of the DremelBLUEHORSESTUDIOS has yet to learn the way of the Dremel
Great job, I love your patience and skill,I work with this product quite a bit and know the time you put into your build.
BLUEHORSESTUDIOS is offline   Reply With Quote
Old 10th Aug 2010, 09:38   #20
nagyizom
Supermodder
nagyizom's Avatar
Thank you, Sir
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
