News Samsung demos USB-powered display
Discussion in 'Article Discussion' started by Lizard, 1 Jun 2010.
  1. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
  2. Tom @ CCL
    Tom @ CCL AKA: Yewen
    10 May 2010
    All comes down to price, if they are priced keenly I could see myself running a three monitor setup from a powered USB hub.
  3. Mongoose132
    Mongoose132 Duckmad
    23 Aug 2007
    *Doesn't see advantage of one less cable*
  4. BlackMage23
    BlackMage23 RPG Loving Freak
    4 Aug 2006
    Will their normal monitors be this energy efficient?
    They could be good in a corporate environment, if the power saving can justify the cost.
  5. eldiablo
    eldiablo What's a Dremel?
    13 Jul 2005
    It says usb powered, but does the video go over the usb cable as well or did they hide the vga/dvi cable in the picture?
  6. bigsharn
    bigsharn Officially demotivated
    9 May 2008
    I hardly dare ask how much the twin USB cable will cost... :p
  7. Sheiken
    Sheiken Wat?
    9 Jan 2005
    This is no use if you have a powerful graphics card
  8. cool_dude
    cool_dude Minimodder
    26 Aug 2004
    just usb powered , requires vga/dvi i would assume
  9. knuck
    knuck Hate your face
    25 Jan 2002
    I bet it's not 120hz....
    ... :D
  10. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    The only application I see here is for HTPC (if it's a touch screen) or low powered workstations (Word, Internet Explorer)
  11. Darkefire
    Darkefire What's a Dremel?
    8 Sep 2008
    Awesome, I'd happily run a third monitor to place Word documents or other similarly mundane things; no matter how much this costs, it's gotta be cheaper than buying a similar sized model and a TripleHead2Go, or buying a second graphics card. At least that's assuming USB is the only connection, I wish the linked article had a higher resolution picture so I could read the little features sign next to the monitor.
  12. Tom @ CCL
    10 May 2010
    Samsung have got a series of USB driven monitors out at the moment, so I assume these will be USB powered and USB driven.
    Would be a dissapointment if they were not.
  13. cyrilthefish
    cyrilthefish What's a Dremel?
    15 Apr 2004
    Well, over here it's written as the data goes over USB too.
    So i'd guess it'd struggle with any sort of video/gaming :( (if it can handle it at all without turning into a slideshow)
  14. DBA
    DBA I do my modding with a spoon
    18 Feb 2009
    I don't know about that. There was a Twin USB cable bundled with my cheap ars HDD case when I bought that. so I couldn't image it would cost much more than a standard USB cable.
  15. capnPedro
    11 Apr 2007
    I'm guessing this is USB 3.0 exclusive, then.
    6.3W/5V=1.26A
    USB 2.0 would require three cables to meet the spec.
  16. javaman
    javaman May irritate Eyes
    10 May 2009
    Does power supply change with usb3 or only data rates?
  17. tank_rider
    tank_rider What's a Dremel?
    3 Feb 2005
    More energy efficiency is always welcome. Especially as this will negate another power converter and use the relatively efficient pc power supply rather than a power brick.
  18. nicae
    nicae What's a Dremel?
    25 Nov 2008
    Needs to be single USB. Can they do roughly half the screen with a single cable?
  19. ZERO <ibis>
    ZERO <ibis> Minimodder
    22 Feb 2005
    This could open up for some nice mod possibilities in the future...
  20. MSHunter
    MSHunter Minimodder
    24 Apr 2009
    OMG FAIL FAIL FAIL.
    This should have been USB3!!!!!!!!!!!!!!!!!!
    I mean would not USB3 be much better for this with higher data rate and higher power!!??!!
    It would also be one of the first inventive uses that woul push USB3 out quicker.
    God I do hope Samsung see this and comes out with a USB3 version.
Tags: Add Tags
