Go Back   bit-tech.net Forums > Modding > Modding
Reply
Thread Tools View Mode
Old 6th May 2010, 15:11   #1
gcwebbyuk
Dib Dabbler
gcwebbyuk's Avatar
gcwebbyuk is a hoopy frood who really knows where their towel is.gcwebbyuk is a hoopy frood who really knows where their towel is.gcwebbyuk is a hoopy frood who really knows where their towel is.gcwebbyuk is a hoopy frood who really knows where their towel is.gcwebbyuk is a hoopy frood who really knows where their towel is.gcwebbyuk is a hoopy frood who really knows where their towel is.gcwebbyuk is a hoopy frood who really knows where their towel is.gcwebbyuk is a hoopy frood who really knows where their towel is.gcwebbyuk is a hoopy frood who really knows where their towel is.gcwebbyuk is a hoopy frood who really knows where their towel is.gcwebbyuk is a hoopy frood who really knows where their towel is.
CM690 II and Zalman Reserator 1 V2
Not totally sure if this is in the right section, but wanted to see what people thought of my current build.
It started out as a Phenom 965C2 build in a small Coolermaster Elite case. It was air cooled and I tried to keep it as quiet as possible.
As you can see from the first pic here, it was quite tight in the case with a Zalman CNPS10x Quiet cooler, and also the fact the cooler blocked 2 of the RAM modules:
I then swapped to a Zalman CNPS9900 NT cooler to allow me to use the other two RAM sockets:
I was running a Zalman GV1000 GPU cooler which was important as the Gigabyte/Zalman cooler was at 100% fan speed all the time and only had a 2pin fan connector
I then started playing around with moving fans around and adding more to keep temps down:
But then decided that the case was too small, so moved onto a CM690-II Advanced...
gcwebbyuk is offline   Reply With Quote
Old 6th May 2010, 15:18   #2
gcwebbyuk
Dib Dabbler
gcwebbyuk's Avatar
This image shows the build with a CNPS 10x Flex fan with an S-Flex E and a Kaze Slim fan attached:
Also my attemps at braided cables, and the 2 Scythe Quiet Drives for my mechanical drives:
I also then modded the Zalman cooler with two Scythe 92mm GTs to try and make the GV1000 even quieter:
However after spending a lot of time messing about with fans I bit the bullet and decided to go watercooled with the Zalman Reserator:
This was OK, but temps were a little off perfect, so I added an XSPC RX240 radiator too:
And as you can see from here, my final temps aren't too shabby after a 12 hour Prime95 run:
The case now has 5 S-Flex E fans all running at 630rpm:
2 on the XSPC as intake (in the photo they are GTs, but I changed them to S-Flexs as wasn't keen on the noise of the GTs.
1 on the rear as exhaust
2 on the top as exhaust
I welcome your thoughts!
Old 7th May 2010, 21:54   #3
gcwebbyuk
Dib Dabbler
gcwebbyuk's Avatar
Full System Spec:
AMD Phenom 965 C2 - 140TDP Version
Gigabyte 790XTA-UD4 F3f BIOS
8GB Corsair XMS3 1600MHz 8/8/8/24
1 x 80GB Intel X-25-M SSD (OS: Windows 7 64bit)
2 x 1TB Samsung EcoGreens in Scythe QuietDrives (Data and Backup)
Gigabyte ATI HD4870 1GB - soon to be replaced with an Asus 5770 1GB
Asus Essence STX - Logitech X230 Speakers / Grado SR80i Headphones
Coolermaster CM690-II Advanced case
Corsair HX620W PSU
Zalman Resorator Watercooling kit
XSPC RX240 Radiator
5x Scythe S-Flex E fans running at 630rpm
Saitek Eclipse II keyboard & Cyborg V3 Mouse
Old 10th May 2010, 22:32   #4
gcwebbyuk
Dib Dabbler
gcwebbyuk's Avatar
New additions arriving soon:
Asus 5770 - arriving Wednesday
Aquatuning goodie bundle in white!
In due course:
Some better speakers possibly...
Old 15th May 2010, 00:30   #5
gcwebbyuk
Dib Dabbler
gcwebbyuk's Avatar
Old 15th May 2010, 00:31   #6
gcwebbyuk
Dib Dabbler
gcwebbyuk's Avatar
My resorator looks bent
Old 9th Jun 2010, 16:13   #7
gcwebbyuk
Dib Dabbler
gcwebbyuk's Avatar
Old 29th Jun 2010, 14:55   #8
lmth
What's a Dremel?
lmth has yet to learn the way of the Dremel
It must be a very expensive project.
lmth is offline   Reply With Quote
Old 29th Jun 2010, 18:28   #9
gcwebbyuk
Dib Dabbler
gcwebbyuk's Avatar
It wasn't so much a project - and not really a mod - just didn't know the best place to show some pics.
Slight change from the last pic - I now have AudioEngine A2 speakers instead of the M-Audio AV20s - went through 3 sets, they all hummed and all were off balance. The A2s are amazing!
I have also now re-used the old case, bought a MB/CPU/RAM kit off of FantasticDan on here, and a Corsair CX400 PSU, used my CNPS10x Flex as a cooler, and the Phobya fan I won on the AquaTuning comp and made a Silent Server too
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
