Reply
Thread Tools View Mode
Old 2nd Jun 2010, 01:54   #1
craigbru
Now... with more CNC!
craigbru's Avatar
craigbru has yet to learn the way of the Dremelcraigbru has yet to learn the way of the Dremel
Project: OSIDIAS - Carbon fiber SFF! (Temporary thread derail... Oct. 24th)
Well, here it goes guys. After more than a year of planning, I've decided to officially to start Project OSIDIAS. Granted, I still have other projects I'm still working on, but I don't want to delay this any longer. I can't promise daily updates, but I have a feeling you all will keep motivated to keep my work as updated as possible.
OSIDIAS will take everything I've learned from my Rogue project, and double it, in both scope and ambition. I've got some pretty unique things I'll be attempting here, and I've got no assurances that everything will work out as I've planned. That doesn't matter though, as I enjoy the challenges of problem solving on the fly. Even though at this point, almost every detail of the case is planned, there are still going to be things I decide to change. However, due to the way the case is designed, there are certain things that must remain set in stone. The overall exterior of the case and the carbon fiber shell for example.
So, where do we begin? Well, for those that may not have been following along up until this point, this video gives the best project overview. If you've got 20 minutes to spare, this should catch you up to speed. You can also read up on my planning thread here.
Now, although this is the first official post of the project, I've only got a few pics to show you. Don't worry, I've got more incoming, but I this should get things started.
This case will be the first time I move away from aluminum as my primary construction material. There will still be plenty of it in this case, but I figured it was time for something more exotic. That's where carbon fiber comes in to the picture. Actually, carbon fiber, as well as a carbon fiber/kevlar blend. The carbon fiber will be placed around molds that I'm currently building, and them vacuum bagged. This is a proven technique for manufacturing, but the first time I'll be attempting it. There aren't many computer mods made from CF, let alone molded as in what I'm trying, but that's where the fun part comes in! I've got to give full credit to MKmods for his advice and input regarding working with carbon fiber. With any luck I'll not end up with a very expensive mess on my hands...
I mentioned having to make the molds, and that's where the following pictures pick up. Thanks to the help of my Romaxx CNC machine, I was able to accurately cut out a few pieces of the OSIDIAS core. These pieces will sit in the center, while an aluminum 'clam-shell' sits around it. After the carbon fiber and vacuum bagging, the idea is to push the center core out, and then remove the shell from the inside. This will leave a solid CF case, from which I will make the needed cuts.
Here are the blank pieces of MDF ready for the Romaxx CNC.
After the CNC cut...
And finally, I've got a stack of them.
Next up, we've got the core assembly!
__________________
Originally Posted by disturbed13
'to cram everything in the box, you must think outside the box'
craigbru is offline   Reply With Quote
Old 2nd Jun 2010, 02:27   #2
disturbed13
Hypermodder
disturbed13 has yet to learn the way of the Dremel
subbd
disturbed13 is offline   Reply With Quote
Old 2nd Jun 2010, 02:34   #3
Gtek
Supermodder
Gtek's Avatar
Gtek can run CrysisGtek can run CrysisGtek can run CrysisGtek can run CrysisGtek can run CrysisGtek can run CrysisGtek can run CrysisGtek can run CrysisGtek can run CrysisGtek can run Crysis
I just ordered some styrofoam blocks for my next project molds. But I chose the cheaper, fiberglass way...
good luck with CF!
__________________
***gtek-computerdesign.com***
Gtek is offline   Reply With Quote
Old 2nd Jun 2010, 03:13   #4
shomann
Supermodder
shomann's Avatar
shomann has yet to learn the way of the Dremel
I am with disturbed13. Subbed. I would double-sub if I could.
Good luck craig!
__________________
Project: Nomad
Notebook: Apple 15" MBP 2010 i5/128SSD/320 Optibay conversion
NAS: Jetway JNC62K | AMD 4850e 2.5 GHz AM2 | 2GB RAM | 2.7 TB RAID-5 - OFFLINE, EVALUATING
shomann is offline   Reply With Quote
Old 2nd Jun 2010, 03:13   #5
Boddaker
TRON CAT!
Boddaker's Avatar
Boddaker can run CrysisBoddaker can run CrysisBoddaker can run CrysisBoddaker can run CrysisBoddaker can run CrysisBoddaker can run CrysisBoddaker can run CrysisBoddaker can run CrysisBoddaker can run CrysisBoddaker can run CrysisBoddaker can run Crysis
Awesome! Been waiting for your next project to officially start. I'm grabbing a front row seat this time!
__________________
www.bods-mods.com
Originally Posted by my brother
Is the name "Neptune's Trident" something you came up with? I can't see how a planet and chewing gum are related.
Boddaker is offline   Reply With Quote
Old 2nd Jun 2010, 03:22   #6
Xtrafresh
It never hurts to help
Xtrafresh's Avatar
Xtrafresh can run CrysisXtrafresh can run CrysisXtrafresh can run CrysisXtrafresh can run CrysisXtrafresh can run CrysisXtrafresh can run CrysisXtrafresh can run CrysisXtrafresh can run CrysisXtrafresh can run CrysisXtrafresh can run CrysisXtrafresh can run Crysis
__________________
Think of how stupid the average person is, and realize half of them are stupider than that.
- George Carlin
Xtrafresh is offline   Reply With Quote
Old 2nd Jun 2010, 03:33   #7
The_Beast
I like wood ಠ_ಠ
The_Beast's Avatar
The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!
Score, I can't wait to see more
__________________
- i7 3770k - MSI Z77A-GD65 - EVGA GTX 570 - 8Gb G.Skill Sniper (1.25v) - Fractal R3 Black - Corsair H50 - Corsair 750HX - Samsung 830 128Gb SSD - 6 Samsung F4EG 2TB - 2 WD Black 1TB - 2 WD Black 750GB - Dell UltraSharp U2410 - WASD V1 Custom - IBM Model M SSK - KBC Poker (Ergo-Clears) - Logitech Mx518 & G500 - Audio Technica AD700 - Logitech Z4 - Windows 7 Pro -
The_Beast is offline   Reply With Quote
Old 2nd Jun 2010, 03:42   #8
hurv
Minimodder
hurv has yet to learn the way of the Dremel
I am psyched to see this happen!
hurv is offline   Reply With Quote
Old 2nd Jun 2010, 03:54   #9
stonedsurd
Is a cackling Yuletide Belgian
stonedsurd's Avatar
stonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for president
*subbed*
__________________
My Flickr
Originally Posted by specofdust View Post
You don't believe people can be trusted to be exposed to ideas, to thought, to expression. I choose to say that even if people can't be trusted, it's moral that they should be, because I have no right to elevate myself above them and decide on their behalf what they should be exposed to, because that is authoritarian, discriminatory, and wrong.
stonedsurd is online now   Reply With Quote
Old 2nd Jun 2010, 04:16   #10
talladega
I'm Squidward
talladega's Avatar
talladega is a hoopy frood who really knows where their towel is.talladega is a hoopy frood who really knows where their towel is.talladega is a hoopy frood who really knows where their towel is.talladega is a hoopy frood who really knows where their towel is.talladega is a hoopy frood who really knows where their towel is.talladega is a hoopy frood who really knows where their towel is.talladega is a hoopy frood who really knows where their towel is.talladega is a hoopy frood who really knows where their towel is.talladega is a hoopy frood who really knows where their towel is.talladega is a hoopy frood who really knows where their towel is.talladega is a hoopy frood who really knows where their towel is.
WOOOHOOOO!!!!!
__________________
"...clearly poop is not nutritious and it tastes bad." -Bindibadgi
"Get off... my... property!"
-Clint Eastman, in Grand Tornado
talladega is offline   Reply With Quote
Old 2nd Jun 2010, 13:36   #11
craigbru
craigbru's Avatar
Originally Posted by disturbed13 View Post
subbd
Glad to have you aboard!
good luck with CF!
Thanks man! I think I'm more concerned about things like the resin drying properly than working with the CF itself. It would be costly if I screwed up, but that's part of why I'm making a mold I can reuse. Just in case...
Good luck craig!
Thanks! Just sub on every forum in which I post. That should keep you busy for a while.
Thanks Brian!
Originally Posted by Xtrafresh View Post
Originally Posted by stonedsurd View Post
*subbed*
Originally Posted by talladega View Post
WOOOHOOOO!!!!!
I appreciate the enthusiasm guys! This is what keeps me motivated and moving forward!
__________________
Old 2nd Jun 2010, 14:11   #12
Dark~3nergy
what was dat sandvich ?
Dark~3nergy's Avatar
Dark~3nergy has yet to learn the way of the DremelDark~3nergy has yet to learn the way of the DremelDark~3nergy has yet to learn the way of the DremelDark~3nergy has yet to learn the way of the Dremel
OH GOD OH GOD
i've been waiting for this for so long
good luck ! can't wait to see more
__________________
My deviantart page : link Battlefield 3: Mindrusted My computer : Link
Dark~3nergy is offline   Reply With Quote
Old 2nd Jun 2010, 14:36   #13
disturbed13
Hypermodder
whoot
i was the first
Old 2nd Jun 2010, 14:48   #14
sb1991
Supermodder
sb1991's Avatar
sb1991 has yet to learn the way of the Dremelsb1991 has yet to learn the way of the Dremelsb1991 has yet to learn the way of the Dremelsb1991 has yet to learn the way of the Dremelsb1991 has yet to learn the way of the Dremel
Sounds like this is going to be very impressive!
sb1991 is offline   Reply With Quote
Old 2nd Jun 2010, 14:53   #15
MrWizard
Supermodder
MrWizard's Avatar
MrWizard has yet to learn the way of the Dremel
Honestly, I saw your name attached to a project log and just subscribed because it's the right thing to do.
__________________
Gigabyte P35-DS3L | Intel E2220 @ 3.0GHz | AC Freezer 7 Pro | eVGA 8800GT 512MB | 2GB Crucial Ballistix DDR2-800 | 1 x Seagate 250GB SATA | 1 x WD Raptor 74GB SATA | X-Fi Extreme Gamer | Silverstone Strider 600 Modular | Modded Antec Nine Hundred
MrWizard is offline   Reply With Quote
Old 2nd Jun 2010, 16:05   #16
craigbru
craigbru's Avatar
Originally Posted by Dark~3nergy View Post
OH GOD OH GOD
Thanks! It has been a while, hasn't it?
whoot
i was the first
Lol, somebody has to be.
Thank you! I try and aim high. The fun part is trying to live up to my crazy ideas.
Haha, thanks for the kind words.
So, are you guys ready for another update?
My last post left off with the cut MDF pieces for the core of the case. What I needed now was some simple way to fasten those pieces together, while still providing strength. I went round and round with possibilities until I decided on the following method. It all started with a trio of 22mm holes courtesy of the Romaxx.
Thanks to the CNC's accuracy and repeatability, I ended up with 6 pieces just like this.
With the first piece laying down, I tapped 3 sections of PVC pipe into the holes. The fit was just tight enough that there was no movement once in place, but taps with a hammer could still allow any needed adjustment.
Now finally, here is the assembled core. It's lightweight, yet very strong. The PVC pipe not only serves to hold the structure together, it also has a secondary purpose. Since the carbon fiber will be vacuum bagged, the pipe will allow for pressure equalization between the front and rear of the mold.
With the core done, I'll be moving on to the 2 part aluminum shell that fits around it. Thanks for reading!
__________________
Old 2nd Jun 2010, 16:15   #17
shomann
Supermodder
shomann's Avatar
I just realized that I DID double sub (For those that don't know, Craig maintains his own forums)
Incidentally, you don't have to ask if we are ready for another update Craig - we are, even if you post them every hour
__________________
Project: Nomad
Old 2nd Jun 2010, 16:42   #18
voigts
Hypermodder
voigts's Avatar
voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.
This looks like it is going to be a fun show to watch.
__________________
Previous Project: Zenith Antique Radio Scratch Build
Current project: Project Quintessence
voigts is offline   Reply With Quote
Old 2nd Jun 2010, 17:13   #19
Fabou
Supermodder
Fabou's Avatar
Fabou has yet to learn the way of the Dremel
Since everibody seems so excited I join the fun. Great start.
__________________
Linux user! Join the revolution
Originally Posted by AnG3L View Post
I really like your comment mate I wish I could express myself like this too! Thanks buddy!!
Fabou is offline   Reply With Quote
Old 2nd Jun 2010, 18:15   #20
Blooddrunken
In Flames we Trust
Blooddrunken's Avatar
Blooddrunken has yet to learn the way of the Dremel
This will be fun and I'll be watching!
Blooddrunken is offline   Reply With Quote
Reply
Tags
carbon fiber, craigbru > skynet, losias, rick-roll, sff, skynet
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
