#1 |
Raspberry Pi owner
Geothermal PC Cooling
Just saw this up on Hackaday and thought i'd share it.
Was going to post it in general but thought that people in modding might enjoy it more
__________________
Project Blog Home Rack build, whole house audio & Spa TV Project Xigmatek Elysium WC i7 920 Build Join the CPC/Bit-Tech FAH Team #35947 |
#2 |
I like wood ಠ_ಠ
Very cool project, I saw it over at XS a while back
Someone at bit needs to out do him
__________________
- i7 3770k - MSI Z77A-GD65 - EVGA GTX 570 - 8Gb G.Skill Sniper (1.25v) - Fractal R3 Black - Corsair H50 - Corsair 750HX - Samsung 830 128Gb SSD - 6 Samsung F4EG 2TB - 2 WD Black 1TB - 2 WD Black 750GB - Dell UltraSharp U2410 - WASD V1 Custom - IBM Model M SSK - KBC Poker (Ergo-Clears) - Logitech Mx518 & G500 - Audio Technica AD700 - Logitech Z4 - Windows 7 Pro -
#3 |
Modder
MY setup doesn't really out do that, but somewhat the same...
About 40m of 22mm copper tubing in the crawlspace under my living room floor. Heats up my toes and keeps my pc cool at the same time. Right now the coolant is at 21c, indoor temp 23c, outdoor 10c. Cooling i920 cpu, 4870 gpu, everything on the mb and two hd's. Not done for extreme colling, rather for very low noise. Only fan is the PSU... |
#4 | |
Multimodder
![]() Quote:
![]() ![]() No seriously, I'd love to see some pics of that build if you have any! ![]() /Mork |
#5 |
Modder
Alright, I'll try to include som pics here:
Here you see the copper pipes under my living room floor. 22mm pipes, about 35 meters in total. As you can see, this is just a crawlspace. Normaly the living room floor is quite cold, this has really helped a lot... ![]() Next the pump. This pump is designed for heating systems and should run almost forever... Also included a filter and a valve to force water through the filter. A drain valve at the bottom. Only thing I'd do different is to also have a valve on the intake of the filter so filter could be changed without draining the loop. ![]() Then the pipes run from my crawlspace, under my kitchen floor and up to the first floor where my computer is. This pic sort of show the pipes coming up from my kichen floor and going into the wall. ![]() Then we have the upper control station This is where the pipes come out and where my res is located. The valves are there so I can isolate the computer without stopping the pump/draining the loop. Just need to cover that hole now...![]() And the reservoir, a simple container from IKEA, reinforced the bottom with fibre glass. But messed it up a bit, that's the white smudge you see... ![]() Finally the computer. Watercooled so not going anywhere, therefor built into my desk. ![]() Another shot showing the insides a little better. The 22mm pipe is split into three 1/2" tubes, so three loops: 1-CPU, 2-GPU, 3-HD+MB
#6 |
Avoiding the "I guess.." since 2004
Oh My God. That is pretty damn impressive. Though it seems like besides covering the hole, you might also want to get some work done with that kitchen floor
![]() +rep
__________________
Half a dozen operational setups and truckloads of spare parts.
AllTheMods - MetkuMods - LedCalc - Flickr - BF:BC2 |
#7 |
MX Reds <3
Epic, absolutely epic.
__________________
#8 |
Modder
Well, the kitchen looks a little different now: (last kitchen pic showed lower left corner of this one, pipes to first floor is inside the wall behind the fridge/freezer)
![]() Did it all while rebuiling an old house, so could do just about everything I wanted. 250 year old house with built in watercooling and Cat6 cabling! |
#9 |
absit iniuria verbis
WOW, that is a sweet setup.....
'nuf said + Rep |
#10 |
Raspberry Pi owner
@veland
Awesome setup, i should think about doing something similar when my house gets built. Nothing like using a i7 to heat your house and crunch numbers
__________________
#11 |
(A shrewd and knavish sprite)
Pure awesome, seriously +1 on that setup!
__________________
If you can't shoot it, drive it, or sleep with it, it ain't worth your time. www.pukit.com |
#12 |
Real gamers overclock
That is a sick set up. How much did that cost to build
#13 |
Modder
Not really sure about total cost, as I was building the cooling while I was working om my house... So bought some bits and bobs now and then...
But a quick round with the calculator gives me a figure of about £500 for all the parts outside the computer. Biggest cost is the copper pipes, high copper price now. If anyone wants to build something similar now, I would recommend going with pex pipe for the "transport stage" i.e. the pipes going from the computer to the cooling bits. Preferably the pex used in normal water installation with two layers so potential leaks will drain and pipes can be replaced if needed. |
#14 |
Supermodder
Damn, +rep veland.
#15 |
Supermodder
Thats awesome. To out do him how bout a whole airconditioning like unit which is one big rad sitting outside the house?
#16 |
sudo rm -Rf /
A few people have done this. The problem comes from being too cold in the winter. You get a lot of condensation.
__________________
I always wanted to have that ideal father son relationship. You know, where I get to see him for like eight hours every other weekend, and send checks to some woman I hate. -- Tucker, Red vs. Blue |
