News AVG Free is best free anti-virus
Discussion in 'Article Discussion' started by CardJoe, 11 Feb 2010.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. Motoko
    Motoko What's a Dremel?
    8 Jul 2009
    I ditched Avira Free because of those annoying nags, the nag that forced me to do it was when I was playing Mass Effect and it popped up making the game tab out and after wouldn't let me back in :angry, so I uninstalled it, fill in the questionnaire telling them they ruined my game and installed Microsoft Security Essentials, which so far has been alright.
  3. paisa666
    paisa666 I WILL END YOU!!!
    4 Mar 2009
    I already knew this... that's why i use it :p
    Seriously, good to know is actualy a good anti-virus, but as you say I am sensible enough to avoid dangerous places or mails or whatever too. (pat pat)
  4. oMonarca
    oMonarca Elitist Brick
    15 Dec 2009
    I use Avira Free and made it work to my favour. I just scheduled the auto-updates to about 1:20a.m. Now it works like an alarm clock, telling me to stop gaming and go to bed, since my work requires me to be awake :)
    The pop-up is jarring, but very easily avoidable - just reschedule the update to run when it's most convenient to you.
  5. TWeaK
    TWeaK Minimodder
    28 Jan 2010
    I used AVG for a while about a year ago but left it when reinstalling OS'. Now I'm using Avast, and I'm quite happy with it. Avast also monitors IMAP email traffic, although this can be a bit annoying as I use SSL and it needs that disabled to scan it, but at least the warnings stopped themselves after a couple attempts.
    At the end of the day, for an advanced user a virus scanner only needs to be there as a safety net or to scan a file you already think is suspicious. If a virus breaks my computer, I can just reinstall the OS and restore my backups and as such there's no need to go for the full fat security suite.
  6. tonyd223
    tonyd223 king of nothing
    12 Nov 2009
    +1 been using it for years and I try not to go to dodgy sites... Wish it was a little less resource hungry but that's what multi-core cpu's are for...
  7. eddtox
    eddtox Homo Interneticus
    7 Jan 2006
    I would have liked to see a comparison with MS Security Essentials, which I'm using at the moment and I think is excellent. I've used Norton, McAfee, Kaspersky, Panda and AVGFree before but since MSSE came out it's been installed on all my machines. I'm also trying out Sandboxie for anything that looks suspicious.
  8. xaser04
    xaser04 Ba Ba Ba BANANA!
    27 Jun 2008
    Using the Free version of Avast here, never had any problems and its 'light weight' too.
    I don't see the point in paid for 'internet security' suits outside of a corporate environment (and only then because of the licencing).
    Common sense if a far better security monitor than most of the available suites put together.
  9. l3v1ck
    l3v1ck Fueling the world, one oil well at a time.
    23 Apr 2009
    That's like saying "Syphilis, the best of the sexually transmitted diseases".
    I stopped using AVG free as it missed viruses that paid for suites found. I wouldn't go back from Kaspersky now.
  10. Dave Lister
    Dave Lister Minimodder
    1 Sep 2009
    I used avg for a while but found a couple years ago that avast free was better than avg. I also run Spybot S&D (also free) at the same time and between the two my systems seems to stay clean.
  11. Xir
    Xir Modder
    26 Apr 2006
    I run AVG on one, and Avast on the other computer.
    Must be an older version though, as it doesn't nag every day, it just autoupdates.
    Never noticed any real difference between the two.
  12. theskirrid
    theskirrid What's a Dremel?
    15 Dec 2009
    I used to use AVG and Spybot together, good coverage, and never missed anything. On 7 however AVG9 just didn't run well.
    Now using MSE, much smaller, faster and tiny footprint. None of that AVG background pre-scan bollocks either.
  13. mi1ez
    mi1ez Modder
    11 Jun 2009
    AVG free is what I recommend to all of my friends when their "30 days free" with a new PC runs out. I personally use NOD32. £40 for 3 years, job done!
  14. Mr T
    Mr T 4 Left Into Long 3 Right
    14 Nov 2001
    +1 for this.
  15. jbloggs
    jbloggs What's a Dremel?
    12 Sep 2007
    You might want to try This to remove the nags...
    The only thing AVG (free) ever did with me was make my desktop freeze, have found Avast, MSE and Avira (free versions) quite superior...
    ________
    California dispensary
  16. cybergenics
    cybergenics What's a Dremel?
    27 Jun 2009
  17. cybergenics
    27 Jun 2009
    You can never take anything a mag like PCP says as you never know if its going to be biased. AVG is ok, but it misses lots of stuff. I think MSSE is better, many people share that view.
  18. Morrius
    Morrius What's a Dremel?
    26 Oct 2009
    A combo of MS Security essentials, Malwarebytes and common sense does the trick for me.
  19. FelixTech
    FelixTech Robot
    12 Jun 2009
    Where did Comodo come in? I know it's not a standalon anti-virus but I like my Anti-virus and Firewall packages to come bundled up together and decided not to pay for the AVG suite.
  20. SteveU
    SteveU Minimodder
    19 Jun 2009
    MSE +1 here too
Tags: Add Tags
