Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 25th Feb 2010, 11:29   #1
Sifter3000
I used to be somebody
Moderator
Sifter3000's Avatar
Sifter3000 has yet to learn the way of the DremelSifter3000 has yet to learn the way of the DremelSifter3000 has yet to learn the way of the DremelSifter3000 has yet to learn the way of the DremelSifter3000 has yet to learn the way of the DremelSifter3000 has yet to learn the way of the DremelSifter3000 has yet to learn the way of the Dremel
ARM unveils 28nm SoC chips
http://www.bit-tech.net/news/hardwar...nm-soc-chips/1
__________________
The Rt Hon Alex Watson.
Dennis Publishing Emerging Platforms, bit and CPC alumni.
My weblog is The Wired Jester.
Photos on Flickr.
Sifter3000 is offline   Reply With Quote
Old 25th Feb 2010, 11:33   #2
javaman
May irritate Eyes
javaman's Avatar
javaman can run Crysisjavaman can run Crysisjavaman can run Crysisjavaman can run Crysisjavaman can run Crysisjavaman can run Crysisjavaman can run Crysisjavaman can run Crysisjavaman can run Crysisjavaman can run Crysisjavaman can run Crysis
Take note TSCM, thats how it should be done
javaman is offline   Reply With Quote
Old 25th Feb 2010, 11:53   #3
mi1ez
Hypermodder
mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!
Good work!
__________________
The Angel Delights?
mi1ez is offline   Reply With Quote
Old 25th Feb 2010, 13:05   #4
rickysio
N900 | HJE900
rickysio has yet to learn the way of the Dremel
Given that every time someone attempts to ape Intel in die shrinking, they seem to encounter tons of issue that forces them to push back and back...
Pardon me if I'm coloured merely interested.
rickysio is offline   Reply With Quote
Old 25th Feb 2010, 13:10   #5
Xir
I Mod, Therefore I Own
Xir's Avatar
Xir is almost as Godly as yodasarmpitXir is almost as Godly as yodasarmpitXir is almost as Godly as yodasarmpitXir is almost as Godly as yodasarmpitXir is almost as Godly as yodasarmpitXir is almost as Godly as yodasarmpitXir is almost as Godly as yodasarmpitXir is almost as Godly as yodasarmpitXir is almost as Godly as yodasarmpitXir is almost as Godly as yodasarmpitXir is almost as Godly as yodasarmpit
...GloFo (so also AMD) have a working 28nm process?
__________________
SN25P
A64 3700+ (San Diego)
2 GB DDR400 OCZ Platinum EL 2-3-2-5 1T
X1800XT 512mb Sapphire
200GB Samsung SP2004C 24" Asus something 1920x1080
Xir is offline   Reply With Quote
Old 25th Feb 2010, 14:16   #6
stonedsurd
Is a cackling Yuletide Belgian
stonedsurd's Avatar
stonedsurd - may the hammer of Bindi be bestowed on youstonedsurd - may the hammer of Bindi be bestowed on youstonedsurd - may the hammer of Bindi be bestowed on youstonedsurd - may the hammer of Bindi be bestowed on youstonedsurd - may the hammer of Bindi be bestowed on youstonedsurd - may the hammer of Bindi be bestowed on youstonedsurd - may the hammer of Bindi be bestowed on youstonedsurd - may the hammer of Bindi be bestowed on youstonedsurd - may the hammer of Bindi be bestowed on youstonedsurd - may the hammer of Bindi be bestowed on youstonedsurd - may the hammer of Bindi be bestowed on you
This is an HKMG 28nm process and I don't think AMD plans to use that.
__________________
stonedsurd is online now   Reply With Quote
Old 25th Feb 2010, 15:26   #7
g3n3tiX
resident frenchy
g3n3tiX's Avatar
g3n3tiX has yet to learn the way of the Dremelg3n3tiX has yet to learn the way of the Dremelg3n3tiX has yet to learn the way of the Dremelg3n3tiX has yet to learn the way of the Dremelg3n3tiX has yet to learn the way of the Dremelg3n3tiX has yet to learn the way of the Dremel
Slight redundancy : SoC : System on Chip
So saying "SoC chips" might be redundantly redundant...
Impressive claimed specs in there. I'm wainting for "real world" numbers now !
__________________
With paracord and duct tape, one can get out of any situation. Except being out of either of them.
g3n3tiX is offline   Reply With Quote
Old 25th Feb 2010, 15:32   #8
wuyanxu
still wants Homeworld 3
wuyanxu's Avatar
wuyanxu is the Cheesecake. Relix smiles down upon them.wuyanxu is the Cheesecake. Relix smiles down upon them.wuyanxu is the Cheesecake. Relix smiles down upon them.wuyanxu is the Cheesecake. Relix smiles down upon them.wuyanxu is the Cheesecake. Relix smiles down upon them.wuyanxu is the Cheesecake. Relix smiles down upon them.wuyanxu is the Cheesecake. Relix smiles down upon them.wuyanxu is the Cheesecake. Relix smiles down upon them.wuyanxu is the Cheesecake. Relix smiles down upon them.wuyanxu is the Cheesecake. Relix smiles down upon them.wuyanxu is the Cheesecake. Relix smiles down upon them.
god i got to get into that company, they are unstoppable.
__________________
i7 2700k \ 16GB \ gtx580 \ D2X \ z68x-UD5 \ m4 128GB +2TB \ Ax850 \ FT02-RW \ G15+G5+G51 \ U2711 27"
5D mkII \ 24-105 L \ 17-40 L \ 85/1.8 \ 35/2 \ 70-300 Di \ 270ExII \ 430ExII \ 3LT Adrian \ Hadley Pro -- Photostreamr
wuyanxu is offline   Reply With Quote
Old 25th Feb 2010, 15:40   #9
Malfrex
Minimodder
Malfrex has yet to learn the way of the Dremel
You can have your SoC chip, but you'll never take my NIC card!
Malfrex is offline   Reply With Quote
Old 25th Feb 2010, 16:59   #10
darklord of chaos
Modder
darklord of chaos has yet to learn the way of the Dremel
all well and good but can you play Crysis on it?
__________________
Knowledge is good.... imagination is better - albert enstien
main rig: .....under repair... I used too big a hammer
darklord of chaos is offline   Reply With Quote
Old 25th Feb 2010, 22:44   #11
wuyanxu
wuyanxu's Avatar
it sure will plays way better than Atom, while consuming a lot less power. that's the beauty of non-x86 architecture.
__________________
Old 26th Feb 2010, 06:59   #12
rickysio
N900 | HJE900
You'd just get an error, being that there's no ARM coded version of Crysis.
Old 26th Feb 2010, 07:42   #13
Xir
Xir's Avatar
GloFo? or ARM?
__________________
SN25P
Old 26th Feb 2010, 08:14   #14
stonedsurd
stonedsurd's Avatar
ARM, of course.
__________________
Old 26th Feb 2010, 09:29   #15
Xir
Xir's Avatar
Just Checking Working for GloFo isn't that....stimulating
__________________
SN25P
Old 26th Feb 2010, 23:36   #16
dec
[blank space]
dec's Avatar
dec has yet to learn the way of the Dremel
Are Radeon's made with SOI or metal gate (or neither)? That rumor about radeon 6000 series being on 28nm (and skipping 32) may be true if global foundries is making the parts. Especially if TSMC cant turn out the number of chips like it couldnt do with the 40nm stuff.
__________________
Pure. Refreshing. Bacon.
dec is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
