Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 2nd May 2010, 14:10   #1
Dark Matter
Supermodder
Dark Matter's Avatar
Dark Matter is a hoopy frood who really knows where their towel is.Dark Matter is a hoopy frood who really knows where their towel is.Dark Matter is a hoopy frood who really knows where their towel is.Dark Matter is a hoopy frood who really knows where their towel is.Dark Matter is a hoopy frood who really knows where their towel is.Dark Matter is a hoopy frood who really knows where their towel is.Dark Matter is a hoopy frood who really knows where their towel is.Dark Matter is a hoopy frood who really knows where their towel is.Dark Matter is a hoopy frood who really knows where their towel is.Dark Matter is a hoopy frood who really knows where their towel is.Dark Matter is a hoopy frood who really knows where their towel is.
How to Remove/unclip a SATA Cable
How do I remove/unclip a SATA Cable From my motherboard or an HDD?
I didn't want to do this without checking first, I know "carefully" but is there a specific technique or part of the connector that is pressed?
Thanks
Dark Matter is offline   Reply With Quote
Old 2nd May 2010, 14:26   #2
mkb
Supermodder
mkb's Avatar
mkb has yet to learn the way of the Dremel
just pull it off if it doesnt have a clip, if it does press the clip mechanism down and remove it
mkb is offline   Reply With Quote
Old 2nd May 2010, 14:33   #3
Cupboard
I'm not a modder.
Cupboard's Avatar
Cupboard has yet to learn the way of the DremelCupboard has yet to learn the way of the DremelCupboard has yet to learn the way of the Dremel
if it is one with a clip, hold the clip release down and pull. If it doesn't have a clip, just pull.
They should come out pretty easily
__________________
i7 920, 5870, 6GB Corsair all in an Intel DX58SO; 60GB Vertex, 1.5TB F2; Fractal Design R2
ThinkPad Edge 13.
Cupboard is offline   Reply With Quote
Old 2nd May 2010, 14:34   #4
Unicorn
Uniform November India
Unicorn's Avatar
Unicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming Saiyan
Before you get flamed for this, I'll alswer the question for you.
There are two types of SATA connector, a locking type and a non-locking type. The locking connectors have a small metal clip on the top of the connector itself. If it's one of these, you need to press the clip down and pull the connector straight out. Like I said, the clip is attached to the connector on the cable itself, so that comes with the connector when you pull it. Don't frek out and think you've broken it because you assumed the metal part was connected to the motherboard or hard drive!
If the connector does not have a metal clip on it, then you just need to pull it straight out of the board or hard drive. They just "click" into place, and only go in or come out one way, so don't be afraid of it... just pull it out straight and gently.
[edit]
Ninja'd
__________________
"For every stalwart bit-tech-worthy tech out there, another 2 cretinous arse-scratchers are out there pulling your patches and reconfiguring your ****." - Krikkit
Unicorn is offline   Reply With Quote
Old 2nd May 2010, 14:44   #5
DK63
Resident magpie
DK63's Avatar
DK63 is a Super Spamming SaiyanDK63 is a Super Spamming SaiyanDK63 is a Super Spamming SaiyanDK63 is a Super Spamming SaiyanDK63 is a Super Spamming SaiyanDK63 is a Super Spamming SaiyanDK63 is a Super Spamming SaiyanDK63 is a Super Spamming SaiyanDK63 is a Super Spamming SaiyanDK63 is a Super Spamming SaiyanDK63 is a Super Spamming Saiyan
Unless you have a latching cable, you just pull it off the connector. Sata is supposed to be hot swappable, but personally I'd rather turn the power off first.
__________________
The Definition of an Upgrade: Take old bugs out, put new ones in.
DK63 is offline   Reply With Quote
Old 2nd May 2010, 14:45   #6
DK63
Resident magpie
DK63's Avatar
Took too long to type, obviously, as there were no replies when I started! lol
__________________
Old 2nd May 2010, 14:55   #7
Dark Matter
Supermodder
Thanks for the answers
Case closed
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
