Reply
Thread Tools View Mode
Old 28th Mar 2010, 00:15   #1
The_Beast
I like wood ಠ_ಠ
The_Beast's Avatar
The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!
Project : Make It Black : Finished : 4/5/10
Another simple, no sponsor case mod, much easier than my last, or so I think . So lets get right to it....
Look familiar?
Everything hung-up and ready for priming. Don't worry the sticker was taken off before painting.
Everything is primed, even the screws.
Tomorrow is wet sanding, oh joy but I'll soldier on
__________________
- i7 3770k - MSI Z77A-GD65 - EVGA GTX 570 - 8Gb G.Skill Sniper (1.25v) - Fractal R3 Black - Corsair H50 - Corsair 750HX - Samsung 830 128Gb SSD - 6 Samsung F4EG 2TB - 2 WD Black 1TB - 2 WD Black 750GB - Dell UltraSharp U2410 - WASD V1 Custom - IBM Model M SSK - KBC Poker (Ergo-Clears) - Logitech Mx518 & G500 - Audio Technica AD700 - Logitech Z4 - Windows 7 Pro -
The_Beast is offline   Reply With Quote
Old 29th Mar 2010, 00:05   #2
The_Beast
I like wood ಠ_ಠ
The_Beast's Avatar
A boring update I know but an update none the less
After drying overnight, I wet sanded at 1000 grit
Everything was washed, dried with a hair dryer, then rubbed down with rubbing alcohol. Everything was rehung in the garage/paint booth and then primed again.
Everything was then rehung again in the basement to dry overnight
Tomorrow is wet sanding an then painting
__________________
Old 29th Mar 2010, 22:46   #3
The_Beast
I like wood ಠ_ಠ
The_Beast's Avatar
Everything was wet sanded at 1500 grit, washed, dried, and rubbed with alcohol clean the surface just in case anything was missed in the washing. After everything was hung up in the garage (aka my paint booth) they were painted with Rustoleum flat black auto paint.
I can't do anything since the dry time is 2 days, so no update tomorrow but the next day there will be.
__________________
Old 29th Mar 2010, 23:24   #4
Bullitdodger
If it ain't broke....Tweak it.
Bullitdodger's Avatar
Bullitdodger has yet to learn the way of the Dremel
Looks good.
__________________
Argueing on the internet, is like running in the special olympics.
Even if you win, you're still retarded....
Bullitdodger is offline   Reply With Quote
Old 31st Mar 2010, 21:42   #5
_-..zKiLLA..-_
Multimodder
_-..zKiLLA..-_'s Avatar
_-..zKiLLA..-_ has yet to learn the way of the Dremel
Gotta love flat black +1
__________________
~ASUS M2N-SLI Deluxe AM2 NVIDIA nForce 570~
~AMD AM2 64X2 5600+ 3.25GHz~
~4gb G.Skill 4-4-4-12~
~nVidia 9800GTX+~
_-..zKiLLA..-_ is offline   Reply With Quote
Old 31st Mar 2010, 22:45   #6
The_Beast
I like wood ಠ_ಠ
The_Beast's Avatar
Well I wet sanded again today and put another coat of flat black on, I would have pic but they would be the same as above. Right now everything is hung up to dry, final pics should be up within a few days.
__________________
Old 5th Apr 2010, 23:27   #7
The_Beast
I like wood ಠ_ಠ
The_Beast's Avatar
All done
Since the paint sealed the button some paint had to be removed so it would work, it's a little sloppy but everything is fixed now
Since black is hard to see in the dark recesses of my desk this will have to do for now
__________________
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
