News Rumour: New socket to replace LGA1366 due in 2011
Discussion in 'Article Discussion' started by Sifter3000, 12 Apr 2010.
  1. Sifter3000
    Sifter3000 I used to be somebody
    11 Jul 2006
  2. GFC
    GFC What's a Dremel?
    7 Nov 2008
    Bad news for me. I was kind of expecting to get a double digit-core cpu in my x58 rig.. :/
  3. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    Well, three years isn't a terrible lifespan for a socket, I suppose. Mind you, it's in Intel's habit to swap sockets/standards with each major chipset release.
    That said, these boards are going to be horribly expensive. Just the thought of wiring up four discrete channels passing through a northbridge.
  4. rickysio
    rickysio N900 | HJE900
    6 Jun 2009
    Will be saving up for now, and upgrade my LGA775 rig!
  5. stonedsurd
    11 Mar 2009
    Oh god, ANOTHER one?
  6. ramliz
    ramliz What's a Dremel?
    16 Feb 2010
    As much as I love computers, I am not rich and a pc is still just a pc I tend to buy a monster every 4-5 years take every little bit of pleasure from the build I still have my lovely Q6600 works good for me, the next socket could be a temptation but this just out confirmed i7 is not for me.
  7. Cerberus90
    Cerberus90 Car Spannerer
    23 Apr 2009
    Intel have turned it AMD from the past.
    And AMD have turned into Intel from the past. :D
    AMD had socket A, 75, 939
    Intel had 775 for ages (and 478).
    AMD ruled performance with the Athlon.
    Intel struggled with the P4.
    AMD has had AM2 and AM3.
    Intel 775, 1366,1156,and now another one
    Intel ruling performance with Core i and c2d range
    AMD struggling.
    :D
  8. BlackMage23
    BlackMage23 RPG Loving Freak
    4 Aug 2006
    How long has 775 been around for?
    I'm still using a E6600 on a P45 board, and see no reason to upgrade my CPU at the moment.
    My next upgrade will probably be for a DX11 graphics card.
    If I feel that I need more CPU power I'll just switch to a Q6600 or Q9300 as lots of people are selling those as they upgrade.
  9. dyzophoria
    dyzophoria Minimodder
    3 May 2004
    if changes to the new architecture is that much or there will be a bunch of new stuff to introduce a new pinout is understable, but introduce a new socket with almost the same specs that's different
  10. Farting Bob
    Farting Bob What's a Dremel?
    21 Jan 2009
    Northbridges? How quaint!
    They seem to be pushing the X58 and this successor into enterprise territory more and more. Its clear that 1156 will last at least a while, anything else and your asking to pay a early adopters fee with no guarantee that your next upgrade will be compatible.
  11. Autti
    Autti What's a Dremel?
    29 Oct 2009
    Eh, i dont really mind this.
    Pin count is a hardware limitation, and we all know there is only one way to remove that limitation.
    Intel must be envisaging that 4gb dimms will be abundant and cheap(ish) in 2011, because servers always want more memory, and limiting it to 4 slots seems crazy. Go try and tell an enterprise server they can only use 3 memory slots per CPU and they would laugh at you and buy something else.
  12. BlackMage23
    4 Aug 2006
    Don't forget that they are talking about the desktop part, not a Xeon.
    This will make its way into workstations, but servers will be for the Xeon part.
    and don't forget that the 4 slots will probably be able to take 32GB of memory (assuming 8GB modules start to show up then).
  13. wyx087
    15 Aug 2007
    well, that's expected, Intel have already moved to 4-channel memory in their 8-core server chip. and when you buy the best, expect to be outdated faster than mainstream folks.
    socket LGA1576 next year?
  14. kingozzy666
    kingozzy666 BLASHYRKH!
    25 Apr 2009
    Oooh I never noticed that pattern. Would be funny if you're right.
  15. wyx087
    15 Aug 2007
    outdated as in not the best in town, it will still be very fast, but you will have to spend more to have similar performance as mainstream. (think i7 860 LGA1156 platform vs i7 930 LGA1366 platform, similar performance, one's the best the other is mainstream)
  16. V3ctor
    V3ctor Tech addict...
    10 Dec 2008
    2011... nice year to retire my Q6600 rig... I was waiting on sandybridge or bulldozer/lano from AMD... But I'll wait until 2011, it's not that my cpu is terribly slow now, maybe it comes at the same time as Windows 8 :)
  17. javaman
    javaman May irritate Eyes
    10 May 2009
    I can see AMD releasing another socket when they integrate their graphics into the CPU. TBH is their any point of integrating graphics into the CPU at this stage. They're no better than what they're replacing and they just added extra heat which will reduce overclocking.
  18. Redbeaver
    Redbeaver The Other Red Meat
    15 Feb 2006
    same boat with u :) Q6600 on 775 is still good for now.
    2011 its a new socket.
    and maybe next year ill grab a cheap Fermi470 to keep it running for another year.
  19. frontline
    frontline Punish Your Machine
    24 Jun 2007
    It wIll be 2011 before i even consider another major upgrade. An i7 system would be nice, but i really can't see the justification for an upgrade at the minute, as my existing system is more than capable of doing everything i need it to do.
  20. l3v1ck
    l3v1ck Fueling the world, one oil well at a time.
    23 Apr 2009
    Well LGA1366 didn't last long then did it? Or maybe we've all been spoiled with LGA775. That would put me off buying an LGA1366 CPU/motherboard now.
Tags: Add Tags
