Reply
Thread Tools View Mode
Old 1st Mar 2010, 18:56   #1
slipperyskip
Member
slipperyskip's Avatar
slipperyskip - it's over 9000!!!!!!!!1!1!1!!!slipperyskip - it's over 9000!!!!!!!!1!1!1!!!slipperyskip - it's over 9000!!!!!!!!1!1!1!!!slipperyskip - it's over 9000!!!!!!!!1!1!1!!!slipperyskip - it's over 9000!!!!!!!!1!1!1!!!slipperyskip - it's over 9000!!!!!!!!1!1!1!!!slipperyskip - it's over 9000!!!!!!!!1!1!1!!!slipperyskip - it's over 9000!!!!!!!!1!1!1!!!slipperyskip - it's over 9000!!!!!!!!1!1!1!!!slipperyskip - it's over 9000!!!!!!!!1!1!1!!!slipperyskip - it's over 9000!!!!!!!!1!1!1!!!
Level Eleven
Skip ahead to final photos.
This project is inspired by my recent trip to San Francisco where I met up with a VIA Marketing rep at the Rods & Mods case mod exhibit. It was a great event and I came away with ideas and enthusiasm. A crowd favorite at the event was my Pico Bayard and it motivated me to do another Pico-ITX mod. I love doing the small stuff and I am due. Here goes...
First...sponsors
This project will be matching up two of the latest pieces of equipment to hit the market, the VIA P820 Pico-ITX mainboard and a Crucial C300 SSD. More to come about the kit but first let's do some project log qualifying work.
A sheet of birch plywood from my local supplier. My working surface is the backside of a chess board I bought in Spain many years ago. I don't know what kind of wood it is but it is very heavy and more importantly, extremely flat. I've been using this board for years with all my small projects.
This sheet cost me $19 which is kinda crazy but what you get is a 5-ply laser-cut piece of very nice wood. It's just not smart to skimp on materials and tools...IMHO, of course.
Using clamps to fix the straightedge I make my mark first in pencil and then in razor. I've learned over the years to spend the time to clamp these things properly instead of using human clamps.
Replaced the straightedge with a 1/2" square laser-cut board to use as a fence.
Weapon of choice is an X-acto Razor Saw with a fresh blade. I usually grasp it in the center instead of using the handle...better control of downward force and I can keep it up against the fence better this way. I saw it half way through then reset the fence on the other side. At intervals I'll run my razor knife down the trench just to "abuse" the saw cut.
That done, I set up another fence to cut a short piece.
The final "cutting-through" of the sawing process is always done with my razor knife. Keeping those edges clean.
The second piece will be exactly the same size as the first. I could measure it but I prefer not to measure anything if I can. Using the two original laser-cut corners as reference I clamp the two pieces together. Sure, I could make a mark and then saw it but I'm going to use the first piece as a fence to cut the second. After about a third of the way through I'll replace the original board with a proper fence.
Clamp the two boards together and "work" the edges over a piece of sandpaper to clean the edges up a little. Not a lot of work done here.
The result is two identical pieces of wood with perfect 90 degree corners. Took around an hour and a half.
I need to sprinkle this first post with some sponsor goodness so here is a SODIMM of Crucial 2GB DDR2-800. Thank you Crucial!
This is my concept of Sketch-up. There will be equipment mounted to both sides of this board with openings for both cables and ventilation.
The two boards I just cut will sandwich this slot-loader slimline optical drive. The drive's face plate has been removed.
That's all for now. Thanks for looking.
__________________
slipperyskip.com
slipperyskip is offline   Reply With Quote
Old 1st Mar 2010, 20:07   #2
stonedsurd
Is a cackling Yuletide Belgian
stonedsurd's Avatar
stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.
Sub'd.
Looking forward to seeing what you give us this time!
Also, that C300 SSD sounds like a marvelous piece of kit. I hope you'll do a mini-review once you get it
__________________
stonedsurd is offline   Reply With Quote
Old 1st Mar 2010, 20:38   #3
confusis
Kiwi-modder
confusis's Avatar
confusis can run Crysisconfusis can run Crysisconfusis can run Crysisconfusis can run Crysisconfusis can run Crysisconfusis can run Crysisconfusis can run Crysisconfusis can run Crysisconfusis can run Crysisconfusis can run Crysis
Originally Posted by slipperyskip View Post
Did they forget a stick of ram?
confusis is offline   Reply With Quote
Old 1st Mar 2010, 20:39   #4
PureSilver
E-tailer Tailor
PureSilver's Avatar
PureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpit
Nah, IIRC this thing only accepts one stick of RAM up to 1GB, right?
__________________
Intel Core i7 920 @ 3Ghz, Noctua NH-U12P SE, Asus P6T Deluxe V1, Corsair 12GB (6x2GB) 1600Mhz C8 @ XMP,
EVGA GTX-680, Corsair AX760, 2x Samsung SpinPoint F3 1TB, Lian-Li V1020R with 3x Noctua NF-P12 & 3x NF-P14FLX
2.4Ghz 13" unibody MacBook, 4GB RAM & 128GB Samsung SSD
PureSilver is offline   Reply With Quote
Old 1st Mar 2010, 21:01   #5
slipperyskip
Member
Originally Posted by stonedsurd View Post
Sub'd.
Difficult to get one of the suckas 'cause everyone wants to review one. It should show up in a couple of weeks. I'm using an Intel X25 as a stand-in until then.
Yes. Just one SODIMM slot. The new P820 maxes out at 2GB. It goes on sale here in the US on March 12th I think. Photos of the unboxing ceremony coming soon.
__________________
slipperyskip.com
Old 1st Mar 2010, 21:21   #6
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming Saiyan
Sweeeeet!
__________________
The Iron Turnip·BlooBalls·Hypnotoad·Plank·Reservoir-Things·NUC-Tooobular·C7Waterblocks·Crusty McBeanbags III·GlassGreen
Powered by: AMD·Gigabyte·Swiftech·Hardware Labs·Noctua·DangerDen
Cheapskate is offline   Reply With Quote
Old 2nd Mar 2010, 00:12   #7
Mach
Multimodder
Mach has yet to learn the way of the DremelMach has yet to learn the way of the DremelMach has yet to learn the way of the DremelMach has yet to learn the way of the DremelMach has yet to learn the way of the DremelMach has yet to learn the way of the Dremel
Awww yeah, front row and center! sub'd!
Mach is offline   Reply With Quote
Old 2nd Mar 2010, 00:38   #8
Boddaker
Still hangin around
Boddaker's Avatar
Boddaker is definitely a rep cheat.Boddaker is definitely a rep cheat.Boddaker is definitely a rep cheat.Boddaker is definitely a rep cheat.Boddaker is definitely a rep cheat.Boddaker is definitely a rep cheat.Boddaker is definitely a rep cheat.Boddaker is definitely a rep cheat.Boddaker is definitely a rep cheat.Boddaker is definitely a rep cheat.Boddaker is definitely a rep cheat.
Dang... I missed Halle Barry AND the VIA rep too??? Guess I was too tied up with keeping kids' grubby hands off of BSG.
Nice work so far. Does that Xacto razor saw have any teeth to speak of?
__________________
www.bods-mods.com
Originally Posted by my brother
Is the name "Neptune's Trident" something you came up with? I can't see how a planet and chewing gum are related.
Boddaker is offline   Reply With Quote
Old 2nd Mar 2010, 01:24   #9
voigts
Hypermodder
voigts's Avatar
voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.
Sub'd
__________________
Project Log: Zenith Antique Radio Scratch Build
Project Log: Project Quintessence
voigts is offline   Reply With Quote
Old 2nd Mar 2010, 01:43   #10
slipperyskip
Member
"Gee mister," said a random lady in the crowd, "Is that a Battlestar Galactica computer?"
"Yeah," Brian Carter replied, "And keep your kid's grubby hands away from it."
Sorry man...had to do it.
__________________
slipperyskip.com
Old 2nd Mar 2010, 17:48   #11
Boddaker
Still hangin around
Boddaker's Avatar
lol!
__________________
www.bods-mods.com
Old 2nd Mar 2010, 19:20   #12
shakka65
Multimodder
shakka65 has yet to learn the way of the Dremel
Sweet! Well you are off to a great start. Keep on modding
shakka65 is offline   Reply With Quote
Old 3rd Mar 2010, 02:19   #13
slipperyskip
Member
Cool! Thanks.
Thanks. I use the "Precision" 40 tooth per inch blade. X-acto also has a 52 tpi but I've never used one.
Here goes the unboxing ceremony. I try not to do these but this IS unobtainium (at least for now) so I give myself an excuse.
Box
Box inside box. Plain brown no-frills industrial box.
Mostly air and packing material inside the box. Welcome to the world of itty-bitty.
Ta-da! The VIA EPIA P820-12L Pico ITX board with a P720-A daughterboard installed.
VIA Nano 1.2GHz 64-bit x86 CPU.
Turned around. The single 3Gbps SATA connector has a hole cut out of the heatsink just for it. To the left is the 44-pin IDE connector. I'll be using both of these. Lined up along the front are the pin headers for four USB ports, audio, power, reset and a bunch of stuff I don't care about.
Backside showing where the SODIMM goes. The yellow thingy is the CMOS battery. Yes, a remote CMOS battery. My biggest complaint about the PX10000 Pico-ITX board was the battery holder soldered to the bottom making the unit much thicker than it needed to be.
Didn't have a Coke can handy so I thought this iPod touch might do in a pinch to show comparable size. Does that work for anybody?
The P720 daughterboard adds 2 USB ports, a VGA port and a Gigabit Ethernet port to the mainboard's onboard HDMI port. That's what I said...HDMI.
Misc. cables I'll look at later.
For me, one of the most amazing things about this board is that it has an onboard power supply. This connector allows you to connect a standard external 60W ACDC power brick directly to the Pico-ITX. I don't have to use a Pico-PSU with this project like I did the last one. TBH..I'm...just...shocked. The power for the rest of the system like the SSD, optical drive and cooling fans comes directly off headers on the Pico board.
So what will this little sucker do? According to VIA I should be able to watch H.264 (BluRay) at 1080p with about 20% CPU utilization. Total system power should max out at around 20W. We'll see.
__________________
slipperyskip.com
Old 3rd Mar 2010, 03:39   #14
murtoz
Busy procrastinating
murtoz has yet to learn the way of the Dremel
What's an iPod?
Seriously though - nice to see another project from you! Will be quietly cheering you on from the sidelines!
murtoz is offline   Reply With Quote
Old 3rd Mar 2010, 04:12   #15
rowin4kicks
a man walked into a bar ...
rowin4kicks's Avatar
rowin4kicks should be considered for presidentrowin4kicks should be considered for presidentrowin4kicks should be considered for presidentrowin4kicks should be considered for presidentrowin4kicks should be considered for presidentrowin4kicks should be considered for presidentrowin4kicks should be considered for presidentrowin4kicks should be considered for presidentrowin4kicks should be considered for presidentrowin4kicks should be considered for presidentrowin4kicks should be considered for president
having had a pico board, i wish you the very best of luck with your project!
those things are f**king tiny mate! Awesome amount of power when you put it next to a full sized board as well.
__________________
Penguin v6.0 - i7 4770k - 7990 - Corsiar 250D - Dell U2410
My Flickr
rowin4kicks is offline   Reply With Quote
Old 3rd Mar 2010, 07:34   #16
stonedsurd
stonedsurd's Avatar
1080p output from _that_?
z0mg o_0
__________________
Old 3rd Mar 2010, 08:10   #17
Bullitdodger
If it ain't broke....Tweak it.
Bullitdodger's Avatar
Bullitdodger has yet to learn the way of the Dremel
z0mg o_0
What he said.....
__________________
Argueing on the internet, is like running in the special olympics.
Even if you win, you're still retarded....
Bullitdodger is offline   Reply With Quote
Old 3rd Mar 2010, 08:43   #18
talladega
I'm Squidward
talladega's Avatar
talladega is a hoopy frood who really knows where their towel is.talladega is a hoopy frood who really knows where their towel is.talladega is a hoopy frood who really knows where their towel is.talladega is a hoopy frood who really knows where their towel is.talladega is a hoopy frood who really knows where their towel is.talladega is a hoopy frood who really knows where their towel is.talladega is a hoopy frood who really knows where their towel is.talladega is a hoopy frood who really knows where their towel is.talladega is a hoopy frood who really knows where their towel is.talladega is a hoopy frood who really knows where their towel is.talladega is a hoopy frood who really knows where their towel is.
i smell much win accumulating in this thread.
__________________
derp
talladega is offline   Reply With Quote
Old 3rd Mar 2010, 08:50   #19
Dragonphreak
Multimodder
Dragonphreak has yet to learn the way of the Dremel
Omg
Must
Watch
That board is amazing.
Dragonphreak is offline   Reply With Quote
Old 3rd Mar 2010, 15:54   #20
BigBazz
What's a Dremel?
BigBazz has yet to learn the way of the Dremel
So whats the plan for this project? I followed your mission project for the cm competition absolutely loved your work (you got my vote ) You have great skills working with wood looking forward to seeing how this pans out
BigBazz is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
