News NEC announces new phase-change cooler
Discussion in 'Article Discussion' started by Sifter3000, 3 May 2010.
  1. Sifter3000
    Sifter3000 I used to be somebody
    11 Jul 2006
  2. memeroot
    memeroot aged and experianced
    31 Oct 2009
    sounds great, sounds far off
  3. [USRF]Obiwan
    [USRF]Obiwan What's a Dremel?
    9 Apr 2003
    interesting indeed! Shame the included pic is a old nec cooling system...
  4. Gareth Halfacree
    4 Dec 2007
    Aye - NEC hasn't released any images of the new system yet.
  5. rickysio
    rickysio N900 | HJE900
    6 Jun 2009
    The only thing I can say is
    REEEALLY?
  6. confusis
    confusis Kiwi-modder
    5 Jan 2006
    once again NEC excels. If it's cheap i'm buying two!
  7. Teknokid
    Teknokid Minimodder
    6 Dec 2007
    80% less energy than a high end air cooling system? right.. so that would be 80% less energy than a fan? I dont think so some how...
  8. GravitySmacked
    GravitySmacked Mostly Harmless
    2 Mar 2009
    Impressive claims indeed.
  9. FelixTech
    FelixTech Robot
    12 Jun 2009
    They might be referring to server racks/hpc systems, which are often like wind tunnels :p
  10. Star*Dagger
    Star*Dagger What's a Dremel?
    30 Nov 2007
    Ill take 3! One for the cpu and one each for my gpus!
  11. Kalcifer
    Kalcifer If you want change, start with yourself.
    23 Sep 2009
    Sign me up, if this lives up to its promises, I will be getting one, maybe even two.
    I am very interested in which type of micro-compressor they used, anyone know?
  12. Xir
    Xir Modder
    26 Apr 2006
    Hmmm, what else boils at 50° Celsius? :D
  13. l3v1ck
    l3v1ck Fueling the world, one oil well at a time.
    23 Apr 2009
    Will it be like some HSF's that cope well with most chips but struggle with high end hot ones?
  14. EdwardTeach
    EdwardTeach What's a Dremel?
    3 May 2010
    sounds like it will take a few years to filter through to the consumer market
  15. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    If it's cheaper than watercooling I'm in.
  16. eddtox
    eddtox Homo Interneticus
    7 Jan 2006
    If it's as good as they say it is they'll make a killing in data centres and similar environments.
  17. Combatus
    16 Feb 2009
    Not sure about the 'impressive' reduced power claims, they seem a bit desperate to me considering your average pump uses about 20W plus a few fans which draw next to nothing - even if they used 70% less power this would still only be a saving of less than 18W. Not exactly earth shattering savings when you consider a GTX 480 uses 300W :D. If the vapour needs to evaporate at 50 degrees Celsius for the circulation to kick in, that's already pretty warm so it would be interesting to see how close to ambient one of these could get compared to a high end custom watercooling system.
  18. Deadpunkdave
    Deadpunkdave ...why you need a 20-sided die
    9 May 2009
    Again, i think the efficiency angle is for server rooms where a 70% saving could save significant money.
  19. Xir
    Xir Modder
    26 Apr 2006
    Two questions about phase change coolers.
    C5H12 Pentan (Boils at) 36°C (ignites at) 309°C
    C6H14 Hexan (Boils at) 69°C (ignites at) 240°C
    First: What fluid is used in the "VaporX" coolers?
    secondly, in a normal ATX-case the graphicscart is placed "Upside down".
    Wouldn't the gas phase be at the hot point (die), and the fluid phase at the cold cooler side?)
  20. Autti
    Autti What's a Dremel?
    29 Oct 2009
    NEC discover how fridges work.
    Good work. :)
    Bit cynical but how can't you be with such claims.
Tags: Add Tags
