News Nvidia launches GTX 480M: Fermi for laptops
Discussion in 'Article Discussion' started by Sifter3000, 27 May 2010.
  1. Sifter3000
    Sifter3000 I used to be somebody
    11 Jul 2006
  2. GiantStickMan
    GiantStickMan What's a Dremel?
    14 Feb 2010
    Keen to see how it stacks up against the 5870. I also see Dell/Alienware are now offering 2 x 5870's in Crossfire in the M17x. Seems Nvidia have a bit of catch-up to do!
  3. TWeaK
    TWeaK Minimodder
    28 Jan 2010
    Wow Bindi, did you invent a time machine? :p
    Seriously though, if these are anything like the desktop counterparts, they really aren't going to be a good idea. I can see the A&E depts swamped with 3rd degree burns on peoples' funny bits.
  4. Sifter3000
    11 Jul 2006
    No, my fault, pushed the wrong button in the CMS :S
  5. javaman
    javaman May irritate Eyes
    10 May 2009
    I imagine it will be similar to the desktop parts: too hot and drains to much battery but performs really well. TBH laptop GPU's are still sort of an enigma. I haven't came across to many reviews. same with lap top CPU's too. The article on the CULV processors highlighted that
  6. D-Cyph3r
    D-Cyph3r Gay for Yunosuke
    31 Aug 2008
    Now where's a picture of a laptop on fire when you need one?
    Oh hai
  7. pimonserry
    pimonserry sounds like a party.
    20 Dec 2008
    AKA the power draw will be ridiculously high, I'd bet.
  8. Tangster
    23 May 2009
    Nvidia 1: Battery Life 0.
  9. TFSakon
    TFSakon What's a Dremel?
    27 May 2010
    Have they totally forgotten that their 400 series flopping i feel of hurt by nVidia
  10. l3v1ck
    l3v1ck Fueling the world, one oil well at a time.
    23 Apr 2009
    This sort of false marketing annoys me annoys me. If it's similar to the desktop GTX 465, than call it a 465M. Don't try and make it sound better than it is by calling it a 480M. It's almost false advertising!
    Also with that kind of power draw, I'd be heading for ATi if I was in the market for a new laptop.
  11. Nature
    Nature Minimodder
    21 Nov 2005
    your skybox HD add is making my netbook lag. And the alienware add before it is clearly contradicted by this article claiming to be the most powerful/fastest laptop available whilst lacking this GPU.
    Whine, whine, whine, I know...
  12. chumbucket843
    chumbucket843 What's a Dremel?
    3 Jul 2009
    it will be fine. note that the clocks are half of the 480. power efficiency will increase by a minimum of 2x.
  13. pimonserry
    20 Dec 2008
    Not if it's really inefficient, but you're more than likely correct.
    Also, 0.5 * (say) 150W is still 75W, which sounds like an awful lot for a laptop's graphics card, especially when you consider a new Intel ULV CPU is only 17W.
    Still, if it beats every other laptop's graphics performance, it's still worth considering.
  14. bob
    bob What's a Dremel?
    15 Dec 2009
    So you'll be able to play games and get sterilized at the same time? cool.
  15. ripmax
    ripmax Minimodder
    8 Apr 2010
    Fermi + Laptop =
  16. r4tch3t
    r4tch3t hmmmm....
    17 Aug 2005
    I would get it, I had to choose between a either a crappy desktop + crappy laptop or decent laptop when I went to Uni so I went with a decent Laptop with a 8600GT battery life has never been good but I use the battery mainly so that I don't have to turn it off when I move between classes/rooms. My laptop running at full draws 90W (empty battery playing games for a couple hours after battery is at ~10% with a 90W adaptor.) So this isn't that bad. Plus I would think they would refine it a bit to further reduce the power draw.
    Also why compare a high end GFX card with a low power slower CPU of course it's going to draw a lot more power.
    In conclusion, battery life is unimportant for these kind of laptops.
  17. Kúsař
    Kúsař regular bit-tech reader
    23 Apr 2008
    I hope they don't underrate thermal output this time or there'll be another geforce holocaust...
  18. phantombudgie
    phantombudgie What's a Dremel?
    19 May 2010
    "Or is your room simply colder than you'd like?" - accurately pre-empting the comments!
    It'll be OK for a 17" desktop replacement that would normally sit on a desk and never be moved. A large enough chassis might be able to shift enough air across the heatsink, but I'd hate to think what the sound of the cooling fans will be like.
  19. Ahadihunter1
    Ahadihunter1 What's a Dremel?
    30 Jun 2009
Tags: Add Tags
