News Distributor announces 2.5" 15K hard drive
Discussion in 'Article Discussion' started by CardJoe, 7 May 2010.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. Redkachina
    Redkachina Califragilistsic Expialidocious
    2 Apr 2009
    Apart from the battery life..I rather keep the 15K spinning drives in my desktop rather than inside the laptop..
  3. confusis
    confusis Kiwi-modder
    5 Jan 2006
    I can imagine someone accidentally putting pressure on the top and the disc shattering at those speeds
  4. mi1ez
    mi1ez Modder
    11 Jun 2009
    also a potential competitor to the velociraptor?
  5. rickysio
    rickysio N900 | HJE900
    6 Jun 2009
    Most likely from the company that makes the VelociRaptor.
  6. liratheal
    liratheal Sharing is Caring
    20 Nov 2005
    ..What the ****
  7. livenoise
    livenoise Virgin Modstar
    22 May 2009
    Wouldn't it be as noisy as hell spinning at 15k?
  8. Picarro
    Picarro What's a Dremel?
    9 Jun 2009
    As soon as you could hear that spinning up, you could see the battery meter of your laptop draining :D
  9. B3CK
    B3CK Minimodder
    14 Jun 2004
    Pricing would have to be well below SSD prices to warrant consideration in my notebook.
  10. general22
    general22 What's a Dremel?
    26 Dec 2008
    Would be madness to put this in a notebook, I am not well versed in storage in servers but would the performance gains really make a difference over arrays of hundreds of drives? Otherwise I am guessing the 2.5" form factor allows greater storage density as you can use more drives.
  11. Iorek
    Iorek What's a Dremel?
    18 Jul 2006
    lol, indeed.
    Its more use for a desktop PC, or a "desktop replacement" rather than a laptop. Think about the heat generated in a laptop too, mine gets hot enough and thats on a 5400rpm drive :/
  12. general22
    26 Dec 2008
    Sooo can I buy your laptop
  13. Iorek
    18 Jul 2006
    heat :p
  14. rickysio
    6 Jun 2009
    Greater storage density, lower power draw (assuming same number of drives) and probably lesser heat vs a 3.5" HDD.
    This probably uses 3 300GB platters.
  15. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    If it's using 3 x 300GB platters, it's going to be 12-15mm thick, rather than the standard 9. Couple that with the rather INSANE heat, and the incredible fragility of laptop drives, and this might be a drive best suited for enterprise usage. Where's it's not going to move. And be in datacenters.
  16. rollo
    rollo Modder
    16 May 2008
    SSD please
    be cheaper id think too
  17. Fordy
    Fordy Minimodder
    28 Feb 2010
    Aww, I'm still saving for an SSD :p
    Ie. Western Digital.
  18. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    Well that goes to be one hot mother....
  19. kHAn_au
    kHAn_au What's a Dremel?
    12 Dec 2005
    Thank god and about time, I need these in the enterprise sector!
    900GB and being able to fit 4 of these in the space of every 3.5 inch drive finally breaks the capacity density stand-off between the form factors.
    The biggest 15k drive i can get currently is only 600GB in 3.5 factor too!
    Odd there has been no whispers around the channel or enterprise news about this until now...
  20. rickysio
    6 Jun 2009
    It's not that I don't know - heck, I run 2 WD drives in my PC. It's just a reply to the post above mine. (Which is quoted below.)
Tags: Add Tags
