Scratch Build – In Progress Biohazard Computer Case Mod-Back Panel-I/O shield 10/18
Discussion in 'Project Logs' started by BLUEHORSESTUDIOS, 25 Apr 2010.
  1. BLUEHORSESTUDIOS
    BLUEHORSESTUDIOS I haven't lost a finger yet!
    19 Apr 2010
    This project is proudy sponsored by
  2. Kumo
    Kumo What's a Dremel?
    18 Oct 2004
    Awesome, dude. Alsmost speechless.
  3. DeadP1xels
    30 Nov 2009
    Saw the videos amazing glad its on here!
    Be careful though your going to be bombarded with questions :D
  4. Hg
    Hg The game known as life
    3 Aug 2007
    i love that case!
    I love the whole RE universe and this case is epic!
  5. Djayness
    Djayness phwupupupup
    7 May 2008
    Wow, what a first post!
  6. Raiden
    Raiden Portuguese reviewer
    26 Oct 2009
    Im speechless , im doing myself a Re modding but this is another level:rock:
  7. MrWizard
    MrWizard What's a Dremel?
    5 Feb 2008
  8. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    Welcome to bit-tech Ron, glad to see you sharing your awesome work here :rock:
  9. Fizzban
    Fizzban Man of Many Typos
    10 Mar 2010
    Wow that's some impressive work dude!
  10. Attila
    Attila still thinking....
    22 Feb 2008
    Really terrific work Ron. :thumb: I'm particularly loving the fine detail ( my favourite are
    the dents in the drums), the ageing and weathering are spot on, oh, and welcome to bit-tech.:)
  11. stonedsurd
    11 Mar 2009
    Welcome to BT :thumb:
    Very impressive paint and detailing. Looking forward to following this mod.
  12. BLUEHORSESTUDIOS
    19 Apr 2010
    Thanks everyone for those nice comments, I'm new to bit-tech and still learning how to post threads. I'll give a more detailed account for each post when I learn how to do it..lol
    Take Care
    Ron L C
  13. razerz
    razerz What's a Dremel?
    2 Aug 2009
    I love computer cases where you can't see it is a computer!
    On a related note, some time ago I saw a Doom 3-themed case in the same vein as this. Was that you too?
  14. BLUEHORSESTUDIOS
    19 Apr 2010
    WORKING ON A NEW BLOG SITE FEATURING BEGINNING TO ADVANCED MODDERS
  15. BLUEHORSESTUDIOS
    19 Apr 2010
    PART 9 almost complete
  16. Djayness
    7 May 2008
    Is his caps key broken?
    Just giving the benefit of the doubt :p
  17. BLUEHORSESTUDIOS
    19 Apr 2010
    A look at the front door of the case.. Im thinking about adding the front panel switches here..
    These stairs will lead to the top of the case roof.The roof will be the case door allowing us access to the interior​
    Up close look at the rust and weather detailing
    In the door and the ceiling are small glowing blue L.E.Ds
    A look at the case and the base, still needing more paint and details. Most of the cables will run under the base.
    Now with some lights added..Starting the first paint layers.. weathering coming a bit later
    Another look before adding signs and other details
    Added some light rust and dirt areas.
    Adding some modelers putty to fill in some small seams
    Scale modelers putty​
    Ive had several people ask me about the tools and the product I use to build this case so heres a brief description..:dremel:
    Polystyrene or "plastic styrene" I use 00.40mm and a 00.60mm 48x96 in sheeting.
    I use a company called Calsak Plastics and each sheet retails for about $25.00 . Most hobby store scarry this type of styrene in smaller sheets but its very expensive.
    Clear Lexicon and Clear Polyester, I use this for my windows ,control panels or any light fixtures in the case.
    Novelty styrene pieces. Plastructs and Evergreen make a wide variety of finishes.
    I use several types of glues. I use the IPS weldon for all structural pieces. This acts as a cold weld , welding the to pieces of styrene together. I only use super glue on the small non structural bits.
    Files and scribers
    Dremel tool..This by far is my favorite modding tool and use it more then anything else.
    Various Knifes and Blades.
    I use a Iwata Hb-Cs dual action brush with a 80psi compressor.
    I picked up both these at TCP Global for about $200 shipped.
    The Iwata will spay several types of medium but requires consistant cleaning to insure good spay quality.
    Acrylic paints and thinner .Non toxic and easy clean-up.
    Scale Modelers square
    Most of these products can be purchased at your local Arts and hobby store
    Cable Management Towers
    Ill be using these to run some of my cables thru.Instead of hiding the cables Im going to enclose them in some small round stock to simulate airducks and vent pipes.
    Biohazard Drum, waiting to be painted.
    Hard drive bay doors. I still need to add the airlock decals and signs.
    Steam generator tower and HDD door before and signs and weathering
    Active steam. I use a small railroad modelers stream generator to achieve this effect
    A closer look at the HDD door and some of the paint and weathering details
    Loading bay plate form
    A closer look at the steam generator. This is made from a small chinese satellite model kit
    A look at the Loading bay plateform and Hdd door
    Water cooling plateform. This will enclosed within the case and all the tubeing will be contained in the structure
    Im also adding a fan cooling option in case that I ever move away from water cooling in this build.
    I started the constuction and the exterior leftwing walls and motherboard try this week
    You can also follow my entire video worklogs here
    http://www.youtube.com/ronleec1
    A few more tool I picked up today to get started on the small railings that will wrap around the case
    Metal siding, One of the many finishes by Evergreen Styene
    A closer look
    Small strip styene that Ill use for the skirting around the entire piece to hide any gaps!
    A closer look at these as well.
    Some rub on letters and vinyl letters that Ill be using in todays project
    So lets get started!!
    Today were going to be creating a very simple stencil with our vinyl and rub-on letters.
    First Im going to lay down a base coat of flat white, then lay down my vinyl letters.
    Next I will spay a mixture of german grey and rust over the top of my mask then remove the mask revealing I decal underneath.Then I finish up by adding a very simple fade and weather effect.
    Ill be adding a Airlock sign to this door
    This is the location of where I want to put it.I marked out in pencil a rough idea of where I want it to go.
    I masked out the area and started to spray even coats of flat white.
    The small vinyl letters Ill be using for the mask
    Artist tape , Ill be using this to create my hazard lines
    Mixing gernam grey and rust for my top coat color
    Q-tip test.. if the paint is to thin it will drip from the Q-tip
    Im looking for the consistency of skim milk
    Adding top-coat
    First coat
    Adding more rust to my mixture
    Added light rust effects
    Now lets peel away the stencil
    Looks good, now the rest
    Oops, looks like I had some peeling!
    No problem..Ill make this work for me by adding my weathered and chipped paint to this area
    touch ups
    Now some metallic effects
    More worklogs coming soon!!​
  18. DeadP1xels
    30 Nov 2009
    Amazing work Ron
    i was actually considering getting my own airbrush for something like this after seeing your videos i went to my local hobby shop and noticed they sold the same plastic styrene sheets and tamiya paints!
    Im looking forward to seeing more work from this
  19. merple
    merple What's a Dremel?
    18 Dec 2007
    wow amazing attention to detail, love the steam effect
    the video log is great too, shows us a lot more of the details than what a bunch of pics can
  20. Danny
    Danny What's a Dremel?
    4 May 2010
    Wow, looks amazing. :D
