Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 6th May 2010, 10:25   #1
CardJoe
Freelance Journalist
CardJoe's Avatar
CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.
Scribd moves to HTML 5, ditches Flash
http://www.bit-tech.net/news/bits/20...es-to-html-5/1
__________________
I was Bit-tech's Games Editor. Now I'm freelance. Find me at:
www.joemartinwords.com
@joethreepwood on Twitter
CardJoe is offline   Reply With Quote
Old 6th May 2010, 10:30   #2
lacuna
Supermodder
lacuna is the Cheesecake. Relix smiles down upon them.lacuna is the Cheesecake. Relix smiles down upon them.lacuna is the Cheesecake. Relix smiles down upon them.lacuna is the Cheesecake. Relix smiles down upon them.lacuna is the Cheesecake. Relix smiles down upon them.lacuna is the Cheesecake. Relix smiles down upon them.lacuna is the Cheesecake. Relix smiles down upon them.lacuna is the Cheesecake. Relix smiles down upon them.lacuna is the Cheesecake. Relix smiles down upon them.lacuna is the Cheesecake. Relix smiles down upon them.lacuna is the Cheesecake. Relix smiles down upon them.
...forcing users onto an alternative browser if they want to use the future Flash-free version of Scribd
Oh no.
lacuna is offline   Reply With Quote
Old 6th May 2010, 10:36   #3
Jamie
ex-Bit-Tech code junkie
Jamie's Avatar
Jamie is definitely a rep cheat.Jamie is definitely a rep cheat.Jamie is definitely a rep cheat.Jamie is definitely a rep cheat.Jamie is definitely a rep cheat.Jamie is definitely a rep cheat.Jamie is definitely a rep cheat.Jamie is definitely a rep cheat.Jamie is definitely a rep cheat.Jamie is definitely a rep cheat.Jamie is definitely a rep cheat.
The more people that move away from IE the better.
__________________
Jamie is offline   Reply With Quote
Old 6th May 2010, 11:38   #4
eddtox
Homo Interneticus
eddtox has yet to learn the way of the Dremeleddtox has yet to learn the way of the Dremel
I'm all for it. Even though I can and do use flash on all my devices, I would love to be rid of it and just have HTML5.
__________________
Check out my big clearout sale - Now with added Kindle
eddtox is offline   Reply With Quote
Old 6th May 2010, 11:56   #5
Farting Bob
Supermodder
Farting Bob's Avatar
Farting Bob has yet to learn the way of the DremelFarting Bob has yet to learn the way of the DremelFarting Bob has yet to learn the way of the Dremel
HTML5 is overrated. It does almost as much as flash, and if you use a flash version with GPU acceleration then HTML5 is usually slower/uses more CPU to playback videos.
Sure flash should die because its bloated, inefficient and has seen more holes in its time than Tiger Woods, but the recent love for HTML5 and hate for flash seems somewhat irrational at times.
Farting Bob is offline   Reply With Quote
Old 6th May 2010, 12:22   #6
cgthomas
Cpt. Handsome
cgthomas's Avatar
cgthomas has yet to learn the way of the Dremel
Originally Posted by Farting Bob
...and has seen more holes in its time than Tiger Woods
Are you sure about this, he has seen many and not only while playing golf
__________________
Iím an AquaTuning product tester - I am........ honestly
cgthomas is offline   Reply With Quote
Old 6th May 2010, 13:11   #7
aussiebear
Minimodder
aussiebear has yet to learn the way of the Dremel
I'm all for moving to HTML5; because Flash does NOT follow the open-ness that is the web. Its a proprietary solution that is controlled by a particular single party. The web is supposed to be universal. It should NOT be relying on any one specific technology to function.
Flash is also an excellent vector for security issues; regardless of platform.
(a) There is no integrity mechanism that prevents running executables in the Adobe Flash cache folder; Unless you specifically enabled the prevention of executables on the OS you're running. (All you need to do is to trick a user into running an animation with malware embedded into the object.)
(b) It allows malware writers to target anyone using Flash. It means end-users suffer from a single point of failure from a security perspective. (No AV app will protect you from flaws in the programs you use.)
...And to be quite frank about the matter; Adobe's response to security issues in their solutions is downright shocking. (Both their Flash and Reader are vulnerable to issues that they still haven't patched for.)
The only issue with HTML5 is the video tag.
You've got Apple and Microsoft (with their MPEG-LA friends) on one side; wanting to push H.263 because they can get royalty payments out of it...They are also intentionally using FUD of software patents to scare others into not adopting royalty free alternatives. ie: By saying things in a deliberately vague manner, and not admitting to what specific patents Theora is infringing. (The point is to use the potential threat of patent infringements as FUD!)
Then you have Firefox and Opera refusing to accept this. They see that the web is supposed to be completely unencumbered and royalty free. So ANYONE is allowed to adopt it for $0, for any purpose. As a result, they both adopt Theora codec.
Google is in an interesting situation:
* They have the power to influence what video web codec is to be run via the popularity of Youtube.
* They have adopted both H.263 and Theora in their Chrome browser and Chrome Frame.
(So technically: Windows, OSX, and Linux are all supported.)
and...
* They can throw a complete monkey-wrench in MS/Apple/MPEG-LA's plans by introducing their VP8 codec in a completely open and royalty free manner.
The less dependent on Adobe products; the more secure we all are.
aussiebear is offline   Reply With Quote
Old 6th May 2010, 14:39   #8
leveller
Yeti Sports 2 - 2011 Champion!
leveller has yet to learn the way of the Dremelleveller has yet to learn the way of the Dremelleveller has yet to learn the way of the Dremelleveller has yet to learn the way of the Dremelleveller has yet to learn the way of the Dremelleveller has yet to learn the way of the Dremel
Guidelines and standards keep everything ticking over nicely (HTML). Flash is more harmful to mobile devices in terms of performance and stability than people seem to realise.
leveller is offline   Reply With Quote
Old 6th May 2010, 14:41   #9
WarrenJ
Mod Master
WarrenJ is the Cheesecake. Relix smiles down upon them.WarrenJ is the Cheesecake. Relix smiles down upon them.WarrenJ is the Cheesecake. Relix smiles down upon them.WarrenJ is the Cheesecake. Relix smiles down upon them.WarrenJ is the Cheesecake. Relix smiles down upon them.WarrenJ is the Cheesecake. Relix smiles down upon them.WarrenJ is the Cheesecake. Relix smiles down upon them.WarrenJ is the Cheesecake. Relix smiles down upon them.WarrenJ is the Cheesecake. Relix smiles down upon them.WarrenJ is the Cheesecake. Relix smiles down upon them.WarrenJ is the Cheesecake. Relix smiles down upon them.
You know my pain
__________________
Originally Posted by Evolutionsic View Post
"Trust no one"
WarrenJ is offline   Reply With Quote
Old 6th May 2010, 15:20   #10
rickysio
N900 | HJE900
rickysio has yet to learn the way of the Dremel
Really? My N900 has yet to crash/lag due to Flash.
Flash (when properly implemented into the browser, like MicroB) is the only thing that will lag if it requires too much CPU, not my device!
rickysio is offline   Reply With Quote
Old 6th May 2010, 16:14   #11
Arj12
Multimodder
Arj12 has yet to learn the way of the Dremel
I always experience problems with flash on most my pcs. Either they start giving errors or they work for a while and then I get something saying flash is causing my pc to be unresponsive! That's why I am happy the HTML 5 is at least starting to be taken up and hopefully in the future it'll become the mainstream!
Doesn't look like Adobe are going to be too happy though!
Arj12 is offline   Reply With Quote
Old 6th May 2010, 17:48   #12
gavomatic57
I Mod, Therefore I Own
gavomatic57 has yet to learn the way of the Dremelgavomatic57 has yet to learn the way of the Dremel
Correct me if I'm wrong, but it's not about system load, it's about the fact that with Flash Adobe owns the internet, with HTML5, assuming VP8 gets adopted and open-sourced, nobody does - nobody has too much influence and nobody gets left out.
If HTML5 goes down the H264 route, it's going to require a $5m buy in from the likes of Mozilla and if Ogg Theora is adopted then there is likely to be much litigation from parasitic patent lawyers to come.
__________________
Core i7 920 (D0), 6GB RAM, Geforce GTX 275, Seasonic M12-600, Samsung 226BW, Ubuntu 10.04 & Vista x64 & a Macbook Pro 13" & a PS3
My Flickr
My Blog
gavomatic57 is offline   Reply With Quote
Old 6th May 2010, 21:44   #13
leveller
rickysio ... in over 10 years of using Flash I can't count how many times I've witnessed lag and Flash crashing and this is from badly written flash programs - in fact I've even written some that lagged and crashed out. I can't say however that I've ever used a badly implemented install of flash to a browser as you suggest. Maybe you could give some examples of that?
And for the rest, Opera is now in on the debate: http://www.electronista.com/articles...oon.to.change/
Old 7th May 2010, 00:44   #14
SaNdCrAwLeR
Multimodder
SaNdCrAwLeR has yet to learn the way of the Dremel
IE9 supports HTML5 and CSS3 it seems... are they finally deciding to catch up to times?
SaNdCrAwLeR is offline   Reply With Quote
Old 7th May 2010, 22:17   #15
SinnerG
Minimodder
SinnerG has yet to learn the way of the Dremel
This will come down to how the browser developers intend to handle those H.264 streams. Just about every GPU can do H.264 accelleration these days and most of the codecs can hand off this task. In Win7, for example, even the Microsoft default codec does H.264 accelleration so pushing that video to a DirectShow graph will get GPU accelleration.
But I guess we'll see how it all pans out and how each browser will cope with it.
SinnerG is offline   Reply With Quote
Old 18th May 2010, 04:11   #16
drclue
What's a Dremel?
drclue has yet to learn the way of the Dremel
How Silly
Flash is used as a wrapper for encoded content. By and large most of that video content is currently encoded using the H.264 CODEC.
It is this H.264 CODEC that has embedded support in computing hardware
not the Flash wrapper, which itself is just added bloat ware.
What this means is that HTML5 browsers are just as able to exploit those
hardware based decoders as Flash , but without the additional bloat of Flash.
Further more , those using Flash are exposing themselves to ever increasing security risks says Symantec.
As reported by Symantec (The security people)
In 2007 Adobe Flash Featured 11 security issues
In 2008 Adobe Flash Featured 16 security issues
In 2009 Adobe Flash Featured 24 security issues
Symantec further reported
[Among the vulnerabilities discovered in 2009, a vulnerability affecting both Adobe Reader and Flash Player was the second most attacked vulnerability. This was also one of four zero-day vulnerabilities affecting Adobe plug-ins during 2009. Two of the vulnerabilities were in the top five attacked vulnerabilities for 2009. Additionally, Adobe vulnerabilities have been associated with malicious code attacks such as the Pidief.E Trojan.]
Adobe is trying it's hardest to run a dis-information campaign to retain the flow from it's cash cow Flash, in the form of the $1300.00 / copy admission price to cover the cost of the tools required to author Flash content and nothing more.
As a BTW, just to head off a particular brand of stupid comments. I'm not an Apple Fan boy, nor do I own any of their products. I'm a web developer of 13 years and have been working with computers since before Microsoft or Apple even existed.
drclue is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
